Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Easy-Jtag
Old 06-13-2019, 00:17   #1 (permalink)
Member: 2895768
Thanks Meter: 6
sp320 dead
I wanted to unlock the Lg sp320, and load the firmware US60112c_00_NAO_US_OP_0409, after that the phone died.
This is what I have done to try to revive it
1.-Format
2.-write the dump rom1, rom2, rom3 and extcsd
3.- write by vendro, lg and load the latest firmware version, tick, repartition and erase and loading extcsd
but the phone does not turn on or enter downloading mode, only the PC recognizes it in MTK mode
Can someone tell me if I'm missing something or that I'm doing something wrong
Old 06-13-2019, 00:19   #2 (permalink)
Member: 2875229
Thanks Meter: 7
Share read text
Sent from my Redmi Note 5 using Tapatalk
Old 06-13-2019, 01:14   #3 (permalink)
Member: 2895768
Thanks Meter: 6
Setting interface to EasyJtag2/E-Socket
Setting bus width to 8 Bit
Setting frequence to 42 Mhz
EMMC Device Information :
EMMC CID: 150100514536334D4203C701D0927585
EMMC CSD: D02701320F5903FFF6DBFFEF8E40400D
EMMC Manufacture : SAMSUNG , EMMC NAME: QE63MB , HEX: 514536334D42 , S/N: C701D092 , rev. 0x03
EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 7/2018
EMMC ROM 1 (Main User Data) Capacity: 14910 MB (0003A3E00000)
EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000)
EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000)
EMMC Permanent Write Protection: No
EMMC Temporary Write Protection: No
Extended CSD Information :
Extended CSD rev: 1.8 (MMC 5.1)
Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1)
Boot Bus Config: 0x00 , width 1bit
H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled
Supported partition features [PARTITIONING_SUPPORT]: 0x07
Device supports partitioning features
Device can have enhanced technological features in partitions and user data area
Device can have extended partitions attribute
Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00
Backup saved: QE63MB_C701D092_20190612_143244.extcsd
EMMC Init completed.
Backup saved: QE63MB_C701D092_20190612_143259.extcsd
Get firmware version
Firmware info not found
Backup saved: QE63MB_C701D092_20190612_143431.extcsd
Operation: Write by vendor (LG)
Creating GPT-partitioninig
Writing PrimaryGPT at address: 000000000000
Writing BackupGPT at address: 0003A3DFBE00
GPT-partitioning done
Filename: M32010d_00_OPEN_AME_DS_OP_0922.kdz
Model: LG-M320
Software: LGM320AT-00-V10w-GLOBAL-COM-SEP-22-2017+0
BuildTime: 0000-00-00 00:00:00
Total Files: 65
Unpacking files from the firmware. Please wait ...
Unpack done
Partition name: PRELOADER
Filename: preloader_0.bin , Offset: 000000000000 , filesize: 524288 bytes
eMMC switching to ROM2
Erasing partition...
Writing partition...
Done writing partition. Write speed: 1460,11 KB/s
Partition name: LK
Filename: lk_98304.bin , Offset: 000003000000 , filesize: 1048576 bytes
eMMC switching to ROM1
Done writing partition. Write speed: 2250,23 KB/s
Partition name: LK2
Filename: lk2_100352.bin , Offset: 000003100000 , filesize: 1048576 bytes
Done writing partition. Write speed: 4890,58 KB/s
Partition name: LAF
Filename: laf_102400.bin , Offset: 000003200000 , filesize: 18350080 bytes
Done writing partition. Write speed: 14074,10 KB/s
Partition name: BOOT
Filename: boot_160768.bin , Offset: 000004E80000 , filesize: 15728640 bytes
Done writing partition. Write speed: 20479,20 KB/s
Partition name: RECOVERY
Filename: recovery_196608.bin , Offset: 000006000000 , filesize: 18350080 bytes
Done writing partition. Write speed: 22124,23 KB/s
Partition name: LOGO
Filename: logo_274432.bin , Offset: 000008600000 , filesize: 1048576 bytes
Done writing partition. Write speed: 10190,82 KB/s
Partition name: LO_BAK_GO
Filename: lo_bak_go_290816.bin , Offset: 000008E00000 , filesize: 1048576 bytes
Done writing partition. Write speed: 10580,81 KB/s
Partition name: SECRO
Filename: secro_360448.bin , Offset: 00000B000000 , filesize: 524288 bytes
