SM-J500F Dead Boot Repair Completed but Doesn't Come ON To Download Mode Dear, JTAG specialist, Please figerout me whats wrong !! Setting interface to EasyJtag2/ISP Setting bus width to 1 Bit Setting frequence to 12 Mhz CMD Pullup Level: 2128 mV CMD Active Level: 2626 mV EMMC Device Information : EMMC CID: 90014A4838473475920119E4950E44EF EMMC CSD: D02701320F5903FFFFFFFFE78A40002B EMMC Manufacture Name: SKHYNIX , EMMC NAME: H8G4u , EMMC NAME (HEX): 483847347500 , S/N: 19E4950E , rev. 0x01 EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Manufacture Date: 4/2017 EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01) Boot configuration [PARTITION_CONFIG]: 0x38 , Boot from: ROM1 (Main User Area) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x01 Backup saved: H8G4u_19E4950E_20200523_031705.extcsd EMMC Init completed. Operation: Write by vendor (Samsung) Creating GPT-partitioninig Writing PIT at address: 000000004400 GPT-partitioning done Unpacking file: non-hlos.bin Unpacking file: modem.bin Unpacking file: sbl1.mbn Unpacking file: aboot.mbn Unpacking file: rpm.mbn Unpacking file: tz.mbn Unpacking file: hyp.mbn Unpacking file: sec.dat Unpacking file: boot.img Unpacking file: recovery.img Unpacking file: persist.img.ext4 Unpacking file: system.img.ext4 Unpacking file: cache.img.ext4 Unpacking file: hidden.img.ext4 Partition name: APNHLOS Filename: non-hlos.bin , Offset: 000000400000 , filesize: 14452480 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1390.86 KB/s Partition name: MODEM Filename: modem.bin , Offset: 000001300000 , filesize: 46647040 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1395.62 KB/s Partition name: SBL1 Filename: sbl1.mbn , Offset: 000004C70000 , filesize: 283892 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1082.25 KB/s Partition name: ABOOT Filename: aboot.mbn , Offset: 000004CF8000 , filesize: 1217664 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1351.33 KB/s Partition name: RPM Filename: rpm.mbn , Offset: 000004EF8000 , filesize: 187836 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1117.42 KB/s Partition name: QSEE Filename: tz.mbn , Offset: 000004F78000 , filesize: 520588 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1277.84 KB/s Partition name: QHEE Filename: hyp.mbn , Offset: 000004FF8000 , filesize: 90368 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1026.38 KB/s Partition name: SEC Filename: sec.dat , Offset: 000005378000 , filesize: 684 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 29.78 KB/s Partition name: BOOT Filename: boot.img , Offset: 000007C00000 , filesize: 10924304 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1397.09 KB/s Partition name: RECOVERY Filename: recovery.img , Offset: 000008900000 , filesize: 12079376 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1391.50 KB/s Partition name: PERSIST Filename: persist.img.ext4 , Offset: 00000AE80000 , filesize: 4350076 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Sparse image found v.1.0 Total chunks: 8 Done writing partition. Write speed: 1361.55 KB/s Partition name: SYSTEM Filename: system.img.ext4 , Offset: 00000C000000 , filesize: 1825843932 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Sparse image found v.1.0 Total chunks: 2960 Done writing partition. Write speed: 1378.26 KB/s Partition name: CACHE Filename: cache.img.ext4 , Offset: 00008E000000 , filesize: 93626588 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Sparse image found v.1.0 Total chunks: 16 Done writing partition. Write speed: 1398.37 KB/s Partition name: HIDDEN Filename: hidden.img.ext4 , Offset: 00009A800000 , filesize: 27239028 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Sparse image found v.1.0 Total chunks: 50 Done