06-06-2021, 06:54 | #1 (permalink) |
Freak Poster Join Date: Jan 2013 Location: INDIA ANDHRAPRADESH Age: 32
Member: 1873923 Status: Offline Thanks Meter: 41 | After Write ffu emmc name 0000 Running:SAMSUNG: eMMC firmware update... Chip Init OK... Downloading FFU:C:\Program Files\Z3X\EASYJTAG\eMMC Firmware\KMDH6001DM-B422_64212EB8.bin Checking security ... Z3X EasyJtag Software ver. 3.7.0.23 Checking firmware type... OK; Skip loading eMMC Addon Firmware Box S/N: 18AA310DF1BA5410, ,FW Ver.: 02.53 Box IO Level:2800 mV CLK Rate:42000 kHz Using firmware file : C:\Program Files\Z3X\EASYJTAG\eMMC Firmware\KMDH6001DM-B422_64212EB8.bin Update Firmware ID Hash: Setup firmware update mode, wait 2..30 sec... Success! Sending eMMC firmware... Success! Verifying eMMC firmware... Success! Flashing eMMC firmware... Success! eMMC CID : 150100303030303030562016061354D1 Repairing eMMC CID... Can't write eMMC CID, Reason: DATA SND Timeout Error Done. Z3X EasyJtag Software ver. 3.7.0.23 Loading eMMC GEN2 Firmware... IO: 2800 mV Initial pull results: clock: 1322mV pin connected ok command: 1545mV pin connected ok data0: 1192mV pin connected ok data1: 1186mV pin connected ok data2: 1192mV pin connected ok data3: 1192mV pin connected ok data4: 1191mV pin connected ok data5: 1190mV pin connected ok data6: 1188mV pin connected ok data7: 1187mV pin connected ok Box S/N: 18AA310DF1BA5410, ,FW Ver.: 02.53 Box IO Level:2800 mV CLK Rate:42000 kHz Bus Width:8bit,SDR HiPower mode is off! ---------- eMMC Device Information ---------- eMMC CID : 150100303030303030562016061354D1 eMMC CSD : 902701320F5903FFF6DB7FE08A40403B eMMC Manufacturer ID: 0015 , OEM ID: 0100 eMMC Date: 05/2017 Rev.0x56 eMMC NAME: 000000 , S/N: 538314259 eMMC NAME (HEX): 303030303030 EMMC ROM1 (Main User Data) Capacity: 2095982 MB EMMC ROM2 (Boot Partition 1) Capacity: 512 kB EMMC ROM3 (Boot Partition 2) Capacity: 512 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 128 kB EMMC RPMB is not yet programmed (clear) or RPMB General failure EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.5 (MMC 4.41) Boot configuration [PARTITION_CONFIG: 0x00] No boot partition configured. Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x00. H/W reset function [RST_N_FUNCTION]: 0x00 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00000000] Partitioning Support [PARTITIONING_SUPPORT]: 0x03 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: 000000_ 538314259_20210606_1120.extcsd Blocks Reading Error (0x0 , 1 , Reason: DATA RCV Timeout Error ) Blocks Reading Error (0x200 , 1 , Reason: DATA RCV Timeout Error ) Warning! Read error 0 strange behavior now likely! Blocks Reading Error (0x1FFB6DFFE00 , 1 , Reason: DATA RCV Timeout Error ) Warning! Read error 0 strange behavior now likely! Partition info not found Done. |
06-06-2021, 16:37 | #2 (permalink) | |
Member: 1873923 Status: Offline Thanks Meter: 41 | solved my problem Quote:
