08-22-2018, 13:52 | #1 (permalink) |
No Life Poster Join Date: Jun 2006 Location: in this world
Member: 292087 Status: Offline Sonork: 1575183 Thanks Meter: 194 | Sm-j500f boot repair done but still dead Get firmware version Brand = samsung Manufacturer = samsung Model = SM-J500F Phone platform = msm8916 CPU Abi = armeabi-v7a Android release = 5.1.1 Firmware version = LMY48B.J500FXXU1AOK5 Firmware date = Mon Nov 23 21:02:26 KST 2015 HiPower mode is ON Setting frequence to 21 Mhz CMD Pullup Level: 2124 mV CMD Active Level: 2908 mV EMMC Device Information : EMMC CID: 90014A483847347521012F889A6123E4 EMMC CSD: D07F01320F5903FFFFFFFFEF8A400012 EMMC Manufacture : SKHYNIX , EMMC NAME: H8G4u , HEX: 483847347500 , S/N: 2F889A61 , rev. 0x01 EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Date: 2/2016 EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01) Boot configuration [PARTITION_CONFIG]: 0x00 , Boot from: no boot Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: H8G4u_2F889A61_20180822_020144.extcsd EMMC Init completed. Erasing for: ROM1 , start: 0x000000000000 , size: 0x0001D2000000 eMMC switching to ROM1 Erasing partition... Done erasing partition. HiPower mode is ON Setting frequence to 21 Mhz CMD Pullup Level: 2114 mV CMD Active Level: 2908 mV EMMC Device Information : EMMC CID: 90014A483847347521012F889A6123E4 EMMC CSD: D07F01320F5903FFFFFFFFEF8A400012 EMMC Manufacture : SKHYNIX , EMMC NAME: H8G4u , HEX: 483847347500 , S/N: 2F889A61 , rev. 0x01 EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Date: 2/2016 EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01) Boot configuration [PARTITION_CONFIG]: 0x00 , Boot from: no boot Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: H8G4u_2F889A61_20180822_024120.extcsd EMMC Init completed. Operation: Write all eMMC Regions at once Writing BootConfig ... Reg: 179 Value: 0x00 Reg: 177 Value: 0x00 Reg: 162 Value: 0x00 Done Writing to: ROM2 , start: 0x000000000000 , size: 0x000000400000 Filename: EMMC_QN16MB_ROM2_000000000000_000000400000.bin eMMC switching to ROM2 Writing partition... Done writing partition. Write speed: 223.58 KB/s Writing to: ROM3 , start: 0x000000000000 , size: 0x000000400000 Filename: EMMC_QN16MB_ROM3_000000000000_000000400000.bin eMMC switching to ROM3 Writing partition... Done writing partition. Write speed: 225.30 KB/s Writing to: ROM1 , start: 0x000000000000 , size: 0x000020000000 Filename: EMMC_QN16MB_ROM1_000000000000_000020000000.bin eMMC switching to ROM1 Writing partition... Done writing partition. Write speed: 488.64 KB/s All done time: [00:18:32:655] HiPower mode is ON Setting frequence to 21 Mhz CMD Pullup Level: 2114 mV CMD Active Level: 2908 mV EMMC Device Information : EMMC CID: 90014A483847347521012F889A6123E4 EMMC CSD: D07F01320F5903FFFFFFFFEF8A400012 EMMC Manufacture : SKHYNIX , EMMC NAME: H8G4u , HEX: 483847347500 , S/N: 2F889A61 , rev. 0x01 EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Date: 2/2016 EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01) Boot configuration [PARTITION_CONFIG]: 0x00 , Boot from: no boot Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: H8G4u_2F889A61_20180822_030146.extcsd EMMC Init completed. Opening file: J5LTE_EUR_OPEN.pit Pit: J5LTE_EUR_OPEN.pit Entry count: 32 The size of the last section has been updated BL_J500FXXU1BQE2_CL10808387_QB13512391_REV00_user_ low_ship_MULTI_CERT.tar.md5 The list of files in the firmware: aboot.mbn sbl1.mbn rpm.mbn tz.mbn hyp.mbn non-hlos.bin sec.dat AP_J500FXXU1BQE2_CL10808387_QB13512391_REV00_user_ low_ship_MULTI_CERT.tar.md5 