Old 11-20-2016, 08:39   #1 (permalink)
Deepesh Sharma's Avatar
Member: 1301233
Sonork: Closed
Thanks Meter: 9,297
samsung j100h emmc repaire done with jtag
Hello
Samsung j100h Dead Recover With Easy Jtag
You See Here Chunk Error But Now Handset Go In Download Mode And Flash With Odin Now Set Working Fine
Sucessfully Dead Boot Recovered
The Following 18 Users Say Thank You to Deepesh Sharma For This Useful Post:
Old 11-20-2016, 10:34   #2 (permalink)
Member: 1197620
Sonork: 100.1602278
Thanks Meter: 647
power full post with story of success
The Following User Says Thank You to saleem5001 For This Useful Post:
Old 11-29-2016, 06:08   #3 (permalink)
bronce's Avatar
Member: 488875
Sonork: 100.1626294
Thanks Meter: 1,129
kindly share the file you used pls.
btw,
useful info.
The Following 3 Users Say Thank You to bronce For This Useful Post:
Old 11-29-2016, 10:38   #4 (permalink)
Member: 1301233
Sonork: Closed
Thanks Meter: 9,297
btw,
useful info.
factory repair file
J100H_XXU0AOA1_OXE0AOA1
The Following 11 Users Say Thank You to Deepesh Sharma For This Useful Post:
Old 12-03-2016, 17:04   #5 (permalink)
Member: 2656356
Thanks Meter: 3
Originally Posted by Deepesh_Sharma View Post
factory repair file
Hello,
My friend bring his SM-J100h/DS to me asking for repair.
it was stuck on boot so i tried to Wipe Data / Factory Reset, but there were many errors, something like "E: can't mount....."
After that, i flashed it with ODIN 3.09 + the latest firmware (September 29, 2016 based on my country code)
The flash was successful and PASS 100%..
but still stuck on boot logo.
so, i found a video on Youtube about this..
i did everything exactly the same:
ROM => J100H_XXU0AOA1_OXE0AOA1 (contain files as shown below)
BL => BL_J100HXXU0AOA1_CL333157_QB3542504_REV01_user_low _ship
AP => AP_J100HXXU0AOA1_CL333157_QB3542504_REV01_user_low _ship
CP => CP_J100HXXU0AOA1_CL333157_QB3542504_REV01_user_low _ship
CSC => CSC_OXE_J100HOXE0AOA1_CL333157_QB3542504_REV01_use r_low_ship
PIT => J13G (Repartition)
The flash once again PASS 100% and the device rebooted automatically but NO POWER.
It is completely DEAD now.
i removed the Battery, put it on again, still cannot be powered on.
i plugged in the USB charging cable, still no power, no charging indicator.
It's now completely dead.
What shall i do now?
Somebody please help me..
i'm a dead man now..
Many thanks in advance
The Following 3 Users Say Thank You to kimdonghwan For This Useful Post:
Old 12-03-2016, 17:16   #6 (permalink)
Member: 507911
Thanks Meter: 22
Originally Posted by kimdonghwan View Post
Hello,
Same with me ..then i try tu isp pin out but not conected...any one have tested isp pinout j100
The Following 2 Users Say Thank You to juwana_pati For This Useful Post:
Old 12-04-2016, 05:48   #7 (permalink)
Member: 1301233
Sonork: Closed
Thanks Meter: 9,297
pin out and allready in support or open easy jtag program and you can see pin out in emmc pin section pin out is testing need to solder carefully
The Following 4 Users Say Thank You to Deepesh Sharma For This Useful Post:
Old 12-16-2016, 14:18   #8 (permalink)
Suny125's Avatar
Member: 2488031
Sonork: 100.1662695
Thanks Meter: 1,947
Samsung J100H/DS Boot Repair Pinout / Dead Boot Repair File
Loading eMMC Addon Firmware... IO: 2800 mV
Box S/N: , ,FW Ver.: 01.55
CMD Pullup Level:2031 mV
CMD Active Level:2371 mV
Box IO Level:2800 mV
CLK Rate:14000 khz
HiPower mode is off!
