05-16-2018, 10:55 | #1 (permalink) |
Freak Poster Join Date: May 2008 Location: IN Age: 36
Member: 768205 Status: Offline Thanks Meter: 45 | Sm-g600fy dead after write sboot. eMMC_tool Suite ver. 1.5.0.0 (release date: 16.04.2018) Microsoft Windows 7 (64 bit) build 7601 (6.1.7601.18015) Looking for EasyJTAG box... EasyJTAG API ver. 2100 EasyJTAG Box Serial = B0623531AA3DB738 Card Serial = AA0F743F EasyJTAG Box Firmware = 2.23 Changelog: 17.04.2018 (ver 1.5.0.0) Fix: Bugs that have been found through your crash report Add: Showing Connected Pins for a Socket (Emmc check) Add: Automatic search and write 8xxx_msimage and BootConfig (write by vendor) Add: SmartReport for Sandisk Add: Vendor Sony Add: Automatic backup of the TrimArea partition for Sony (read by vendor) Add: Grouping of extracted messages by sender (Explorer) Add: Extract Calendar (Explorer) Add: Checking FullDiskEncryption from Boot (Explorer) Add: Scan FullFlash from devices with UFS-memory (Explorer) Add: Converting EFS to Z3X-Samsung format (read by vendor Samsung) Add: Ext4 formatting is completely rewritten (write by vendor) Add: Reading files with emmc errors (Explorer) Add: Skipping for existing files while saving (Explorer) Add: Write protection for ROM 2/3 Setting interface to EasyJtag2/ISP Setting bus width to 1 Bit Setting frequence to 12 Mhz CMD Pullup Level: 639 mV CMD Active Level: 1562 mV Can't init device. Reason: CMD Timeout Error Setting interface to EasyJtag2/ISP Setting bus width to 1 Bit Setting frequence to 12 Mhz CMD Pullup Level: 369 mV CMD Active Level: 1177 mV Can't init device. Reason: CMD Timeout Error Setting interface to EasyJtag2/ISP Setting bus width to 1 Bit Setting frequence to 12 Mhz CMD Pullup Level: 401 mV CMD Active Level: 1649 mV Can't init device. Reason: CMD Timeout Error Setting interface to EasyJtag2/ISP Setting bus width to 1 Bit Setting frequence to 12 Mhz CMD Pullup Level: 413 mV CMD Active Level: 2006 mV Can't init device. Reason: CMD Timeout Error Setting interface to EasyJtag2/ISP Setting bus width to 1 Bit Setting frequence to 18 Mhz CMD Pullup Level: 371 mV CMD Active Level: 1175 mV Can't init device. Reason: CMD Timeout Error Setting interface to EasyJtag2/ISP Setting bus width to 1 Bit Setting frequence to 18 Mhz CMD Pullup Level: 371 mV CMD Active Level: 1174 mV Can't init device. Reason: CMD Timeout Error Setting interface to EasyJtag2/ISP Setting bus width to 1 Bit Setting frequence to 18 Mhz CMD Pullup Level: 369 mV CMD Active Level: 1175 mV Can't init device. Reason: CMD Timeout Error Setting interface to EasyJtag2/ISP Setting bus width to 1 Bit Setting frequence to 9 Mhz CMD Pullup Level: 369 mV CMD Active Level: 1173 mV Can't init device. Reason: CMD Timeout Error Setting interface to EasyJtag2/ISP Setting bus width to 1 Bit Setting frequence to 9 Mhz CMD Pullup Level: 401 mV CMD Active Level: 1645 mV Can't init device. Reason: CMD Timeout Error Setting interface to EasyJtag2/ISP Setting bus width to 1 Bit Setting frequence to 12 Mhz CMD Pullup Level: 401 mV CMD Active Level: 1644 mV Can't init device. Reason: CMD Timeout Error Setting interface to EasyJtag2/ISP Setting bus width to 1 Bit Setting frequence to 12 Mhz CMD Pullup Level: 2110 mV CMD Active Level: 2614 mV EMMC Device Information : EMMC CID: 150100514E31364D42005FF0D48CB2EB EMMC CSD: D02701320F5903FFF6DBFFEF8E40400D EMMC Manufacture : SAMSUNG , EMMC NAME: QN16MB , HEX: 514E31364D42 , S/N: 5FF0D48C , rev. 0x00 EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 