Old 01-10-2018, 08:41   #1 (permalink)
kothamamun's Avatar
Member: 2556542
Thanks Meter: 1,790
sony c1904 error every time help please
Old 01-10-2018, 08:45   #2 (permalink)
kothamamun's Avatar
Member: 2556542
Thanks Meter: 1,790
Compression is ON
Z3X EasyJtag Software ver. 2.9.0.0
Loading eMMC GEN1 Firmware... IO: 1850 mV
Box S/N: 0500D01E3BC5A469, ,FW Ver.: 01.62
CMD Pullup Level:897 mV
CMD Active Level:11830 mV
Box IO Level:1850 mV
CLK Rate:14000 kHz
Bus Width:1bit,SDR
HiPower mode is off!
Can't init device, Reason: OCR Ready Timeout Error [Check VCC or eMMC DEAD]
Done.
Old 01-10-2018, 13:52   #3 (permalink)
Member: 1625192
Sonork: 100.1657037
Thanks Meter: 256
Originally Posted by kothamamun View Post
Compression is ON
CLK Rate:14000 kHz
Bus Width:1bit,SDR
Done.
This problem is only for VCC, VCCQ
(Last EMMC DEAD)
Old 01-12-2018, 07:13   #4 (permalink)
kothamamun's Avatar
Member: 2556542
Thanks Meter: 1,790
(Last EMMC DEAD)
phone problem is decrypt storage password
Old 01-13-2018, 07:19   #5 (permalink)
kothamamun's Avatar
Member: 2556542
Thanks Meter: 1,790
after install old version show this
Compression is ON
Z3X EasyJtag Software ver. 2.6.0.1
Box S/N: xxxxxxxxx, ,FW Ver.: 01.62
CMD Pullup Level:1742 mV
CMD Active Level:1815 mV
CLK Rate:14000 khz
Can't init device, Reason: CMD Timeout Error
Done.
Old 01-13-2018, 07:23   #6 (permalink)
kothamamun's Avatar
Member: 2556542
Thanks Meter: 1,790
Compression is ON
Loading eMMC GEN1 Firmware... IO: 2800 mV
CMD Pullup Level:2072 mV
CMD Active Level:2433 mV
Box IO Level:2800 mV
CLK Rate:14000 khz
---------- eMMC Device Information ----------
EMMC CID : 45010053454D3034472808888BCA90A4
EMMC CSD : D00F00320F5903FFFFFFFDFF8A4040A6
EMMC Manufacturer ID: 0045 , OEM ID: 0100
EMMC Date: 09/2013 Rev.0x28
EMMC NAME: SEM04G , S/N: 143166410
EMMC NAME (HEX): 53454D30344700
EMMC ROM1 (Main User Data) Capacity: 3776 MB
EMMC ROM2 (Boot Partition 1) Capacity: 2048 kB
EMMC ROM3 (Boot Partition 2) Capacity: 2048 kB
EMMC RPMB (Replay Protected Memory Block) Capacity: 2048 kB
EMMC Permanent Write Protection: No
EMMC Temporary Write Protection: No
EMMC Password Locked: No
Extended CSD rev 1.6 (MMC 4.5)
Boot configuration [PARTITION_CONFIG: 0x00] No boot partition configured.
Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x00.
H/W reset function [RST_N_FUNCTION]: 0x00
High-capacity W protect group size [HC_WP_GRP_SIZE: 0x00000000]
Partitioning Support [PARTITIONING_SUPPORT]: 0x01
Device support partitioning feature
Device cannot have enhanced tech.
Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00
Backup saved: SEM04G_ 143166410_20180112_2222.extcsd
Done.
Old 01-13-2018, 07:35   #7 (permalink)
kothamamun's Avatar
Member: 2556542
Thanks Meter: 1,790
Skip loading eMMC Addon Firmware
CMD Pullup Level:2041 mV
CMD Active Level:2423 mV
Length limit is enabled!
Input file : C:\Users\ktha\Desktop\Sony_C1904_emmc_direct_dump\ EMMC_ROM1_00000000_08000000.bin
Writing 0000000200 bytes to 0000000000... ROM1 (USER ROM)
Done. Write Speed: 3 kB/s
Input file : C:\Users\ktha\Desktop\Sony_C1904_emmc_direct_dump\ EMMC_ROM2_00000000_00200000.bin
Writing 0000200000 bytes to 0000000000 ...ROM2 (BOOT1 ROM)
Done. Write Speed: 1600 kB/s
Input file : C:\Users\ktha\Desktop\Sony_C1904_emmc_direct_dump\ EMMC_ROM3_00000000_00200000.bin
Writing 0000200000 bytes to 0000000000 ...ROM3 (BOOT2 ROM)
Old 01-13-2018, 08:52   #8 (permalink)
kothamamun's Avatar
Member: 2556542
Thanks Meter: 1,790
still remaining password
Old 08-16-2019, 06:41   #9 (permalink)
Member: 2683704
moto XT1643
Z3X EasyJtag Software ver. 3.6.1.2
CMD Pullup Level:2650 mV
CMD Active Level:2753 mV
CLK Rate:21000 kHz
Bus Width:1bit,SDR
Done.
Old 08-16-2019, 06:42   #10 (permalink)
kothamamun's Avatar
Member: 2556542
Thanks Meter: 1,790
CLK Rate:21000 kHz
Bus Width:1bit,SDR
Done.
check all connection andselect 2.8 io usb connection nedded
Old 08-20-2019, 10:03   #11 (permalink)
Member: 2129060
Thanks Meter: 13
c1904
use sony pc companion bro to restore your firmware, instead of using jtag
Page generated in 0.17425 seconds with 9 queries
