11-06-2018, 09:32 | #1 (permalink) |
Junior Member Join Date: Oct 2018
Member: 2874213 Status: Offline Thanks Meter: 9 | SM-J700F dead boot CMD Pullup Level: 484 mV CMD Active Level: 2093 mV EMMC Device Information : EMMC CID: 1101003430303037330046B341D0B2E0 EMMC CSD: D07E00320F5903FFFFFFFFE78A4000D0 EMMC Manufacture : TOSHIBA , EMMC NAME: 400073 , HEX: 343030303733 , S/N: 46B341D0 , rev. 0x00 EMMC Manufacture ID: 0x11 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 11/2015 EMMC ROM 1 (Main User Data) Capacity: 15028 MB (0003AB400000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01) Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1) Boot Bus Config: 0x01 , width 4bit H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: 400073_46B341D0_20181106_111713.extcsd EMMC Init completed. Operation: Write by vendor (Samsung) Creating GPT-partitioninig Writing PrimaryGPT at address: 000000000000 Writing BackupGPT at address: 0003AB3FBE00 Writing PIT at address: 000000004400 GPT-partitioning done Unpacking file: cm.bin Unpacking file: sboot.bin Partition name: CM Filename: cm.bin , Offset: 000000000000 , filesize: 2113808 bytes eMMC switching to ROM3 Erasing partition... Writing partition... Done writing partition. Write speed: 338.75 KB/s Partition name: BOOTLOADER Filename: sboot.bin , Offset: 000000000000 , filesize: 1618192 bytes eMMC switching to ROM2 Erasing partition... Writing partition... Done writing partition. Write speed: 333.51 KB/s Check BootConfig for the selected vendor All done time: [00:00:37:152] Setting frequence to 14 Mhz CMD Pullup Level: 474 mV CMD Active Level: 2103 mV EMMC Device Information : EMMC CID: 1101003430303037330046B341D0B2E0 EMMC CSD: D07E00320F5903FFFFFFFFE78A4000D0 EMMC Manufacture : TOSHIBA , EMMC NAME: 400073 , HEX: 343030303733 , S/N: 46B341D0 , rev. 0x00 EMMC Manufacture ID: 0x11 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 11/2015 EMMC ROM 1 (Main User Data) Capacity: 15028 MB (0003AB400000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01) Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1) Boot Bus Config: 0x01 , width 4bit H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: 400073_46B341D0_20181106_112245.extcsd EMMC Init completed. Scanning soft partitions GPT header is found and is valid Partition: bota0, [000000400000 - 000000800000], size: 000000400000 (4.00 MB) Partition: bota1, [000000800000 - 000000C00000], size: 000000400000 (4.00 MB) Partition: efs, [000000C00000 - 000002000000], size: 000001400000 (20.0 MB) Partition: cpefs, [000002000000 - 000002800000], size: 000000800000 (8.00 MB) Partition: m9kefs1, [000002800000 - 000002C00000], size: 000000400000 (4.00 MB) Partition: m9kefs2, [000002C00000 - 000003000000], size: 000000400000 (4.00 MB) Partition: m9kefs3, [000003000000 - 000003400000], size: 000000400000 (4.00 MB) Partition: carrier, [000003400000 - 000003500000], size: 000000100000 (1.00 MB) Partition: param, [000003500000 - 000003D00000], size: 000000800000 (8.00 MB) Partition: boot, [000003D00000 - 000005D00000], size: 000002000000 (32.0 MB) Partition: recovery, [000005D00000 - 000008300000], size: 000002600000 (38.0 MB) Partition: ota, [000008300000 - 000008B00000], size: 000000800000 (8.00 MB) Partition: cdma-radio, [000008B00000 - 000008F00000], size: 000000400000 (4.00 MB) Partition: radio, [000008F00000 - 00000E700000], size: 000005800000 (88.0 MB) Partition: tombstones, [00000E700000 - 00000E800000], size: 000000100000 (1.00 MB) Partition: dnt, [00000E800000 - 00000E900000], size: 000000100000 (1.00 MB) Partition: persistent, [00000E900000 - 00000E980000], size: 000000080000 (512. KB) Partition: persdata, [00000E980000 - 00000F580000], size: 000000C00000 (12.0 MB) Partition: reserved2, [00000F580000 - 00000F800000], size: 000000280000 (2.50 MB) Partition: system, [00000F800000 - 000093000000], size: 000083800000 (2.05 GB) Partition: cache, [000093000000 - 00009F800000], size: 00000C800000 (200. MB) Partition: hidden, [00009F800000 - 0000A2000000], size: 000002800000 (40.0 MB) Partition: userdata, [0000A2000000 - 0003AB3FBE00], size: 0003093FBE00 (12.1 GB) GPT header successfully parsed Get firmware version Brand = samsung Manufacturer = samsung Model = SM-J700F Phone platform = exynos5 CPU Abi = armeabi-v7a Android release = 5.1.1 Firmware version = LMY48B.J700FXXU1AOL2 Firmware date = Thu Dec 17 12:59:54 KST 2015 |