512 KB (000000080000) Extended CSD Information : Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01) Supported partition features [PARTITIONING_SUPPORT]: 0x07 Backup saved: QN16MB_5FF0D48C_20180516_150544.extcsd EMMC Init completed. Warning: Health report is very BAD Device Life Time Estimation (MLC) [269]: 0x06 50% - 60% device life time used Device Life Time Estimation (SLC) [268]: 0x06 50% - 60% device life time used Pre EOL information [267]: 0x01 Normal Setting interface to EasyJtag2/ISP Setting bus width to 1 Bit Setting frequence to 12 Mhz CMD Pullup Level: 2105 mV CMD Active Level: 2615 mV EMMC Device Information : EMMC CID: 150100514E31364D42005FF0D48CB2EB EMMC CSD: D02701320F5903FFF6DBFFEF8E40400D EMMC Manufacture : SAMSUNG , EMMC NAME: QN16MB , HEX: 514E31364D42 , S/N: 5FF0D48C , rev. 0x00 EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 512 KB (000000080000) Extended CSD Information : Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01) Supported partition features [PARTITIONING_SUPPORT]: 0x07 Backup saved: QN16MB_5FF0D48C_20180516_150719.extcsd EMMC Init completed. Warning: Health report is very BAD Device Life Time Estimation (MLC) [269]: 0x06 50% - 60% device life time used Device Life Time Estimation (SLC) [268]: 0x06 50% - 60% device life time used Pre EOL information [267]: 0x01 Normal Reading from: ROM1 , start: 0x000000000000 , size: 0x000020000000 Output file: C:\Users\Ram\Desktop\G600fy\EMMC_QN16MB_ROM1_00000 0000000_000020000000.bin eMMC switching to ROM1 Reading partition... Done reading partition. Read speed: 1426.37 Kb/s All done time: [00:06:07:751] Setting interface to EasyJtag2/ISP Setting bus width to 1 Bit Setting frequence to 12 Mhz CMD Pullup Level: 2104 mV CMD Active Level: 2612 mV EMMC Device Information : EMMC CID: 150100514E31364D42005FF0D48CB2EB EMMC CSD: D02701320F5903FFF6DBFFEF8E40400D EMMC Manufacture : SAMSUNG , EMMC NAME: QN16MB , HEX: 514E31364D42 , S/N: 5FF0D48C , rev. 0x00 EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 512 KB (000000080000) Extended CSD Information : Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01) Supported partition features [PARTITIONING_SUPPORT]: 0x07 Backup saved: QN16MB_5FF0D48C_20180516_151449.extcsd EMMC Init completed. Warning: Health report is very BAD Device Life Time Estimation (MLC) [269]: 0x06 50% - 60% device life time used Device Life Time Estimation (SLC) [268]: 0x06 50% - 60% device life time used Pre EOL information [267]: 0x01 Normal Reading from: ROM2 , start: 0x000000000000 , size: 0x000000400000 Output file: C:\Users\Ram\Desktop\G600fy\EMMC_QN16MB_ROM2_00000 0000000_000000400000.bin eMMC switching to ROM2 Reading partition... Done reading partition. Read speed: 1293.00 Kb/s All done time: [00:00:03:328] Setting interface to EasyJtag2/ISP Setting bus width to 1 Bit Setting frequence to 12 Mhz CMD Pullup Level: 2106 mV CMD Active Level: 2574 mV EMMC Device Information : EMMC CID: 150100514E31364D42005FF0D48CB2EB EMMC CSD: D02701320F5903FFF6DBFFEF8E40400D EMMC Manufacture : SAMSUNG , EMMC NAME: QN16MB , HEX: 514E31364D42 , S/N: 5FF0D48C , rev. 0x00 EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 512 KB (000000080000) Extended CSD Information : Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01) Supported partition features [PARTITIONING_SUPPORT]: 0x07 Backup saved: QN16MB_5FF0D48C_20180516_151510.extcsd EMMC Init completed. Warning: Health report is very BAD Device Life Time Estimation (MLC) [269]: 0x06 50% - 60% device life