The list of files in the firmware: boot.img recovery.img system.img.ext4 persist.img.ext4 userdata.img.ext4 CP_J500FDDU1BPK2_CL9873630_QB11637372_REV00_user_l ow_ship_MULTI_CERT.tar.md5 The list of files in the firmware: modem.bin CSC_ODD_J500FODD1BQC5_CL10271628_QB13031931_REV00_ user_low_ship_MULTI_CERT.tar.md5 The list of files in the firmware: j5lte_eur_open.pit cache.img.ext4 hidden.img.ext4 HiPower mode is ON Setting frequence to 21 Mhz CMD Pullup Level: 2124 mV CMD Active Level: 2908 mV EMMC Device Information : EMMC CID: 90014A483847347521012F889A6123E4 EMMC CSD: D07F01320F5903FFFFFFFFEF8A400012 EMMC Manufacture : SKHYNIX , EMMC NAME: H8G4u , HEX: 483847347500 , S/N: 2F889A61 , rev. 0x01 EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Date: 2/2016 EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01) Boot configuration [PARTITION_CONFIG]: 0x00 , Boot from: no boot Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: H8G4u_2F889A61_20180822_030253.extcsd EMMC Init completed. Operation: Write by vendor (Samsung) Creating GPT-partitioninig Writing PrimaryGPT at address: 000000000000 Writing BackupGPT at address: 0001D1FFBE00 Writing PIT at address: 000000004400 GPT-partitioning done Unpacking file: non-hlos.bin Unpacking file: modem.bin Unpacking file: sbl1.mbn Unpacking file: aboot.mbn Unpacking file: rpm.mbn Unpacking file: tz.mbn Unpacking file: hyp.mbn Unpacking file: sec.dat Unpacking file: boot.img Unpacking file: recovery.img Unpacking file: persist.img.ext4 Unpacking file: system.img.ext4 Not enough disk space HiPower mode is ON Setting frequence to 21 Mhz CMD Pullup Level: 2124 mV CMD Active Level: 2918 mV EMMC Device Information : EMMC CID: 90014A483847347521012F889A6123E4 EMMC CSD: D07F01320F5903FFFFFFFFEF8A400012 EMMC Manufacture : SKHYNIX , EMMC NAME: H8G4u , HEX: 483847347500 , S/N: 2F889A61 , rev. 0x01 EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Date: 2/2016 EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01) Boot configuration [PARTITION_CONFIG]: 0x00 , Boot from: no boot Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: H8G4u_2F889A61_20180822_030338.extcsd EMMC Init completed. Operation: Write by vendor (Samsung) Creating GPT-partitioninig Writing PrimaryGPT at address: 000000000000 Writing BackupGPT at address: 0001D1FFBE00 Writing PIT at address: 000000004400 GPT-partitioning done Unpacking file: non-hlos.bin Unpacking file: modem.bin Unpacking file: sbl1.mbn Unpacking file: aboot.mbn Unpacking file: rpm.mbn Unpacking file: tz.mbn Unpacking file: hyp.mbn Unpacking file: sec.dat Unpacking file: boot.img Unpacking file: recovery.img Unpacking file: persist.img.ext4 Unpacking file: system.img.ext4 Unpacking file: cache.img.ext4 Unpacking file: hidden.img.ext4 Unpacking file: userdata.img.ext4 Not enough disk space HiPower mode is ON Setting frequence to 21 Mhz CMD Pullup Level: 2114 mV CMD Active Level: 2918 mV EMMC Device Information : EMMC CID: 90014A483847347521012F889A6123E4 EMMC CSD: D07F01320F5903FFFFFFFFEF8A400012 EMMC Manufacture : SKHYNIX , EMMC NAME: H8G4u , HEX: 483847347500 , S/N: 2F889A61 , rev. 0x01 EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Date: 2/2016 EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01) Boot configuration [PARTITION_CONFIG]: 0x00 , Boot from: no boot Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: H8G4u_2F889A61_20180822_030814.extcsd EMMC Init completed. Operation: Write by vendor (Samsung) Creating GPT-partitioninig Writing PrimaryGPT at address: 000000000000 Writing BackupGPT