04-20-2018, 16:06 | #1 (permalink) |
Freak Poster Join Date: Sep 2015
Member: 2463805 Status: Offline Thanks Meter: 32 | SM G900F connection probleam If anyone have tested pinout or successfully connected please share info pichttps://ibb.co/dKCGWn logs Code: Z3X EasyJtag Software ver. 2.9.0.0 Loading eMMC GEN1 Firmware... IO: 2800 mV Box S/N: 0301200C8AB5FBA1, ,FW Ver.: 01.62 CMD Pullup Level:866 mV CMD Active Level:2186 mV Box IO Level:2800 mV CLK Rate:14000 kHz Bus Width:1bit,SDR HiPower mode is off! Can't init device, Reason: CMD Timeout Error Done. Z3X EasyJtag Software ver. 2.9.0.0 Loading eMMC GEN1 Firmware... IO: 1850 mV Box S/N: 0301200C8AB5FBA1, ,FW Ver.: 01.62 CMD Pullup Level:742 mV CMD Active Level:11830 mV Box IO Level:1850 mV CLK Rate:14000 kHz Bus Width:1bit,SDR HiPower mode is off! Can't init device, Reason: OCR Ready Timeout Error [Check VCC or eMMC DEAD] Done. Z3X EasyJtag Software ver. 2.9.0.0 Loading eMMC GEN1 Firmware... IO: 1850 mV Box S/N: 0301200C8AB5FBA1, ,FW Ver.: 01.62 CMD Pullup Level:825 mV CMD Active Level:11830 mV Box IO Level:1850 mV CLK Rate:14000 kHz Bus Width:1bit,SDR HiPower mode is off! Can't init device, Reason: OCR Ready Timeout Error [Check VCC or eMMC DEAD] Done. |
04-23-2018, 14:37 | #3 (permalink) |
Member: 2463805 Status: Offline Thanks Meter: 32 | it is different Thank you but the pin out is it is different. here is the clear pic https://ibb.co/nwuh9H |
04-23-2018, 15:05 | #4 (permalink) | |
No Life Poster Join Date: May 2009 Location: mumbai wadala
Member: 1037372 Status: Offline Thanks Meter: 557 | Quote:
Your cmd clk dato line is good connected Check only vcc and vccq if not connect then remove vcc and vccq ( connect usb to motherboard and try again) | |
The Following User Says Thank You to royalnasim For This Useful Post: |
