Sm-j200h gpt shows error but repair done(phone not bootup) SEE ERROR BELOW Opening file: J23G_EUR_OPEN.pit Pit: J23G_EUR_OPEN.pit Entry count: 31 The size of the last section has been updated BL_J200HXXU0AQG1_J200HOJV0AQG1_J200HXXU0AQF1.tar.m d5 The list of files in the firmware: spl.img sboot.bin sboot2.bin HiPower mode is OFF Frequence: 14 Mhz CMD Pullup Level: 2701 mV CMD Active Level: 3310 mV EMMC Device Information : EMMC CID: 90014A4838473474210150E3985F9282 EMMC CSD: D07F01320F5903FFFFFFFFEF8A400012 EMMC Manufacture Name: SKHYNIX EMMC Manufacture ID: 0x90 , OEM ID: 014A EMMC Manufacture Date: 9/2015 , Rev: 01 EMMC NAME: H8G4t! , S/N: 50E3985F , rev. 01 EMMC NAME (HEX): 483847347421 EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01) Boot configuration [PARTITION_CONFIG]: 0x08 , Boot from: ROM2 (Boot partition 1) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: H8G4t!_50E3985F_20171104_150624.extcsd EMMC Init completed. Operation: Write by vendor (Samsung) Creating GPT-partitioninig Error writing at address: 000000000000 ... Retry #1 Error writing at address: 000000000000 ... Retry #2 Error writing at address: 000000000000 ... Retry #3 Writing PIT at address: 000000080000 GPT-partitioning done Unpacking file: spl.img Unpacking file: sboot.bin Unpacking file: sboot2.bin Partition name: BOOT Filename: spl.img , Offset: 000000000000 , filesize: 32768 bytes eMMC switching to ROM2 Erasing partition... Writing partition... Done writing partition. Write speed: 252.29 Kb/s Partition name: SBOOT Filename: sboot.bin , Offset: 000000400000 , filesize: 1573888 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1066.28 Kb/s Partition name: SBOOT2 Filename: sboot2.bin , Offset: 000000600000 , filesize: 1573888 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1068.44 Kb/s All done =============================================== HiPower mode is OFF Frequence: 14 Mhz CMD Pullup Level: 2629 mV CMD Active Level: 3341 mV EMMC Device Information : EMMC CID: 90014A4838473474210150E3985F9282 EMMC CSD: D07F01320F5903FFFFFFFFEF8A400012 EMMC Manufacture Name: SKHYNIX EMMC Manufacture ID: 0x90 , OEM ID: 014A EMMC Manufacture Date: 9/2015 , Rev: 01 EMMC NAME: H8G4t! , S/N: 50E3985F , rev. 01 EMMC NAME (HEX): 483847347421 EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01) Boot configuration [PARTITION_CONFIG]: 0x08 , Boot from: ROM2 (Boot partition 1) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: H8G4t!_50E3985F_20171104_150606.extcsd EMMC Init completed. Scanning soft partitions GPT header is found and is valid Partition: SBOOT, [000000400000 - 000000600000], size: 000000200000 Partition: SBOOT2, [000000600000 - 000000800000], size: 000000200000 Partition: wfixnv1, [000000800000 - 000000900000], size: 000000100000 Partition: wfixnv2, [000000900000 - 000000A00000], size: 000000100000 Partition: tdfixnv1, [000000A00000 - 000000B00000], size: 000000100000 Partition: tdfixnv2, [000000B00000 - 000000C00000], size: 000000100000 Partition: WDSP, [000000C00000 - 000001000000], size: 000000400000 Partition: MODEM, [000001000000 - 000001800000], size: 000000800000 Partition: MODEM2, [000001800000 - 000002000000], size: 000000800000 Partition: TDDSP, [000002000000 - 000002400000], size: 000000400000 Partition: FOTA_SIG, [000002400000 - 000002500000], size: 000000100000 Partition: wruntimenv1, [000002500000 - 000002600000], size: 000000100000 Partition: wruntimenv2, [000002600000 - 000002700000], size: 000000100000 Partition: tdruntimenv1, [000002700000 - 000002800000], size: 000000100000 Partition: tdruntimenv2, [000002800000 - 000002900000], size: 000000100000 Partition: PARAM, [000002900000 - 000002B00000], size: 000000200000 Partition: efs, [000002B00000 - 000003F00000], size: 000001400000 Partition: prodnv, [000003F00000 - 000004400000], size: 000000500000 Partition: RESERVED2, [000004400000 - 000004600000], size: 000000200000 Partition: KERNEL, [000004600000 - 000005600000], size: 000001000000 Partition: RECOVERY, [000005600000 - 000006600000], size: 000001000000 Partition: PERSISTENT, [000006600000 - 000006700000], size: 000000100000 Partition: persdata, [000006700000 - 000007000000], size: 000000900000 Partition: CACHE, [000007000000 - 000013800000], size: 00000C800000 Partition: SYSTEM, [000013800000 - 000071400000], size: 00005DC00000 Partition: HIDDEN, [000071400000 - 000073200000], size: 000001E00000 Partition: userdata, [000073200000 - 0001D1200000], size: 00015E000000 GPT header successfully parsed Get firmware version Firmware info not found HiPower mode is OFF Frequence: 14 Mhz CMD Pullup Level: 2701 mV CMD Active Level: 3310 mV EMMC Device Information : EMMC CID: 90014A4838473474210150E3985F9282 EMMC CSD: D07F01320F5903FFFFFFFFEF8A400012 EMMC Manufacture Name: SKHYNIX EMMC Manufacture ID: 0x90 , OEM ID: 014A EMMC Manufacture Date: 9/2015 , Rev: 01 EMMC NAME: H8G4t! , S/N: 50E3985F , rev. 01 EMMC NAME (HEX): 483847347421 EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01) Boot configuration [PARTITION_CONFIG]: 0x08 , Boot from: ROM2 (Boot partition 1) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: H8G4t!_50E3985F_20171104_150616.extcsd EMMC Init completed. Opening file: J23G_EUR_OPEN.pit Pit: J23G_EUR_OPEN.pit Entry count: 31 The size of the last section has been updated BL_J200HXXU0AQG1_J200HOJV0AQG1_J200HXXU0AQF1.tar.m d5 The list of files in the firmware: spl.img sboot.bin sboot2.bin HiPower mode is OFF Frequence: 14 Mhz CMD Pullup Level: 2701 mV CMD Active Level: 3310 mV EMMC Device Information : EMMC CID: 90014A4838473474210150E3985F9282 EMMC CSD: D07F01320F5903FFFFFFFFEF8A400012 EMMC Manufacture Name: SKHYNIX EMMC Manufacture ID: 0x90 , OEM ID: 014A EMMC Manufacture Date: 9/2015 , Rev: 01 EMMC NAME: H8G4t! , S/N: 50E3985F , rev. 01 EMMC NAME (HEX): 483847347421 EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01) Boot configuration [PARTITION_CONFIG]: 0x08 , Boot from: ROM2 (Boot partition 1) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: H8G4t!_50E3985F_20171104_150624.extcsd EMMC Init completed. Operation: Write by vendor (Samsung) Creating GPT-partitioninig Error writing at address: 000000000000 ... Retry #1 Error writing at address: 000000000000 ... Retry #2 Error writing at address: 000000000000 ... Retry #3 Writing PIT at address: 000000080000 GPT-partitioning done Unpacking file: spl.img Unpacking file: sboot.bin Unpacking file: sboot2.bin Partition name: BOOT Filename: spl.img , Offset: 000000000000 , filesize: 32768 bytes eMMC switching to ROM2 Erasing partition... Writing partition... Done writing partition. Write speed: 252.29 Kb/s Partition name: SBOOT Filename: sboot.bin , Offset: 000000400000 , filesize: 1573888 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1066.28 Kb/s Partition name: SBOOT2 Filename: sboot2.bin , Offset: 000000600000 , filesize: 1573888 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1068.44 Kb/s All done PLEASE ANY POSSIBLE SOLUTION FOR ME TO DO PHONE CONDITION CUSTOMER SAID IT WAS FLASHED WITH WRONG FIRMWARE |
