Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Easy-Jtag
Old 10-09-2018, 10:50   #1 (permalink)
Member: 2226456
Sonork: jerrenn
Thanks Meter: 80
SM-G532G dead successfully back in to life via replace emmc and easy jtag flash
TNX easy jtag plus for powerfull update
10/8/2018 11:08:31 PM> Setting interface to EasyJtag2/ISP_HiPower
10/8/2018 11:08:31 PM> Setting bus width to 1 Bit
10/8/2018 11:08:31 PM> HiPower mode is ON
10/8/2018 11:08:31 PM> Setting frequence to 24 Mhz
10/8/2018 11:08:31 PM> CMD Pullup Level: 2115 mV
10/8/2018 11:08:31 PM> CMD Active Level: 2663 mV
10/8/2018 11:08:31 PM> eMMC Init returned = 0
10/8/2018 11:08:31 PM> EMMC Device Information :
10/8/2018 11:08:31 PM> EMMC CID: 90014A4838473475920133A5DC5D5459
10/8/2018 11:08:31 PM> EMMC CSD: D02701320F5903FFFFFFFFE78A40002B
10/8/2018 11:08:31 PM> EMMC Manufacture : SKHYNIX , EMMC NAME: H8G4u , HEX: 483847347500 , S/N: 33A5DC5D , rev. 0x01
10/8/2018 11:08:31 PM> EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Date: 5/2017
10/8/2018 11:08:31 PM> EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000)
10/8/2018 11:08:31 PM> EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000)
10/8/2018 11:08:31 PM> EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000)
10/8/2018 11:08:32 PM> EMMC Permanent Write Protection: No
10/8/2018 11:08:32 PM> EMMC Temporary Write Protection: No
10/8/2018 11:08:32 PM> Extended CSD Information :
10/8/2018 11:08:32 PM> Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01)
10/8/2018 11:08:32 PM> Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1)
10/8/2018 11:08:32 PM> Boot Bus Config: 0x00 , width 1bit
10/8/2018 11:08:32 PM> H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled
10/8/2018 11:08:32 PM> Supported partition features [PARTITIONING_SUPPORT]: 0x07
10/8/2018 11:08:32 PM> Device supports partitioning features
10/8/2018 11:08:32 PM> Device can have enhanced technological features in partitions and user data area
10/8/2018 11:08:32 PM> Device can have extended partitions attribute
10/8/2018 11:08:32 PM> Partition Settings [PARTITION_SETTING_COMPLETED]: 0x01
10/8/2018 11:08:32 PM> Backup saved: H8G4u_33A5DC5D_20181008_230832.extcsd
10/8/2018 11:08:32 PM> EMMC Init completed.
10/8/2018 11:08:32 PM> Operation: Write by vendor (Samsung)
10/8/2018 11:08:32 PM> Creating GPT-partitioninig
10/8/2018 11:08:32 PM> Writing PrimaryGPT at address: 000000000000
10/8/2018 11:08:32 PM> Writing BackupGPT at address: 0001D1FFBE00
10/8/2018 11:08:32 PM> Writing PIT at address: 000000004400
10/8/2018 11:08:32 PM> GPT-partitioning done
10/8/2018 11:08:32 PM> Unpacking file: preloader.img
10/8/2018 11:08:32 PM> Unpacking file: lk.bin
10/8/2018 11:08:32 PM> Unpacking file: efuse.img
10/8/2018 11:08:32 PM> Unpacking file: trustzone.bin
10/8/2018 11:08:32 PM> Unpacking file: param.bin
10/8/2018 11:08:32 PM> Partition name: BOOTLOADER
10/8/2018 11:08:32 PM> Filename: preloader.img , Offset: 000000000000 , filesize: 170240 bytes
10/8/2018 11:08:32 PM> eMMC switching to ROM2
10/8/2018 11:08:32 PM> Erasing partition...
10/8/2018 11:08:37 PM> Writing partition...
10/8/2018 11:08:37 PM> Done writing partition. Write speed: 563.58 KB/s
10/8/2018 11:08:37 PM> Partition name: LK
10/8/2018 11:08:37 PM> Filename: lk.bin , Offset: 000001000000 , filesize: 590336 bytes
10/8/2018 11:08:37 PM> eMMC switching to ROM1
10/8/2018 11:08:38 PM> Erasing partition...
10/8/2018 11:08:39 PM> Writing partition...
10/8/2018 11:08:39 PM> Done writing partition. Write speed: 1366.79 KB/s
10/8/2018 11:08:39 PM> Partition name: EFUSE
10/8/2018 11:08:39 PM> Filename: efuse.img , Offset: 000001B80000 , filesize: 768 bytes
10/8/2018 11:08:39 PM> eMMC switching to ROM1
10/8/2018 11:08:40 PM> Erasing partition...