at address: 0001D1FFBE00 Writing PIT at address: 000000004400 GPT-partitioning done Unpacking file: non-hlos.bin Unpacking file: modem.bin Unpacking file: sbl1.mbn Unpacking file: aboot.mbn Unpacking file: rpm.mbn Unpacking file: tz.mbn Unpacking file: hyp.mbn Unpacking file: sec.dat Unpacking file: boot.img Unpacking file: recovery.img Unpacking file: persist.img.ext4 Unpacking file: system.img.ext4 Unpacking file: cache.img.ext4 Unpacking file: hidden.img.ext4 Unpacking file: userdata.img.ext4 Partition name: APNHLOS Filename: non-hlos.bin , Offset: 000000400000 , filesize: 12896000 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 476.82 KB/s Partition name: MODEM Filename: modem.bin , Offset: 000001300000 , filesize: 46712576 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 483.74 KB/s Partition name: SBL1 Filename: sbl1.mbn , Offset: 000004C70000 , filesize: 285428 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 415.82 KB/s Partition name: ABOOT Filename: aboot.mbn , Offset: 000004CF8000 , filesize: 1321048 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 469.52 KB/s Partition name: RPM Filename: rpm.mbn , Offset: 000004EF8000 , filesize: 188484 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 386.93 KB/s Partition name: QSEE Filename: tz.mbn , Offset: 000004F78000 , filesize: 508476 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 453.25 KB/s Partition name: QHEE Filename: hyp.mbn , Offset: 000004FF8000 , filesize: 90368 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 385.30 KB/s Partition name: SEC Filename: sec.dat , Offset: 000005378000 , filesize: 684 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 12.90 KB/s Partition name: BOOT Filename: boot.img , Offset: 000007C00000 , filesize: 11763984 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 480.95 KB/s Partition name: RECOVERY Filename: recovery.img , Offset: 000008900000 , filesize: 13156624 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 483.27 KB/s Partition name: PERSIST Filename: persist.img.ext4 , Offset: 00000AE80000 , filesize: 4350076 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Sparse image found v.1.0 Total chunks: 8 Done writing partition. Write speed: 473.12 KB/s Partition name: SYSTEM Filename: system.img.ext4 , Offset: 00000C000000 , filesize: 2003970348 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Sparse image found v.1.0 Total chunks: 2924 Done writing partition. Write speed: 478.14 KB/s Partition name: CACHE Filename: cache.img.ext4 , Offset: 00008E000000 , filesize: 85475548 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Sparse image found v.1.0 Total chunks: 16 Done writing partition. Write speed: 486.59 KB/s Partition name: HIDDEN Filename: hidden.img.ext4 , Offset: 00009A800000 , filesize: 8253624 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Sparse image found v.1.0 Total chunks: 13 Done writing partition. Write speed: 475.77 KB/s Partition name: USERDATA Filename: userdata.img.ext4 , Offset: 00009EE00000 , filesize: 1252343640 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Sparse image found v.1.0 Total chunks: 325 Done writing partition. Write speed: 483.22 KB/s Writing BootConfig ... Reg: 179 Value: 0x00 Reg: 177 Value: 0x00 Reg: 162 Value: 0x00 Done All done time: [02:14:01:713] |
08-23-2018, 12:39 | #3 (permalink) |
Member: 292087 Status: Offline Sonork: 1575183 Thanks Meter: 194 | j500f deatect as qualcomm HS-USB 9008 After try to repair boot now sm-j500f/ds detect as qualcomm hs-usb qdloader 9008,any ideal please? |