post emmc check log after write. then well talk |
I DID UNIVERSAL FACTORY FORMAT AND WRITE EXTCSD BACK NOW I DID NORMAL REPAIR BUT ALWAYS SHOWS BELOW ERRORS NOW AFTER REPAIR 11/4/2017 5:59:54 PM> eMMC_tool Suite ver. 1.4.8.0 11/4/2017 5:59:54 PM> Microsoft Windows 7 (32 bit) build 7601 (6.1.7601.18015) 11/4/2017 5:59:54 PM> 11/4/2017 5:59:54 PM> Looking for EasyJTAG box... 11/4/2017 5:59:54 PM> EasyJTAG API ver. 2008 11/4/2017 5:59:54 PM> Setting IO Levels to 3.3V 11/4/2017 5:59:54 PM> Setting frequence to 21 Mhz 11/4/2017 5:59:54 PM> HiPower mode is OFF 11/4/2017 5:59:56 PM> OpenUSB returned = 0 11/4/2017 5:59:56 PM> Power Controller returned = 0 11/4/2017 5:59:57 PM> EasyJTAG Box Serial = 1200D0035CA63064 11/4/2017 6:00:03 PM> Card Serial = AADF-497C 11/4/2017 6:00:03 PM> CardAttr = 3B7D95000080318065B0831148C883009000 11/4/2017 6:00:03 PM> EasyJTAG Box Firmware = 01.60 11/4/2017 6:00:03 PM> 11/4/2017 6:03:56 PM> Looking for EasyJTAG box... 11/4/2017 6:03:56 PM> EasyJTAG API ver. 2008 11/4/2017 6:03:56 PM> Setting IO Levels to 3.3V 11/4/2017 6:03:56 PM> Setting frequence to 21 Mhz 11/4/2017 6:03:56 PM> HiPower mode is OFF 11/4/2017 6:03:58 PM> OpenUSB returned = 0 11/4/2017 6:03:58 PM> Power Controller returned = 0 11/4/2017 6:03:59 PM> EasyJTAG Box Serial = 1200D0035CA63064 11/4/2017 6:03:59 PM> EasyJTAG Box Firmware = 01.60 11/4/2017 6:03:59 PM> HiPower mode is OFF 11/4/2017 6:03:59 PM> Frequence: 21 Mhz 11/4/2017 6:03:59 PM> CMD Pullup Level: 2701 mV 11/4/2017 6:03:59 PM> CMD Active Level: 3320 mV 11/4/2017 6:03:59 PM> eMMC Init returned = 0 11/4/2017 6:03:59 PM> EMMC Device Information : 11/4/2017 6:03:59 PM> EMMC CID: 90014A4838473474210150E3985F9282 11/4/2017 6:03:59 PM> EMMC CSD: D07F01320F5903FFFFFFFFEF8A400012 11/4/2017 6:03:59 PM> EMMC Manufacture Name: SKHYNIX 11/4/2017 6:03:59 PM> EMMC Manufacture ID: 0x90 , OEM ID: 014A 11/4/2017 6:03:59 PM> EMMC Manufacture Date: 9/2015 , Rev: 01 11/4/2017 6:03:59 PM> EMMC NAME: H8G4t! , S/N: 50E3985F , rev. 01 11/4/2017 6:03:59 PM> EMMC NAME (HEX): 483847347421 11/4/2017 6:03:59 PM> EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000) 11/4/2017 6:03:59 PM> EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) 11/4/2017 6:03:59 PM> EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) 11/4/2017 6:03:59 PM> EMMC Permanent Write Protection: No 11/4/2017 6:03:59 PM> EMMC Temporary Write Protection: No 11/4/2017 6:03:59 PM> Extended CSD Information : 11/4/2017 6:03:59 PM> Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01) 11/4/2017 6:03:59 PM> Boot configuration [PARTITION_CONFIG]: 0x08 , Boot from: ROM2 (Boot partition 1) 11/4/2017 6:03:59 PM> Boot Bus Config: 0x00 , width 1bit 11/4/2017 6:03:59 PM> H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled 11/4/2017 6:03:59 PM> Supported partition features [PARTITIONING_SUPPORT]: 0x07 11/4/2017 6:03:59 PM> Device supports partitioning features 11/4/2017 6:03:59 PM> Device can have enhanced technological features in partitions and user data area 11/4/2017 6:03:59 PM> Device can have extended partitions attribute 11/4/2017 6:03:59 PM> Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 11/4/2017 6:03:59 PM> Backup saved: H8G4t!_50E3985F_20171104_180359.extcsd 11/4/2017 6:03:59 PM> EMMC Init completed. 11/4/2017 6:03:59 PM> 11/4/2017 6:03:59 PM> Scanning soft partitions 11/4/2017 6:04:02 PM> 11/4/2017 6:04:02 PM> Stopped by User request... 11/4/2017 6:04:02 PM> 11/4/2017 6:05:55 PM> Looking for EasyJTAG box... 11/4/2017 6:05:55 PM> EasyJTAG API ver. 2008 11/4/2017 6:05:55 PM> Setting IO Levels to 3.3V 11/4/2017 6:05:55 PM> Setting frequence to 21 Mhz 11/4/2017 6:05:55 PM> HiPower mode is OFF 11/4/2017 6:05:56 PM> OpenUSB returned = 0 11/4/2017 6:05:56 PM> Power Controller returned = 0 11/4/2017 6:05:57 PM> EasyJTAG Box Serial = 1200D0035CA63064 11/4/2017 6:05:57 PM> EasyJTAG Box Firmware = 01.60 11/4/2017 6:05:57 PM> HiPower mode is OFF 11/4/2017 6:05:57 PM> Frequence: 21 Mhz 11/4/2017 6:05:57 PM> CMD Pullup Level: 2691 mV 11/4/2017 6:05:57 PM> CMD Active Level: 3310 mV 11/4/2017 6:05:57 PM> eMMC Init returned = 0 11/4/2017 6:05:57 PM> EMMC Device Information : 11/4/2017 6:05:57 PM> EMMC CID: 90014A4838473474210150E3985F9282 11/4/2017 6:05:57 PM> EMMC CSD: D07F01320F5903FFFFFFFFEF8A400012 11/4/2017 6:05:57 PM> EMMC Manufacture Name: SKHYNIX 11/4/2017 6:05:57 PM> EMMC Manufacture ID: 0x90 , OEM ID: 014A 11/4/2017 6:05:57 PM> EMMC Manufacture Date: 9/2015 , Rev: 01 11/4/2017 6:05:57 PM> EMMC NAME: H8G4t! , S/N: 50E3985F , rev. 01 11/4/2017 6:05:57 PM> EMMC NAME (HEX): 483847347421 11/4/2017 6:05:57 PM> EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000) 11/4/2017 6:05:57 PM> EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) 11/4/2017 6:05:57 PM> EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) 11/4/2017 6:05:57 PM> EMMC Permanent Write Protection: No 11/4/2017 6:05:57 PM> EMMC Temporary Write Protection: No 11/4/2017 6:05:57 PM> Extended CSD Information : 11/4/2017 6:05:57 PM> Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01) 11/4/2017 6:05:57 PM> Boot configuration [PARTITION_CONFIG]: 0x08 , Boot from: ROM2 (Boot partition 1) 11/4/2017 6:05:57 PM> Boot Bus Config: 0x00 , width 1bit 11/4/2017 6:05:57 PM> H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled 11/4/2017 6:05:57 PM> Supported partition features [PARTITIONING_SUPPORT]: 0x07 11/4/2017 6:05:57 PM> Device supports partitioning features 11/4/2017 6:05:57 PM> Device can have enhanced technological features in partitions and user data area 11/4/2017 6:05:57 PM> Device can have extended partitions attribute 11/4/2017 6:05:57 PM> Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 11/4/2017 6:05:58 PM> Backup saved: H8G4t!_50E3985F_20171104_180558.extcsd 11/4/2017 6:05:58 PM> EMMC Init completed. 