11-03-2018, 14:01 | #1 (permalink) |
Junior Member Join Date: Oct 2018
Member: 2874213 Status: Offline Thanks Meter: 9 | sm-j701 dead boot done. CMD Pullup Level: 1247 mV CMD Active Level: 2371 mV EMMC Device Information : EMMC CID: 150100414A5444345200C09FB41C15F6 EMMC CSD: D02701320F5903FFF6DBFFEF8E40400C EMMC Manufacture : SAMSUNG , EMMC NAME: AJTD4R , HEX: 414A54443452 , S/N: C09FB41C , rev. 0x00 EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 1/2018 EMMC ROM 1 (Main User Data) Capacity: 15028 MB (0003AB400000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 KB (000001000000) EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1) Boot Bus Config: 0x01 , width 4bit H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: AJTD4R_C09FB41C_20181103_154830.extcsd EMMC Init completed. Operation: Write by vendor (Samsung) Creating GPT-partitioninig Writing PrimaryGPT at address: 000000000000 Writing BackupGPT at address: 0003AB3FBE00 Writing PIT at address: 000000004400 GPT-partitioning done Unpacking file: cm.bin Unpacking file: sboot.bin Unpacking file: param.bin Unpacking file: boot.img Unpacking file: recovery.img Unpacking file: modem.bin Partition name: CM Filename: cm.bin , Offset: 000000000000 , filesize: 2445584 bytes eMMC switching to ROM3 Erasing partition... Writing partition... Done writing partition. Write speed: 433.06 KB/s Partition name: BOOTLOADER Filename: sboot.bin , Offset: 000000000000 , filesize: 1728784 bytes eMMC switching to ROM2 Erasing partition... Writing partition... Done writing partition. Write speed: 445.49 KB/s Partition name: PARAM Filename: param.bin , Offset: 000003500000 , filesize: 849920 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 610.03 KB/s Partition name: BOOT Filename: boot.img , Offset: 000003D00000 , filesize: 18112800 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 946.28 KB/s Partition name: RECOVERY Filename: recovery.img , Offset: 000005D00000 , filesize: 20508960 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 950.54 KB/s Partition name: RADIO Filename: modem.bin , Offset: 000008B00000 , filesize: 38409424 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 951.36 KB/s Partition USERDATA : formatting as EXT4. Please wait ... Formatting completed Check BootConfig for the selected vendor All done time: [00:02:14:034] Setting frequence to 14 Mhz CMD Pullup Level: 1340 mV CMD Active Level: 2402 mV EMMC Device Information : EMMC CID: 150100414A5444345200C09FB41C15F6 EMMC CSD: D02701320F5903FFF6DBFFEF8E40400C EMMC Manufacture : SAMSUNG , EMMC NAME: AJTD4R , HEX: 414A54443452 , S/N: C09FB41C , rev. 0x00 EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 1/2018 EMMC ROM 1 (Main User Data) Capacity: 15028 MB (0003AB400000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 KB (000001000000) EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1) Boot Bus Config: 0x01 , width 4bit H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: AJTD4R_C09FB41C_20181103_155212.extcsd EMMC Init completed. Scanning soft partitions GPT header is found and is valid Partition: bota0, [000000400000 - 000000800000], size: 000000400000 (4.00 MB) Partition: bota1, [000000800000 - 000000C00000], size: 000000400000 (4.00 MB) Partition: efs, [000000C00000 - 000002000000], size: 000001400000 (20.0 MB) Partition: cpefs, [000002000000 - 000002800000], size: 000000800000 (8.00 MB) Partition: m9kefs1, [000002800000 - 000002C00000], size: 000000400000 (4.00 MB) Partition: m9kefs2, [000002C00000 - 000003000000], size: 000000400000 (4.00 MB) Partition: m9kefs3, [000003000000 - 000003400000], size: 000000400000 (4.00 MB) Partition: carrier, [000003400000 - 000003500000], size: 000000100000 (1.00 MB) Partition: param, [000003500000 - 000003D00000], size: 000000800000 (8.00 MB) Partition: boot, [000003D00000 - 000005D00000], size: 000002000000 (32.0 MB) Partition: recovery, [000005D00000 - 000008300000], size: 000002600000 (38.0 MB) Partition: ota, [000008300000 - 000008B00000], size: 000000800000 (8.00 MB) Partition: radio, [000008B00000 - 00000E300000], size: 000005800000 (88.0 MB) Partition: tombstones, [00000E300000 - 00000E400000], size: 000000100000 (1.00 MB) Partition: persistent, [00000E400000 - 00000E480000], size: 000000080000 (512. KB) Partition: steady, [00000E480000 - 00000E880000], size: 000000400000 (4.00 MB) Partition: reserved2, [00000E880000 - 00000F000000], size: 000000780000 (7.50 MB) Partition: system, [00000F000000 - 0000CF000000], size: 0000C0000000 (3.00 GB) Partition: cache, [0000CF000000 - 0000DB800000], size: 00000C800000 (200. MB) Partition: hidden, [0000DB800000 - 0000E1C00000], size: 000006400000 (100. MB) Partition: cp_debug, [0000E1C00000 - 0000E2100000], size: 000000500000 (5.00 MB) Partition: nad_fw, [0000E2100000 - 0000E3500000], size: 000001400000 (20.0 MB) Partition: nad_refer, [0000E3500000 - 0000E3600000], size: 000000100000 (1.00 MB) Partition: userdata, [0000E3600000 - 0003AB3FBE00], size: 0002C7DFBE00 (11.1 GB) GPT header successfully parsed Get firmware version Brand = samsung Manufacturer = samsung Model = SM-J701F Phone platform = exynos5 CPU Abi = armeabi-v7a Android release = 7.0 Firmware version = NRD90M.J701FXXU3AQL2 Firmware date = Fri Dec 8 18:13:37 KST 2017 |
The Following User Says Thank You to EMMC PT KING For This Useful Post: |
11-03-2018, 15:03 | #2 (permalink) |
Member: 2874213 Status: Offline Thanks Meter: 9 | sm-j701f info Setting frequence to 14 Mhz CMD Pullup Level: 917 mV CMD Active Level: 2145 mV EMMC Device Information : EMMC CID: 150100424A54443452004EC9FE6235C6 EMMC CSD: D02701320F5903FFF6DBFFEF8E40400C EMMC Manufacture : SAMSUNG , EMMC NAME: BJTD4R , HEX: 424A54443452 , S/N: 4EC9FE62 , rev. 0x00 EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 3/2018 EMMC ROM 1 (Main User Data) Capacity: 29820 MB (000747C00000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 KB (000001000000) EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1) Boot Bus Config: 0x01 , width 4bit H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: BJTD4R_4EC9FE62_20181103_170239.extcsd EMMC Init completed. Scanning soft partitions GPT header is found and is valid Partition: BOTA0, [000000400000 - 000000800000], size: 000000400000 (4.00 MB) Partition: BOTA1, [000000800000 - 000000C00000], size: 000000400000 (4.00 MB) Partition: EFS, [000000C00000 - 000002000000], size: 000001400000 (20.0 MB) Partition: CPEFS, [000002000000 - 000002800000], size: 000000800000 (8.00 MB) Partition: m9kefs1, [000002800000 - 000002C00000], size: 000000400000 (4.00 MB) Partition: m9kefs2, [000002C00000 - 000003000000], size: 000000400000 (4.00 MB) Partition: m9kefs3, [000003000000 - 000003400000], size: 000000400000 (4.00 MB) Partition: CARRIER, [000003400000 - 000003500000], size: 000000100000 (1.00 MB) Partition: PARAM, [000003500000 - 000003D00000], size: 000000800000 (8.00 MB) Partition: BOOT, [000003D00000 - 000005D00000], size: 000002000000 (32.0 MB) Partition: RECOVERY, [000005D00000 - 000008300000], size: 000002600000 (38.0 MB) Partition: OTA, [000008300000 - 000008B00000], size: 000000800000 (8.00 MB) Partition: RADIO, [000008B00000 - 00000E300000], size: 000005800000 (88.0 MB) Partition: TOMBSTONES, [00000E300000 - 00000E400000], size: 000000100000 (1.00 MB) Partition: PERSISTENT, [00000E400000 - 00000E480000], size: 000000080000 (512. KB) Partition: STEADY, [00000E480000 - 00000E880000], size: 000000400000 (4.00 MB) Partition: RESERVED2, [00000E880000 - 00000F000000], size: 000000780000 (7.50 MB) Partition: SYSTEM, [00000F000000 - 0000CF000000], size: 0000C0000000 (3.00 GB) Partition: CACHE, [0000CF000000 - 0000DB800000], size: 00000C800000 (200. MB) Partition: HIDDEN, [0000DB800000 - 0000E1C00000], size: 000006400000 (100. MB) Partition: CP_DEBUG, [0000E1C00000 - 0000E2100000], size: 000000500000 (5.00 MB) Partition: NAD_FW, [0000E2100000 - 0000E3500000], size: 000001400000 (20.0 MB) Partition: NAD_REFER, [0000E3500000 - 0000E3600000], size: 000000100000 (1.00 MB) Partition: USERDATA, [0000E3600000 - 000747600000], size: 000664000000 (25.5 GB) GPT header successfully parsed Get firmware version Brand = samsung Manufacturer = samsung Model = SM-J701F Phone platform = exynos5 CPU Abi = armeabi-v7a Android release = 8.1.0 Firmware version = M1AJQ.J701FXXU6BRI9 Firmware date = Wed Sep 19 11:28:40 KST 2018 |
10-24-2020, 01:29 | #4 (permalink) | |
No Life Poster Join Date: Apr 2008 Location: <<heaven>> Age: 43
Member: 754364 Status: Offline Thanks Meter: 59 | EMMC NAME: AJTD4R EMMC NAME: BJTD4R emmc replice ? did you solve the problem by replacing emmc? Quote:
