Old 11-04-2017, 15:53   #1 (permalink)
johnoroo37's Avatar
Member: 2025428
Thanks Meter: 445
Sm-j200h gpt shows error but repair done(phone not bootup)
SEE ERROR BELOW
Opening file: J23G_EUR_OPEN.pit
Pit: J23G_EUR_OPEN.pit
Entry count: 31
The size of the last section has been updated
BL_J200HXXU0AQG1_J200HOJV0AQG1_J200HXXU0AQF1.tar.m d5
The list of files in the firmware:
spl.img
sboot.bin
sboot2.bin
HiPower mode is OFF
Frequence: 14 Mhz
CMD Pullup Level: 2701 mV
CMD Active Level: 3310 mV
EMMC Device Information :
EMMC CID: 90014A4838473474210150E3985F9282
EMMC CSD: D07F01320F5903FFFFFFFFEF8A400012
EMMC Manufacture Name: SKHYNIX
EMMC Manufacture ID: 0x90 , OEM ID: 014A
EMMC Manufacture Date: 9/2015 , Rev: 01
EMMC NAME: H8G4t! , S/N: 50E3985F , rev. 01
EMMC NAME (HEX): 483847347421
EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000)
EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000)
EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000)
EMMC Permanent Write Protection: No
EMMC Temporary Write Protection: No
Extended CSD Information :
Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01)
Boot configuration [PARTITION_CONFIG]: 0x08 , Boot from: ROM2 (Boot partition 1)
Boot Bus Config: 0x00 , width 1bit
H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled
Supported partition features [PARTITIONING_SUPPORT]: 0x07
Device supports partitioning features
Device can have enhanced technological features in partitions and user data area
Device can have extended partitions attribute
Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00
Backup saved: H8G4t!_50E3985F_20171104_150624.extcsd
EMMC Init completed.
Operation: Write by vendor (Samsung)
Creating GPT-partitioninig
Error writing at address: 000000000000 ... Retry #1
Error writing at address: 000000000000 ... Retry #2
Error writing at address: 000000000000 ... Retry #3
Writing PIT at address: 000000080000
GPT-partitioning done
Unpacking file: spl.img
Unpacking file: sboot.bin
Unpacking file: sboot2.bin
Partition name: BOOT
Filename: spl.img , Offset: 000000000000 , filesize: 32768 bytes
eMMC switching to ROM2
Erasing partition...
Writing partition...
Done writing partition. Write speed: 252.29 Kb/s
Partition name: SBOOT
Filename: sboot.bin , Offset: 000000400000 , filesize: 1573888 bytes
eMMC switching to ROM1
Done writing partition. Write speed: 1066.28 Kb/s
Partition name: SBOOT2
Filename: sboot2.bin , Offset: 000000600000 , filesize: 1573888 bytes
Done writing partition. Write speed: 1068.44 Kb/s
All done
HiPower mode is OFF
Frequence: 14 Mhz
CMD Pullup Level: 2629 mV
CMD Active Level: 3341 mV
Backup saved: H8G4t!_50E3985F_20171104_150606.extcsd
Scanning soft partitions
GPT header is found and is valid
Partition: SBOOT, [000000400000 - 000000600000], size: 000000200000
Partition: SBOOT2, [000000600000 - 000000800000], size: 000000200000
Partition: wfixnv1, [000000800000 - 000000900000], size: 000000100000
Partition: wfixnv2, [000000900000 - 000000A00000], size: 000000100000
Partition: tdfixnv1, [000000A00000 - 000000B00000], size: 000000100000
Partition: tdfixnv2, [000000B00000 - 000000C00000], size: 000000100000
Partition: WDSP, [000000C00000 - 000001000000], size: 000000400000
Partition: MODEM, [000001000000 - 000001800000], size: 000000800000
Partition: MODEM2, [000001800000 - 000002000000], size: 000000800000
Partition: TDDSP, [000002000000 - 000002400000], size: 000000400000
Partition: FOTA_SIG, [000002400000 - 000002500000], size: 000000100000
Partition: wruntimenv1, [000002500000 - 000002600000], size: 000000100000
Partition: wruntimenv2, [000002600000 - 000002700000], size: 000000100000
Partition: tdruntimenv1, [000002700000 - 000002800000], size: 000000100000
Partition: tdruntimenv2, [000002800000 - 000002900000], size: 000000100000
Partition: PARAM, [000002900000 - 000002B00000], size: 000000200000
Partition: efs, [000002B00000 - 000003F00000], size: 000001400000
Partition: prodnv, [000003F00000 - 000004400000], size: 000000500000
Partition: RESERVED2, [000004400000 - 000004600000], size: 000000200000
Partition: KERNEL, [000004600000 - 000005600000], size: 000001000000
Partition: RECOVERY, [000005600000 - 000006600000], size: 000001000000
Partition: PERSISTENT, [000006600000 - 000006700000], size: 000000100000
Partition: persdata, [000006700000 - 000007000000], size: 000000900000
Partition: CACHE, [000007000000 - 000013800000], size: 00000C800000
Partition: SYSTEM, [000013800000 - 000071400000], size: 00005DC00000
Partition: HIDDEN, [000071400000 - 000073200000], size: 000001E00000
Partition: userdata, [000073200000 - 0001D1200000], size: 00015E000000
GPT header successfully parsed
Get firmware version
Firmware info not found
HiPower mode is OFF
Frequence: 14 Mhz
Backup saved: H8G4t!_50E3985F_20171104_150616.extcsd
Entry count: 31
spl.img
sboot.bin
sboot2.bin
HiPower mode is OFF
Frequence: 14 Mhz
All done
PLEASE ANY POSSIBLE SOLUTION FOR ME TO DO
PHONE CONDITION
CUSTOMER SAID IT WAS FLASHED WITH WRONG FIRMWARE
Old 11-04-2017, 16:07   #2 (permalink)
Member: 794019
Thanks Meter: 31
post emmc check log after write. then well talk
Old 11-05-2017, 17:52   #3 (permalink)
johnoroo37's Avatar
Member: 2025428
Thanks Meter: 445
I DID UNIVERSAL FACTORY FORMAT AND WRITE EXTCSD BACK
NOW I DID NORMAL REPAIR BUT ALWAYS SHOWS BELOW ERRORS NOW AFTER REPAIR
11/4/2017 5:59:54 PM> eMMC_tool Suite ver. 1.4.8.0
11/4/2017 5:59:54 PM> Microsoft Windows 7 (32 bit) build 7601 (6.1.7601.18015)
11/4/2017 5:59:54 PM> Looking for EasyJTAG box...