---------- eMMC Device Information ----------
EMMC CID : 1501004E4A325A4D42009E73B45192AC
EMMC CSD : D02701320F5903FFF6DBFFEF8E40400C
EMMC Manufacturer ID: 0015 , OEM ID: 0100
EMMC Date: 09/2015 Rev.0x0
EMMC NAME: NJ2ZMB , S/N: 2658382929
EMMC NAME (HEX): 4E4A325A4D4200
EMMC ROM1 (Main User Data) Capacity: 3728 MB
EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB
EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB
EMMC RPMB (Replay Protected Memory Block) Capacity: 512 kB
EMMC Permanent Write Protection: No
EMMC Temporary Write Protection: No
EMMC Password Locked: No
Extended CSD rev 1.7 (MMC 5.0)
Boot configuration [PARTITION_CONFIG: 0x08] Boot from:ROM2 (Boot Partition 1)
Boot bus config [177]: 0x01 , width 4bits , Partition config [179]: 0x08.
H/W reset function [RST_N_FUNCTION]: 0x00
High-capacity W protect group size [HC_WP_GRP_SIZE: 0x00000000]
Partitioning Support [PARTITIONING_SUPPORT]: 0x07
Device support partitioning feature
Device can have enhanced tech.
Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00
Backup saved: NJ2ZMB_2658382929_20161009_1201.extcsd
Done.
Z3X EasyJtag Software ver. 2.4.0.0
Skip loading eMMC Addon Firmware
Input file : E:\JTAG\Z3X Easy-JTAG\J100H\SM-J100h_J100HXCU0AOD4_ROM1_OK.bin
Writing 0040000000 bytes to 00000000 ...ROM1 (USER ROM)
Done. Write Speed: 941 kB/s
Suny125
The Following 8 Users Say Thank You to Suny125 For This Useful Post:
Old 12-17-2016, 07:26   #9 (permalink)
mobifone's Avatar
Member: 860880
Thanks Meter: 83
@Suny125
could you please give guide step by step how to repair?
The Following 3 Users Say Thank You to mobifone For This Useful Post:
Old 01-15-2017, 19:42   #10 (permalink)
Member: 1675290
Thanks Meter: 177
this phone hynix emmc you just lucky repair this emmc ... for 100% repair you change it to samsung i solved many time with kmnjs/kmn5x/kmkjs or you can used mercedes emmc kmi8 to make it 1gb ram / 16 gb storage
back up extcd rom1 512 rom2 rom3 . then write it to new emmc the flash it with 4 files (dont use pit or phone will random error ) -- done
The Following 4 Users Say Thank You to bagus.dps For This Useful Post:
Old 02-26-2017, 10:59   #11 (permalink)
ramrajbhopal's Avatar
Member: 768205
Thanks Meter: 45
SM-J100H Partitioning not detected...
​SM-J100H DEAD AFTER FLAH
EMMC CID : 90014A4834473262110104412CD0222C
EMMC CSD : D07F01320F5903FFFFFFFFEF8A4040DA
EMMC Manufacturer ID: 0090 , OEM ID: 014A
EMMC Date: 02/2015 Rev.0x1
EMMC NAME: H4G2b , S/N: 71380176
EMMC NAME (HEX): 48344732622000
EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB
Extended CSD rev 1.6 (MMC 4.5)
Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x08.
Backup saved: H4G2b _ 71380176_20170226_1439.extcsd
Searching for partition tables...
Done.
The Following 3 Users Say Thank You to ramrajbhopal For This Useful Post:
Old 02-26-2017, 21:16   #12 (permalink)
BABAK NURI's Avatar
Member: 131131
Sonork: 100.1606847
Thanks Meter: 4,475
Hi
as i see in your log ,Your phone is SPD based CPU
I have no idea about this model but i think SPD no show Partitions like MTK
Anyway
Please Write Pit+latest BL via Easy Plus
The Following 6 Users Say Thank You to BABAK NURI For This Useful Post:
Old 02-26-2017, 21:41   #13 (permalink)
bast3800's Avatar
Member: 731596
Thanks Meter: 164
Easy jitag can't repair dead boot for J100H
The Following 3 Users Say Thank You to bast3800 For This Useful Post:
Old 02-27-2017, 00:30   #14 (permalink)
Member: 205475
Thanks Meter: 179
no
u r wrong i done many j1
---------- eMMC Device Information ----------EMMC CID : 90014A48344732621101C66824096218
EMMC Date: 06/2015 Rev.0x1
EMMC NAME: H4G2b , S/N: 3328713737
Backup saved: H4G2b _3328713737_20160823_1755.extcsd
Detected GPT over MBR...
