02-27-2018, 14:05 | #1 (permalink) |
No Life Poster Join Date: Jan 2003 Location: Iassy Age: 59
Member: 19723 Status: Offline Thanks Meter: 359 | G630-U20 error (again) Code: Compression is ON Z3X EasyJtag Software ver. 2.6.0.1 Loading eMMC GEN1 Firmware... IO: 2800 mV Box S/N: xxxxxxxxxxxxxx, ,FW Ver.: 01.62 CMD Pullup Level:2650 mV CMD Active Level:2722 mV Box IO Level:2800 mV CLK Rate:14000 khz HiPower mode is off! Can't init device, Reason: CMD Timeout Error Done. What could be wrong ? Thanks ! |
02-28-2018, 14:02 | #7 (permalink) | |
Member: 19723 Status: Offline Thanks Meter: 359 | Quote:
I think is something wrong with the adaptor or the box . Can you tell me what to check ? Thanks ! | |
02-28-2018, 16:22 | #8 (permalink) |
Member: 19723 Status: Offline Thanks Meter: 359 | Code: Compression is ON Z3X EasyJtag Software ver. 2.6.0.1 Loading eMMC GEN1 Firmware... IO: 2800 mV Box S/N: xxxxxxxxxxxxx, ,FW Ver.: 01.62 CMD Pullup Level:2660 mV CMD Active Level:2732 mV Box IO Level:2800 mV CLK Rate:14000 khz HiPower mode is off! Can't init device, Reason: CMD Timeout Error Done. |