11/4/2017 5:59:54 PM> EasyJTAG API ver. 2008
11/4/2017 5:59:54 PM> Setting IO Levels to 3.3V
11/4/2017 5:59:54 PM> Setting frequence to 21 Mhz
11/4/2017 5:59:54 PM> HiPower mode is OFF
11/4/2017 5:59:56 PM> OpenUSB returned = 0
11/4/2017 5:59:56 PM> Power Controller returned = 0
11/4/2017 5:59:57 PM> EasyJTAG Box Serial = 1200D0035CA63064
11/4/2017 6:00:03 PM> Card Serial = AADF-497C
11/4/2017 6:00:03 PM> CardAttr = 3B7D95000080318065B0831148C883009000
11/4/2017 6:00:03 PM> EasyJTAG Box Firmware = 01.60
11/4/2017 6:03:56 PM> Looking for EasyJTAG box...
11/4/2017 6:03:56 PM> EasyJTAG API ver. 2008
11/4/2017 6:03:56 PM> Setting IO Levels to 3.3V
11/4/2017 6:03:56 PM> Setting frequence to 21 Mhz
11/4/2017 6:03:56 PM> HiPower mode is OFF
11/4/2017 6:03:58 PM> OpenUSB returned = 0
11/4/2017 6:03:58 PM> Power Controller returned = 0
11/4/2017 6:03:59 PM> EasyJTAG Box Serial = 1200D0035CA63064
11/4/2017 6:03:59 PM> EasyJTAG Box Firmware = 01.60
11/4/2017 6:03:59 PM> HiPower mode is OFF
11/4/2017 6:03:59 PM> Frequence: 21 Mhz
11/4/2017 6:03:59 PM> CMD Pullup Level: 2701 mV
11/4/2017 6:03:59 PM> CMD Active Level: 3320 mV
11/4/2017 6:03:59 PM> eMMC Init returned = 0
11/4/2017 6:03:59 PM> EMMC Device Information :
11/4/2017 6:03:59 PM> EMMC CID: 90014A4838473474210150E3985F9282
11/4/2017 6:03:59 PM> EMMC CSD: D07F01320F5903FFFFFFFFEF8A400012
11/4/2017 6:03:59 PM> EMMC Manufacture Name: SKHYNIX
11/4/2017 6:03:59 PM> EMMC Manufacture ID: 0x90 , OEM ID: 014A
11/4/2017 6:03:59 PM> EMMC Manufacture Date: 9/2015 , Rev: 01
11/4/2017 6:03:59 PM> EMMC NAME: H8G4t! , S/N: 50E3985F , rev. 01
11/4/2017 6:03:59 PM> EMMC NAME (HEX): 483847347421
11/4/2017 6:03:59 PM> EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000)
11/4/2017 6:03:59 PM> EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000)
11/4/2017 6:03:59 PM> EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000)
11/4/2017 6:03:59 PM> EMMC Permanent Write Protection: No
11/4/2017 6:03:59 PM> EMMC Temporary Write Protection: No
11/4/2017 6:03:59 PM> Extended CSD Information :
11/4/2017 6:03:59 PM> Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01)
11/4/2017 6:03:59 PM> Boot configuration [PARTITION_CONFIG]: 0x08 , Boot from: ROM2 (Boot partition 1)
11/4/2017 6:03:59 PM> Boot Bus Config: 0x00 , width 1bit
11/4/2017 6:03:59 PM> H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled
11/4/2017 6:03:59 PM> Supported partition features [PARTITIONING_SUPPORT]: 0x07
11/4/2017 6:03:59 PM> Device supports partitioning features
11/4/2017 6:03:59 PM> Device can have enhanced technological features in partitions and user data area
11/4/2017 6:03:59 PM> Device can have extended partitions attribute
11/4/2017 6:03:59 PM> Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00
11/4/2017 6:03:59 PM> Backup saved: H8G4t!_50E3985F_20171104_180359.extcsd
11/4/2017 6:03:59 PM> EMMC Init completed.
11/4/2017 6:03:59 PM> Scanning soft partitions
11/4/2017 6:04:02 PM>
11/4/2017 6:04:02 PM> Stopped by User request...
11/4/2017 6:05:55 PM> Looking for EasyJTAG box...
11/4/2017 6:05:55 PM> EasyJTAG API ver. 2008
11/4/2017 6:05:55 PM> Setting IO Levels to 3.3V
11/4/2017 6:05:55 PM> Setting frequence to 21 Mhz
11/4/2017 6:05:55 PM> HiPower mode is OFF
11/4/2017 6:05:56 PM> OpenUSB returned = 0
11/4/2017 6:05:56 PM> Power Controller returned = 0
11/4/2017 6:05:57 PM> EasyJTAG Box Serial = 1200D0035CA63064
11/4/2017 6:05:57 PM> EasyJTAG Box Firmware = 01.60
11/4/2017 6:05:57 PM> HiPower mode is OFF
11/4/2017 6:05:57 PM> Frequence: 21 Mhz
11/4/2017 6:05:57 PM> CMD Pullup Level: 2691 mV
11/4/2017 6:05:57 PM> CMD Active Level: 3310 mV
11/4/2017 6:05:57 PM> eMMC Init returned = 0
11/4/2017 6:05:57 PM> EMMC Device Information :
11/4/2017 6:05:57 PM> EMMC CID: 90014A4838473474210150E3985F9282
11/4/2017 6:05:57 PM> EMMC CSD: D07F01320F5903FFFFFFFFEF8A400012
11/4/2017 6:05:57 PM> EMMC Manufacture Name: SKHYNIX
11/4/2017 6:05:57 PM> EMMC Manufacture ID: 0x90 , OEM ID: 014A
11/4/2017 6:05:57 PM> EMMC Manufacture Date: 9/2015 , Rev: 01
11/4/2017 6:05:57 PM> EMMC NAME: H8G4t! , S/N: 50E3985F , rev. 01
11/4/2017 6:05:57 PM> EMMC NAME (HEX): 483847347421
11/4/2017 6:05:57 PM> EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000)
11/4/2017 6:05:57 PM> EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000)
11/4/2017 6:05:57 PM> EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000)
11/4/2017 6:05:57 PM> EMMC Permanent Write Protection: No
11/4/2017 6:05:57 PM> EMMC Temporary Write Protection: No
11/4/2017 6:05:57 PM> Extended CSD Information :
11/4/2017 6:05:57 PM> Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01)
11/4/2017 6:05:57 PM> Boot configuration [PARTITION_CONFIG]: 0x08 , Boot from: ROM2 (Boot partition 1)
11/4/2017 6:05:57 PM> Boot Bus Config: 0x00 , width 1bit
11/4/2017 6:05:57 PM> H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled
11/4/2017 6:05:57 PM> Supported partition features [PARTITIONING_SUPPORT]: 0x07
11/4/2017 6:05:57 PM> Device supports partitioning features
11/4/2017 6:05:57 PM> Device can have enhanced technological features in partitions and user data area
11/4/2017 6:05:57 PM> Device can have extended partitions attribute
11/4/2017 6:05:57 PM> Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00
11/4/2017 6:05:58 PM> Backup saved: H8G4t!_50E3985F_20171104_180558.extcsd
11/4/2017 6:05:58 PM> EMMC Init completed.
11/4/2017 6:05:58 PM> Opening file: C:\Users\JOHNOROO37\Desktop\ALL PHONE FIRMWARE\SM-J200H NEW ALL\J200HXXU0AQG1_J200HOJV0AQG1_J200HXXU0AQF1___4f iles_repair\J23G_EUR_OPEN.pit
11/4/2017 6:05:58 PM> Pit: J23G_EUR_OPEN.pit
11/4/2017 6:05:58 PM> Entry count: 31
11/4/2017 6:05:58 PM> The size of the last section has been updated
11/4/2017 6:06:05 PM> Selected file: C:\Users\JOHNOROO37\Desktop\ALL PHONE FIRMWARE\SM-J200H NEW ALL\J200HXXU0AQG1_J200HOJV0AQG1_J200HXXU0AQF1___4f iles_repair\BL_J200HXXU0AQG1_J200HOJV0AQG1_J200HXX U0AQF1.tar.md5
11/4/2017 6:06:05 PM> BL_J200HXXU0AQG1_J200HOJV0AQG1_J200HXXU0AQF1.tar.m d5
11/4/2017 6:06:05 PM> The list of files in the firmware:
11/4/2017 6:06:05 PM> spl.img
11/4/2017 6:06:05 PM> sboot.bin
11/4/2017 6:06:05 PM> sboot2.bin
11/4/2017 6:06:13 PM> Looking for EasyJTAG box...
11/4/2017 6:06:13 PM> EasyJTAG API ver. 2008
11/4/2017 6:06:13 PM> Setting IO Levels to 3.3V
11/4/2017 6:06:13 PM> Setting frequence to 21 Mhz
11/4/2017 6:06:13 PM> HiPower mode is OFF
11/4/2017 6:06:14 PM> OpenUSB returned = 0
11/4/2017 6:06:14 PM> Power Controller returned = 0
11/4/2017 6:06:15 PM> EasyJTAG Box Serial = 1200D0035CA63064
11/4/2017 6:06:15 PM> EasyJTAG Box Firmware = 01.60
11/4/2017 6:06:15 PM> HiPower mode is OFF
11/4/2017 6:06:15 PM> Frequence: 21 Mhz
11/4/2017 6:06:15 PM> CMD Pullup Level: 2712 mV
11/4/2017 6:06:15 PM> CMD Active Level: 3320 mV
11/4/2017 6:06:15 PM> eMMC Init returned = 0
11/4/2017 6:06:15 PM> EMMC Device Information :
11/4/2017 6:06:15 PM> EMMC CID: 90014A4838473474210150E3985F9282
11/4/2017 6:06:15 PM> EMMC CSD: D07F01320F5903FFFFFFFFEF8A400012
11/4/2017 6:06:15 PM> EMMC Manufacture Name: SKHYNIX
11/4/2017 6:06:15 PM> EMMC Manufacture ID: 0x90 , OEM ID: 014A
11/4/2017 6:06:15 PM> EMMC Manufacture Date: 9/2015 , Rev: 01
11/4/2017 6:06:15 PM> EMMC NAME: H8G4t! , S/N: 50E3985F , rev. 01
11/4/2017 6:06:15 PM> EMMC NAME (HEX): 483847347421
11/4/2017 6:06:15 PM> EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000)
11/4/2017 6:06:15 PM> EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000)
11/4/2017 6:06:15 PM> EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000)
11/4/2017 6:06:15 PM> EMMC Permanent Write Protection: No
11/4/2017 6:06:15 PM> EMMC Temporary Write Protection: No
11/4/2017 6:06:15 PM> Extended CSD Information :
11/4/2017 6:06:15 PM> Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01)
11/4/2017 6:06:15 PM> Boot configuration [PARTITION_CONFIG]: 0x08 , Boot from: ROM2 (Boot partition 1)
11/4/2017 6:06:15 PM> Boot Bus Config: 0x00 , width 1bit
11/4/2017 6:06:15 PM> H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled
11/4/2017 6:06:15 PM> Supported partition features [PARTITIONING_SUPPORT]: 0x07
11/4/2017 6:06:15 PM> Device supports partitioning features
11/4/2017 6:06:15 PM> Device can have enhanced technological features in partitions and user data area
11/4/2017 6:06:15 PM> Device can have extended partitions attribute
11/4/2017 6:06:15 PM> Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00
11/4/2017 6:06:15 PM> Backup saved: H8G4t!_50E3985F_20171104_180615.extcsd
11/4/2017 6:06:15 PM> EMMC Init completed.