Done writing partition. Write speed: 6633,83 KB/s
Partition name: TEE1
Filename: tee1_393216.bin , Offset: 00000C000000 , filesize: 524288 bytes
Done writing partition. Write speed: 7522,25 KB/s
Partition name: TEE2
Filename: tee2_403456.bin , Offset: 00000C500000 , filesize: 524288 bytes
Done writing partition. Write speed: 2333,04 KB/s
Partition name: RCT
Filename: rct_507904.bin , Offset: 00000F800000 , filesize: 524288 bytes
Done writing partition. Write speed: 8017,49 KB/s
Partition name: FACTORY
Filename: factory_509952.bin , Offset: 00000F900000 , filesize: 524288 bytes
Done writing partition. Write speed: 8076,18 KB/s
Partition name: EFUSE
Filename: efuse_624640.bin , Offset: 000013100000 , filesize: 524288 bytes
Done writing partition. Write speed: 7611,07 KB/s
Partition name: MD1IMG
Filename: md1img_884736.bin , Offset: 00001B000000 , filesize: 17825792 bytes
Done writing partition. Write speed: 22701,87 KB/s
Partition name: MD1DSP
Filename: md1dsp_933888.bin , Offset: 00001C800000 , filesize: 1048576 bytes
Done writing partition. Write speed: 11102,97 KB/s
Partition name: MD1ARM7
Filename: md1arm7_942080.bin , Offset: 00001CC00000 , filesize: 524288 bytes
Done writing partition. Write speed: 7329,61 KB/s
Partition name: MD3IMG
Filename: md3img_948224.bin , Offset: 00001CF00000 , filesize: 524288 bytes
Done writing partition. Write speed: 7217,17 KB/s
Partition name: CUST
Filename: cust_958464.bin , Offset: 00001D400000 , filesize: 15204352 bytes
Done writing partition. Write speed: 21649,58 KB/s
Partition name: SYSTEM
Filename: system_1179648.bin , Offset: 000024000000 , filesize: 134742016 bytes
Done writing partition. Write speed: 25848,46 KB/s
Filename: system_1442816.bin , Offset: 00002C080000 , filesize: 524288 bytes
Done writing partition. Write speed: 3769,68 KB/s
Filename: system_1446912.bin , Offset: 00002C280000 , filesize: 132120576 bytes
Done writing partition. Write speed: 24122,24 KB/s
Filename: system_1707008.bin , Offset: 000034180000 , filesize: 133169152 bytes
Done writing partition. Write speed: 24484,58 KB/s
Filename: system_1967104.bin , Offset: 00003C080000 , filesize: 524288 bytes
Done writing partition. Write speed: 6769,29 KB/s
Filename: system_1971200.bin , Offset: 00003C280000 , filesize: 132120576 bytes
Done writing partition. Write speed: 24887,97 KB/s
Filename: system_2231296.bin , Offset: 000044180000 , filesize: 133169152 bytes
Done writing partition. Write speed: 25179,66 KB/s
Filename: system_2491392.bin , Offset: 00004C080000 , filesize: 524288 bytes
Done writing partition. Write speed: 6450,82 KB/s
Filename: system_2495488.bin , Offset: 00004C280000 , filesize: 132120576 bytes
Done writing partition. Write speed: 25167,00 KB/s
Filename: system_2755584.bin , Offset: 000054180000 , filesize: 42467328 bytes
Done writing partition. Write speed: 23183,34 KB/s
Filename: system_3014656.bin , Offset: 00005C000000 , filesize: 524288 bytes
Done writing partition. Write speed: 6916,01 KB/s
Filename: system_3015680.bin , Offset: 00005C080000 , filesize: 524288 bytes
Done writing partition. Write speed: 5776,44 KB/s
Filename: system_3019776.bin , Offset: 00005C280000 , filesize: 132120576 bytes
Done writing partition. Write speed: 25037,89 KB/s
Filename: system_3279872.bin , Offset: 000064180000 , filesize: 9961472 bytes
Done writing partition. Write speed: 24124,07 KB/s
Filename: system_3538944.bin , Offset: 00006C000000 , filesize: 524288 bytes
Done writing partition. Write speed: 13197,47 KB/s
Filename: system_3539968.bin , Offset: 00006C080000 , filesize: 524288 bytes
Done writing partition. Write speed: 12182,82 KB/s
Filename: system_3544064.bin , Offset: 00006C280000 , filesize: 132120576 bytes
Done writing partition. Write speed: 25649,27 KB/s
Filename: system_3804160.bin , Offset: 000074180000 , filesize: 1572864 bytes
Done writing partition. Write speed: 14626,99 KB/s
Filename: system_4063232.bin , Offset: 00007C000000 , filesize: 524288 bytes