10/8/2018 11:08:40 PM> Writing partition...
10/8/2018 11:08:40 PM> Done writing partition. Write speed: 22.41 KB/s
10/8/2018 11:08:40 PM> Partition name: TEE1
10/8/2018 11:08:40 PM> Filename: trustzone.bin , Offset: 000001C00000 , filesize: 324352 bytes
10/8/2018 11:08:40 PM> eMMC switching to ROM1
10/8/2018 11:08:41 PM> Erasing partition...
10/8/2018 11:08:41 PM> Writing partition...
10/8/2018 11:08:41 PM> Done writing partition. Write speed: 2247.58 KB/s
10/8/2018 11:08:41 PM> Partition name: PARAM
10/8/2018 11:08:41 PM> Filename: param.bin , Offset: 000005000000 , filesize: 747520 bytes
10/8/2018 11:08:41 PM> eMMC switching to ROM1
10/8/2018 11:08:42 PM> Erasing partition...
10/8/2018 11:08:42 PM> Writing partition...
10/8/2018 11:08:43 PM> Done writing partition. Write speed: 2367.71 KB/s
10/8/2018 11:08:43 PM> Check BootConfig for the selected vendor
10/8/2018 11:08:43 PM> All done time: [00:00:11:239]
The Following User Says Thank You to jennydahan For This Useful Post:
Old 10-11-2018, 10:28   #2 (permalink)
Member: 2340647
Thanks Meter: 61
G532F Boot Repair Done
G532F Boot Repair Done By Easy Jtag Plus
10/10/2018 09:36:26 م> Operation: Write by vendor (Samsung)
10/10/2018 09:36:26 م> Creating GPT-partitioninig
10/10/2018 09:36:26 م> Writing PrimaryGPT at address: 000000000000
10/10/2018 09:36:26 م> Error writing at address: 000000000000 , error: -1 , CMD Timeout Error ... Retry #1
10/10/2018 09:36:26 م> Error writing at address: 000000000000 , error: -1 , CMD Timeout Error ... Retry #2
10/10/2018 09:36:26 م> Error writing at address: 000000000000 , error: -1 , CMD Timeout Error ... Retry #3
10/10/2018 09:36:26 م> Too many errors. Writing has been stopped
10/10/2018 09:36:27 م>
10/10/2018 09:36:29 م> Looking for EasyJTAG box...
10/10/2018 09:36:29 م> EasyJTAG API ver. 2100
10/10/2018 09:36:29 م> Setting IO Levels to 2.8V
10/10/2018 09:36:29 م> Setting frequence to 36 Mhz
10/10/2018 09:36:29 م> EasyJTAG Box Serial = FBE84B4C2A0EC2BE
10/10/2018 09:36:29 م> EasyJTAG Box Firmware = 2.30
10/10/2018 09:36:29 م> Setting interface to EasyJtag2/ISP_HiPower
10/10/2018 09:36:29 م> Setting bus width to 1 Bit
10/10/2018 09:36:29 م> HiPower mode is ON
10/10/2018 09:36:29 م> CMD Pullup Level: 2083 mV
10/10/2018 09:36:29 م> CMD Active Level: 2636 mV
10/10/2018 09:36:30 م> eMMC Init returned = 0
10/10/2018 09:36:30 م> EMMC Device Information :
10/10/2018 09:36:30 م> EMMC CID: 90014A4838473475920120219807B4D3
10/10/2018 09:36:30 م> EMMC CSD: D02701320F5903FFFFFFFFE78A40002B
10/10/2018 09:36:30 م> EMMC Manufacture : SKHYNIX , EMMC NAME: H8G4u , HEX: 483847347500 , S/N: 20219807 , rev. 0x01
10/10/2018 09:36:30 م> EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Date: 11/2017
10/10/2018 09:36:30 م>    EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000)
10/10/2018 09:36:30 م>    EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000)
10/10/2018 09:36:30 م>    EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000)
10/10/2018 09:36:30 م> EMMC Permanent Write Protection: No
10/10/2018 09:36:30 م> EMMC Temporary Write Protection: No
10/10/2018 09:36:30 م> Extended CSD Information :
10/10/2018 09:36:30 م> Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01)
10/10/2018 09:36:30 م> Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1)
10/10/2018 09:36:30 م> Boot Bus Config: 0x00 , width 1bit
10/10/2018 09:36:30 م> H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled
10/10/2018 09:36:30 م> Supported partition features [PARTITIONING_SUPPORT]: 0x07
10/10/2018 09:36:30 م> Device supports partitioning features
10/10/2018 09:36:30 م> Device can have enhanced technological features in partitions and user data area
10/10/2018 09:36:30 م> Device can have extended partitions attribute
10/10/2018 09:36:30 م> Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00
10/10/2018 09:36:30 م> Backup saved: H8G4u_20219807_20181010_213630.extcsd
10/10/2018 09:36:30 م> EMMC Init completed.
