Old 02-17-2018, 14:44   #1 (permalink)
Member: 2307631
Sonork: 100.1661033
Thanks Meter: 9
SM-G570F DEAD BOOT writing error please help
2/13/2018 6:46:43 PM>
2/13/2018 6:46:43 PM> eMMC_tool Suite ver. 1.4.9.0 (release date: 12.12.2017)
2/13/2018 6:46:43 PM> Microsoft Windows 7 (32 bit) build 7601 (6.1.7600.16385)
2/13/2018 6:46:43 PM> Looking for EasyJTAG box...
2/13/2018 6:46:43 PM> EasyJTAG API ver. 2022
2/13/2018 6:46:44 PM> OpenUSB returned = 0
2/13/2018 6:46:45 PM> EasyJTAG Box Serial = 0101100DA******
2/13/2018 6:46:49 PM> Card Serial = AAF8-CD2D
2/13/2018 6:46:49 PM> CardAttr = 3B7D95000080318065B0831148C883009000
2/13/2018 6:46:49 PM> EasyJTAG Box Firmware = 1.62
2/13/2018 6:47:22 PM> Looking for EasyJTAG box...
2/13/2018 6:47:22 PM> EasyJTAG API ver. 2022
2/13/2018 6:47:22 PM> Setting IO Levels to 2.8V
2/13/2018 6:47:22 PM> Setting frequence to 21 Mhz
2/13/2018 6:47:22 PM> EasyJTAG Box Serial = 0101100DA*******
2/13/2018 6:47:22 PM> EasyJTAG Box Firmware = 1.62
2/13/2018 6:47:23 PM> Setting frequence to 21 Mhz
2/13/2018 6:47:23 PM> CMD Pullup Level: 371 mV
2/13/2018 6:47:23 PM> CMD Active Level: 2258 mV
2/13/2018 6:47:23 PM> eMMC Init returned = 0
2/13/2018 6:47:23 PM> EMMC Device Information :
2/13/2018 6:47:23 PM> EMMC CID: 150100513331334242007298D85CB3AC
2/13/2018 6:47:23 PM> EMMC CSD: D02701320F5903FFF6DBFFEF8E40400C
2/13/2018 6:47:23 PM> EMMC Manufacture Name: SAMSUNG , EMMC NAME: Q313BB , EMMC NAME (HEX): 513331334242 , S/N: 7298D85C , rev. 0x00
2/13/2018 6:47:23 PM> EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Manufacture Date: 11/2016
2/13/2018 6:47:23 PM> EMMC ROM 1 (Main User Data) Capacity: 15028 MB (0003AB400000)
2/13/2018 6:47:23 PM> EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000)
2/13/2018 6:47:23 PM> EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000)
2/13/2018 6:47:23 PM> EMMC Permanent Write Protection: No
2/13/2018 6:47:23 PM> EMMC Temporary Write Protection: No
2/13/2018 6:47:23 PM> Extended CSD Information :
2/13/2018 6:47:23 PM> Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01)
2/13/2018 6:47:23 PM> Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1)
2/13/2018 6:47:23 PM> Boot Bus Config: 0x01 , width 4bit
2/13/2018 6:47:23 PM> H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled
2/13/2018 6:47:23 PM> Supported partition features [PARTITIONING_SUPPORT]: 0x07
2/13/2018 6:47:23 PM> Device supports partitioning features
2/13/2018 6:47:23 PM> Device can have enhanced technological features in partitions and user data area
2/13/2018 6:47:23 PM> Device can have extended partitions attribute
2/13/2018 6:47:23 PM> Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00
2/13/2018 6:47:23 PM> Backup saved: Q313BB_7298D85C_20180213_184723.extcsd
2/13/2018 6:47:23 PM> EMMC Init completed.