time used Device Life Time Estimation (SLC) [268]: 0x06 50% - 60% device life time used Pre EOL information [267]: 0x01 Normal Reading from: ROM3 , start: 0x000000000000 , size: 0x000000400000 Output file: C:\Users\Ram\Desktop\G600fy\EMMC_QN16MB_ROM3_00000 0000000_000000400000.bin eMMC switching to ROM3 Reading partition... Done reading partition. Read speed: 1268.73 Kb/s All done time: [00:00:03:384] Not supported yet ... Setting interface to EasyJtag2/ISP Setting bus width to 1 Bit Setting frequence to 12 Mhz CMD Pullup Level: 2104 mV CMD Active Level: 2612 mV EMMC Device Information : EMMC CID: 150100514E31364D42005FF0D48CB2EB EMMC CSD: D02701320F5903FFF6DBFFEF8E40400D EMMC Manufacture : SAMSUNG , EMMC NAME: QN16MB , HEX: 514E31364D42 , S/N: 5FF0D48C , rev. 0x00 EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 512 KB (000000080000) Extended CSD Information : Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01) Supported partition features [PARTITIONING_SUPPORT]: 0x07 Backup saved: QN16MB_5FF0D48C_20180516_151630.extcsd EMMC Init completed. Reading S.M.A.R.T Report ... Device Life Time Estimation (MLC) [269]: 0x06 50% - 60% device life time used Device Life Time Estimation (SLC) [268]: 0x06 50% - 60% device life time used Pre EOL information [267]: 0x01 Normal Optimal Read Size [266]: 0x00 Not defined Optimal Write Size [265]: 0x08 32 KB Optimal Trim Unit Size [264]: 0x01 4 KB Setting interface to EasyJtag2/ISP Setting bus width to 1 Bit Setting frequence to 12 Mhz CMD Pullup Level: 2108 mV CMD Active Level: 2614 mV EMMC Device Information : EMMC CID: 150100514E31364D42005FF0D48CB2EB EMMC CSD: D02701320F5903FFF6DBFFEF8E40400D EMMC Manufacture : SAMSUNG , EMMC NAME: QN16MB , HEX: 514E31364D42 , S/N: 5FF0D48C , rev. 0x00 EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 512 KB (000000080000) Extended CSD Information : Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01) Supported partition features [PARTITIONING_SUPPORT]: 0x07 Backup saved: QN16MB_5FF0D48C_20180516_151641.extcsd EMMC Init completed. Warning: Health report is very BAD Device Life Time Estimation (MLC) [269]: 0x06 50% - 60% device life time used Device Life Time Estimation (SLC) [268]: 0x06 50% - 60% device life time used Pre EOL information [267]: 0x01 Normal MoviNand Reset ... Sending Smart Wipe Request... Wiping Card... Please do not touch it! Successfully Please don't forget to repair extCSD from backup! Setting interface to EasyJtag2/ISP Setting bus width to 1 Bit Setting frequence to 12 Mhz CMD Pullup Level: 2105 mV CMD Active Level: 2536 mV EMMC Device Information : EMMC CID: 150100514E31364D42005FF0D48CB2EB EMMC CSD: D02701320F5903FFF6DBFFEF8E40400D EMMC Manufacture : SAMSUNG , EMMC NAME: QN16MB , HEX: 514E31364D42 , S/N: 5FF0D48C , rev. 0x00 EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 512 KB (000000080000) Extended CSD Information : Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01) Supported partition features [PARTITIONING_SUPPORT]: 0x07 Backup saved: QN16MB_5FF0D48C_20180516_151659.extcsd EMMC Init completed. Warning: Health report is very BAD Device Life Time Estimation (MLC) [269]: 0x06 50% - 60% device life time used Device Life Time Estimation (SLC) [268]: 0x06 50% - 60% device life time used Pre EOL information [267]: 0x01 Normal MoviNand Format + reset ... EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB EMMC RPMB (Replay Protected Memory Block) Capacity: 512 KB Sending Internal Reconfiguration Request... Waiting configuration