01-14-2017, 15:17 | #1 (permalink) |
No Life Poster Join Date: Jan 2010 Location: South africa Age: 35
Member: 1197620 Status: Offline Sonork: 100.1602278 Thanks Meter: 647 | htc m8 after writting 1gb rom same phone qcom mode EMMC CSD : D02701320F5903FFFFFFFFEF8A4040D2 EMMC Manufacturer ID: 0090 , OEM ID: 014A EMMC Date: 05/2014 Rev.0x5 EMMC NAME: HAG4d , S/N: 210060103 EMMC NAME (HEX): 48414734642000 EMMC ROM1 (Main User Data) Capacity: 15032 MB EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.6 (MMC 4.5) Boot configuration [PARTITION_CONFIG: 0x00] No boot partition configured. Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x00. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity W protect group size [HC_WP_GRP_SIZE: 0x00000000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: HAG4d _ 210060103_20170114_1754.extcsd Done. Checking NAND Image : G:\Devices\Z3x\Easy Jtag\m8\HTC-M8_ROM1_00000000_40000000.bin File successefuly loaded! Processing file...G:\Devices\Z3x\Easy Jtag\m8\HTC-M8_ROM1_00000000_40000000.bin Z3X EasyJtag Software ver. 2.5.0.4 Skip loading eMMC Addon Firmware CMD Pullup Level:2691 mV CMD Active Level:2753 mV Input file : G:\Devices\Z3x\Easy Jtag\m8\HTC-M8_ROM1_00000000_40000000.bin Writing 0040000000 bytes to 00000000 ...ROM1 (USER ROM) Done. Write Speed: 1103 kB/s |
03-16-2017, 18:46 | #2 (permalink) |
Freak Poster Join Date: Jul 2006 Location: TIMISOARA , ROMANIA Age: 34
Member: 310822 Status: Offline Sonork: ALIAS: POLITEHNICA_1921 Thanks Meter: 9 | same here phone history phone was phone is american 0pb70000 wanted to change to 0pb10000 found out later that that is not possible too late for normal flashing recovery because now at getvar i got MID 0pb10000 and can't change by fastboot phone state before jtag emmc - only fastboot phone state after jtag emmc - dead only qualcomm hs-usb here is log Z3X EasyJtag Software ver. 2.5.0.8 Loading eMMC Addon Firmware... IO: 2800 mV Box S/N: 161610055F56B5ED, ,FW Ver.: 01.58 CMD Pullup Level:1732 mV CMD Active Level:2340 mV Box IO Level:2800 mV CLK Rate:14000 khz HiPower mode is off! ---------- eMMC Device Information ---------- EMMC CID : 90014A4842473465050101E63FE75132 EMMC CSD : D02701320F5903FFFFFFFFEF8A4040D2 EMMC Manufacturer ID: 0090 , OEM ID: 014A EMMC Date: 05/2014 Rev.0x1 EMMC NAME: HBG4e , S/N: 31866855 EMMC NAME (HEX): 48424734652000 EMMC ROM1 (Main User Data) Capacity: 29824 MB EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.6 (MMC 4.5) Boot configuration [PARTITION_CONFIG: 0x00] No boot partition configured. Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x00. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity W protect group size [HC_WP_GRP_SIZE: 0x00000000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: HBG4e _ 31866855_20170316_1735.extcsd Done. Z3X EasyJtag Software ver. 2.5.0.8 Skip loading eMMC Addon Firmware CMD Pullup Level:1732 mV CMD Active Level:2340 mV Input file : D:\z3x\jtag\HTC-M8_ROM1_1Gb\HTC-M8_ROM1_00000000_40000000.bin Writing 0040000000 bytes to 0000000000... ROM1 (USER ROM) Done. Write Speed: 1296 kB/s maybe rom1 file is bad can you guys provide full dump ? rom 2 , 3 ? or what is the solution thanks in advance |
03-20-2017, 17:29 | #4 (permalink) | |
Member: 310822 Status: Offline Sonork: ALIAS: POLITEHNICA_1921 Thanks Meter: 9 | Quote: my phone is 0p6b700000 with your file when i try to load it i get Caution: invalid backup GPT header, but valid main header! Loading Partitions List... Setting Metadata 0 length are 22 Checking EFI Table CRC fields. Warning! Main and backup partition tables differ! Use the 'c' and 'e' options on the recovery & transformation menu to examine the two tables. Warning! One or more CRCs don't match. You should repair the disk! Partition table scan: APM: not present GPT: damaged Caution: Found protective or hybrid MBR and corrupt GPT. Using GPT, but disk verification and recovery are STRONGLY recommended. can anyone else help ? guys from support ? are you in holiday or something ? | |