11/4/2017 6:05:58 PM> 11/4/2017 6:05:58 PM> Opening file: C:\Users\JOHNOROO37\Desktop\ALL PHONE FIRMWARE\SM-J200H NEW ALL\J200HXXU0AQG1_J200HOJV0AQG1_J200HXXU0AQF1___4f iles_repair\J23G_EUR_OPEN.pit 11/4/2017 6:05:58 PM> 11/4/2017 6:05:58 PM> Pit: J23G_EUR_OPEN.pit 11/4/2017 6:05:58 PM> Entry count: 31 11/4/2017 6:05:58 PM> 11/4/2017 6:05:58 PM> The size of the last section has been updated 11/4/2017 6:06:05 PM> Selected file: C:\Users\JOHNOROO37\Desktop\ALL PHONE FIRMWARE\SM-J200H NEW ALL\J200HXXU0AQG1_J200HOJV0AQG1_J200HXXU0AQF1___4f iles_repair\BL_J200HXXU0AQG1_J200HOJV0AQG1_J200HXX U0AQF1.tar.md5 11/4/2017 6:06:05 PM> 11/4/2017 6:06:05 PM> BL_J200HXXU0AQG1_J200HOJV0AQG1_J200HXXU0AQF1.tar.m d5 11/4/2017 6:06:05 PM> The list of files in the firmware: 11/4/2017 6:06:05 PM> spl.img 11/4/2017 6:06:05 PM> sboot.bin 11/4/2017 6:06:05 PM> sboot2.bin 11/4/2017 6:06:05 PM> 11/4/2017 6:06:13 PM> Looking for EasyJTAG box... 11/4/2017 6:06:13 PM> EasyJTAG API ver. 2008 11/4/2017 6:06:13 PM> Setting IO Levels to 3.3V 11/4/2017 6:06:13 PM> Setting frequence to 21 Mhz 11/4/2017 6:06:13 PM> HiPower mode is OFF 11/4/2017 6:06:14 PM> OpenUSB returned = 0 11/4/2017 6:06:14 PM> Power Controller returned = 0 11/4/2017 6:06:15 PM> EasyJTAG Box Serial = 1200D0035CA63064 11/4/2017 6:06:15 PM> EasyJTAG Box Firmware = 01.60 11/4/2017 6:06:15 PM> HiPower mode is OFF 11/4/2017 6:06:15 PM> Frequence: 21 Mhz 11/4/2017 6:06:15 PM> CMD Pullup Level: 2712 mV 11/4/2017 6:06:15 PM> CMD Active Level: 3320 mV 11/4/2017 6:06:15 PM> eMMC Init returned = 0 11/4/2017 6:06:15 PM> EMMC Device Information : 11/4/2017 6:06:15 PM> EMMC CID: 90014A4838473474210150E3985F9282 11/4/2017 6:06:15 PM> EMMC CSD: D07F01320F5903FFFFFFFFEF8A400012 11/4/2017 6:06:15 PM> EMMC Manufacture Name: SKHYNIX 11/4/2017 6:06:15 PM> EMMC Manufacture ID: 0x90 , OEM ID: 014A 11/4/2017 6:06:15 PM> EMMC Manufacture Date: 9/2015 , Rev: 01 11/4/2017 6:06:15 PM> EMMC NAME: H8G4t! , S/N: 50E3985F , rev. 01 11/4/2017 6:06:15 PM> EMMC NAME (HEX): 483847347421 11/4/2017 6:06:15 PM> EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000) 11/4/2017 6:06:15 PM> EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) 11/4/2017 6:06:15 PM> EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) 11/4/2017 6:06:15 PM> EMMC Permanent Write Protection: No 11/4/2017 6:06:15 PM> EMMC Temporary Write Protection: No 11/4/2017 6:06:15 PM> Extended CSD Information : 11/4/2017 6:06:15 PM> Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01) 11/4/2017 6:06:15 PM> Boot configuration [PARTITION_CONFIG]: 0x08 , Boot from: ROM2 (Boot partition 1) 11/4/2017 6:06:15 PM> Boot Bus Config: 0x00 , width 1bit 11/4/2017 6:06:15 PM> H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled 11/4/2017 6:06:15 PM> Supported partition features [PARTITIONING_SUPPORT]: 0x07 11/4/2017 6:06:15 PM> Device supports partitioning features 11/4/2017 6:06:15 PM> Device can have enhanced technological features in partitions and user data area 11/4/2017 6:06:15 PM> Device can have extended partitions attribute 11/4/2017 6:06:15 PM> Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 11/4/2017 6:06:15 PM> Backup saved: H8G4t!_50E3985F_20171104_180615.extcsd 11/4/2017 6:06:15 PM> EMMC Init completed. 11/4/2017 6:06:15 PM> 11/4/2017 6:06:15 PM> Operation: Write by vendor (Samsung) 11/4/2017 6:06:15 PM> 11/4/2017 6:06:15 PM> Creating GPT-partitioninig 11/4/2017 6:06:16 PM> Error writing at address: 000000000000 ... Retry #1 11/4/2017 6:06:16 PM> Error writing at address: 000000000000 ... Retry #2 11/4/2017 6:06:17 PM> Error writing at address: 000000000000 ... Retry #3 11/4/2017 6:06:17 PM> Writing PIT at address: 000000080000 11/4/2017 6:06:17 PM> GPT-partitioning done 11/4/2017 6:06:17 PM> 11/4/2017 6:06:17 PM> Unpacking file: spl.img 11/4/2017 6:06:17 PM> Unpacking file: sboot.bin 11/4/2017 6:06:17 PM> Unpacking file: sboot2.bin 11/4/2017 6:06:17 PM> 11/4/2017 6:06:17 PM> Partition name: BOOT 11/4/2017 6:06:17 PM> Filename: spl.img , Offset: 000000000000 , filesize: 32768 bytes 11/4/2017 6:06:17 PM> eMMC switching to ROM2 11/4/2017 6:06:17 PM> Erasing partition... 11/4/2017 6:06:20 PM> Writing partition... 11/4/2017 6:06:20 PM> Done writing partition. Write speed: 253.70 Kb/s 11/4/2017 6:06:20 PM> Partition name: SBOOT 11/4/2017 6:06:20 PM> Filename: sboot.bin , Offset: 000000400000 , filesize: 1573888 bytes 11/4/2017 6:06:20 PM> eMMC switching to ROM1 11/4/2017 6:06:20 PM> Erasing partition... 11/4/2017 6:06:22 PM> Writing partition... 11/4/2017 6:06:23 PM> Done writing partition. Write speed: 1078.54 Kb/s 11/4/2017 6:06:23 PM> Partition name: SBOOT2 11/4/2017 6:06:23 PM> Filename: sboot2.bin , Offset: 000000600000 , filesize: 1573888 bytes 11/4/2017 6:06:23 PM> eMMC switching to ROM1 11/4/2017 6:06:23 PM> Erasing partition... 11/4/2017 6:06:24 PM> Writing partition... 11/4/2017 6:06:26 PM> Done writing partition. Write speed: 1078.69 Kb/s 11/4/2017 6:06:26 PM> 11/4/2017 6:06:26 PM> All done 11/4/2017 6:06:26 PM> 11/4/2017 6:07:17 PM> Looking for EasyJTAG box... 11/4/2017 6:07:17 PM> EasyJTAG API ver. 2008 11/4/2017 6:07:17 PM> Setting IO Levels to 3.3V 11/4/2017 6:07:17 PM> Setting frequence to 21 Mhz 11/4/2017 6:07:17 PM> HiPower mode is OFF 11/4/2017 6:07:18 PM> OpenUSB returned = 0 11/4/2017 6:07:18 PM> Error: Previous operation is not finished yet. 11/4/2017 6:07:18 PM> 11/4/2017 6:07:18 PM> Power Controller returned = 0 11/4/2017 6:07:19 PM> EasyJTAG Box Serial = 1200D0035CA63064 11/4/2017 6:07:19 PM> EasyJTAG Box Firmware = 01.60 11/4/2017 6:07:19 PM> HiPower mode is OFF 11/4/2017 6:07:19 PM> Frequence: 21 Mhz 11/4/2017 6:07:19 PM> CMD Pullup Level: 2712 mV 11/4/2017 6:07:19 PM> CMD Active Level: 3320 mV 11/4/2017 6:07:19 PM> eMMC Init returned = 0 11/4/2017 6:07:19 PM> EMMC Device Information : 11/4/2017 6:07:19 PM> EMMC CID: 90014A4838473474210150E3985F9282 11/4/2017 6:07:19 PM> EMMC CSD: D07F01320F5903FFFFFFFFEF8A400012 11/4/2017 6:07:19 PM> EMMC Manufacture Name: SKHYNIX 11/4/2017 6:07:19 PM> EMMC Manufacture ID: 0x90 , OEM ID: 014A 11/4/2017 6:07:19 PM> EMMC Manufacture Date: 9/2015 , Rev: 01 11/4/2017 6:07:19 PM> EMMC NAME: H8G4t! , S/N: 50E3985F , rev. 01 11/4/2017 6:07:19 PM> EMMC NAME (HEX): 483847347421 11/4/2017 6:07:19 PM> EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000) 11/4/2017 6:07:19 PM> EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) 11/4/2017 6:07:19 PM> EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) 11/4/2017 6:07:19 PM> EMMC Permanent Write Protection: No 11/4/2017 6:07:19 PM> EMMC Temporary Write Protection: No 11/4/2017 6:07:19 PM> Extended CSD Information : 11/4/2017 6:07:19 PM> Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01) 11/4/2017 6:07:19 PM> Boot configuration [PARTITION_CONFIG]: 0x08 , Boot from: ROM2 (Boot partition 1) 11/4/2017 6:07:19 PM> Boot Bus Config: 0x00 , width 1bit 11/4/2017 6:07:19 PM> H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled 11/4/2017 6:07:20 PM> Supported partition features [PARTITIONING_SUPPORT]: 0x07 11/4/2017 6:07:20 PM> Device supports partitioning features 11/4/2017 6:07:20 PM> Device can have enhanced technological features in partitions and user data area 11/4/2017 6:07:20 PM> Device can have extended partitions attribute 11/4/2017 6:07:20 PM> Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 11/4/2017 6:07:20 PM> Backup saved: H8G4t!_50E3985F_20171104_180720.extcsd 11/4/2017 6:07:20 PM> EMMC Init completed. 