writing partition. Write speed: 1360.27 KB/s Partition EFS : formatting as EXT4. Please wait ... Formatting completed All done time: [00:26:22:423] Setting interface to EasyJtag2/ISP Setting bus width to 1 Bit Setting frequence to 12 Mhz CMD Pullup Level: 2128 mV CMD Active Level: 2626 mV EMMC Device Information : EMMC CID: 90014A4838473475920119E4950E44EF EMMC CSD: D02701320F5903FFFFFFFFE78A40002B EMMC Manufacture Name: SKHYNIX , EMMC NAME: H8G4u , EMMC NAME (HEX): 483847347500 , S/N: 19E4950E , rev. 0x01 EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Manufacture Date: 4/2017 EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01) Boot configuration [PARTITION_CONFIG]: 0x38 , Boot from: ROM1 (Main User Area) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x01 Backup saved: H8G4u_19E4950E_20200523_034539.extcsd EMMC Init completed. Scanning soft partitions GPT header is found and is valid Partition: apnhlos, [000000400000 - 000001300000], size: 000000F00000 Partition: modem, [000001300000 - 000004C70000], size: 000003970000 Partition: sbl1, [000004C70000 - 000004CF0000], size: 000000080000 Partition: ddr, [000004CF0000 - 000004CF8000], size: 000000008000 Partition: aboot, [000004CF8000 - 000004EF8000], size: 000000200000 Partition: rpm, [000004EF8000 - 000004F78000], size: 000000080000 Partition: qsee, [000004F78000 - 000004FF8000], size: 000000080000 Partition: qhee, [000004FF8000 - 000005078000], size: 000000080000 Partition: fsg, [000005078000 - 000005378000], size: 000000300000 Partition: sec, [000005378000 - 00000537C000], size: 000000004000 Partition: pad, [00000537C000 - 000005E00000], size: 000000A84000 Partition: param, [000005E00000 - 000006800000], size: 000000A00000 Partition: efs, [000006800000 - 000007600000], size: 000000E00000 Partition: modemst1, [000007600000 - 000007900000], size: 000000300000 Partition: modemst2, [000007900000 - 000007C00000], size: 000000300000 Partition: boot, [000007C00000 - 000008900000], size: 000000D00000 Partition: recovery, [000008900000 - 000009800000], size: 000000F00000 Partition: fota, [000009800000 - 00000A480400], size: 000000C80400 Partition: backup, [00000A480400 - 00000AB7E000], size: 0000006FDC00 Partition: fsc, [00000AB7E000 - 00000AE7E000], size: 000000300000 Partition: ssd, [00000AE7E000 - 00000AE80000], size: 000000002000 Partition: persist, [00000AE80000 - 00000B680000], size: 000000800000 Partition: persistent, [00000B680000 - 00000B700000], size: 000000080000 Partition: persdata, [00000B700000 - 00000C000000], size: 000000900000 Partition: system, [00000C000000 - 00008E000000], size: 000082000000 Partition: cache, [00008E000000 - 00009A800000], size: 00000C800000 Partition: hidden, [00009A800000 - 00009EE00000], size: 000004600000 Partition: userdata, [00009EE00000 - 0001D1FFBE00], size: 0001331FBE00 GPT header successfully parsed Get firmware version Brand = samsung Manufacturer = samsung Model = SM-J500F Phone platform = msm8916 CPU Abi = armeabi-v7a Android release = 5.1.1 Firmware version = LMY48B.J500FXXU1AOH2 Firmware date = Thu Aug 13 14:19:56 KST 2015 |
try to write latest FW |
Finally my phone has been revive with this dump file, SK Hynix_Dump_ 100%_Tested_SM-J500F_(LMY48B.J500FXWU1AOJ2-5.1.1-LMY48B)[H8G4u_35E3C581] Download, Link 1 Link 2 Link 3 1'st create backup security area, just erase eMMC then write the dump https://i.imgur.com/592aOMd.png eMMC_tool Suite ver. 1.6.2.0 (release date: 30.06.2019) Microsoft Windows 7 (32 bit) build 7601 (6.1.7600.16385) Setting interface to EasyJtag2/ISP Setting bus width to 1 Bit Setting frequence to 12 MHz CMD Pullup Level: 2132 mV CMD Active Level: 2626 mV EMMC Device Information : EMMC CID: 90014A4838473475920119E4950E44EF EMMC CSD: D02701320F5903FFFFFFFFE78A40002B