10/10/2018 09:36:30 م> Operation: Write by vendor (Samsung)
10/10/2018 09:36:30 م> Creating GPT-partitioninig
10/10/2018 09:36:30 م> Writing PrimaryGPT at address: 000000000000
10/10/2018 09:36:30 م> Writing BackupGPT at address: 0001D1FFBE00
10/10/2018 09:36:30 م> Writing PIT at address: 000000004400
10/10/2018 09:36:30 م> GPT-partitioning done
10/10/2018 09:36:30 م> Unpacking file: preloader.img
10/10/2018 09:36:30 م> Unpacking file: lk.bin
10/10/2018 09:36:30 م> Unpacking file: efuse.img
10/10/2018 09:36:30 م> Unpacking file: trustzone.bin
10/10/2018 09:36:30 م> Unpacking file: param.bin
10/10/2018 09:36:30 م> Partition name: BOOTLOADER
10/10/2018 09:36:31 م> Filename: preloader.img , Offset: 000000000000 , filesize: 170240 bytes
10/10/2018 09:36:31 م> eMMC switching to ROM2
10/10/2018 09:36:31 م> Erasing partition...
10/10/2018 09:36:34 م> Writing partition...
10/10/2018 09:36:34 م> Done writing partition. Write speed: 648.42 KB/s
10/10/2018 09:36:34 م> Partition name: LK
10/10/2018 09:36:34 م> Filename: lk.bin , Offset: 000001000000 , filesize: 590336 bytes
10/10/2018 09:36:34 م> eMMC switching to ROM1
10/10/2018 09:36:34 م> Erasing partition...
10/10/2018 09:36:36 م> Writing partition...
10/10/2018 09:36:36 م> Done writing partition. Write speed: 1925.05 KB/s
10/10/2018 09:36:36 م> Partition name: EFUSE
10/10/2018 09:36:36 م> Filename: efuse.img , Offset: 000001B80000 , filesize: 768 bytes
10/10/2018 09:36:36 م> eMMC switching to ROM1
10/10/2018 09:36:36 م> Erasing partition...
10/10/2018 09:36:37 م> Writing partition...
10/10/2018 09:36:37 م> Done writing partition. Write speed: 19.98 KB/s
10/10/2018 09:36:37 م> Partition name: TEE1
10/10/2018 09:36:37 م> Filename: trustzone.bin , Offset: 000001C00000 , filesize: 324352 bytes
10/10/2018 09:36:37 م> eMMC switching to ROM1
10/10/2018 09:36:37 م> Erasing partition...
10/10/2018 09:36:38 م> Writing partition...
10/10/2018 09:36:38 م> Done writing partition. Write speed: 3244.68 KB/s
10/10/2018 09:36:38 م> Partition name: PARAM
10/10/2018 09:36:38 م> Filename: param.bin , Offset: 000005000000 , filesize: 747520 bytes
10/10/2018 09:36:38 م> eMMC switching to ROM1
10/10/2018 09:36:38 م> Erasing partition...
10/10/2018 09:36:39 م> Writing partition...
10/10/2018 09:36:39 م> Done writing partition. Write speed: 3625.56 KB/s
10/10/2018 09:36:40 م> Check BootConfig for the selected vendor
10/10/2018 09:36:40 م> All done   time: [00:00:09:370]
10/10/2018 09:37:01 م> Looking for EasyJTAG box...
