GSM-Forum (https://forum.gsmhosting.com/vbb/)
-   Easy-Jtag / Easy-Jtag Plus (https://forum.gsmhosting.com/vbb/f672/)
-   -   Sm.j320m help (https://forum.gsmhosting.com/vbb/f672/sm-j320m-help-2285079/)
electron 11-10-2017 00:49
Sm.j320m help
1 Attachment(s)
Hi...
I have problem whith gpt demanged....
Watt is solution for this¿¿
Compression is ON
Z3X EasyJtag Software ver. 2.6.0.1
Loading eMMC GEN1 Firmware... IO: 2800 mV
Box S/N: 0FFFB013496F58A3, ,FW Ver.: 01.60
CMD Pullup Level:1804 mV
CMD Active Level:2547 mV
Box IO Level:2800 mV
CLK Rate:14000 khz
HiPower mode is ON!
---------- eMMC Device Information ----------
EMMC CID : 150100514E3136424200A60B684414C4
EMMC CSD : D02701320F5903FFF6DBFFEF8E40400C
EMMC Manufacturer ID: 0015 , OEM ID: 0100
EMMC Date: 01/2017 Rev.0x0
EMMC NAME: QN16BB , S/N: 2785765444
EMMC NAME (HEX): 514E3136424200
EMMC ROM1 (Main User Data) Capacity: 7456 MB
EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB
EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB
EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB
EMMC Permanent Write Protection: No
EMMC Temporary Write Protection: No
EMMC Password Locked: No
Extended CSD rev 1.7 (MMC 5.0)
Boot configuration [PARTITION_CONFIG: 0x08] Boot from:ROM2 (Boot Partition 1)
Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x08.
H/W reset function [RST_N_FUNCTION]: 0x00
High-capacity W protect group size [HC_WP_GRP_SIZE: 0x00000000]
Partitioning Support [PARTITIONING_SUPPORT]: 0x07
Device support partitioning feature
Device can have enhanced tech.
Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00
Backup saved: QN16BB_2785765444_20171109_2008.extcsd
Caution: invalid backup GPT header, but valid main header!
Warning! Main and backup partition tables differ!n
Warning! One or more CRCs don't match. You should repair the disk!
Partition table scan:
GPT: damaged
Caution: Found protective or hybrid MBR and corrupt GPT.
You will need to delete this partition or resize it in another utility.
Real (Hardware) Disk/Image size: E90000 sectors 7.3 GiB
Soft (Partitioned) Disk/Image size: 507FDD sectors 2.5 GiB
Logical sector size: 0x200 bytes
Disk identifier (GUID): 98101B32-BBE2-4BF2-A06E-2BB33D000C20
First usable sector: 34
Last usable sector: 5275647
Found Data areas (firmware parts) count is: 29
Partition info successfully found
P2 (SBOOT) [0x400000 0x200000] Size: 2.0MB
P3 (SBOOT2) [0x600000 0x200000] Size: 2.0MB
P4 (L_FIXNV1) [0x800000 0x100000] Size: 1.0MB
P5 (L_FIXNV2) [0x900000 0x100000] Size: 1.0MB
P6 (PM_SYS) [0xa00000 0x100000] Size: 1.0MB
P7 (RSVDFIXNV1) [0xb00000 0x100000] Size: 1.0MB
P8 (L_LDSP) [0xc00000 0x400000] Size: 4.0MB
P9 (L_MODEM) [0x1000000 0x1000000] Size: 16.0MB
P10 (L_GDSP) [0x2000000 0x400000] Size: 4.0MB
P11 (L_WARM) [0x2400000 0x400000] Size: 4.0MB
P12 (FOTA_SIG) [0x2800000 0x100000] Size: 1.0MB
P13 (L_RUNTIMENV1) [0x2900000 0x100000] Size: 1.0MB
P14 (L_RUNTIMENV2) [0x2a00000 0x100000] Size: 1.0MB
P15 (TD_RUNTIMENV1) [0x2b00000 0x100000] Size: 1.0MB
P16 (TD_RUNTIMENV2) [0x2c00000 0x100000] Size: 1.0MB
P17 (PARAM) [0x2d00000 0x200000] Size: 2.0MB
P18 (EFS) [0x2f00000 0x1400000] Size: 20.0MB
P19 (PRODNV) [0x4300000 0x500000] Size: 5.0MB
P20 (RESERVED2) [0x4800000 0x600000] Size: 6.0MB
P21 (KERNEL) [0x4e00000 0x1400000] Size: 20.0MB
P22 (RECOVERY) [0x6200000 0x1400000] Size: 20.0MB
P23 (PERSISTENT) [0x7600000 0x100000] Size: 1.0MB
P24 (PERSDATA) [0x7700000 0x900000] Size: 9.0MB
Page generated in 0.09169 seconds with 6 queries