EMMC Manufacture : SKHYNIX , EMMC NAME: H8G4u , HEX: 483847347500 , S/N: 19E4950E , rev. 0x01 EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Date: 4/2017 EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 146890 , Response: Not Clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01) Boot configuration [PARTITION_CONFIG]: 0x00 , Boot from: no boot Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x01 Backup saved: H8G4u_19E4950E_20200523_234359.extcsd EMMC Init completed. Scanning soft partitions GPT header is found and is valid Partition: apnhlos, [000000400000 - 000001300000], size: 000000F00000 (15.0 MB) Partition: modem, [000001300000 - 000004C70000], size: 000003970000 (57.4 MB) Partition: sbl1, [000004C70000 - 000004CF0000], size: 000000080000 (512. KB) Partition: ddr, [000004CF0000 - 000004CF8000], size: 000000008000 (32.0 KB) Partition: aboot, [000004CF8000 - 000004EF8000], size: 000000200000 (2.00 MB) Partition: rpm, [000004EF8000 - 000004F78000], size: 000000080000 (512. KB) Partition: qsee, [000004F78000 - 000004FF8000], size: 000000080000 (512. KB) Partition: qhee, [000004FF8000 - 000005078000], size: 000000080000 (512. KB) Partition: fsg, [000005078000 - 000005378000], size: 000000300000 (3.00 MB) Partition: sec, [000005378000 - 00000537C000], size: 000000004000 (16.0 KB) Partition: pad, [00000537C000 - 000005E00000], size: 000000A84000 (10.5 MB) Partition: param, [000005E00000 - 000006800000], size: 000000A00000 (10.0 MB) Partition: efs, [000006800000 - 000007600000], size: 000000E00000 (14.0 MB) Partition: modemst1, [000007600000 - 000007900000], size: 000000300000 (3.00 MB) Partition: modemst2, [000007900000 - 000007C00000], size: 000000300000 (3.00 MB) Partition: boot, [000007C00000 - 000008900000], size: 000000D00000 (13.0 MB) Partition: recovery, [000008900000 - 000009800000], size: 000000F00000 (15.0 MB) Partition: fota, [000009800000 - 00000A480400], size: 000000C80400 (12.5 MB) Partition: backup, [00000A480400 - 00000AB7E000], size: 0000006FDC00 (6.99 MB) Partition: fsc, [00000AB7E000 - 00000AE7E000], size: 000000300000 (3.00 MB) Partition: ssd, [00000AE7E000 - 00000AE80000], size: 000000002000 (8.00 KB) Partition: persist, [00000AE80000 - 00000B680000], size: 000000800000 (8.00 MB) Partition: persistent, [00000B680000 - 00000B700000], size: 000000080000 (512. KB) Partition: persdata, [00000B700000 - 00000C000000], size: 000000900000 (9.00 MB) Partition: system, [00000C000000 - 00008E000000], size: 000082000000 (2.03 GB) Partition: cache, [00008E000000 - 00009A800000], size: 00000C800000 (200. MB) Partition: hidden, [00009A800000 - 00009EE00000], size: 000004600000 (70.0 MB) Partition: userdata, [00009EE00000 - 0001D1FFBE00], size: 0001331FBE00 (4.80 GB) GPT header successfully parsed Get firmware version Brand = samsung Manufacturer = samsung Device = j5lte Model = SM-J500F Phone platform = msm8916 CPU Abi = armeabi-v7a Android release = 5.1.1 Firmware version = LMY48B.J500FXXU1AOH2 Firmware date = Thu Aug 13 14:19:56 KST 2015 Setting interface to EasyJtag2/ISP Setting bus width to 1 Bit Setting frequence to 12 MHz CMD Pullup Level: 2133 mV CMD Active Level: 2628 mV EMMC Device Information : EMMC CID: 90014A4838473475920119E4950E44EF EMMC CSD: D02701320F5903FFFFFFFFE78A40002B EMMC Manufacture : SKHYNIX , EMMC NAME: H8G4u , HEX: 483847347500 , S/N: 19E4950E , rev. 0x01 EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Date: 4/2017 EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 146890 , Response: Not Clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01) Boot configuration [PARTITION_CONFIG]: 0x00 , Boot from: no boot Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x01 Backup saved: H8G4u_19E4950E_20200523_234529.extcsd