Apply! Restoring configuration... EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB EMMC RPMB (Replay Protected Memory Block) Capacity: 512 KB Wiping Card... Please do not touch it! Successfully Please don't forget to repair extCSD from backup! Setting interface to EasyJtag2/ISP Setting bus width to 1 Bit Setting frequence to 12 Mhz CMD Pullup Level: 2105 mV CMD Active Level: 2535 mV EMMC Device Information : EMMC CID: 150100514E31364D42005FF0D48CB2EB EMMC CSD: D02701320F5903FFF6DBFFEF8E40400D EMMC Manufacture : SAMSUNG , EMMC NAME: QN16MB , HEX: 514E31364D42 , S/N: 5FF0D48C , rev. 0x00 EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 512 KB (000000080000) Extended CSD Information : Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01) Supported partition features [PARTITIONING_SUPPORT]: 0x07 Backup saved: QN16MB_5FF0D48C_20180516_151903.extcsd EMMC Init completed. Warning: Health report is very BAD Device Life Time Estimation (MLC) [269]: 0x06 50% - 60% device life time used Device Life Time Estimation (SLC) [268]: 0x06 50% - 60% device life time used Pre EOL information [267]: 0x01 Normal Setting interface to EasyJtag2/ISP Setting bus width to 1 Bit Setting frequence to 12 Mhz CMD Pullup Level: 2105 mV CMD Active Level: 2614 mV EMMC Device Information : EMMC CID: 150100514E31364D42005FF0D48CB2EB EMMC CSD: D02701320F5903FFF6DBFFEF8E40400D EMMC Manufacture : SAMSUNG , EMMC NAME: QN16MB , HEX: 514E31364D42 , S/N: 5FF0D48C , rev. 0x00 EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 512 KB (000000080000) Extended CSD Information : Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01) Supported partition features [PARTITIONING_SUPPORT]: 0x07 Backup saved: QN16MB_5FF0D48C_20180516_151920.extcsd EMMC Init completed. Warning: Health report is very BAD Device Life Time Estimation (MLC) [269]: 0x06 50% - 60% device life time used Device Life Time Estimation (SLC) [268]: 0x06 50% - 60% device life time used Pre EOL information [267]: 0x01 Normal Operation: Changing GP sizes (test mode) ... GP1 size: 0 MB , WR_REL: 1 , ENH 0 GP2 size: 0 MB , WR_REL: 1 , ENH 0 GP3 size: 0 MB , WR_REL: 1 , ENH 0 GP4 size: 0 MB , WR_REL: 1 , ENH 0 HW_PART error. Reason: Zero sizes Setting interface to EasyJtag2/ISP Setting bus width to 1 Bit Setting frequence to 12 Mhz CMD Pullup Level: 2105 mV CMD Active Level: 2613 mV EMMC Device Information : EMMC CID: 150100514E31364D42005FF0D48CB2EB EMMC CSD: D02701320F5903FFF6DBFFEF8E40400D EMMC Manufacture : SAMSUNG , EMMC NAME: QN16MB , HEX: 514E31364D42 , S/N: 5FF0D48C , rev. 0x00 EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 512 KB (000000080000) Extended CSD Information : Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01) Supported partition features [PARTITIONING_SUPPORT]: 0x07 Backup saved: QN16MB_5FF0D48C_20180516_151926.extcsd EMMC Init completed. Warning: Health report is very BAD Device Life Time Estimation (MLC) [269]: 0x06 50% - 60% device life time used Device Life Time Estimation (SLC) [268]: 0x06 50% - 60% device life time used Pre EOL information [267]: 0x01 Normal Operation: Changing GP sizes (final write) ... GP1 size: 0 MB , WR_REL: 1 , ENH 0 GP2 size: 0 MB , WR_REL: 1 , ENH 0 GP3 size: 0 MB , WR_REL: 1 , ENH 0 GP4 size: 0 MB , WR_REL: 1 , ENH 0 HW_PART error. Reason: Zero sizes Setting interface to EasyJtag2/ISP Setting bus width to 1 Bit Setting frequence to 12 Mhz CMD Pullup Level: 2127 mV CMD Active Level: 2587 mV EMMC Device Information : EMMC CID: 150100514E31364D42005FF0D48CB2EB