2/13/2018 6:47:24 PM>
2/13/2018 6:47:24 PM> Opening file: C:\Temp temp\G570F\G570F 7.0\ON5XELTE_MEA_OPEN.pit
2/13/2018 6:47:24 PM> Pit: ON5XELTE_MEA_OPEN.pit
2/13/2018 6:47:24 PM> Entry count: 29
2/13/2018 6:47:24 PM> The size of the last section has been updated
2/13/2018 6:47:42 PM> Selected file: C:\Temp temp\G570F\G570F 7.0\SM-G570F_1_20180104212140_8kfp3o400c_fac\BL_G570FXXU1 BQL2_CL12687762_QB16110527_REV00_user_low_ship.tar .md5
2/13/2018 6:47:42 PM> BL_G570FXXU1BQL2_CL12687762_QB16110527_REV00_user_ low_ship.tar.md5
2/13/2018 6:47:42 PM> The list of files in the firmware:
2/13/2018 6:47:42 PM> sboot.bin
2/13/2018 6:47:42 PM> param.bin
2/13/2018 6:47:42 PM> cm.bin
2/13/2018 6:47:48 PM> Looking for EasyJTAG box...
2/13/2018 6:47:48 PM> EasyJTAG API ver. 2022
2/13/2018 6:47:48 PM> Setting IO Levels to 2.8V
2/13/2018 6:47:48 PM> Setting frequence to 21 Mhz
2/13/2018 6:47:48 PM> EasyJTAG Box Serial = 0101100DA88B2125
2/13/2018 6:47:48 PM> EasyJTAG Box Firmware = 1.62
2/13/2018 6:47:50 PM> Setting frequence to 21 Mhz
2/13/2018 6:47:50 PM> CMD Pullup Level: 422 mV
2/13/2018 6:47:50 PM> CMD Active Level: 2268 mV
2/13/2018 6:47:50 PM> eMMC Init returned = 0
2/13/2018 6:47:50 PM> EMMC Device Information :
2/13/2018 6:47:50 PM> EMMC CID: 150100513331334242007298D85CB3AC
2/13/2018 6:47:50 PM> EMMC CSD: D02701320F5903FFF6DBFFEF8E40400C
2/13/2018 6:47:50 PM> EMMC Manufacture Name: SAMSUNG , EMMC NAME: Q313BB , EMMC NAME (HEX): 513331334242 , S/N: 7298D85C , rev. 0x00
2/13/2018 6:47:50 PM> EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Manufacture Date: 11/2016
2/13/2018 6:47:50 PM> EMMC ROM 1 (Main User Data) Capacity: 15028 MB (0003AB400000)
2/13/2018 6:47:50 PM> EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000)
2/13/2018 6:47:50 PM> EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000)
2/13/2018 6:47:50 PM> EMMC Permanent Write Protection: No
2/13/2018 6:47:50 PM> EMMC Temporary Write Protection: No
2/13/2018 6:47:50 PM> Extended CSD Information :
2/13/2018 6:47:50 PM> Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01)
2/13/2018 6:47:50 PM> Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1)
2/13/2018 6:47:50 PM> Boot Bus Config: 0x01 , width 4bit
2/13/2018 6:47:50 PM> H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled
2/13/2018 6:47:50 PM> Supported partition features [PARTITIONING_SUPPORT]: 0x07
2/13/2018 6:47:50 PM> Device supports partitioning features
2/13/2018 6:47:50 PM> Device can have enhanced technological features in partitions and user data area
2/13/2018 6:47:50 PM> Device can have extended partitions attribute
2/13/2018 6:47:50 PM> Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00
2/13/2018 6:47:50 PM> Backup saved: Q313BB_7298D85C_20180213_184750.extcsd
2/13/2018 6:47:50 PM> EMMC Init completed.
2/13/2018 6:47:50 PM> Operation: Write by vendor (Samsung)
2/13/2018 6:47:50 PM> Creating GPT-partitioninig
2/13/2018 6:47:50 PM> Writing PIT at address: 000000004400
2/13/2018 6:47:50 PM> GPT-partitioning done
2/13/2018 6:47:50 PM> Unpacking file: cm.bin
2/13/2018 6:47:50 PM> Unpacking file: sboot.bin
2/13/2018 6:47:50 PM> Unpacking file: param.bin
2/13/2018 6:47:50 PM> Partition name: CM
2/13/2018 6:47:50 PM> Filename: cm.bin , Offset: 000000000000 , filesize: 2183440 bytes
2/13/2018 6:47:50 PM> eMMC switching to ROM3
2/13/2018 6:47:50 PM> Erasing partition...
