Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Easy-Jtag
Old 11-27-2017, 13:10   #46 (permalink)
lifegood8's Avatar
Member: 757297
Thanks Meter: 33
Unhappy Sm-g532f dead boot done but not power on
HI
I TRY TO REPAIR SM-G532F DEAD BOOT PROSESS DONE BUT PHONE NOT POWER ON OR NO DWONLOD MODE.
I TRY WITH LETEST BOOT+PIT AND ALSO TRT WITH WORKING PHONE ROM1 ,2,3 BUT NOTHING I HAVE 3 PHONE ALL SAME.
HiPower mode is OFF
Frequence: 14 Mhz
CMD Pullup Level: 1680 mV
CMD Active Level: 1742 mV
EMMC Device Information :
EMMC CID: 150100514E3136424200C805E4863412
EMMC CSD: D02701320F5903FFF6DBFFEF8E40400C
EMMC Manufacture Name: SAMSUNG
EMMC Manufacture ID: 0x15 , OEM ID: 0100
EMMC Manufacture Date: 3/2017 , Rev: 00
EMMC NAME: QN16BB , S/N: C8***** , rev. 00
EMMC NAME (HEX): 514*********
EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000)
EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000)
EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000)
EMMC Permanent Write Protection: No
EMMC Temporary Write Protection: No
Extended CSD Information :
Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01)
Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1)
Boot Bus Config: 0x00 , width 1bit
H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled
Supported partition features [PARTITIONING_SUPPORT]: 0x07
Device supports partitioning features
Device can have enhanced technological features in partitions and user data area
Device can have extended partitions attribute
Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00
Backup saved: QN16BB_C805E486_20171127_035139.extcsd
EMMC Init completed.
Get firmware version
Brand = samsung
Model = SM-G532F
Phone platform = mt6737t
CPU Abi = armeabi-v7a
Mediatek platform = MT6737T
Android release = 6.0.1
Firmware version = MMB29T.G532FXXU1AQC2
Firmware date = Fri Mar 17 17:03:11 KST 2017
Old 11-27-2017, 14:04   #47 (permalink)
ar.vill's Avatar
Member: 1757686
Thanks Meter: 27
Not all dead phones can be simply repair with Jtagging, consider also the power supply section which might be faulty as well. If you do have that regulated power supply then try to measure current consumption and post screen shoot so that we can isolate the problem if it could be hardware or software problem.
Old 11-27-2017, 19:32   #48 (permalink)
lifegood8's Avatar
Member: 757297
Thanks Meter: 33
Unhappy
Brother this is dead boot problam not a hadwaer issu i allready chek .
And custumer say to me this phone dead on softwaer.
I have 3 pice for dead boot problam
The Following User Says Thank You to lifegood8 For This Useful Post:
Old 11-27-2017, 22:46   #49 (permalink)
Pijush Das's Avatar
Member: 1902789
Thanks Meter: 406
Hello, Just Do this...
1 : Read 512 MB UserArea Dump & Backup EXT_CSD File ,
2 : Do Samsung Factory Format,
3 : Repair EXT_CSD From Backup,
4 : Write 512 MB UserArea File From Backup,
5 : Select Correct PIT File & Add Only Bootloader File, Check Repartition & Finally Write From Write By Vendor TAB,
6 : Check Info For Software Partition OK or Not, When OK...
7 : Now 100% Comes Download Mode,
8 : Now Just Write Full Flash By Odin tool Or Any Other Tool
(NOTE : That Tricks Not Work When Device Have Hardware Fault)
The Following 6 Users Say Thank You to Pijush Das For This Useful Post:
Old 01-12-2018, 22:24   #50 (permalink)
Member: 1358365
Thanks Meter: 15
i need help g532F/ds emmc riper problem
DUMP FILE....................................
Old 01-13-2018, 05:55   #51 (permalink)
nagesss's Avatar
Member: 2306223
Sonork: 1660968:1234
Thanks Meter: 65
I have 256 mb read file..wait for it I will upload....
Sent from my Redmi Note 4 using Tapatalk
Old 01-13-2018, 09:02   #52 (permalink)
Member: 1630066
Sonork: 520074
Thanks Meter: 146
Write by vender bl+pit
no need dump for this model
The Following User Says Thank You to ilyasrao For This Useful Post:
Old 01-16-2018, 14:43   #53 (permalink)
nagesss's Avatar
Member: 2306223
Thanks Meter: 65
g532f domp rom
samsung g532f dump
https://www.4shared.com/folder/Y5CXQpxB/_online.html
The Following 3 Users Say Thank You to nagesss For This Useful Post:
Old 01-17-2018, 12:14   #54 (permalink)
.::niroshan::.'s Avatar
Member: 1728575
Thanks Meter: 124
here succsess report
look here
https://www.youtube.com/watch?v=5WWZEnXcOoM
The Following User Says Thank You to .::niroshan::. For This Useful Post:
Old 01-17-2018, 12:18   #55 (permalink)
Member: 1728575
Thanks Meter: 124
done many times
here success video
Old 01-17-2018, 13:46   #56 (permalink)
Member: 1627229
Thanks Meter: 45
after imei null drk failed
Old 02-04-2018, 21:24   #57 (permalink)
khalidahmed's Avatar
Member: 2298142
Thanks Meter: 214
Z3x EASY JTAG plus not working g532f.i try 4 ded mobile, bt no luck.
Its only work G532G .
G532F show only mtk driver after repair bord....
Whare Z3x team...
We need this salutions first.
Please share any video/screen capture salutions............
The Following User Says Thank You to khalidahmed For This Useful Post:
Old 02-05-2018, 22:24   #58 (permalink)
Member: 2298142
Thanks Meter: 214
g532f not possible repair with z3x jtag plus.
its only work g532g.
u need medusa tool....100% working......
Old 02-05-2018, 22:26   #59 (permalink)
Member: 2298142
Thanks Meter: 214
Z3X jtag not work g532F.........
its working only g532G...
Old 02-05-2018, 22:42   #60 (permalink)
Member: 2298142
Thanks Meter: 214
G532F NOT Working Z3X JTAG Plus.Its work only G532G.......
Itry 4 g5312f ded bord.Not done.
G532G working 100%
Page generated in 0.35361 seconds with 8 queries