EMMC CSD: D02701320F5903FFF6DBFFEF8E40400D EMMC Manufacture : SAMSUNG , EMMC NAME: QN16MB , HEX: 514E31364D42 , S/N: 5FF0D48C , rev. 0x00 EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 512 KB (000000080000) Extended CSD Information : Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01) Supported partition features [PARTITIONING_SUPPORT]: 0x07 Backup saved: QN16MB_5FF0D48C_20180516_151954.extcsd EMMC Init completed. Warning: Health report is very BAD Device Life Time Estimation (MLC) [269]: 0x06 50% - 60% device life time used Device Life Time Estimation (SLC) [268]: 0x06 50% - 60% device life time used Pre EOL information [267]: 0x01 Normal Setting interface to EasyJtag2/ISP Setting bus width to 1 Bit Setting frequence to 12 Mhz CMD Pullup Level: 2121 mV CMD Active Level: 2547 mV EMMC Device Information : EMMC CID: 150100514E31364D42005FF0D48CB2EB EMMC CSD: D02701320F5903FFF6DBFFEF8E40400D EMMC Manufacture : SAMSUNG , EMMC NAME: QN16MB , HEX: 514E31364D42 , S/N: 5FF0D48C , rev. 0x00 EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 512 KB (000000080000) Extended CSD Information : Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01) Supported partition features [PARTITIONING_SUPPORT]: 0x07 Backup saved: QN16MB_5FF0D48C_20180516_152142.extcsd EMMC Init completed. Warning: Health report is very BAD Device Life Time Estimation (MLC) [269]: 0x06 50% - 60% device life time used Device Life Time Estimation (SLC) [268]: 0x06 50% - 60% device life time used Pre EOL information [267]: 0x01 Normal Operation: Universal Factory Format Please, wait ... Successfully Setting interface to EasyJtag2/ISP Setting bus width to 1 Bit Setting frequence to 12 Mhz CMD Pullup Level: 2120 mV CMD Active Level: 2614 mV EMMC Device Information : EMMC CID: 150100514E31364D42005FF0D48CB2EB EMMC CSD: D02701320F5903FFF6DBFFEF8E40400D EMMC Manufacture : SAMSUNG , EMMC NAME: QN16MB , HEX: 514E31364D42 , S/N: 5FF0D48C , rev. 0x00 EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 512 KB (000000080000) Extended CSD Information : Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01) Supported partition features [PARTITIONING_SUPPORT]: 0x07 Backup saved: QN16MB_5FF0D48C_20180516_152149.extcsd EMMC Init completed. Reading S.M.A.R.T Report ... Device Life Time Estimation (MLC) [269]: 0x06 50% - 60% device life time used Device Life Time Estimation (SLC) [268]: 0x06 50% - 60% device life time used Pre EOL information [267]: 0x01 Normal Optimal Read Size [266]: 0x00 Not defined Optimal Write Size [265]: 0x08 32 KB Optimal Trim Unit Size [264]: 0x01 4 KB Setting interface to EasyJtag2/ISP Setting bus width to 1 Bit Setting frequence to 12 Mhz CMD Pullup Level: 2120 mV CMD Active Level: 2617 mV EMMC Device Information : EMMC CID: 150100514E31364D42005FF0D48CB2EB EMMC CSD: D02701320F5903FFF6DBFFEF8E40400D EMMC Manufacture : SAMSUNG , EMMC NAME: QN16MB , HEX: 514E31364D42 , S/N: 5FF0D48C , rev. 0x00 EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 512 KB (000000080000) Extended CSD Information : Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01) Supported partition features [PARTITIONING_SUPPORT]: 0x07 Backup saved: QN16MB_5FF0D48C_20180516_152206.extcsd EMMC Init completed. Warning: Health report is very BAD Device Life Time Estimation (MLC) [269]: 0x06 50% - 60% device life time used Device Life Time Estimation (SLC) [268]: 0x06 50% - 60% device life time used Pre EOL information [267]: 0x01 Normal Error: This emmc does not have write protection |
