sp320 dead I wanted to unlock the Lg sp320, and load the firmware US60112c_00_NAO_US_OP_0409, after that the phone died. This is what I have done to try to revive it 1.-Format 2.-write the dump rom1, rom2, rom3 and extcsd 3.- write by vendro, lg and load the latest firmware version, tick, repartition and erase and loading extcsd but the phone does not turn on or enter downloading mode, only the PC recognizes it in MTK mode Can someone tell me if I'm missing something or that I'm doing something wrong |
Share read text Sent from my Redmi Note 5 using Tapatalk |
Setting interface to EasyJtag2/E-Socket Setting bus width to 8 Bit Setting frequence to 42 Mhz EMMC Device Information : EMMC CID: 150100514536334D4203C701D0927585 EMMC CSD: D02701320F5903FFF6DBFFEF8E40400D EMMC Manufacture : SAMSUNG , EMMC NAME: QE63MB , HEX: 514536334D42 , S/N: C701D092 , rev. 0x03 EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 7/2018 EMMC ROM 1 (Main User Data) Capacity: 14910 MB (0003A3E00000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: QE63MB_C701D092_20190612_143244.extcsd EMMC Init completed. Setting interface to EasyJtag2/E-Socket Setting bus width to 8 Bit Setting frequence to 42 Mhz EMMC Device Information : EMMC CID: 150100514536334D4203C701D0927585 EMMC CSD: D02701320F5903FFF6DBFFEF8E40400D EMMC Manufacture : SAMSUNG , EMMC NAME: QE63MB , HEX: 514536334D42 , S/N: C701D092 , rev. 0x03 EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 7/2018 EMMC ROM 1 (Main User Data) Capacity: 14910 MB (0003A3E00000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: QE63MB_C701D092_20190612_143259.extcsd EMMC Init completed. Get firmware version Firmware info not found Setting interface to EasyJtag2/E-Socket Setting bus width to 8 Bit Setting frequence to 42 Mhz EMMC Device Information : EMMC CID: 150100514536334D4203C701D0927585 EMMC CSD: D02701320F5903FFF6DBFFEF8E40400D EMMC Manufacture : SAMSUNG , EMMC NAME: QE63MB , HEX: 514536334D42 , S/N: C701D092 , rev. 0x03 EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 7/2018 EMMC ROM 1 (Main User Data) Capacity: 14910 MB (0003A3E00000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: QE63MB_C701D092_20190612_143431.extcsd EMMC Init completed. Operation: Write by vendor (LG) Creating GPT-partitioninig Writing PrimaryGPT at address: 000000000000 Writing BackupGPT at address: 0003A3DFBE00 GPT-partitioning done Filename: M32010d_00_OPEN_AME_DS_OP_0922.kdz Model: LG-M320 Software: LGM320AT-00-V10w-GLOBAL-COM-SEP-22-2017+0 BuildTime: 0000-00-00 00:00:00 Total Files: 65 Unpacking files from the firmware. Please wait ... Unpack done Partition name: PRELOADER Filename: preloader_0.bin , Offset: 000000000000 , filesize: 524288 bytes eMMC switching to ROM2 Erasing partition... Writing partition... Done writing partition. Write speed: 1460,11 KB/s Partition name: LK Filename: lk_98304.bin , Offset: 000003000000 , filesize: 1048576 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 2250,23 KB/s Partition name: LK2 Filename: lk2_100352.bin , Offset: 000003100000 , filesize: 1048576 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 4890,58 KB/s Partition name: LAF Filename: laf_102400.bin , Offset: 000003200000 , filesize: 18350080 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 14074,10 KB/s Partition name: BOOT Filename: boot_160768.bin , Offset: 000004E80000 , filesize: 15728640 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 20479,20 KB/s Partition name: RECOVERY Filename: recovery_196608.bin , Offset: 000006000000 , filesize: 18350080 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 22124,23 KB/s Partition name: LOGO Filename: logo_274432.bin , Offset: 000008600000 , filesize: 1048576 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 10190,82 KB/s Partition name: LO_BAK_GO Filename: lo_bak_go_290816.bin , Offset: 000008E00000 , filesize: 1048576 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 10580,81 KB/s Partition name: SECRO Filename: secro_360448.bin , Offset: 00000B000000 , filesize: 524288 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 6633,83 KB/s Partition name: TEE1 Filename: tee1_393216.bin , Offset: 00000C000000 , filesize: 524288 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 7522,25 KB/s Partition name: TEE2 Filename: tee2_403456.bin , Offset: 00000C500000 , filesize: 524288 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 2333,04 KB/s Partition name: RCT Filename: rct_507904.bin , Offset: 00000F800000 , filesize: 524288 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 8017,49 KB/s Partition name: FACTORY Filename: factory_509952.bin , Offset: 00000F900000 , filesize: 524288 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 8076,18 KB/s Partition name: EFUSE Filename: efuse_624640.bin , Offset: 000013100000 , filesize: 524288 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 7611,07 KB/s Partition name: MD1IMG Filename: md1img_884736.bin , Offset: 00001B000000 , filesize: 17825792 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 22701,87 KB/s Partition name: MD1DSP Filename: md1dsp_933888.bin , Offset: 00001C800000 , filesize: 1048576 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 11102,97 KB/s Partition name: MD1ARM7 Filename: md1arm7_942080.bin , Offset: 00001CC00000 , filesize: 524288 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 7329,61 KB/s Partition name: MD3IMG Filename: md3img_948224.bin , Offset: 00001CF00000 , filesize: 524288 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 7217,17 KB/s Partition name: CUST Filename: cust_958464.bin , Offset: 00001D400000 , filesize: 15204352 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 21649,58 KB/s Partition name: SYSTEM Filename: system_1179648.bin , Offset: 000024000000 , filesize: 134742016 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 25848,46 KB/s Partition name: SYSTEM Filename: system_1442816.bin , Offset: 00002C080000 , filesize: 524288 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 3769,68 KB/s Partition name: SYSTEM Filename: system_1446912.bin , Offset: 00002C280000 , filesize: 132120576 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 24122,24 KB/s Partition name: SYSTEM Filename: system_1707008.bin , Offset: 000034180000 , filesize: 133169152 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 24484,58 KB/s Partition name: SYSTEM Filename: system_1967104.bin , Offset: 00003C080000 , filesize: 524288 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 6769,29 KB/s Partition name: SYSTEM Filename: system_1971200.bin , Offset: 00003C280000 , filesize: 132120576 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 24887,97 KB/s Partition name: SYSTEM Filename: system_2231296.bin , Offset: 000044180000 , filesize: 133169152 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 25179,66 KB/s Partition name: SYSTEM Filename: system_2491392.bin , Offset: 00004C080000 , filesize: 524288 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 6450,82 KB/s Partition name: SYSTEM Filename: system_2495488.bin , Offset: 00004C280000 , filesize: 132120576 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 25167,00 KB/s Partition name: SYSTEM Filename: system_2755584.bin , Offset: 000054180000 , filesize: 42467328 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 23183,34 KB/s Partition name: SYSTEM Filename: system_3014656.bin , Offset: 00005C000000 , filesize: 524288 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 6916,01 KB/s Partition name: SYSTEM Filename: system_3015680.bin , Offset: 00005C080000 , filesize: 524288 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 5776,44 KB/s Partition name: SYSTEM Filename: system_3019776.bin , Offset: 00005C280000 , filesize: 132120576 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 25037,89 KB/s Partition name: SYSTEM Filename: system_3279872.bin , Offset: 000064180000 , filesize: 9961472 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 24124,07 KB/s Partition name: SYSTEM Filename: system_3538944.bin , Offset: 00006C000000 , filesize: 524288 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 13197,47 KB/s Partition name: SYSTEM Filename: system_3539968.bin , Offset: 00006C080000 , filesize: 524288 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 12182,82 KB/s Partition name: SYSTEM Filename: system_3544064.bin , Offset: 00006C280000 , filesize: 132120576 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 25649,27 KB/s Partition name: SYSTEM Filename: system_3804160.bin , Offset: 000074180000 , filesize: 1572864 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 14626,99 KB/s Partition name: SYSTEM Filename: system_4063232.bin , Offset: 00007C000000 , filesize: 524288 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 7793,61 KB/s Partition name: SYSTEM Filename: system_4066304.bin , Offset: 00007C180000 , filesize: 