EMMC Init completed. Operation: Erasing eMMC... Erasing for: ROM1 , start: 0x000000000000 , size: 0x0001D2000000 eMMC switching to ROM1 Erasing partition... Done erasing partition. Setting interface to EasyJtag2/ISP Setting bus width to 1 Bit Setting frequence to 18 MHz CMD Pullup Level: 2133 mV CMD Active Level: 2626 mV EMMC Device Information : EMMC CID: 90014A4838473475920119E4950E44EF EMMC CSD: D02701320F5903FFFFFFFFE78A40002B EMMC Manufacture : SKHYNIX , EMMC NAME: H8G4u , HEX: 483847347500 , S/N: 19E4950E , rev. 0x01 EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Date: 4/2017 EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 146890 , Response: Not Clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01) Boot configuration [PARTITION_CONFIG]: 0x00 , Boot from: no boot Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x01 Backup saved: H8G4u_19E4950E_20200523_235322.extcsd EMMC Init completed. Operation: Writing all eMMC Regions... Operation: Writing BootConfig ... Reg: 179 Value: 0x00 Reg: 177 Value: 0x00 Reg: 162 Value: 0x00 Done Writing to: ROM2 , start: 0x000000000000 , size: 0x000000400000 Filename: boot1.bin eMMC switching to ROM2 Writing partition... Done writing partition. Write speed: 867.65 KB/s Writing to: ROM3 , start: 0x000000000000 , size: 0x000000400000 Filename: boot2.bin eMMC switching to ROM3 Writing partition... Done writing partition. Write speed: 851.69 KB/s Writing to: ROM1 , start: 0x000000000000 , size: 0x000040000000 Filename: userarea_1GiB.bin eMMC switching to ROM1 Writing partition... Done writing partition. Write speed: 2072.32 KB/s All done time: [00:08:38:000] Setting interface to EasyJtag2/ISP Setting bus width to 1 Bit Setting frequence to 18 MHz CMD Pullup Level: 2130 mV CMD Active Level: 2625 mV EMMC Device Information : EMMC CID: 90014A4838473475920119E4950E44EF EMMC CSD: D02701320F5903FFFFFFFFE78A40002B EMMC Manufacture : SKHYNIX , EMMC NAME: H8G4u , HEX: 483847347500 , S/N: 19E4950E , rev. 0x01 EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Date: 4/2017 EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 146890 , Response: Not Clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01) Boot configuration [PARTITION_CONFIG]: 0x00 , Boot from: no boot Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x01 Backup saved: H8G4u_19E4950E_20200524_000211.extcsd EMMC Init completed. Scanning soft partitions GPT header is found and is valid Partition: apnhlos, [000000400000 - 000001300000], size: 000000F00000 (15.0 MB) Partition: modem, [000001300000 - 000004C70000], size: 000003970000 (57.4 MB) Partition: sbl1, [000004C70000 - 000004CF0000], size: 000000080000 (512. KB) Partition: ddr, [000004CF0000 - 000004CF8000], size: 000000008000 (32.0 KB) Partition: aboot, [000004CF8000 - 000004EF8000], size: 000000200000 (2.00 MB) Partition: rpm, [000004EF8000 - 000004F78000], size: 000000080000 (512. KB) Partition: qsee, [000004F78000 - 000004FF8000], size: 000000080000 (512. KB) Partition: qhee, [000004FF8000 - 000005078000], size: 000000080000 (512. KB) Partition: fsg, [000005078000 - 000005378000], size: 000000300000 (3.00 MB) Partition: sec, [000005378000 - 00000537C000], size: 000000004000 (16.0 KB) Partition: pad, [00000537C000 - 000005E00000], size: 000000A84000 (10.5 MB) Partition: param, [000005E00000 - 000006800000], size: 000000A00000 (10.0 MB) Partition: efs, [000006800000 - 000007600000], size: 000000E00000 (14.0 MB) Partition: modemst1, [000007600000 - 000007900000], size: 000000300000 (3.00 MB) Partition: modemst2, [000007900000 - 000007C00000], size: 000000300000 (3.00 MB) Partition: boot, [000007C00000 - 000008900000], size: 000000D00000 (13.0 MB) Partition: recovery, [000008900000 - 000009800000], size: 