Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Easy-Jtag
Old 08-01-2018, 08:09   #1 (permalink)
ALI_MAFIA's Avatar
Member: 537240
Sonork: 100.1660416
Thanks Meter: 223
SM-J250f emmc repair done.
Compression if OFF
Z3X EasyJtag Software ver. 3.0.0.0
Loading eMMC GEN2 Firmware... IO: 2800 mV
Box S/N: 67483A8698781033, ,FW Ver.: 02.29
CMD Pullup Level:2052 mV
CMD Active Level:2491 mV
Box IO Level:2800 mV
CLK Rate:24000 kHz
Bus Width:1bit,SDR
HiPower mode is ON!
---------- eMMC Device Information ----------
eMMC CID : 150100514536364D42007723C67C3571
eMMC CSD : D02701320F5903FFF6DBFFEF8E40400D
eMMC Manufacturer ID: 0015 , OEM ID: 0100
eMMC Date: 03/2018 Rev.0x0
eMMC NAME: QE66MB , S/N: 1998833276
eMMC NAME (HEX): 514536364D42
EMMC ROM1 (Main User Data) Capacity: 15028 MB
EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB
EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB
EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 kB
EMMC Permanent Write Protection: No
EMMC Temporary Write Protection: No
EMMC Password Locked: No
Extended CSD rev 1.8 (MMC 5.1)
Boot configuration [PARTITION_CONFIG: 0x38] Boot from:ROM1 (Main User Area)
Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x38.
H/W reset function [RST_N_FUNCTION]: 0x01
High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000]
Partitioning Support [PARTITIONING_SUPPORT]: 0x07
Device support partitioning feature
Device can have enhanced tech.
Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00
Backup saved: QE66MB_1998833276_20180729_1649.extcsd
Partition table scan:
GPT: present
Found valid GPT with protective MBR; using GPT.
Real (Hardware) Disk/Image size: 1D5A000 sectors 14.7 GiB
Soft (Partitioned) Disk/Image size: 1D59FBC sectors 14.7 GiB
Logical sector size: 0x200 bytes
Disk identifier (GUID): 98101B32-BBE2-4BF2-A06E-2BB33D000C20
First usable sector: 34
Last usable sector: 30777310
Found Data areas (firmware parts) count is: 48
Partition info successfully found
P0 (SBL1) [0x400000 0x80000] Size: 512.0KB
P1 (SBL1BAK) [0x480000 0x80000] Size: 512.0KB
P2 (DDR) [0x500000 0x8000] Size: 32.0KB
P3 (LIMITS) [0x508000 0x8000] Size: 32.0KB
P4 (ABOOT) [0x510000 0x200000] Size: 2.0MB
P5 (RPM) [0x710000 0x80000] Size: 512.0KB
P6 (TZ) [0x790000 0x200000] Size: 2.0MB
P7 (HYP) [0x990000 0x80000] Size: 512.0KB
P8 (DEVCFG) [0xa10000 0x40000] Size: 256.0KB
P9 (FSG) [0xa50000 0x300000] Size: 3.0MB
P10 (SEC) [0xd50000 0x4000] Size: 16.0KB
P11 (KEYMASTER) [0xd54000 0x80000] Size: 512.0KB
P12 (CMNLIB) [0xdd4000 0x40000] Size: 256.0KB
P13 (CMNLIB64) [0xe14000 0x40000] Size: 256.0KB
P14 (LKSECAPP) [0xe54000 0x80000] Size: 512.0KB
P15 (APDP) [0xed4000 0x40000] Size: 256.0KB
P16 (MSADP) [0xf14000 0x40000] Size: 256.0KB
P17 (PAD) [0xf54000 0xac000] Size: 688.0KB
P18 (MODEMST1) [0x1000000 0x300000] Size: 3.0MB
