12-07-2018, 17:32 | #1 (permalink) |
Freak Poster Join Date: Jan 2011 Location: Dhaka,Bangladesh Age: 40
Member: 1505853 Status: Offline Thanks Meter: 19 | SM-J700H dead boot repair problem here is screenshot............ |
12-07-2018, 17:46 | #2 (permalink) | |
Product Supporter Join Date: Mar 2013 Location: JTAG/eMMC/UFS
Member: 1902789 Status: Offline Thanks Meter: 1,101 | Quote:
1st carefully recheck or resold all wire from adapter to pcb then re check, if get same error then do next.... 1. Try to Write eMMC Firmware using eMMC Part Number...(if supported then possible only) 2. Reprogram eMMC for ur Samsung SM-J700H.. Last edited by Pijush Das; 12-07-2018 at 17:55. | |
12-07-2018, 18:09 | #3 (permalink) |
Member: 1505853 Status: Offline Thanks Meter: 19 | Hellow bro,i re-check solder or all wire is 100% ok & same result. i try to Write eMMC FW but not supported. emmc number- KLMAG1JENB-B031. how to solve? |
12-08-2018, 06:18 | #4 (permalink) | |
Need eMMC Firmware "KLMAG1JENB-B031.bin" So, if you have same eMMC then just Dump eMMC firmware & then put KLMAG1JENB-B031.bin file into "C:\Program Files\Z3X\EASYJTAG\eMMC Firmware" Directory & then try again | |
