06-19-2017, 10:14 | #1 (permalink) |
Freak Poster Join Date: May 2015
Member: 2399952 Status: Offline Thanks Meter: 40 | SM-J100H Dead Boot Repair Fail please HELP Here is info HiPower mode is OFF CMD Pullup Level: 2640 mV CMD Active Level: 3238 mV EMMC Device Information : EMMC CID: 90014A48344732621101E6D8BEC04222 EMMC CSD: D07F01320F5903FFFFFFFFEF8A4040DA EMMC Manufacture Name: SKHYNIX EMMC NAME: H4G2b , S/N: E6D8BEC0 , rev. 01 EMMC NAME (HEX): 483447326211 EMMC ROM 1 (Main User Data) Capacity: 3728 MB (0000E9000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Backup saved: H4G2b_E6D8BEC0_20170619_110424.extcsd EMMC Init completed. Get firmware version Firmware info not found Try to read table form EMMC HiPower mode is OFF CMD Pullup Level: 2640 mV CMD Active Level: 3238 mV EMMC Device Information : EMMC CID: 90014A48344732621101E6D8BEC04222 EMMC CSD: D07F01320F5903FFFFFFFFEF8A4040DA EMMC Manufacture Name: SKHYNIX EMMC NAME: H4G2b , S/N: E6D8BEC0 , rev. 01 EMMC NAME (HEX): 483447326211 EMMC ROM 1 (Main User Data) Capacity: 3728 MB (0000E9000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Backup saved: H4G2b_E6D8BEC0_20170619_110424.extcsd EMMC Init completed. Get firmware version Firmware info not found HiPower mode is OFF CMD Pullup Level: 2640 mV CMD Active Level: 3238 mV EMMC Device Information : EMMC CID: 90014A48344732621101E6D8BEC04222 EMMC CSD: D07F01320F5903FFFFFFFFEF8A4040DA EMMC Manufacture Name: SKHYNIX EMMC NAME: H4G2b , S/N: E6D8BEC0 , rev. 01 EMMC NAME (HEX): 483447326211 EMMC ROM 1 (Main User Data) Capacity: 3728 MB (0000E9000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Backup saved: H4G2b_E6D8BEC0_20170619_111327.extcsd EMMC Init completed. Operation: Try to read table from emmc Vendor: Samsung Searching GPT ... GPT header is not found Partition table not found |
07-12-2017, 21:18 | #7 (permalink) |
Member: 131131 Status: Offline Sonork: 100.1606847 Thanks Meter: 4,475 | Hi This mean SW can't find correct partitions,may you need select SPD first then try read Partitions if your phone is spd Anyway,Just try write latest BL+pit if not Power on,Try replace eMMC |
The Following User Says Thank You to BABAK NURI For This Useful Post: |
07-15-2017, 06:05 | #8 (permalink) |
Freak Poster Join Date: Sep 2014 Location: Bahawal Nagar
Member: 2250995 Status: Offline Thanks Meter: 47 | Hv repaired same ,like J200H Via easy jtag.... select SPD first then try read Partitions if your phone is spd Then Erase just write pit then write by vander (use Of Lateset Firmware IS necessery)... i used same steps at J200H WAS Facing problem like you |