000000F00000 (15.0 MB) Partition: fota, [000009800000 - 00000A480400], size: 000000C80400 (12.5 MB) Partition: backup, [00000A480400 - 00000AB7E000], size: 0000006FDC00 (6.99 MB) Partition: fsc, [00000AB7E000 - 00000AE7E000], size: 000000300000 (3.00 MB) Partition: ssd, [00000AE7E000 - 00000AE80000], size: 000000002000 (8.00 KB) Partition: persist, [00000AE80000 - 00000B680000], size: 000000800000 (8.00 MB) Partition: persistent, [00000B680000 - 00000B700000], size: 000000080000 (512. KB) Partition: persdata, [00000B700000 - 00000C000000], size: 000000900000 (9.00 MB) Partition: system, [00000C000000 - 00008E000000], size: 000082000000 (2.03 GB) Partition: cache, [00008E000000 - 00009A800000], size: 00000C800000 (200. MB) Partition: hidden, [00009A800000 - 00009EE00000], size: 000004600000 (70.0 MB) Partition: userdata, [00009EE00000 - 0001D1FFB000], size: 0001331FB000 (4.80 GB) GPT header successfully parsed Get firmware version Brand = samsung Manufacturer = samsung Device = j5lte Model = SM-J500F Phone platform = msm8916 CPU Abi = armeabi-v7a Android release = 5.1.1 Firmware version = LMY48B.J500FXWU1AOJ2 Firmware date = Tue Oct 6 14:22:11 KST 2015 Setting interface to EasyJtag2/ISP Setting bus width to 1 Bit Setting frequence to 18 MHz CMD Pullup Level: 2139 mV CMD Active Level: 2628 mV EMMC Device Information : EMMC CID: 90014A4838473475920119E4950E44EF EMMC CSD: D02701320F5903FFFFFFFFE78A40002B EMMC Manufacture : SKHYNIX , EMMC NAME: H8G4u , HEX: 483847347500 , S/N: 19E4950E , rev. 0x01 EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Date: 4/2017 EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 146890 , Response: Not Clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01) Boot configuration [PARTITION_CONFIG]: 0x00 , Boot from: no boot Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x01 Backup saved: H8G4u_19E4950E_20200524_001132.extcsd EMMC Init completed. Scanning soft partitions GPT header is found and is valid Partition: apnhlos, [000000400000 - 000001300000], size: 000000F00000 (15.0 MB) Partition: modem, [000001300000 - 000004C70000], size: 000003970000 (57.4 MB) Partition: sbl1, [000004C70000 - 000004CF0000], size: 000000080000 (512. KB) Partition: ddr, [000004CF0000 - 000004CF8000], size: 000000008000 (32.0 KB) Partition: aboot, [000004CF8000 - 000004EF8000], size: 000000200000 (2.00 MB) Partition: rpm, [000004EF8000 - 000004F78000], size: 000000080000 (512. KB) Partition: qsee, [000004F78000 - 000004FF8000], size: 000000080000 (512. KB) Partition: qhee, [000004FF8000 - 000005078000], size: 000000080000 (512. KB) Partition: fsg, [000005078000 - 000005378000], size: 000000300000 (3.00 MB) Partition: sec, [000005378000 - 00000537C000], size: 000000004000 (16.0 KB) Partition: pad, [00000537C000 - 000005E00000], size: 000000A84000 (10.5 MB) Partition: param, [000005E00000 - 000006800000], size: 000000A00000 (10.0 MB) Partition: efs, [000006800000 - 000007600000], size: 000000E00000 (14.0 MB) Partition: modemst1, [000007600000 - 000007900000], size: 000000300000 (3.00 MB) Partition: modemst2, [000007900000 - 000007C00000], size: 000000300000 (3.00 MB) Partition: boot, [000007C00000 - 000008900000], size: 000000D00000 (13.0 MB) Partition: recovery, [000008900000 - 000009800000], size: 000000F00000 (15.0 MB) Partition: fota, [000009800000 - 00000A480400], size: 000000C80400 (12.5 MB) Partition: backup, [00000A480400 - 00000AB7E000], size: 0000006FDC00 (6.99 MB) Partition: fsc, [00000AB7E000 - 00000AE7E000], size: 000000300000 (3.00 MB) Partition: ssd, [00000AE7E000 - 00000AE80000], size: 000000002000 (8.00 KB) Partition: persist, [00000AE80000 - 00000B680000], size: 000000800000 (8.00 MB) Partition: persistent, [00000B680000 - 00000B700000], size: 