11/4/2017 6:06:15 PM> Operation: Write by vendor (Samsung)
11/4/2017 6:06:15 PM> Creating GPT-partitioninig
11/4/2017 6:06:16 PM> Error writing at address: 000000000000 ... Retry #1
11/4/2017 6:06:16 PM> Error writing at address: 000000000000 ... Retry #2
11/4/2017 6:06:17 PM> Error writing at address: 000000000000 ... Retry #3
11/4/2017 6:06:17 PM> Writing PIT at address: 000000080000
11/4/2017 6:06:17 PM> GPT-partitioning done
11/4/2017 6:06:17 PM> Unpacking file: spl.img
11/4/2017 6:06:17 PM> Unpacking file: sboot.bin
11/4/2017 6:06:17 PM> Unpacking file: sboot2.bin
11/4/2017 6:06:17 PM> Partition name: BOOT
11/4/2017 6:06:17 PM> Filename: spl.img , Offset: 000000000000 , filesize: 32768 bytes
11/4/2017 6:06:17 PM> eMMC switching to ROM2
11/4/2017 6:06:17 PM> Erasing partition...
11/4/2017 6:06:20 PM> Writing partition...
11/4/2017 6:06:20 PM> Done writing partition. Write speed: 253.70 Kb/s
11/4/2017 6:06:20 PM> Partition name: SBOOT
11/4/2017 6:06:20 PM> Filename: sboot.bin , Offset: 000000400000 , filesize: 1573888 bytes
11/4/2017 6:06:20 PM> eMMC switching to ROM1
11/4/2017 6:06:20 PM> Erasing partition...
11/4/2017 6:06:22 PM> Writing partition...
11/4/2017 6:06:23 PM> Done writing partition. Write speed: 1078.54 Kb/s
11/4/2017 6:06:23 PM> Partition name: SBOOT2
11/4/2017 6:06:23 PM> Filename: sboot2.bin , Offset: 000000600000 , filesize: 1573888 bytes
11/4/2017 6:06:23 PM> eMMC switching to ROM1
11/4/2017 6:06:23 PM> Erasing partition...
11/4/2017 6:06:24 PM> Writing partition...
11/4/2017 6:06:26 PM> Done writing partition. Write speed: 1078.69 Kb/s
11/4/2017 6:06:26 PM> All done
11/4/2017 6:07:17 PM> Looking for EasyJTAG box...
11/4/2017 6:07:17 PM> EasyJTAG API ver. 2008
11/4/2017 6:07:17 PM> Setting IO Levels to 3.3V
11/4/2017 6:07:17 PM> Setting frequence to 21 Mhz
11/4/2017 6:07:17 PM> HiPower mode is OFF
11/4/2017 6:07:18 PM> OpenUSB returned = 0
11/4/2017 6:07:18 PM> Error: Previous operation is not finished yet.
11/4/2017 6:07:18 PM> Power Controller returned = 0
11/4/2017 6:07:19 PM> EasyJTAG Box Serial = 1200D0035CA63064
11/4/2017 6:07:19 PM> EasyJTAG Box Firmware = 01.60
11/4/2017 6:07:19 PM> HiPower mode is OFF
11/4/2017 6:07:19 PM> Frequence: 21 Mhz
11/4/2017 6:07:19 PM> CMD Pullup Level: 2712 mV
11/4/2017 6:07:19 PM> CMD Active Level: 3320 mV
11/4/2017 6:07:19 PM> eMMC Init returned = 0
11/4/2017 6:07:19 PM> EMMC Device Information :
11/4/2017 6:07:19 PM> EMMC CID: 90014A4838473474210150E3985F9282
11/4/2017 6:07:19 PM> EMMC CSD: D07F01320F5903FFFFFFFFEF8A400012
11/4/2017 6:07:19 PM> EMMC Manufacture Name: SKHYNIX
11/4/2017 6:07:19 PM> EMMC Manufacture ID: 0x90 , OEM ID: 014A
11/4/2017 6:07:19 PM> EMMC Manufacture Date: 9/2015 , Rev: 01
11/4/2017 6:07:19 PM> EMMC NAME: H8G4t! , S/N: 50E3985F , rev. 01
11/4/2017 6:07:19 PM> EMMC NAME (HEX): 483847347421
11/4/2017 6:07:19 PM> EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000)
11/4/2017 6:07:19 PM> EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000)
11/4/2017 6:07:19 PM> EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000)
11/4/2017 6:07:19 PM> EMMC Permanent Write Protection: No
11/4/2017 6:07:19 PM> EMMC Temporary Write Protection: No
11/4/2017 6:07:19 PM> Extended CSD Information :
11/4/2017 6:07:19 PM> Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01)
11/4/2017 6:07:19 PM> Boot configuration [PARTITION_CONFIG]: 0x08 , Boot from: ROM2 (Boot partition 1)
11/4/2017 6:07:19 PM> Boot Bus Config: 0x00 , width 1bit
11/4/2017 6:07:19 PM> H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled
11/4/2017 6:07:20 PM> Supported partition features [PARTITIONING_SUPPORT]: 0x07
11/4/2017 6:07:20 PM> Device supports partitioning features
11/4/2017 6:07:20 PM> Device can have enhanced technological features in partitions and user data area
11/4/2017 6:07:20 PM> Device can have extended partitions attribute
11/4/2017 6:07:20 PM> Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00
11/4/2017 6:07:20 PM> Backup saved: H8G4t!_50E3985F_20171104_180720.extcsd
11/4/2017 6:07:20 PM> EMMC Init completed.
11/4/2017 6:07:20 PM> Scanning soft partitions
11/4/2017 6:07:29 PM> Partition table not found
11/4/2017 6:07:29 PM> Get firmware version
11/4/2017 6:08:03 PM> Firmware info not found
BEFORE I DID UNIVERSAL FORMAT SEE LOGS BELOW BEFORE I DID FORMAT
11/4/2017 5:11:03 PM> Looking for EasyJTAG box...