Warning: Header Size = 512 (expected 92)
Medium UUID: 52444E41-494F-2044-4D4D-43204449534B
Warning: Entries Count = 128
MMCBLK0P0 (SBOOT) Range: [0X400000,0X5FFE00] ,Len: 200000
MMCBLK0P1 (SBOOT2) Range: [0X600000,0X7FFE00] ,Len: 200000
MMCBLK0P2 (WFIXNV1) Range: [0X800000,0X8FFE00] ,Len: 100000
MMCBLK0P3 (WFIXNV2) Range: [0X900000,0X9FFE00] ,Len: 100000
MMCBLK0P4 (TDFIXNV1) Range: [0XA00000,0XAFFE00] ,Len: 100000
MMCBLK0P5 (TDFIXNV2) Range: [0XB00000,0XBFFE00] ,Len: 100000
MMCBLK0P6 (WDSP) Range: [0XC00000,0XFFFE00] ,Len: 400000
MMCBLK0P7 (MODEM) Range: [0X1000000,0X17FFE00] ,Len: 800000
MMCBLK0P8 (MODEM2) Range: [0X1800000,0X1FFFE00] ,Len: 800000
MMCBLK0P9 (TDDSP) Range: [0X2000000,0X23FFE00] ,Len: 400000
MMCBLK0P10 (FOTA_SIG) Range: [0X2400000,0X24FFE00] ,Len: 100000
MMCBLK0P11 (WRUNTIMENV1) Range: [0X2500000,0X25FFE00] ,Len: 100000
MMCBLK0P12 (WRUNTIMENV2) Range: [0X2600000,0X26FFE00] ,Len: 100000
MMCBLK0P13 (TDRUNTIMENV1) Range: [0X2700000,0X27FFE00] ,Len: 100000
MMCBLK0P14 (TDRUNTIMENV2) Range: [0X2800000,0X28FFE00] ,Len: 100000
MMCBLK0P15 (PARAM) Range: [0X2900000,0X2AFFE00] ,Len: 200000
MMCBLK0P16 (EFS) Range: [0X2B00000,0X3EFFE00] ,Len: 1400000
MMCBLK0P17 (PRODNV) Range: [0X3F00000,0X43FFE00] ,Len: 500000
MMCBLK0P18 (RESERVED2) Range: [0X4400000,0X44FFE00] ,Len: 100000
MMCBLK0P19 (KERNEL) Range: [0X4500000,0X54FFE00] ,Len: 1000000
MMCBLK0P20 (RECOVERY) Range: [0X5500000,0X64FFE00] ,Len: 1000000
MMCBLK0P21 (CSC) Range: [0X6500000,0X12CFFE00] ,Len: C800000
MMCBLK0P22 (SYSTEM) Range: [0X12D00000,0X53CFFE00] ,Len: 41000000
MMCBLK0P23 (HIDDEN) Range: [0X53D00000,0X564FFE00] ,Len: 2800000
MMCBLK0P24 (USERDATA) Range: [0X56500000,0XE80FFE00] ,Len: 91C00000
Done...Presets has been updated...
Done.
The Following User Says Thank You to anasshe For This Useful Post:
Old 02-27-2017, 21:55   #15 (permalink)
BABAK NURI's Avatar
Member: 131131
Sonork: 100.1606847
Thanks Meter: 4,475
Hi
Can you explain me why you think this?
The Following User Says Thank You to BABAK NURI For This Useful Post:
Page generated in 0.26652 seconds with 10 queries