11/4/2017 6:07:20 PM> 11/4/2017 6:07:20 PM> Scanning soft partitions 11/4/2017 6:07:29 PM> Partition table not found 11/4/2017 6:07:29 PM> 11/4/2017 6:07:29 PM> Get firmware version 11/4/2017 6:08:03 PM> Firmware info not found ========================== BEFORE I DID UNIVERSAL FORMAT SEE LOGS BELOW BEFORE I DID FORMAT 11/4/2017 5:11:03 PM> Looking for EasyJTAG box... 11/4/2017 5:11:03 PM> EasyJTAG API ver. 2008 11/4/2017 5:11:03 PM> Setting IO Levels to 3.3V 11/4/2017 5:11:03 PM> Setting frequence to 14 Mhz 11/4/2017 5:11:03 PM> HiPower mode is OFF 11/4/2017 5:11:04 PM> OpenUSB returned = 0 11/4/2017 5:11:04 PM> Power Controller returned = 0 11/4/2017 5:11:05 PM> EasyJTAG Box Serial = 1200D0035CA63064 11/4/2017 5:11:05 PM> EasyJTAG Box Firmware = 01.60 11/4/2017 5:11:05 PM> HiPower mode is OFF 11/4/2017 5:11:05 PM> Frequence: 14 Mhz 11/4/2017 5:11:05 PM> CMD Pullup Level: 2227 mV 11/4/2017 5:11:05 PM> CMD Active Level: 2598 mV 11/4/2017 5:11:05 PM> eMMC Init returned = 0 11/4/2017 5:11:05 PM> EMMC Device Information : 11/4/2017 5:11:05 PM> EMMC CID: 90014A4838473474210150E3985F9282 11/4/2017 5:11:05 PM> EMMC CSD: D07F01320F5903FFFFFFFFEF8A400012 11/4/2017 5:11:05 PM> EMMC Manufacture Name: SKHYNIX 11/4/2017 5:11:05 PM> EMMC Manufacture ID: 0x90 , OEM ID: 014A 11/4/2017 5:11:05 PM> EMMC Manufacture Date: 9/2015 , Rev: 01 11/4/2017 5:11:05 PM> EMMC NAME: H8G4t! , S/N: 50E3985F , rev. 01 11/4/2017 5:11:05 PM> EMMC NAME (HEX): 483847347421 11/4/2017 5:11:05 PM> EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000) 11/4/2017 5:11:05 PM> EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) 11/4/2017 5:11:05 PM> EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) 11/4/2017 5:11:05 PM> EMMC Permanent Write Protection: No 11/4/2017 5:11:05 PM> EMMC Temporary Write Protection: No 11/4/2017 5:11:05 PM> Extended CSD Information : 11/4/2017 5:11:05 PM> Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01) 11/4/2017 5:11:05 PM> Boot configuration [PARTITION_CONFIG]: 0x08 , Boot from: ROM2 (Boot partition 1) 11/4/2017 5:11:05 PM> Boot Bus Config: 0x00 , width 1bit 11/4/2017 5:11:05 PM> H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled 11/4/2017 5:11:05 PM> Supported partition features [PARTITIONING_SUPPORT]: 0x07 11/4/2017 5:11:05 PM> Device supports partitioning features 11/4/2017 5:11:05 PM> Device can have enhanced technological features in partitions and user data area 11/4/2017 5:11:05 PM> Device can have extended partitions attribute 11/4/2017 5:11:05 PM> Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 11/4/2017 5:11:06 PM> Backup saved: H8G4t!_50E3985F_20171104_171105.extcsd 11/4/2017 5:11:06 PM> EMMC Init completed. 11/4/2017 5:11:06 PM> 11/4/2017 5:11:06 PM> Scanning soft partitions 11/4/2017 5:11:06 PM> GPT header is found and is valid 11/4/2017 5:11:06 PM> Partition: SBOOT, [000000400000 - 000000600000], size: 000000200000 11/4/2017 5:11:06 PM> Partition: SBOOT2, [000000600000 - 000000800000], size: 000000200000 11/4/2017 5:11:06 PM> Partition: wfixnv1, [000000800000 - 000000900000], size: 000000100000 11/4/2017 5:11:06 PM> Partition: wfixnv2, [000000900000 - 000000A00000], size: 000000100000 11/4/2017 5:11:06 PM> Partition: tdfixnv1, [000000A00000 - 000000B00000], size: 000000100000 11/4/2017 5:11:06 PM> Partition: tdfixnv2, [000000B00000 - 000000C00000], size: 000000100000 11/4/2017 5:11:06 PM> Partition: WDSP, [000000C00000 - 000001000000], size: 000000400000 11/4/2017 5:11:06 PM> Partition: MODEM, [000001000000 - 000001800000], size: 000000800000 11/4/2017 5:11:06 PM> Partition: MODEM2, [000001800000 - 000002000000], size: 000000800000 11/4/2017 5:11:06 PM> Partition: TDDSP, [000002000000 - 000002400000], size: 000000400000 11/4/2017 5:11:06 PM> Partition: FOTA_SIG, [000002400000 - 000002500000], size: 000000100000 11/4/2017 5:11:06 PM> Partition: wruntimenv1, [000002500000 - 000002600000], size: 000000100000 11/4/2017 5:11:06 PM> Partition: wruntimenv2, [000002600000 - 000002700000], size: 000000100000 11/4/2017 5:11:06 PM> Partition: tdruntimenv1, [000002700000 - 000002800000], size: 000000100000 11/4/2017 5:11:06 PM> Partition: tdruntimenv2, [000002800000 - 000002900000], size: 000000100000 11/4/2017 5:11:06 PM> Partition: PARAM, [000002900000 - 000002B00000], size: 000000200000 11/4/2017 5:11:06 PM> Partition: efs, [000002B00000 - 000003F00000], size: 000001400000 11/4/2017 5:11:06 PM> Partition: prodnv, [000003F00000 - 000004400000], size: 000000500000 11/4/2017 5:11:06 PM> Partition: RESERVED2, [000004400000 - 000004600000], size: 000000200000 11/4/2017 5:11:06 PM> Partition: KERNEL, [000004600000 - 000005600000], size: 000001000000 11/4/2017 5:11:06 PM> Partition: RECOVERY, [000005600000 - 000006600000], size: 000001000000 11/4/2017 5:11:06 PM> Partition: PERSISTENT, [000006600000 - 000006700000], size: 000000100000 11/4/2017 5:11:06 PM> Partition: persdata, [000006700000 - 000007000000], size: 000000900000 11/4/2017 5:11:06 PM> Partition: CACHE, [000007000000 - 000013800000], size: 00000C800000 11/4/2017 5:11:06 PM> Partition: SYSTEM, [000013800000 - 000071400000], size: 00005DC00000 11/4/2017 5:11:06 PM> Partition: HIDDEN, [000071400000 - 000073200000], size: 000001E00000 11/4/2017 5:11:06 PM> Partition: userdata, [000073200000 - 0001D1200000], size: 00015E000000 11/4/2017 5:11:06 PM> GPT header successfully parsed 11/4/2017 5:11:06 PM> 11/4/2017 5:11:06 PM> Get firmware version 11/4/2017 5:11:06 PM> 11/4/2017 5:11:08 PM> Firmware info not found PLEASE WHAT AM I DOING WRONG PLEASE I WANT TO KNOW.. |
DONE DONE DONE AND ALL IS OK eMMC_tool Suite ver. 1.4.8.0 Microsoft Windows 7 (32 bit) build 7601 (6.1.7601.18015) Looking for EasyJTAG box... EasyJTAG API ver. 2008 Setting IO Levels to 3.3V Setting frequence to 21 Mhz HiPower mode is OFF EasyJTAG Box Serial = 1200D0035CA63064 Card Serial = AADF-497C EasyJTAG Box Firmware = 01.60 Changelog: 08.08.2017 (ver 1.4.8.0) Fix: Bugs that have been found through your crash report Fix: Saving VCF for contacts Add: Multiple file selection for Samsung firmware Add: Write full Extcsd or write only the boot configuration ("Repair Extcsd" button) Add: Intel vendor (for easy read/write ROM2/ROM3/GP1) Add: "Pinouts" tab (taken from the catalog of classic software) Add: Checker for Sony TrimArea Add: Speed graph for "Random verify emmc" Add: Fat16/Fat32/exFat support (Explorer) HiPower mode is OFF Frequence: 21 Mhz CMD Pullup Level: 495 mV CMD Active Level: 3021 mV Can't init device. Reason: OCR Ready Timeout Error [Check VCC or eMMC DEAD] HiPower mode is OFF Frequence: 21 Mhz CMD Pullup Level: 495 mV CMD Active Level: 3031 mV Can't init device. Reason: OCR Ready Timeout Error [Check VCC or eMMC DEAD] HiPower mode is OFF Frequence: 21 Mhz CMD Pullup Level: 876 mV CMD Active Level: 3155 mV Can't init device. Reason: CMD Timeout Error HiPower mode is OFF Frequence: 21 Mhz CMD Pullup Level: 484 mV CMD Active Level: 3021 mV Can't init device. Reason: OCR Ready Timeout Error [Check VCC or eMMC DEAD] HiPower mode is OFF Frequence: 21 Mhz CMD Pullup Level: 2227 mV CMD Active Level: 3320 mV EMMC Device Information : EMMC CID: 90014A4838473474210150E3985F9282 EMMC CSD: D07F01320F5903FFFFFFFFEF8A400012 EMMC Manufacture Name: SKHYNIX EMMC Manufacture ID: 0x90 , OEM ID: 014A EMMC Manufacture Date: 9/2015 , Rev: 01 EMMC NAME: H8G4t! , S/N: 50E3985F , rev. 01 EMMC NAME (HEX): 483847347421 EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01) Boot configuration [PARTITION_CONFIG]: 0x08 , Boot from: ROM2 (Boot partition 1) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x01 Backup saved: H8G4t!