10/10/2018 09:37:01 م> EasyJTAG API ver. 2100
10/10/2018 09:37:01 م> Setting IO Levels to 2.8V
10/10/2018 09:37:01 م> Setting frequence to 36 Mhz
10/10/2018 09:37:01 م> EasyJTAG Box Serial = FBE84B4C2A0EC2BE
10/10/2018 09:37:01 م> EasyJTAG Box Firmware = 2.30
10/10/2018 09:37:01 م> Setting interface to EasyJtag2/ISP_HiPower
10/10/2018 09:37:01 م> Setting bus width to 1 Bit
10/10/2018 09:37:01 م> HiPower mode is ON
10/10/2018 09:37:01 م> CMD Pullup Level: 2084 mV
10/10/2018 09:37:01 م> CMD Active Level: 2628 mV
10/10/2018 09:37:01 م> eMMC Init returned = 0
10/10/2018 09:37:01 م> EMMC Device Information :
10/10/2018 09:37:01 م> EMMC CID: 90014A4838473475920120219807B4D3
10/10/2018 09:37:01 م> EMMC CSD: D02701320F5903FFFFFFFFE78A40002B
10/10/2018 09:37:01 م> EMMC Manufacture : SKHYNIX , EMMC NAME: H8G4u , HEX: 483847347500 , S/N: 20219807 , rev. 0x01
10/10/2018 09:37:01 م> EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Date: 11/2017
10/10/2018 09:37:01 م>    EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000)
10/10/2018 09:37:01 م>    EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000)
10/10/2018 09:37:01 م>    EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000)
10/10/2018 09:37:01 م> EMMC Permanent Write Protection: No
10/10/2018 09:37:01 م> EMMC Temporary Write Protection: No
10/10/2018 09:37:01 م> Extended CSD Information :
10/10/2018 09:37:01 م> Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01)
10/10/2018 09:37:02 م> Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1)
10/10/2018 09:37:02 م> Boot Bus Config: 0x00 , width 1bit
10/10/2018 09:37:02 م> H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled
10/10/2018 09:37:02 م> Supported partition features [PARTITIONING_SUPPORT]: 0x07
10/10/2018 09:37:02 م> Device supports partitioning features
10/10/2018 09:37:02 م> Device can have enhanced technological features in partitions and user data area
10/10/2018 09:37:02 م> Device can have extended partitions attribute
10/10/2018 09:37:02 م> Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00
10/10/2018 09:37:02 م> Backup saved: H8G4u_20219807_20181010_213702.extcsd
10/10/2018 09:37:02 م> EMMC Init completed.
10/10/2018 09:37:02 م> Operation: Write by vendor (Samsung)
10/10/2018 09:37:02 م> Creating GPT-partitioninig
10/10/2018 09:37:02 م> Writing PrimaryGPT at address: 000000000000
10/10/2018 09:37:02 م> Writing BackupGPT at address: 0001D1FFBE00
10/10/2018 09:37:02 م> Writing PIT at address: 000000004400
10/10/2018 09:37:02 م> GPT-partitioning done
10/10/2018 09:37:02 م> Unpacking file: preloader.img
10/10/2018 09:37:02 م> Unpacking file: lk.bin
10/10/2018 09:37:02 م> Unpacking file: efuse.img
10/10/2018 09:37:02 م> Unpacking file: trustzone.bin
10/10/2018 09:37:02 م> Unpacking file: param.bin
10/10/2018 09:37:02 م> Partition name: BOOTLOADER
10/10/2018 09:37:02 م> Filename: preloader.img , Offset: 000000000000 , filesize: 170240 bytes
10/10/2018 09:37:02 م> eMMC switching to ROM2
10/10/2018 09:37:02 م> Erasing partition...
10/10/2018 09:37:06 م> Writing partition...
10/10/2018 09:37:06 م> Done writing partition. Write speed: 987.56 KB/s
10/10/2018 09:37:06 م> Partition name: LK
10/10/2018 09:37:06 م> Filename: lk.bin , Offset: 000001000000 , filesize: 590336 bytes
10/10/2018 09:37:06 م> eMMC switching to ROM1
10/10/2018 09:37:06 م> Erasing partition...
10/10/2018 09:37:07 م> Writing partition...
10/10/2018 09:37:07 م> Done writing partition. Write speed: 1946.66 KB/s
10/10/2018 09:37:07 م> Partition name: EFUSE
10/10/2018 09:37:07 م> Filename: efuse.img , Offset: 000001B80000 , filesize: 768 bytes
10/10/2018 09:37:08 م> eMMC switching to ROM1
10/10/2018 09:37:08 م> Erasing partition...
10/10/2018 09:37:08 م> Writing partition...
10/10/2018 09:37:08 م> Done writing partition. Write speed: 20.00 KB/s
10/10/2018 09:37:08 م> Partition name: TEE1
10/10/2018 09:37:09 م> Filename: trustzone.bin , Offset: 000001C00000 , filesize: 324352 bytes
10/10/2018 09:37:09 م> eMMC switching to ROM1
10/10/2018 09:37:09 م> Erasing partition...
10/10/2018 09:37:10 م> Writing partition...
10/10/2018 09:37:10 م> Done writing partition. Write speed: 2928.36 KB/s
10/10/2018 09:37:10 م> Partition name: PARAM
10/10/2018 09:37:10 م> Filename: param.bin , Offset: 000005000000 , filesize: 747520 bytes
10/10/2018 09:37:10 م> eMMC switching to ROM1
10/10/2018 09:37:10 م> Erasing partition...
10/10/2018 09:37:11 م> Writing partition...
10/10/2018 09:37:11 م> Done writing partition. Write speed: 3617.61 KB/s
10/10/2018 09:37:12 م> Check BootConfig for the selected vendor
10/10/2018 09:37:12 م> All done   time: [00:00:09:409]
The Following 2 Users Say Thank You to wahby4 For This Useful Post:
Page generated in 0.23107 seconds with 7 queries
