11-06-2018, 16:00 | #1 (permalink) |
Freak Poster Join Date: Jul 2013
Member: 1980910 Status: Offline Sonork: 100.1650130 Thanks Meter: 35 | GT-N8000 Can't connect to easy jtag but octoplus works fine OS ver.: Windows 10 (build 17134), 64-bit edition. Admin rights OK Android Explorer ver:1.0.0.13 Autorun Agent ver:1.0.0.0 Crash Reporting ver:1.4.0.3 eMMC Odin ver:1.0.0.6 QUALCOMM Direct ver:1.0.6688.36675 Android ADB API ver:2.0.0.0 FTDI API ver:3.2.4.0 LibUSB API ver:1.2.6.0 Visual C++ Runtime ver:10.0.30319.1 Setting box Pinout ... Box Drivers version: 0.0.0.0, may affect on box performance. Z3X Card Serial : AXXX-XXXF , ver: 22 Z3X Card Activation [JTAGPLUS] : NOT ACTIVATED Z3X Card Activation [LG] : NOT ACTIVATED Z3X Card Activation [SAMS] : ACTIVATED Z3X Card Activation [JTAG] : ACTIVATED Found 3 serial devices COM6 USB\VID_0325&PID_0032&REV_0100&MI_00 Easy Jtag Control Port (COM6) COM1 ACPI\VEN_PNP&DEV_0501 Communications Port (COM1) COM2 ACPI\VEN_PNP&DEV_0501 Communications Port (COM2) Selected pinout: EasyJTAG GEN1 ISP Pinout Change EasyJTAG Pinout OK Cant Connect any Phone giving cmd error and on octoplus emmc box connect ok with same connection... please help Easy Jtag Connect With all volt option & Clock Rate Found 3 serial devices COM6 USB\VID_0325&PID_0032&REV_0100&MI_00 Easy Jtag Control Port (COM6) COM1 ACPI\VEN_PNP&DEV_0501 Communications Port (COM1) COM2 ACPI\VEN_PNP&DEV_0501 Communications Port (COM2) Selected pinout: EasyJTAG GEN1 ISP Pinout Change EasyJTAG Pinout OK Compression is ON Z3X EasyJtag Software ver. 3.3.0.0 Loading eMMC GEN1 Firmware... IO: 3300 mV Box S/N: 1212171610F7FF01, ,FW Ver.: 01.63 CMD Pullup Level:814 mV CMD Active Level:2423 mV Box IO Level:3300 mV CLK Rate:21000 kHz Bus Width:1bit,SDR HiPower mode is ON! Can't init device, Reason: CMD Ready Timeout Error [Box Internal Failure] Done. Connect With Octoplus Model Settings: Interface : eMMC Brand : Samsung Model : GT-N8000 SRF : C:/Android/Box/Octoplus/Octoplus Pro JTAG Software/firmwareFolder/SAMSUNG_GT-N8000_EMMC_MAG2GA.srf Voltage : 2.0V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Samsung eMMC MAG2GA Page size : 512 B Block size : 512 B Block count : 30777344 Size : 14.68 GB (15028.00 MB) --------------------------------------------------------------- CID Info CID : 1501004D414732474107DA8A3B208F4B Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : MAG2GA Full name : KLMAG2GE2A-A001 Product revision : 0.7 Product serial number : (hex) DA8A3B20 Manufacturing date : 08/2012 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFFF8A404007 CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.5 (for MMC v4.41) Erase block size : 512 Kbytes Boot1 size : 2048 Kbytes Boot2 size : 2048 Kbytes RPMB size : 128 Kbytes Partition config : (0x48) 01001000 Boot partition enable : Boot partition 1 (Bus width = 4Bit) Boot ACK : Boot acknowledge sent during boot operation Bit Boot bus conditions : (0x01) 00000001 Boot bus width : x4 (sdr/ddr) bus width in boot operation mode Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x00) RST_n signal is temporary disabled (default) Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 7659520 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info... Not found --------------------------------------------------------------- Backup EXT_CSD saved to file C:/Android/Box/Octoplus/Octoplus Pro JTAG Software/EXT_CSD Backups/MAG2GA_06_11_2018_19_13_14.bin. Connect successful. --------------------------------------------------------------- SW: 1.6.9; FW: 1.24. P00: PART_EE (00000001, 01D59FFF) 14.68 GB Selected pit file: C:/Users/Adeeba/Desktop/note10.pit Open file "C:/Users/Adeeba/Desktop/GT-N8000_INU_1_20140612192230_chapm6qyga_fac/BL_N8000XXUDNE6_1813067_REV00_user_low_ship.tar.md 5". Open file "C:/Users/Adeeba/Desktop/GT-N8000_INU_1_20140612192230_chapm6qyga_fac/AP_N8000XXUDNE6_1813067_REV00_user_low_ship.tar.md 5". Open file "C:/Users/Adeeba/Desktop/GT-N8000_INU_1_20140612192230_chapm6qyga_fac/MODEM_N8000DDUCNE2_REV_00_CL1603814.tar.md5". Open file "C:/Users/Adeeba/Desktop/GT-N8000_INU_1_20140612192230_chapm6qyga_fac/CSC_ODD_N8000ODDDNE4_1813067_REV00_user_low_ship.t ar.md5". Writing MBR...Done. Writing primary GPT...Done. Writing secondary GPT... ERROR[012]: Write error. At sector 30777311. Disconnected. please help |
11-06-2018, 22:01 | #2 (permalink) | |
Product Supporter Join Date: Jun 2002 Location: Belarus Age: 47
Member: 13148 Status: Offline Thanks Meter: 2,948 | Quote:
2) Disable Hipower mode if it no use 3) Reduce Freqence from 21 to 14Mhz or low | |
The Following 3 Users Say Thank You to layder For This Useful Post: |