133169152 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 25738,31 KB/s Partition name: SYSTEM Filename: system_4328448.bin , Offset: 000084180000 , filesize: 133169152 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 25321,47 KB/s Partition name: SYSTEM Filename: system_4590592.bin , Offset: 00008C180000 , filesize: 133169152 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 25502,64 KB/s Partition name: SYSTEM Filename: system_4852736.bin , Offset: 000094180000 , filesize: 133169152 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 25332,95 KB/s Partition name: SYSTEM Filename: system_5114880.bin , Offset: 00009C180000 , filesize: 133169152 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 25376,71 KB/s Partition name: SYSTEM Filename: system_5377024.bin , Offset: 0000A4180000 , filesize: 133169152 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 25644,05 KB/s Partition name: SYSTEM Filename: system_5639168.bin , Offset: 0000AC180000 , filesize: 133169152 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 25534,93 KB/s Partition name: SYSTEM Filename: system_5901312.bin , Offset: 0000B4180000 , filesize: 133169152 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 25546,93 KB/s Partition name: SYSTEM Filename: system_6163456.bin , Offset: 0000BC180000 , filesize: 133169152 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 25507,69 KB/s Partition name: SYSTEM Filename: system_6425600.bin , Offset: 0000C4180000 , filesize: 133169152 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 25531,51 KB/s Partition name: SYSTEM Filename: system_6687744.bin , Offset: 0000CC180000 , filesize: 133169152 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 25585,72 KB/s Partition name: SYSTEM Filename: system_6949888.bin , Offset: 0000D4180000 , filesize: 133169152 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 25431,45 KB/s Partition name: SYSTEM Filename: system_7212032.bin , Offset: 0000DC180000 , filesize: 133169152 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 25506,61 KB/s Partition name: SYSTEM Filename: system_7474176.bin , Offset: 0000E4180000 , filesize: 133169152 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 25582,15 KB/s Partition name: SYSTEM Filename: system_7734272.bin , Offset: 0000EC080000 , filesize: 524288 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 10777,29 KB/s Partition name: SYSTEM Filename: system_7738368.bin , Offset: 0000EC280000 , filesize: 132120576 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 25553,77 KB/s Partition name: SYSTEM Filename: system_7998464.bin , Offset: 0000F4180000 , filesize: 133169152 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 24598,44 KB/s Partition name: SYSTEM Filename: system_8258560.bin , Offset: 0000FC080000 , filesize: 524288 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 5175,08 KB/s Partition name: SYSTEM Filename: system_8262656.bin , Offset: 0000FC280000 , filesize: 132120576 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 25705,80 KB/s Partition name: SYSTEM Filename: system_8522752.bin , Offset: 000104180000 , filesize: 113770496 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 25516,19 KB/s Partition name: SYSTEM Filename: system_8781824.bin , Offset: 00010C000000 , filesize: 524288 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 9013,19 KB/s Partition name: SYSTEM Filename: system_9043968.bin , Offset: 000114000000 , filesize: 524288 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 11117,39 KB/s Partition name: SYSTEM Filename: system_9047040.bin , Offset: 000114180000 , filesize: 132644864 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 25627,80 KB/s Partition name: LAFBAK Filename: lafbak_10354688.bin , Offset: 00013C000000 , filesize: 18350080 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 24688,19 KB/s Partition name: OP_T Filename: 0_op_open_ame_ds.img , Offset: 00013E000000 , filesize: 117440512 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 26506,24 KB/s Partition USERDATA : formatting as EXT4. Please wait ... Formatting completed |
Someone help? Which is the process to repair a LG dead? i Need just to load latest firmware or i need to load dump ? |
Check video by easyjtag repair boot sp320 done Video |
Check video by easyjtag repair boot sp320 done Videohttps://m.youtube.com/watch?feature=&v=b9wdODXTvxY |
hi need dump file for this model sp320 can you share it tnx.... |