11/4/2017 5:11:03 PM> EasyJTAG API ver. 2008
11/4/2017 5:11:03 PM> Setting IO Levels to 3.3V
11/4/2017 5:11:03 PM> Setting frequence to 14 Mhz
11/4/2017 5:11:03 PM> HiPower mode is OFF
11/4/2017 5:11:04 PM> OpenUSB returned = 0
11/4/2017 5:11:04 PM> Power Controller returned = 0
11/4/2017 5:11:05 PM> EasyJTAG Box Serial = 1200D0035CA63064
11/4/2017 5:11:05 PM> EasyJTAG Box Firmware = 01.60
11/4/2017 5:11:05 PM> HiPower mode is OFF
11/4/2017 5:11:05 PM> Frequence: 14 Mhz
11/4/2017 5:11:05 PM> CMD Pullup Level: 2227 mV
11/4/2017 5:11:05 PM> CMD Active Level: 2598 mV
11/4/2017 5:11:05 PM> eMMC Init returned = 0
11/4/2017 5:11:05 PM> EMMC Device Information :
11/4/2017 5:11:05 PM> EMMC CID: 90014A4838473474210150E3985F9282
11/4/2017 5:11:05 PM> EMMC CSD: D07F01320F5903FFFFFFFFEF8A400012
11/4/2017 5:11:05 PM> EMMC Manufacture Name: SKHYNIX
11/4/2017 5:11:05 PM> EMMC Manufacture ID: 0x90 , OEM ID: 014A
11/4/2017 5:11:05 PM> EMMC Manufacture Date: 9/2015 , Rev: 01
11/4/2017 5:11:05 PM> EMMC NAME: H8G4t! , S/N: 50E3985F , rev. 01
11/4/2017 5:11:05 PM> EMMC NAME (HEX): 483847347421
11/4/2017 5:11:05 PM> EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000)
11/4/2017 5:11:05 PM> EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000)
11/4/2017 5:11:05 PM> EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000)
11/4/2017 5:11:05 PM> EMMC Permanent Write Protection: No
11/4/2017 5:11:05 PM> EMMC Temporary Write Protection: No
11/4/2017 5:11:05 PM> Extended CSD Information :
11/4/2017 5:11:05 PM> Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01)
11/4/2017 5:11:05 PM> Boot configuration [PARTITION_CONFIG]: 0x08 , Boot from: ROM2 (Boot partition 1)
11/4/2017 5:11:05 PM> Boot Bus Config: 0x00 , width 1bit
11/4/2017 5:11:05 PM> H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled
11/4/2017 5:11:05 PM> Supported partition features [PARTITIONING_SUPPORT]: 0x07
11/4/2017 5:11:05 PM> Device supports partitioning features
11/4/2017 5:11:05 PM> Device can have enhanced technological features in partitions and user data area
11/4/2017 5:11:05 PM> Device can have extended partitions attribute
11/4/2017 5:11:05 PM> Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00
11/4/2017 5:11:06 PM> Backup saved: H8G4t!_50E3985F_20171104_171105.extcsd
11/4/2017 5:11:06 PM> EMMC Init completed.
11/4/2017 5:11:06 PM> Scanning soft partitions
11/4/2017 5:11:06 PM> GPT header is found and is valid
11/4/2017 5:11:06 PM> Partition: SBOOT, [000000400000 - 000000600000], size: 000000200000
11/4/2017 5:11:06 PM> Partition: SBOOT2, [000000600000 - 000000800000], size: 000000200000
11/4/2017 5:11:06 PM> Partition: wfixnv1, [000000800000 - 000000900000], size: 000000100000
11/4/2017 5:11:06 PM> Partition: wfixnv2, [000000900000 - 000000A00000], size: 000000100000
11/4/2017 5:11:06 PM> Partition: tdfixnv1, [000000A00000 - 000000B00000], size: 000000100000
11/4/2017 5:11:06 PM> Partition: tdfixnv2, [000000B00000 - 000000C00000], size: 000000100000
11/4/2017 5:11:06 PM> Partition: WDSP, [000000C00000 - 000001000000], size: 000000400000
11/4/2017 5:11:06 PM> Partition: MODEM, [000001000000 - 000001800000], size: 000000800000
11/4/2017 5:11:06 PM> Partition: MODEM2, [000001800000 - 000002000000], size: 000000800000
11/4/2017 5:11:06 PM> Partition: TDDSP, [000002000000 - 000002400000], size: 000000400000
11/4/2017 5:11:06 PM> Partition: FOTA_SIG, [000002400000 - 000002500000], size: 000000100000
11/4/2017 5:11:06 PM> Partition: wruntimenv1, [000002500000 - 000002600000], size: 000000100000
11/4/2017 5:11:06 PM> Partition: wruntimenv2, [000002600000 - 000002700000], size: 000000100000
11/4/2017 5:11:06 PM> Partition: tdruntimenv1, [000002700000 - 000002800000], size: 000000100000
11/4/2017 5:11:06 PM> Partition: tdruntimenv2, [000002800000 - 000002900000], size: 000000100000
11/4/2017 5:11:06 PM> Partition: PARAM, [000002900000 - 000002B00000], size: 000000200000
11/4/2017 5:11:06 PM> Partition: efs, [000002B00000 - 000003F00000], size: 000001400000
11/4/2017 5:11:06 PM> Partition: prodnv, [000003F00000 - 000004400000], size: 000000500000
11/4/2017 5:11:06 PM> Partition: RESERVED2, [000004400000 - 000004600000], size: 000000200000
11/4/2017 5:11:06 PM> Partition: KERNEL, [000004600000 - 000005600000], size: 000001000000
11/4/2017 5:11:06 PM> Partition: RECOVERY, [000005600000 - 000006600000], size: 000001000000
11/4/2017 5:11:06 PM> Partition: PERSISTENT, [000006600000 - 000006700000], size: 000000100000
11/4/2017 5:11:06 PM> Partition: persdata, [000006700000 - 000007000000], size: 000000900000
11/4/2017 5:11:06 PM> Partition: CACHE, [000007000000 - 000013800000], size: 00000C800000
11/4/2017 5:11:06 PM> Partition: SYSTEM, [000013800000 - 000071400000], size: 00005DC00000
11/4/2017 5:11:06 PM> Partition: HIDDEN, [000071400000 - 000073200000], size: 000001E00000
11/4/2017 5:11:06 PM> Partition: userdata, [000073200000 - 0001D1200000], size: 00015E000000
11/4/2017 5:11:06 PM> GPT header successfully parsed
11/4/2017 5:11:06 PM> Get firmware version
11/4/2017 5:11:08 PM> Firmware info not found
PLEASE WHAT AM I DOING WRONG PLEASE I WANT TO KNOW..