P19 (MODEMST2) [0x1300000 0x300000] Size: 3.0MB
P20 (PARAM) [0x1600000 0xa00000] Size: 10.0MB
P21 (EFS) [0x2000000 0xe00000] Size: 14.0MB
P22 (BOOT) [0x2e00000 0x2000000] Size: 32.0MB
P23 (RECOVERY) [0x4e00000 0x2000000] Size: 32.0MB
P24 (BOTA) [0x6e00000 0x700000] Size: 7.0MB
P25 (FOTA) [0x7500000 0x500400] Size: 5.0MB
P26 (BACKUP) [0x7a00400 0x5fec00] Size: 5.995MB
P27 (FSC) [0x7fff000 0x300000] Size: 3.0MB
P28 (SSD) [0x82ff000 0x2000] Size: 8.0KB
P29 (PERSIST) [0x8301000 0x2000000] Size: 32.0MB
P30 (PERSISTENT) [0xa301000 0x80000] Size: 512.0KB
P31 (STEADY) [0xa381000 0x400000] Size: 4.0MB
P32 (KEYSTORE) [0xa781000 0x80000] Size: 512.0KB
P33 (CONFIG) [0xa801000 0x8000] Size: 32.0KB
P34 (MOTA) [0xa809000 0x80000] Size: 512.0KB
P35 (DPO) [0xa889000 0x40000] Size: 256.0KB
P36 (MDTP) [0xa8c9000 0x10000] Size: 64.0KB
P37 (DIP) [0xa8d9000 0x100000] Size: 1.0MB
P38 (OEM) [0xa9d9000 0x10000] Size: 64.0KB
P39 (MCFG) [0xa9e9000 0x400000] Size: 4.0MB
P40 (DSP) [0xade9000 0x1000000] Size: 16.0MB
P41 (MODEM) [0xbde9000 0x5b97000] Size: 91.589MB
P42 (APNHLOS) [0x11980000 0x1c00000] Size: 28.0MB
P43 (RESERVED2) [0x13580000 0x280000] Size: 2.500MB
P44 (SYSTEM) [0x13800000 0xd1800000] Size: 3.273GB
P45 (CACHE) [0xe5000000 0xc800000] Size: 200.0MB
P46 (HIDDEN) [0xf1800000 0x3c00000] Size: 60.0MB
P47 (USERDATA) [0xf5400000 0x2b5ffb000] Size: 10.842GB
------ Android information ------
Detected LINUX(Android) SYSTEM : 0x0013800000 (3.273GB)
Build ID: NMF26X
Display Build ID: NMF26X.J250FXXU1ARA1
Release ID: 7.1.1
Device Model: SM-J250F
Product ID: j2y18lte
Device Name: j2y18ltejx
Architecture ABI: armeabi-v7a
Device manufacturer: samsung
Device Platform: msm8937
Build Description: j2y18ltejx-user 7.1.1 NMF26X J250FXXU1ARA1 release-keys
Samsung CPU: MSM8937
Done.
The Following 5 Users Say Thank You to ALI_MAFIA For This Useful Post:
Old 08-01-2018, 14:41   #2 (permalink)
lifegood8's Avatar
Member: 757297
Thanks Meter: 33
Red face j250f dead boot done but not power on
brother can you give me a link tested boot repair file for this model.
Old 08-01-2018, 17:40   #3 (permalink)
farukpdm's Avatar
Member: 1417131
Sonork: 100.1625249
Thanks Meter: 808
Look
He was use this File J250FXXU1ARA1
Autorun EXE
The Following User Says Thank You to farukpdm For This Useful Post:
Old 08-05-2018, 05:43   #4 (permalink)
Member: 2306084
Sonork: no
i want pinout emmc plz
Old 08-05-2018, 05:45   #5 (permalink)
Member: 484531
Thanks Meter: 67
https://imgur.com/YiDAUbi
Old 03-15-2019, 02:31   #6 (permalink)
Crazy Poster
Member: 64371
Thanks Meter: 2
pinout solution
the pinout fro z3x shell is ok
but you must connect the board to the charger or usb cable to the computer then you will detect it fast and happy
regards
Page generated in 0.30739 seconds with 7 queries
