09-12-2018, 04:58 | #1 (permalink) |
No Life Poster Join Date: Oct 2007 Location: chennai Age: 38
Member: 616909 Status: Offline Sonork: 1672125 Thanks Meter: 648 | SM-G600FY combination write after dead solved by jtaq Setting bus width to 1 Bit HiPower mode is ON Setting frequence to 24 Mhz CMD Pullup Level: 1804 mV CMD Active Level: 1861 mV EMMC Device Information : EMMC CID: 150100513331334242005949EC761491 EMMC CSD: D02701320F5903FFF6DBFFEF8E40400D EMMC Manufacture Name: SAMSUNG , EMMC NAME: Q313BB , EMMC NAME (HEX): 513331334242 , S/N: 5949EC76 , rev. 0x00 EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Manufacture Date: 1/2017 EMMC ROM 1 (Main User Data) Capacity: 15028 MB (0003AB400000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01) Boot configuration [PARTITION_CONFIG]: 0x00 , Boot from: no boot Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: Q313BB_5949EC76_20180911_205104.extcsd EMMC Init completed. Scanning soft partitions GPT header is found and is valid Partition: apnhlos, [000000400000 - 000001300000], size: 000000F00000 Partition: modem, [000001300000 - 000004C70000], size: 000003970000 Partition: sbl1, [000004C70000 - 000004CF0000], size: 000000080000 Partition: ddr, [000004CF0000 - 000004CF8000], size: 000000008000 Partition: aboot, [000004CF8000 - 000004EF8000], size: 000000200000 Partition: rpm, [000004EF8000 - 000004F78000], size: 000000080000 Partition: qsee, [000004F78000 - 000005038000], size: 0000000C0000 Partition: qhee, [000005038000 - 0000050B8000], size: 000000080000 Partition: fsg, [0000050B8000 - 0000053B8000], size: 000000300000 Partition: sec, [0000053B8000 - 0000053BC000], size: 000000004000 Partition: pad, [0000053BC000 - 000005E00000], size: 000000A44000 Partition: param, [000005E00000 - 000006800000], size: 000000A00000 Partition: efs, [000006800000 - 000007600000], size: 000000E00000 Partition: modemst1, [000007600000 - 000007900000], size: 000000300000 Partition: modemst2, [000007900000 - 000007C00000], size: 000000300000 Partition: boot, [000007C00000 - 000008900000], size: 000000D00000 Partition: recovery, [000008900000 - 000009800000], size: 000000F00000 Partition: fota, [000009800000 - 00000A400400], size: 000000C00400 Partition: backup, [00000A400400 - 00000AAFE000], size: 0000006FDC00 Partition: fsc, [00000AAFE000 - 00000ADFE000], size: 000000300000 Partition: ssd, [00000ADFE000 - 00000AE00000], size: 000000002000 Partition: persist, [00000AE00000 - 00000B600000], size: 000000800000 Partition: persistent, [00000B600000 - 00000B700000], size: 000000100000 Partition: persdata, [00000B700000 - 00000C000000], size: 000000900000 Partition: system, [00000C000000 - 00009C000000], size: 000090000000 Partition: cache, [00009C000000 - 0000A8800000], size: 00000C800000 Partition: userdata, [0000A8800000 - 0001D1FFB000], size: 0001297FB000 GPT header successfully parsed Get firmware version Brand = samsung Manufacturer = samsung Model = SM-G600FY Phone platform = msm8916 CPU Abi = armeabi-v7a Android release = 6.0.1 Firmware version = MMB29M.G600FYXXU1BRC3 Firmware date = Wed Mar 21 21:04:00 KST 2018 |
The Following User Says Thank You to umarmsn For This Useful Post: |