Old 11-05-2017, 19:39   #4 (permalink)
yuvraj9x2's Avatar
Member: 2213928
Thanks Meter: 440
http://forum.gsmhosting.com/vbb/f672...-puls-2280061/
The Following User Says Thank You to yuvraj9x2 For This Useful Post:
Old 11-08-2017, 00:04   #5 (permalink)
johnoroo37's Avatar
Member: 2025428
Thanks Meter: 445
DONE DONE DONE AND ALL IS OK
HiPower mode is OFF
Changelog:
08.08.2017 (ver 1.4.8.0)
Fix: Bugs that have been found through your crash report
Fix: Saving VCF for contacts
Add: Multiple file selection for Samsung firmware
Add: Write full Extcsd or write only the boot configuration ("Repair Extcsd" button)
Add: Intel vendor (for easy read/write ROM2/ROM3/GP1)
Add: "Pinouts" tab (taken from the catalog of classic software)
Add: Checker for Sony TrimArea
Add: Speed graph for "Random verify emmc"
Add: Fat16/Fat32/exFat support (Explorer)
HiPower mode is OFF
Frequence: 21 Mhz
CMD Pullup Level: 495 mV
CMD Active Level: 3021 mV
Can't init device. Reason: OCR Ready Timeout Error [Check VCC or eMMC DEAD]
HiPower mode is OFF
Frequence: 21 Mhz
CMD Active Level: 3031 mV
HiPower mode is OFF
Frequence: 21 Mhz
CMD Pullup Level: 876 mV
CMD Active Level: 3155 mV
Can't init device. Reason: CMD Timeout Error
HiPower mode is OFF
Frequence: 21 Mhz
CMD Pullup Level: 484 mV
HiPower mode is OFF
Frequence: 21 Mhz
Partition Settings [PARTITION_SETTING_COMPLETED]: 0x01
Backup saved: H8G4t!_50E3985F_20171107_162511.extcsd
Brand = samsung
Model = SM-J200H
Phone platform = sc8830
CPU Abi = armeabi-v7a
Android release = 5.1.1
Firmware version = LMY48B.J200HXXU0AQG1
Firmware date = Tue Jul 4 19:17:28 KST 2017
HiPower mode is OFF
Frequence: 21 Mhz
Backup saved: H8G4t!_50E3985F_20171107_162648.extcsd
Opening file: SAMSUNG_SM-J200H_emmc_dump_ROM1_112MB.bin
Analyzing Image: SAMSUNG_SM-J200H_emmc_dump_ROM1_112MB.bin
Vendor: Samsung
Searching GPT ...
HiPower mode is OFF
Frequence: 21 Mhz
CMD Active Level: 3330 mV
Backup saved: H8G4t!_50E3985F_20171107_162733.extcsd
Partition name: GPT
Filename: SAMSUNG_SM-J200H_emmc_dump_ROM1_112MB.bin , Offset: 000000000000 , filesize: 17408 bytes
Done writing partition. Write speed: 208.05 Kb/s
Filename: SAMSUNG_SM-J200H_emmc_dump_ROM1_112MB.bin , Offset: 000000400000 , filesize: 2097152 bytes
Done writing partition. Write speed: 743.91 Kb/s
Filename: SAMSUNG_SM-J200H_emmc_dump_ROM1_112MB.bin , Offset: 000000600000 , filesize: 2097152 bytes
Done writing partition. Write speed: 1110.89 Kb/s
Partition name: wfixnv1
Filename: SAMSUNG_SM-J200H_emmc_dump_ROM1_112MB.bin , Offset: 000000800000 , filesize: 1048576 bytes
Done writing partition. Write speed: 1166.76 Kb/s
Partition name: wfixnv2
Filename: SAMSUNG_SM-J200H_emmc_dump_ROM1_112MB.bin , Offset: 000000900000 , filesize: 1048576 bytes
Done writing partition. Write speed: 1187.21 Kb/s
Partition name: tdfixnv1
Filename: SAMSUNG_SM-J200H_emmc_dump_ROM1_112MB.bin , Offset: 000000A00000 , filesize: 1048576 bytes
Done writing partition. Write speed: 1236.20 Kb/s
Partition name: tdfixnv2
Filename: SAMSUNG_SM-J200H_emmc_dump_ROM1_112MB.bin , Offset: 000000B00000 , filesize: 1048576 bytes
Done writing partition. Write speed: 1239.45 Kb/s
Partition name: WDSP
Filename: SAMSUNG_SM-J200H_emmc_dump_ROM1_112MB.bin , Offset: 000000C00000 , filesize: 4194304 bytes
Done writing partition. Write speed: 1170.09 Kb/s
Partition name: MODEM
Filename: SAMSUNG_SM-J200H_emmc_dump_ROM1_112MB.bin , Offset: 000001000000 , filesize: 8388608 bytes
Done writing partition. Write speed: 885.99 Kb/s
Partition name: MODEM2
Filename: SAMSUNG_SM-J200H_emmc_dump_ROM1_112MB.bin , Offset: 000001800000 , filesize: 8388608 bytes
Done writing partition. Write speed: 1285.56 Kb/s
Partition name: TDDSP
Filename: SAMSUNG_SM-J200H_emmc_dump_ROM1_112MB.bin , Offset: 000002000000 , filesize: 4194304 bytes
Done writing partition. Write speed: 1275.73 Kb/s
Partition name: FOTA_SIG