_50E3985F_20171107_162511.extcsd EMMC Init completed. Scanning soft partitions GPT header is found and is valid Partition: SBOOT, [000000400000 - 000000600000], size: 000000200000 Partition: SBOOT2, [000000600000 - 000000800000], size: 000000200000 Partition: wfixnv1, [000000800000 - 000000900000], size: 000000100000 Partition: wfixnv2, [000000900000 - 000000A00000], size: 000000100000 Partition: tdfixnv1, [000000A00000 - 000000B00000], size: 000000100000 Partition: tdfixnv2, [000000B00000 - 000000C00000], size: 000000100000 Partition: WDSP, [000000C00000 - 000001000000], size: 000000400000 Partition: MODEM, [000001000000 - 000001800000], size: 000000800000 Partition: MODEM2, [000001800000 - 000002000000], size: 000000800000 Partition: TDDSP, [000002000000 - 000002400000], size: 000000400000 Partition: FOTA_SIG, [000002400000 - 000002500000], size: 000000100000 Partition: wruntimenv1, [000002500000 - 000002600000], size: 000000100000 Partition: wruntimenv2, [000002600000 - 000002700000], size: 000000100000 Partition: tdruntimenv1, [000002700000 - 000002800000], size: 000000100000 Partition: tdruntimenv2, [000002800000 - 000002900000], size: 000000100000 Partition: PARAM, [000002900000 - 000002B00000], size: 000000200000 Partition: efs, [000002B00000 - 000003F00000], size: 000001400000 Partition: prodnv, [000003F00000 - 000004400000], size: 000000500000 Partition: RESERVED2, [000004400000 - 000004600000], size: 000000200000 Partition: KERNEL, [000004600000 - 000005600000], size: 000001000000 Partition: RECOVERY, [000005600000 - 000006600000], size: 000001000000 Partition: PERSISTENT, [000006600000 - 000006700000], size: 000000100000 Partition: persdata, [000006700000 - 000007000000], size: 000000900000 Partition: CACHE, [000007000000 - 000013800000], size: 00000C800000 Partition: SYSTEM, [000013800000 - 000071400000], size: 00005DC00000 Partition: HIDDEN, [000071400000 - 000073200000], size: 000001E00000 Partition: userdata, [000073200000 - 0001D1200000], size: 00015E000000 GPT header successfully parsed Get firmware version Brand = samsung Model = SM-J200H Phone platform = sc8830 CPU Abi = armeabi-v7a Android release = 5.1.1 Firmware version = LMY48B.J200HXXU0AQG1 Firmware date = Tue Jul 4 19:17:28 KST 2017 HiPower mode is OFF Frequence: 21 Mhz CMD Pullup Level: 2701 mV CMD Active Level: 3320 mV EMMC Device Information : EMMC CID: 90014A4838473474210150E3985F9282 EMMC CSD: D07F01320F5903FFFFFFFFEF8A400012 EMMC Manufacture Name: SKHYNIX EMMC Manufacture ID: 0x90 , OEM ID: 014A EMMC Manufacture Date: 9/2015 , Rev: 01 EMMC NAME: H8G4t! , S/N: 50E3985F , rev. 01 EMMC NAME (HEX): 483847347421 EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01) Boot configuration [PARTITION_CONFIG]: 0x08 , Boot from: ROM2 (Boot partition 1) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x01 Backup saved: H8G4t!_50E3985F_20171107_162648.extcsd EMMC Init completed. Opening file: SAMSUNG_SM-J200H_emmc_dump_ROM1_112MB.bin Analyzing Image: SAMSUNG_SM-J200H_emmc_dump_ROM1_112MB.bin Vendor: Samsung Searching GPT ... GPT header is found and is valid GPT header successfully parsed HiPower mode is OFF Frequence: 21 Mhz CMD Pullup Level: 2691 mV CMD Active Level: 3330 mV EMMC Device Information : EMMC CID: 90014A4838473474210150E3985F9282 EMMC CSD: D07F01320F5903FFFFFFFFEF8A400012 EMMC Manufacture Name: SKHYNIX EMMC Manufacture ID: 0x90 , OEM ID: 014A EMMC Manufacture Date: 9/2015 , Rev: 01 EMMC NAME: H8G4t! , S/N: 50E3985F , rev. 01 EMMC NAME (HEX): 483847347421 EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01) Boot configuration [PARTITION_CONFIG]: 0x08 , Boot from: ROM2 (Boot partition 1) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x01 Backup saved: H8G4t!_50E3985F_20171107_162733.extcsd EMMC Init completed. Operation: Write by vendor (Samsung) Partition name: GPT Filename: SAMSUNG_SM-J200H_emmc_dump_ROM1_112MB.bin , Offset: 000000000000 , filesize: 17408 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 208.05 Kb/s Partition name: SBOOT Filename: SAMSUNG_SM-J200H_emmc_dump_ROM1_112MB.bin , Offset: 000000400000 , filesize: 2097152 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 743.91 Kb/s Partition name: SBOOT2 Filename: SAMSUNG_SM-J200H_emmc_dump_ROM1_112MB.bin , Offset: 000000600000 , filesize: 2097152 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1110.89 Kb/s Partition name: wfixnv1 Filename: SAMSUNG_SM-J200H_emmc_dump_ROM1_112MB.bin , Offset: 000000800000 , filesize: 1048576 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1166.76 Kb/s Partition name: wfixnv2 Filename: SAMSUNG_SM-J200H_emmc_dump_ROM1_112MB.bin , Offset: 000000900000 , filesize: 1048576 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1187.21 Kb/s Partition name: tdfixnv1 Filename: SAMSUNG_SM-J200H_emmc_dump_ROM1_112MB.bin , Offset: 000000A00000 , filesize: 1048576 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1236.20 Kb/s Partition name: tdfixnv2 Filename: SAMSUNG_SM-J200H_emmc_dump_ROM1_112MB.bin , Offset: 000000B00000 , filesize: 1048576 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1239.45 Kb/s Partition name: WDSP Filename: SAMSUNG_SM-J200H_emmc_dump_ROM1_112MB.bin , Offset: 000000C00000 , filesize: 4194304 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1170.09 Kb/s Partition name: MODEM Filename: SAMSUNG_SM-J200H_emmc_dump_ROM1_112MB.bin , Offset: 000001000000 , filesize: 8388608 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 885.99 Kb/s Partition name: MODEM2 Filename: SAMSUNG_SM-J200H_emmc_dump_ROM1_112MB.bin , Offset: 000001800000 , filesize: 8388608 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1285.56 Kb/s Partition name: TDDSP Filename: SAMSUNG_SM-J200H_emmc_dump_ROM1_112MB.bin , Offset: 000002000000 , filesize: 4194304 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1275.73 Kb/s Partition name: FOTA_SIG Filename: SAMSUNG_SM-J200H_emmc_dump_ROM1_112MB.bin , Offset: 000002400000 , filesize: 1048576 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1292.32 Kb/s Partition name: wruntimenv1 Filename: SAMSUNG_SM-J200H_emmc_dump_ROM1_112MB.bin , Offset: 000002500000 , filesize: 1048576 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1123.55 Kb/s Partition name: wruntimenv2 Filename: SAMSUNG_SM-J200H_emmc_dump_ROM1_112MB.bin , Offset: 000002600000 , filesize: 1048576 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1163.80 Kb/s Partition name: tdruntimenv1 Filename: SAMSUNG_SM-J200H_emmc_dump_ROM1_112MB.bin , Offset: 000002700000 , filesize: 1048576 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1286.25 Kb/s Partition name: tdruntimenv2 Filename: SAMSUNG_SM-J200H_emmc_dump_ROM1_112MB.bin , Offset: 000002800000 , filesize: 1048576 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1216.52 Kb/s Partition name: PARAM Filename: SAMSUNG_SM-J200H_emmc_dump_ROM1_112MB.bin , Offset: 000002900000 , filesize: 2097152 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1034.61 Kb/s Partition name: efs Filename: SAMSUNG_SM-J200H_emmc_dump_ROM1_112MB.bin , Offset: 000002B00000 , filesize: 20971520 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1276.43 Kb/s Partition name: prodnv Filename: SAMSUNG_SM-J200H_emmc_dump_ROM1_112MB.bin , Offset: 000003F00000 , filesize: 5242880 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1220.14 Kb/s Partition name: RESERVED2 Filename: SAMSUNG_SM-J200H_emmc_dump_ROM1_112MB.bin , Offset: 000004400000 , filesize: 2097152 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1292.78 Kb/s Partition name: KERNEL Filename: SAMSUNG_SM-J200H_emmc_dump_ROM1_112MB.bin , Offset: 000004600000 , filesize: 16777216 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 902.13 Kb/s Partition name: RECOVERY Filename: SAMSUNG_SM-J200H_emmc_dump_ROM1_112MB.bin , Offset: 000005600000 , filesize: 16777216 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 892.43 Kb/s Partition name: PERSISTENT Filename: SAMSUNG_SM-J200H_emmc_dump_ROM1_112MB.bin , Offset: 000006600000 , filesize: 1048576 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1286.88 Kb/s Partition name: persdata Filename: SAMSUNG_SM-J200H_emmc_dump_ROM1_112MB.bin , Offset: 000006700000 , filesize: 9437184 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1283.41 Kb/s All done HiPower mode is OFF Frequence: 21 Mhz CMD Pullup Level: 2712 mV CMD Active Level: 3320 mV EMMC Device Information : EMMC CID: 90014A4838473474210150E3985F9282 EMMC CSD: D07F01320F5903FFFFFFFFEF8A400012 EMMC Manufacture Name: SKHYNIX EMMC Manufacture ID: 0x90 , OEM ID: 014A EMMC Manufacture Date: 9/2015 , Rev: 01 EMMC NAME: H8G4t! , S/N: 50E3985F , rev. 01 EMMC NAME (HEX): 483847347421 EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01) Boot configuration [PARTITION_CONFIG]: 0x08 , Boot from: ROM2 (Boot partition 1) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x01 Backup saved: H8G4t!_50E3985F_20171107_163128.extcsd EMMC Init completed. Scanning soft partitions GPT header is found and is valid Partition: SBOOT, [000000400000 - 000000600000], size: 000000200000 Partition: SBOOT2, [000000600000 - 000000800000], size: 000000200000 Partition: wfixnv1, [000000800000 - 000000900000], size: 000000100000 Partition: wfixnv2, [000000900000 - 000000A00000], size: 000000100000 Partition: tdfixnv1, [000000A00000 - 000000B00000], size: 000000100000 Partition: tdfixnv2, [000000B00000 - 000000C00000], size: 000000100000 Partition: WDSP, [000000C00000 - 000001000000], size: 000000400000 Partition: MODEM, [000001000000 - 000001800000], size: 000000800000 Partition: MODEM2, [000001800000 - 000002000000], size: 000000800000 Partition: TDDSP, [000002000000 - 000002400000], size: 000000400000 Partition: FOTA_SIG, [000002400000 - 000002500000], size: 000000100000 Partition: wruntimenv1, [000002500000 - 000002600000], size: 000000100000 Partition: wruntimenv2, [000002600000 - 000002700000], size: 000000100000 Partition: tdruntimenv1, [000002700000 - 000002800000], size: 000000100000 Partition: tdruntimenv2, [000002800000 - 000002900000], size: 000000100000 Partition: PARAM, [000002900000 - 000002B00000], size: 000000200000 Partition: efs, [000002B00000 - 000003F00000], size: 000001400000 Partition: prodnv, [000003F00000 - 000004400000], size: 000000500000 Partition: RESERVED2, [000004400000 - 000004600000], size: 000000200000 Partition: KERNEL, [000004600000 - 000005600000], size: 000001000000 Partition: RECOVERY, [000005600000 - 000006600000], size: 000001000000 Partition: PERSISTENT, [000006600000 - 000006700000], size: 000000100000 Partition: persdata, [000006700000 - 000007000000], size: 000000900000 Partition: CACHE, [000007000000 - 000013800000], size: 00000C800000 Partition: SYSTEM, [000013800000 - 000071400000], size: 00005DC00000 Partition: HIDDEN, [000071400000 - 000073200000], size: 000001E00000 Partition: userdata, [000073200000 - 0001D1200000], size: 00015E000000 GPT header successfully parsed Get firmware version Brand = samsung Model = SM-J200H Phone platform = sc8830 CPU Abi = armeabi-v7a Android release = 5.1.1 Firmware version = LMY48B.J200HXXU0AQG1 Firmware date = Tue Jul 4 19:17:28 KST 2017 HiPower mode is OFF Frequence: 21 Mhz CMD Pullup Level: 2701 mV CMD Active Level: 3320 mV EMMC Device Information : EMMC CID: 90014A4838473474210150E3985F9282 EMMC CSD: D07F01320F5903FFFFFFFFEF8A400012 EMMC Manufacture Name: SKHYNIX EMMC Manufacture ID: 0x90 , OEM ID: 014A EMMC Manufacture Date: 9/2015 , Rev: 01 EMMC NAME: H8G4t! , S/N: 50E3985F , rev. 01 EMMC NAME (HEX): 483847347421 EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01) Boot configuration [PARTITION_CONFIG]: 0x08 , Boot from: ROM2 (Boot partition 1) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x01 Backup saved: H8G4t!_50E3985F_20171107_163142.extcsd EMMC Init completed. Opening file: SAMSUNG_SM-J200H_emmc_dump_ROM2.bin Analyzing Image: SAMSUNG_SM-J200H_emmc_dump_ROM2.bin Vendor: Samsung Searching GPT ... GPT header is not found Searching PIT ... PIT not found Partition table not found HiPower mode is OFF Frequence: 21 Mhz CMD Pullup Level: 2712 mV CMD Active Level: 3320 mV EMMC Device Information : EMMC CID: 90014A4838473474210150E3985F9282 EMMC CSD: D07F01320F5903FFFFFFFFEF8A400012 EMMC Manufacture Name: SKHYNIX EMMC Manufacture ID: 0x90 , OEM ID: 014A EMMC Manufacture Date: 9/2015 , Rev: 01 EMMC NAME: H8G4t! , S/N: 50E3985F , rev. 01 EMMC NAME (HEX): 483847347421 EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01) Boot configuration [PARTITION_CONFIG]: 0x08 , Boot from: ROM2 (Boot partition 1) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x01 Backup saved: H8G4t!_50E3985F_20171107_163156.extcsd EMMC Init completed. Opening file: SAMSUNG_SM-J200H_emmc_dump_ROM3.bin Analyzing Image: SAMSUNG_SM-J200H_emmc_dump_ROM3.bin Vendor: Samsung Searching GPT ... GPT header is not found Searching PIT ... PIT not found Partition table not found HiPower mode is OFF Frequence: 21 Mhz CMD Pullup Level: 2712 mV CMD Active Level: 3320 mV EMMC Device Information : EMMC CID: 90014A4838473474210150E3985F9282 EMMC CSD: D07F01320F5903FFFFFFFFEF8A400012 EMMC Manufacture Name: SKHYNIX EMMC Manufacture ID: 0x90 , OEM ID: 014A EMMC Manufacture Date: 9/2015 , Rev: 01 EMMC NAME: H8G4t! , S/N: 50E3985F , rev. 01 EMMC NAME (HEX): 483847347421 EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01) Boot configuration [PARTITION_CONFIG]: 0x08 , Boot from: ROM2 (Boot partition 1) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x01 Backup saved: H8G4t!