2/13/2018 6:48:13 PM> Error erasing at address: 000000040000 , error: -15, -15 Unknown error ... Retry #1
2/13/2018 6:48:40 PM> Error erasing at address: 000000218000 , error: -15, -15 Unknown error ... Retry #1
2/13/2018 6:49:02 PM> Error erasing at address: 000000220000 , error: -15, -15 Unknown error ... Retry #1
2/13/2018 6:49:25 PM> Error erasing at address: 0000002D8000 , error: -15, -15 Unknown error ... Retry #1
2/13/2018 6:49:47 PM> Error erasing at address: 0000002E0000 , error: -15, -15 Unknown error ... Retry #1
2/13/2018 6:50:08 PM> Error erasing at address: 0000002F0000 , error: -15, -15 Unknown error ... Retry #1
2/13/2018 6:50:09 PM> Writing partition...
2/13/2018 6:50:32 PM> Error writing at address: 000000110000 , error: -15, -15 Unknown error ... Retry #1
2/13/2018 6:50:55 PM> Error writing at address: 000000178000 , error: -15, -15 Unknown error ... Retry #1
2/13/2018 6:50:57 PM> Done writing partition. Write speed: 44.43 KB/s
2/13/2018 6:50:57 PM> Partition name: BOOTLOADER
2/13/2018 6:50:57 PM> Filename: sboot.bin , Offset: 000000000000 , filesize: 1601808 bytes
2/13/2018 6:50:57 PM> eMMC switching to ROM2
2/13/2018 6:50:57 PM> Erasing partition...
2/13/2018 6:51:19 PM> Error erasing at address: 000000040000 , error: -15, -15 Unknown error ... Retry #1
2/13/2018 6:51:43 PM> Error erasing at address: 0000000F8000 , error: -15, -15 Unknown error ... Retry #1
2/13/2018 6:52:05 PM> Error erasing at address: 000000180000 , error: -15, -15 Unknown error ... Retry #1
2/13/2018 6:52:27 PM> Error erasing at address: 0000001C8000 , error: -15, -15 Unknown error ... Retry #1
2/13/2018 6:52:51 PM> Error erasing at address: 000000268000 , error: -15, -15 Unknown error ... Retry #1
2/13/2018 6:53:13 PM> Error erasing at address: 0000002A8000 , error: -15, -15 Unknown error ... Retry #1
2/13/2018 6:53:36 PM> Error erasing at address: 000000328000 , error: -15, -15 Unknown error ... Retry #1
2/13/2018 6:53:58 PM> Error erasing at address: 000000350000 , error: -15, -15 Unknown error ... Retry #1
2/13/2018 6:54:22 PM> Error erasing at address: 0000003F0000 , error: -15, -15 Unknown error ... Retry #1
2/13/2018 6:54:22 PM> Writing partition...
2/13/2018 6:54:24 PM> Error writing at address: 000000088000 , error: -2, CMD CRC Error ... Retry #1
2/13/2018 6:54:25 PM> Error writing at address: 000000108000 , error: -2, CMD CRC Error ... Retry #1
2/13/2018 6:54:27 PM> Done writing partition. Write speed: 371.19 KB/s
2/13/2018 6:54:27 PM> Partition name: PARAM
2/13/2018 6:54:27 PM> Filename: param.bin , Offset: 000003500000 , filesize: 819200 bytes
2/13/2018 6:54:27 PM> eMMC switching to ROM1
2/13/2018 6:54:27 PM> Erasing partition...
2/13/2018 6:54:29 PM> Writing partition...
2/13/2018 6:54:30 PM> Done writing partition. Write speed: 886.24 KB/s
2/13/2018 6:54:30 PM> Error reading at address: 0000CA800000 , error: -2, CMD CRC Error ... Retry #1
2/13/2018 6:54:30 PM> All done time: [00:06:40:306]
Old 02-17-2018, 17:13   #2 (permalink)
royalnasim's Avatar
Member: 1037372
Thanks Meter: 557
Change Setting frequence to 14 Mhz and post result
The Following User Says Thank You to royalnasim For This Useful Post:
Old 02-17-2018, 17:19   #3 (permalink)
Member: 1988604
Thanks Meter: 17
u ned to update emmc firmware
Page generated in 0.20452 seconds with 8 queries