Filename: SAMSUNG_SM-J200H_emmc_dump_ROM1_112MB.bin , Offset: 000002400000 , filesize: 1048576 bytes
Done writing partition. Write speed: 1292.32 Kb/s
Partition name: wruntimenv1
Filename: SAMSUNG_SM-J200H_emmc_dump_ROM1_112MB.bin , Offset: 000002500000 , filesize: 1048576 bytes
Done writing partition. Write speed: 1123.55 Kb/s
Partition name: wruntimenv2
Filename: SAMSUNG_SM-J200H_emmc_dump_ROM1_112MB.bin , Offset: 000002600000 , filesize: 1048576 bytes
Done writing partition. Write speed: 1163.80 Kb/s
Partition name: tdruntimenv1
Filename: SAMSUNG_SM-J200H_emmc_dump_ROM1_112MB.bin , Offset: 000002700000 , filesize: 1048576 bytes
Done writing partition. Write speed: 1286.25 Kb/s
Partition name: tdruntimenv2
Filename: SAMSUNG_SM-J200H_emmc_dump_ROM1_112MB.bin , Offset: 000002800000 , filesize: 1048576 bytes
Done writing partition. Write speed: 1216.52 Kb/s
Partition name: PARAM
Filename: SAMSUNG_SM-J200H_emmc_dump_ROM1_112MB.bin , Offset: 000002900000 , filesize: 2097152 bytes
Done writing partition. Write speed: 1034.61 Kb/s
Partition name: efs
Filename: SAMSUNG_SM-J200H_emmc_dump_ROM1_112MB.bin , Offset: 000002B00000 , filesize: 20971520 bytes
Done writing partition. Write speed: 1276.43 Kb/s
Partition name: prodnv
Filename: SAMSUNG_SM-J200H_emmc_dump_ROM1_112MB.bin , Offset: 000003F00000 , filesize: 5242880 bytes
Done writing partition. Write speed: 1220.14 Kb/s
Partition name: RESERVED2
Filename: SAMSUNG_SM-J200H_emmc_dump_ROM1_112MB.bin , Offset: 000004400000 , filesize: 2097152 bytes
Done writing partition. Write speed: 1292.78 Kb/s
Partition name: KERNEL
Filename: SAMSUNG_SM-J200H_emmc_dump_ROM1_112MB.bin , Offset: 000004600000 , filesize: 16777216 bytes
Done writing partition. Write speed: 902.13 Kb/s
Partition name: RECOVERY
Filename: SAMSUNG_SM-J200H_emmc_dump_ROM1_112MB.bin , Offset: 000005600000 , filesize: 16777216 bytes
Done writing partition. Write speed: 892.43 Kb/s
Partition name: PERSISTENT
Filename: SAMSUNG_SM-J200H_emmc_dump_ROM1_112MB.bin , Offset: 000006600000 , filesize: 1048576 bytes
Done writing partition. Write speed: 1286.88 Kb/s
Partition name: persdata
Filename: SAMSUNG_SM-J200H_emmc_dump_ROM1_112MB.bin , Offset: 000006700000 , filesize: 9437184 bytes
Done writing partition. Write speed: 1283.41 Kb/s
All done
HiPower mode is OFF
Frequence: 21 Mhz
Backup saved: H8G4t!_50E3985F_20171107_163128.extcsd
Brand = samsung
Model = SM-J200H
HiPower mode is OFF
Frequence: 21 Mhz
Backup saved: H8G4t!_50E3985F_20171107_163142.extcsd
Opening file: SAMSUNG_SM-J200H_emmc_dump_ROM2.bin
Analyzing Image: SAMSUNG_SM-J200H_emmc_dump_ROM2.bin
Vendor: Samsung
Searching GPT ...
GPT header is not found
Searching PIT ...
PIT not found
HiPower mode is OFF
Frequence: 21 Mhz
Backup saved: H8G4t!_50E3985F_20171107_163156.extcsd
Opening file: SAMSUNG_SM-J200H_emmc_dump_ROM3.bin
Analyzing Image: SAMSUNG_SM-J200H_emmc_dump_ROM3.bin
Vendor: Samsung
Searching GPT ...
Searching PIT ...
PIT not found
HiPower mode is OFF
Frequence: 21 Mhz
Backup saved: H8G4t!_50E3985F_20171107_163205.extcsd
Brand = samsung
Model = SM-J200H
HiPower mode is OFF
Frequence: 21 Mhz
Backup saved: H8G4t!_50E3985F_20171107_163307.extcsd
Opening file: EMMC_ROM2_H8G4t_1701297375_00000000_00400000.bin
Analyzing Image: EMMC_ROM2_H8G4t_1701297375_00000000_00400000.bin
Vendor: Samsung
Searching GPT ...
Searching PIT ...
PIT not found
HiPower mode is OFF
Frequence: 21 Mhz
Backup saved: H8G4t!_50E3985F_20171107_163314.extcsd
Opening file: EMMC_ROM3_H8G4t_1701297375_00000000_00400000.bin
Analyzing Image: EMMC_ROM3_H8G4t_1701297375_00000000_00400000.bin
Vendor: Samsung
Searching GPT ...
Searching PIT ...
PIT not found
HiPower mode is OFF
Frequence: 21 Mhz
Backup saved: H8G4t!_50E3985F_20171107_163322.extcsd
Opening file: EMMC_ROM1_H8G4t_1701297375_00000000_73200000.bin
Analyzing Image: EMMC_ROM1_H8G4t_1701297375_00000000_73200000.bin
Vendor: Samsung
Searching GPT ...
Brand = samsung
Model = SM-J200H
Firmware version = LMY48B.J200HXXU0APK1
Firmware date = Tue Nov 8 13:26:48 KST 2016
HiPower mode is OFF
Frequence: 21 Mhz
Backup saved: H8G4t!_50E3985F_20171107_163350.extcsd
Partition name: GPT
Filename: EMMC_ROM1_H8G4t_1701297375_00000000_73200000.bin , Offset: 000000000000 , filesize: 17408 bytes
Done writing partition. Write speed: 207.94 Kb/s
Filename: EMMC_ROM1_H8G4t_1701297375_00000000_73200000.bin , Offset: 000000400000 , filesize: 2097152 bytes
Done writing partition. Write speed: 729.48 Kb/s
Filename: EMMC_ROM1_H8G4t_1701297375_00000000_73200000.bin , Offset: 000000600000 , filesize: 2097152 bytes
Done writing partition. Write speed: 1111.70 Kb/s
Filename: EMMC_ROM1_H8G4t_1701297375_00000000_73200000.bin , Offset: 000000800000 , filesize: 1048576 bytes
Done writing partition. Write speed: 1174.61 Kb/s
Filename: EMMC_ROM1_H8G4t_1701297375_00000000_73200000.bin , Offset: 000000900000 , filesize: 1048576 bytes
Done writing partition. Write speed: 1212.99 Kb/s
Filename: EMMC_ROM1_H8G4t_1701297375_00000000_73200000.bin , Offset: 000000A00000 , filesize: 1048576 bytes
Done writing partition. Write speed: 1233.29 Kb/s
Filename: EMMC_ROM1_H8G4t_1701297375_00000000_73200000.bin , Offset: 000000B00000 , filesize: 1048576 bytes
Done writing partition. Write speed: 1230.22 Kb/s
Filename: EMMC_ROM1_H8G4t_1701297375_00000000_73200000.bin , Offset: 000000C00000 , filesize: 4194304 bytes
Done writing partition. Write speed: 1177.44 Kb/s
Filename: EMMC_ROM1_H8G4t_1701297375_00000000_73200000.bin , Offset: 000001000000 , filesize: 8388608 bytes
Done writing partition. Write speed: 884.66 Kb/s
Filename: EMMC_ROM1_H8G4t_1701297375_00000000_73200000.bin , Offset: 000001800000 , filesize: 8388608 bytes
Done writing partition. Write speed: 1284.84 Kb/s
Filename: EMMC_ROM1_H8G4t_1701297375_00000000_73200000.bin , Offset: 000002000000 , filesize: 4194304 bytes
Done writing partition. Write speed: 1285.98 Kb/s
Filename: EMMC_ROM1_H8G4t_1701297375_00000000_73200000.bin , Offset: 000002400000 , filesize: 1048576 bytes
Done writing partition. Write speed: 1263.61 Kb/s
Filename: EMMC_ROM1_H8G4t_1701297375_00000000_73200000.bin , Offset: 000002500000 , filesize: 1048576 bytes
Done writing partition. Write speed: 1123.74 Kb/s
Filename: EMMC_ROM1_H8G4t_1701297375_00000000_73200000.bin , Offset: 000002600000 , filesize: 1048576 bytes
Done writing partition. Write speed: 1174.56 Kb/s
Filename: EMMC_ROM1_H8G4t_1701297375_00000000_73200000.bin , Offset: 000002700000 , filesize: 1048576 bytes
Done writing partition. Write speed: 1257.03 Kb/s
Filename: EMMC_ROM1_H8G4t_1701297375_00000000_73200000.bin , Offset: 000002800000 , filesize: 1048576 bytes
Done writing partition. Write speed: 1286.00 Kb/s
Filename: EMMC_ROM1_H8G4t_1701297375_00000000_73200000.bin , Offset: 000002900000 , filesize: 2097152 bytes
Done writing partition. Write speed: 1022.14 Kb/s
Partition name: efs
Filename: EMMC_ROM1_H8G4t_1701297375_00000000_73200000.bin , Offset: 000002B00000 , filesize: 20971520 bytes
Done writing partition. Write speed: 1233.38 Kb/s
Filename: EMMC_ROM1_H8G4t_1701297375_00000000_73200000.bin , Offset: 000003F00000 , filesize: 5242880 bytes
Done writing partition. Write speed: 1281.21 Kb/s
Filename: EMMC_ROM1_H8G4t_1701297375_00000000_73200000.bin , Offset: 000004400000 , filesize: 2097152 bytes
Done writing partition. Write speed: 1248.86 Kb/s
Filename: EMMC_ROM1_H8G4t_1701297375_00000000_73200000.bin , Offset: 000004600000 , filesize: 16777216 bytes
Done writing partition. Write speed: 901.58 Kb/s
Filename: EMMC_ROM1_H8G4t_1701297375_00000000_73200000.bin , Offset: 000005600000 , filesize: 16777216 bytes
Done writing partition. Write speed: 893.01 Kb/s
Filename: EMMC_ROM1_H8G4t_1701297375_00000000_73200000.bin , Offset: 000006600000 , filesize: 1048576 bytes
Done writing partition. Write speed: 1253.24 Kb/s
Filename: EMMC_ROM1_H8G4t_1701297375_00000000_73200000.bin , Offset: 000006700000 , filesize: 9437184 bytes
Done writing partition. Write speed: 1256.11 Kb/s
Partition name: CACHE
Filename: EMMC_ROM1_H8G4t_1701297375_00000000_73200000.bin , Offset: 000007000000 , filesize: 209715200 bytes
Done writing partition. Write speed: 1280.90 Kb/s
Partition name: SYSTEM
Filename: EMMC_ROM1_H8G4t_1701297375_00000000_73200000.bin , Offset: 000013800000 , filesize: 1572864000 bytes
Done writing partition. Write speed: 841.42 Kb/s
Partition name: HIDDEN
Filename: EMMC_ROM1_H8G4t_1701297375_00000000_73200000.bin , Offset: 000071400000 , filesize: 31457280 bytes
Done writing partition. Write speed: 950.72 Kb/s
All done
HiPower mode is OFF
Frequence: 21 Mhz
Backup saved: H8G4t!_50E3985F_20171107_171351.extcsd
Brand = samsung
Model = SM-J200H
Page generated in 0.39710 seconds with 8 queries