_50E3985F_20171107_163205.extcsd EMMC Init completed. Scanning soft partitions GPT header is found and is valid Partition: SBOOT, [000000400000 - 000000600000], size: 000000200000 Partition: SBOOT2, [000000600000 - 000000800000], size: 000000200000 Partition: wfixnv1, [000000800000 - 000000900000], size: 000000100000 Partition: wfixnv2, [000000900000 - 000000A00000], size: 000000100000 Partition: tdfixnv1, [000000A00000 - 000000B00000], size: 000000100000 Partition: tdfixnv2, [000000B00000 - 000000C00000], size: 000000100000 Partition: WDSP, [000000C00000 - 000001000000], size: 000000400000 Partition: MODEM, [000001000000 - 000001800000], size: 000000800000 Partition: MODEM2, [000001800000 - 000002000000], size: 000000800000 Partition: TDDSP, [000002000000 - 000002400000], size: 000000400000 Partition: FOTA_SIG, [000002400000 - 000002500000], size: 000000100000 Partition: wruntimenv1, [000002500000 - 000002600000], size: 000000100000 Partition: wruntimenv2, [000002600000 - 000002700000], size: 000000100000 Partition: tdruntimenv1, [000002700000 - 000002800000], size: 000000100000 Partition: tdruntimenv2, [000002800000 - 000002900000], size: 000000100000 Partition: PARAM, [000002900000 - 000002B00000], size: 000000200000 Partition: efs, [000002B00000 - 000003F00000], size: 000001400000 Partition: prodnv, [000003F00000 - 000004400000], size: 000000500000 Partition: RESERVED2, [000004400000 - 000004600000], size: 000000200000 Partition: KERNEL, [000004600000 - 000005600000], size: 000001000000 Partition: RECOVERY, [000005600000 - 000006600000], size: 000001000000 Partition: PERSISTENT, [000006600000 - 000006700000], size: 000000100000 Partition: persdata, [000006700000 - 000007000000], size: 000000900000 Partition: CACHE, [000007000000 - 000013800000], size: 00000C800000 Partition: SYSTEM, [000013800000 - 000071400000], size: 00005DC00000 Partition: HIDDEN, [000071400000 - 000073200000], size: 000001E00000 Partition: userdata, [000073200000 - 0001D1200000], size: 00015E000000 GPT header successfully parsed Get firmware version Brand = samsung Model = SM-J200H Phone platform = sc8830 CPU Abi = armeabi-v7a Android release = 5.1.1 Firmware version = LMY48B.J200HXXU0AQG1 Firmware date = Tue Jul 4 19:17:28 KST 2017 HiPower mode is OFF Frequence: 21 Mhz CMD Pullup Level: 2712 mV CMD Active Level: 3310 mV EMMC Device Information : EMMC CID: 90014A4838473474210150E3985F9282 EMMC CSD: D07F01320F5903FFFFFFFFEF8A400012 EMMC Manufacture Name: SKHYNIX EMMC Manufacture ID: 0x90 , OEM ID: 014A EMMC Manufacture Date: 9/2015 , Rev: 01 EMMC NAME: H8G4t! , S/N: 50E3985F , rev. 01 EMMC NAME (HEX): 483847347421 EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01) Boot configuration [PARTITION_CONFIG]: 0x08 , Boot from: ROM2 (Boot partition 1) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x01 Backup saved: H8G4t!_50E3985F_20171107_163307.extcsd EMMC Init completed. Opening file: EMMC_ROM2_H8G4t_1701297375_00000000_00400000.bin Analyzing Image: EMMC_ROM2_H8G4t_1701297375_00000000_00400000.bin Vendor: Samsung Searching GPT ... GPT header is not found Searching PIT ... PIT not found Partition table not found HiPower mode is OFF Frequence: 21 Mhz CMD Pullup Level: 2712 mV CMD Active Level: 3320 mV EMMC Device Information : EMMC CID: 90014A4838473474210150E3985F9282 EMMC CSD: D07F01320F5903FFFFFFFFEF8A400012 EMMC Manufacture Name: SKHYNIX EMMC Manufacture ID: 0x90 , OEM ID: 014A EMMC Manufacture Date: 9/2015 , Rev: 01 EMMC NAME: H8G4t! , S/N: 50E3985F , rev. 01 EMMC NAME (HEX): 483847347421 EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01) Boot configuration [PARTITION_CONFIG]: 0x08 , Boot from: ROM2 (Boot partition 1) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x01 Backup saved: H8G4t!_50E3985F_20171107_163314.extcsd EMMC Init completed. Opening file: EMMC_ROM3_H8G4t_1701297375_00000000_00400000.bin Analyzing Image: EMMC_ROM3_H8G4t_1701297375_00000000_00400000.bin Vendor: Samsung Searching GPT ... GPT header is not found Searching PIT ... PIT not found Partition table not found HiPower mode is OFF Frequence: 21 Mhz CMD Pullup Level: 2712 mV CMD Active Level: 3320 mV EMMC Device Information : EMMC CID: 90014A4838473474210150E3985F9282 EMMC CSD: D07F01320F5903FFFFFFFFEF8A400012 EMMC Manufacture Name: SKHYNIX EMMC Manufacture ID: 0x90 , OEM ID: 014A EMMC Manufacture Date: 9/2015 , Rev: 01 EMMC NAME: H8G4t! , S/N: 50E3985F , rev. 01 EMMC NAME (HEX): 483847347421 EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01) Boot configuration [PARTITION_CONFIG]: 0x08 , Boot from: ROM2 (Boot partition 1) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x01 Backup saved: H8G4t!_50E3985F_20171107_163322.extcsd EMMC Init completed. Opening file: EMMC_ROM1_H8G4t_1701297375_00000000_73200000.bin Analyzing Image: EMMC_ROM1_H8G4t_1701297375_00000000_73200000.bin Vendor: Samsung Searching GPT ... GPT header is found and is valid GPT header successfully parsed Brand = samsung Model = SM-J200H Phone platform = sc8830 CPU Abi = armeabi-v7a Android release = 5.1.1 Firmware version = LMY48B.J200HXXU0APK1 Firmware date = Tue Nov 8 13:26:48 KST 2016 HiPower mode is OFF Frequence: 21 Mhz CMD Pullup Level: 2701 mV CMD Active Level: 3310 mV EMMC Device Information : EMMC CID: 90014A4838473474210150E3985F9282 EMMC CSD: D07F01320F5903FFFFFFFFEF8A400012 EMMC Manufacture Name: SKHYNIX EMMC Manufacture ID: 0x90 , OEM ID: 014A EMMC Manufacture Date: 9/2015 , Rev: 01 EMMC NAME: H8G4t! , S/N: 50E3985F , rev. 01 EMMC NAME (HEX): 483847347421 EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01) Boot configuration [PARTITION_CONFIG]: 0x08 , Boot from: ROM2 (Boot partition 1) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x01 Backup saved: H8G4t!_50E3985F_20171107_163350.extcsd EMMC Init completed. Operation: Write by vendor (Samsung) Partition name: GPT Filename: EMMC_ROM1_H8G4t_1701297375_00000000_73200000.bin , Offset: 000000000000 , filesize: 17408 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 207.94 Kb/s Partition name: SBOOT Filename: EMMC_ROM1_H8G4t_1701297375_00000000_73200000.bin , Offset: 000000400000 , filesize: 2097152 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 729.48 Kb/s Partition name: SBOOT2 Filename: EMMC_ROM1_H8G4t_1701297375_00000000_73200000.bin , Offset: 000000600000 , filesize: 2097152 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1111.70 Kb/s Partition name: wfixnv1 Filename: EMMC_ROM1_H8G4t_1701297375_00000000_73200000.bin , Offset: 000000800000 , filesize: 1048576 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1174.61 Kb/s Partition name: wfixnv2 Filename: EMMC_ROM1_H8G4t_1701297375_00000000_73200000.bin , Offset: 000000900000 , filesize: 1048576 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1212.99 Kb/s Partition name: tdfixnv1 Filename: EMMC_ROM1_H8G4t_1701297375_00000000_73200000.bin , Offset: 000000A00000 , filesize: 1048576 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1233.29 Kb/s Partition