000000080000 (512. KB) Partition: persdata, [00000B700000 - 00000C000000], size: 000000900000 (9.00 MB) Partition: system, [00000C000000 - 00008E000000], size: 000082000000 (2.03 GB) Partition: cache, [00008E000000 - 00009A800000], size: 00000C800000 (200. MB) Partition: hidden, [00009A800000 - 00009EE00000], size: 000004600000 (70.0 MB) Partition: userdata, [00009EE00000 - 0001D1FFB000], size: 0001331FB000 (4.80 GB) GPT header successfully parsed Get firmware version Brand = samsung Manufacturer = samsung Device = j5lte Model = SM-J500F Phone platform = msm8916 CPU Abi = armeabi-v7a Android release = 5.1.1 Firmware version = LMY48B.J500FXWU1AOJ2 Firmware date = Tue Oct 6 14:22:11 KST 2015 Setting interface to EasyJtag2/ISP Setting bus width to 1 Bit Setting frequence to 18 MHz CMD Pullup Level: 2139 mV CMD Active Level: 2624 mV EMMC Device Information : EMMC CID: 90014A4838473475920119E4950E44EF EMMC CSD: D02701320F5903FFFFFFFFE78A40002B EMMC Manufacture : SKHYNIX , EMMC NAME: H8G4u , HEX: 483847347500 , S/N: 19E4950E , rev. 0x01 EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Date: 4/2017 EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 146890 , Response: Not Clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01) Boot configuration [PARTITION_CONFIG]: 0x00 , Boot from: no boot Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x01 Backup saved: H8G4u_19E4950E_20200524_001150.extcsd EMMC Init completed. Operation: Try to read table from emmc Vendor: Qualcomm Searching GPT ... GPT header is found and is valid Checking for ROM2 ... ROM2 is blank Checking for ROM3 ... ROM3 is blank GPT header successfully parsed Setting interface to EasyJtag2/ISP Setting bus width to 1 Bit Setting frequence to 18 MHz CMD Pullup Level: 2136 mV CMD Active Level: 2623 mV EMMC Device Information : EMMC CID: 90014A4838473475920119E4950E44EF EMMC CSD: D02701320F5903FFFFFFFFE78A40002B EMMC Manufacture : SKHYNIX , EMMC NAME: H8G4u , HEX: 483847347500 , S/N: 19E4950E , rev. 0x01 EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Date: 4/2017 EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 146890 , Response: Not Clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01) Boot configuration [PARTITION_CONFIG]: 0x00 , Boot from: no boot Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x01 Backup saved: H8G4u_19E4950E_20200524_001347.extcsd EMMC Init completed. Operation: Write by vendor (Qualcomm/HiSilicon/Omap) Partition name: fsg Filename: fsg.bin , Offset: 000005078000 , filesize: 3145728 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1204.67 KB/s Partition name: efs Filename: efs.bin , Offset: 000006800000 , filesize: 14680064 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 2074.66 KB/s Partition name: modemst1 Filename: modemst1.bin , Offset: 000007600000 , filesize: 3145728 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 2048.98 KB/s Partition name: modemst2 Filename: modemst2.bin , Offset: 000007900000 , filesize: 3145728 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 2000.38 KB/s Partition name: fsc Filename: fsc.bin , Offset: 00000AB7E000 , filesize: 3145728 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 2008.01 KB/s Partition name: persist Filename: persist.bin , Offset: 00000AE80000 , filesize: 8388608 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 2053.43 KB/s Check BootConfig for the selected vendor All done time: [00:00:32:237] Finally flash with this firmware J500FXXU1AOH2_ J500FOJV1AOH1_V5.1.1_Repair_Firmware_4Files_( XFV South Africa (Vodafone) Download, Link 1 Link 2 Link 3 https://i.imgur.com/pfUhDYl.jpg https://i.imgur.com/QiDuken.jpg https://i.imgur.com/vhUhtH8.jpg https://i.imgur.com/uE7MxKX.jpg |
thanks very goood its work |