name: tdfixnv2 Filename: EMMC_ROM1_H8G4t_1701297375_00000000_73200000.bin , Offset: 000000B00000 , filesize: 1048576 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1230.22 Kb/s Partition name: WDSP Filename: EMMC_ROM1_H8G4t_1701297375_00000000_73200000.bin , Offset: 000000C00000 , filesize: 4194304 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1177.44 Kb/s Partition name: MODEM Filename: EMMC_ROM1_H8G4t_1701297375_00000000_73200000.bin , Offset: 000001000000 , filesize: 8388608 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 884.66 Kb/s Partition name: MODEM2 Filename: EMMC_ROM1_H8G4t_1701297375_00000000_73200000.bin , Offset: 000001800000 , filesize: 8388608 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1284.84 Kb/s Partition name: TDDSP Filename: EMMC_ROM1_H8G4t_1701297375_00000000_73200000.bin , Offset: 000002000000 , filesize: 4194304 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1285.98 Kb/s Partition name: FOTA_SIG Filename: EMMC_ROM1_H8G4t_1701297375_00000000_73200000.bin , Offset: 000002400000 , filesize: 1048576 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1263.61 Kb/s Partition name: wruntimenv1 Filename: EMMC_ROM1_H8G4t_1701297375_00000000_73200000.bin , Offset: 000002500000 , filesize: 1048576 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1123.74 Kb/s Partition name: wruntimenv2 Filename: EMMC_ROM1_H8G4t_1701297375_00000000_73200000.bin , Offset: 000002600000 , filesize: 1048576 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1174.56 Kb/s Partition name: tdruntimenv1 Filename: EMMC_ROM1_H8G4t_1701297375_00000000_73200000.bin , Offset: 000002700000 , filesize: 1048576 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1257.03 Kb/s Partition name: tdruntimenv2 Filename: EMMC_ROM1_H8G4t_1701297375_00000000_73200000.bin , Offset: 000002800000 , filesize: 1048576 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1286.00 Kb/s Partition name: PARAM Filename: EMMC_ROM1_H8G4t_1701297375_00000000_73200000.bin , Offset: 000002900000 , filesize: 2097152 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1022.14 Kb/s Partition name: efs Filename: EMMC_ROM1_H8G4t_1701297375_00000000_73200000.bin , Offset: 000002B00000 , filesize: 20971520 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1233.38 Kb/s Partition name: prodnv Filename: EMMC_ROM1_H8G4t_1701297375_00000000_73200000.bin , Offset: 000003F00000 , filesize: 5242880 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1281.21 Kb/s Partition name: RESERVED2 Filename: EMMC_ROM1_H8G4t_1701297375_00000000_73200000.bin , Offset: 000004400000 , filesize: 2097152 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1248.86 Kb/s Partition name: KERNEL Filename: EMMC_ROM1_H8G4t_1701297375_00000000_73200000.bin , Offset: 000004600000 , filesize: 16777216 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 901.58 Kb/s Partition name: RECOVERY Filename: EMMC_ROM1_H8G4t_1701297375_00000000_73200000.bin , Offset: 000005600000 , filesize: 16777216 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 893.01 Kb/s Partition name: PERSISTENT Filename: EMMC_ROM1_H8G4t_1701297375_00000000_73200000.bin , Offset: 000006600000 , filesize: 1048576 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1253.24 Kb/s Partition name: persdata Filename: EMMC_ROM1_H8G4t_1701297375_00000000_73200000.bin , Offset: 000006700000 , filesize: 9437184 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1256.11 Kb/s Partition name: CACHE Filename: EMMC_ROM1_H8G4t_1701297375_00000000_73200000.bin , Offset: 000007000000 , filesize: 209715200 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1280.90 Kb/s Partition name: SYSTEM Filename: EMMC_ROM1_H8G4t_1701297375_00000000_73200000.bin , Offset: 000013800000 , filesize: 1572864000 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 841.42 Kb/s Partition name: HIDDEN Filename: EMMC_ROM1_H8G4t_1701297375_00000000_73200000.bin , Offset: 000071400000 , filesize: 31457280 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 950.72 Kb/s All done HiPower mode is OFF Frequence: 21 Mhz CMD Pullup Level: 2701 mV CMD Active Level: 3330 mV EMMC Device Information : EMMC CID: 90014A4838473474210150E3985F9282 EMMC CSD: D07F01320F5903FFFFFFFFEF8A400012 EMMC Manufacture Name: SKHYNIX EMMC Manufacture ID: 0x90 , OEM ID: 014A EMMC Manufacture Date: 9/2015 , Rev: 01 EMMC NAME: H8G4t! , S/N: 50E3985F , rev. 01 EMMC NAME (HEX): 483847347421 EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01) Boot configuration [PARTITION_CONFIG]: 0x08 , Boot from: ROM2 (Boot partition 1) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x01 Backup saved: H8G4t!_50E3985F_20171107_171351.extcsd EMMC Init completed. Scanning soft partitions GPT header is found and is valid Partition: SBOOT, [000000400000 - 000000600000], size: 000000200000 Partition: SBOOT2, [000000600000 - 000000800000], size: 000000200000 Partition: wfixnv1, [000000800000 - 000000900000], size: 000000100000 Partition: wfixnv2, [000000900000 - 000000A00000], size: 000000100000 Partition: tdfixnv1, [000000A00000 - 000000B00000], size: 000000100000 Partition: tdfixnv2, [000000B00000 - 000000C00000], size: 000000100000 Partition: WDSP, [000000C00000 - 000001000000], size: 000000400000 Partition: MODEM, [000001000000 - 000001800000], size: 000000800000 Partition: MODEM2, [000001800000 - 000002000000], size: 000000800000 Partition: TDDSP, [000002000000 - 000002400000], size: 000000400000 Partition: FOTA_SIG, [000002400000 - 000002500000], size: 000000100000 Partition: wruntimenv1, [000002500000 - 000002600000], size: 000000100000 Partition: wruntimenv2, [000002600000 - 000002700000], size: 000000100000 Partition: tdruntimenv1, [000002700000 - 000002800000], size: 000000100000 Partition: tdruntimenv2, [000002800000 - 000002900000], size: 000000100000 Partition: PARAM, [000002900000 - 000002B00000], size: 000000200000 Partition: efs, [000002B00000 - 000003F00000], size: 000001400000 Partition: prodnv, [000003F00000 - 000004400000], size: 000000500000 Partition: RESERVED2, [000004400000 - 000004600000], size: 000000200000 Partition: KERNEL, [000004600000 - 000005600000], size: 000001000000 Partition: RECOVERY, [000005600000 - 000006600000], size: 000001000000 Partition: PERSISTENT, [000006600000 - 000006700000], size: 000000100000 Partition: persdata, [000006700000 - 000007000000], size: 000000900000 Partition: CACHE, [000007000000 - 000013800000], size: 00000C800000 Partition: SYSTEM, [000013800000 - 000071400000], size: 00005DC00000 Partition: HIDDEN, [000071400000 - 000073200000], size: 000001E00000 Partition: userdata, [000073200000 - 0001D1200000], size: 00015E000000 GPT header successfully parsed Get firmware version Brand = samsung Model = SM-J200H Phone platform = sc8830 CPU Abi = armeabi-v7a Android release = 5.1.1 Firmware version = LMY48B.J200HXXU0APK1 Firmware date = Tue Nov 8 13:26:48 KST 2016 |