Done writing partition. Write speed: 7793,61 KB/s
Filename: system_4066304.bin , Offset: 00007C180000 , filesize: 133169152 bytes
Done writing partition. Write speed: 25738,31 KB/s
Filename: system_4328448.bin , Offset: 000084180000 , filesize: 133169152 bytes
Done writing partition. Write speed: 25321,47 KB/s
Filename: system_4590592.bin , Offset: 00008C180000 , filesize: 133169152 bytes
Done writing partition. Write speed: 25502,64 KB/s
Filename: system_4852736.bin , Offset: 000094180000 , filesize: 133169152 bytes
Done writing partition. Write speed: 25332,95 KB/s
Filename: system_5114880.bin , Offset: 00009C180000 , filesize: 133169152 bytes
Done writing partition. Write speed: 25376,71 KB/s
Filename: system_5377024.bin , Offset: 0000A4180000 , filesize: 133169152 bytes
Done writing partition. Write speed: 25644,05 KB/s
Filename: system_5639168.bin , Offset: 0000AC180000 , filesize: 133169152 bytes
Done writing partition. Write speed: 25534,93 KB/s
Filename: system_5901312.bin , Offset: 0000B4180000 , filesize: 133169152 bytes
Done writing partition. Write speed: 25546,93 KB/s
Filename: system_6163456.bin , Offset: 0000BC180000 , filesize: 133169152 bytes
Done writing partition. Write speed: 25507,69 KB/s
Filename: system_6425600.bin , Offset: 0000C4180000 , filesize: 133169152 bytes
Done writing partition. Write speed: 25531,51 KB/s
Filename: system_6687744.bin , Offset: 0000CC180000 , filesize: 133169152 bytes
Done writing partition. Write speed: 25585,72 KB/s
Filename: system_6949888.bin , Offset: 0000D4180000 , filesize: 133169152 bytes
Done writing partition. Write speed: 25431,45 KB/s
Filename: system_7212032.bin , Offset: 0000DC180000 , filesize: 133169152 bytes
Done writing partition. Write speed: 25506,61 KB/s
Filename: system_7474176.bin , Offset: 0000E4180000 , filesize: 133169152 bytes
Done writing partition. Write speed: 25582,15 KB/s
Filename: system_7734272.bin , Offset: 0000EC080000 , filesize: 524288 bytes
Done writing partition. Write speed: 10777,29 KB/s
Filename: system_7738368.bin , Offset: 0000EC280000 , filesize: 132120576 bytes
Done writing partition. Write speed: 25553,77 KB/s
Filename: system_7998464.bin , Offset: 0000F4180000 , filesize: 133169152 bytes
Done writing partition. Write speed: 24598,44 KB/s
Filename: system_8258560.bin , Offset: 0000FC080000 , filesize: 524288 bytes
Done writing partition. Write speed: 5175,08 KB/s
Filename: system_8262656.bin , Offset: 0000FC280000 , filesize: 132120576 bytes
Done writing partition. Write speed: 25705,80 KB/s
Filename: system_8522752.bin , Offset: 000104180000 , filesize: 113770496 bytes
Done writing partition. Write speed: 25516,19 KB/s
Filename: system_8781824.bin , Offset: 00010C000000 , filesize: 524288 bytes
Done writing partition. Write speed: 9013,19 KB/s
Filename: system_9043968.bin , Offset: 000114000000 , filesize: 524288 bytes
Done writing partition. Write speed: 11117,39 KB/s
Filename: system_9047040.bin , Offset: 000114180000 , filesize: 132644864 bytes
Done writing partition. Write speed: 25627,80 KB/s
Partition name: LAFBAK
Filename: lafbak_10354688.bin , Offset: 00013C000000 , filesize: 18350080 bytes
Done writing partition. Write speed: 24688,19 KB/s
Partition name: OP_T
Filename: 0_op_open_ame_ds.img , Offset: 00013E000000 , filesize: 117440512 bytes
Done writing partition. Write speed: 26506,24 KB/s
Partition USERDATA : formatting as EXT4. Please wait ...
Formatting completed
Old 06-14-2019, 13:25   #4 (permalink)
Member: 2895768
Thanks Meter: 6
Someone help?
Which is the process to repair a LG dead?
i Need just to load latest firmware or i need to load dump ?
Old 06-19-2019, 07:42   #5 (permalink)
kzafquiel's Avatar
Member: 1318721
Thanks Meter: 140
Check video by easyjtag repair boot sp320 done
Videohttps://*********/b9wdODXTvxY &fs=1" width="644" height="390">https://*********/b9wdODXTvxY &fs=1" />https://*********/b9wdODXTvxY ">http://www.youtube.com/watch?v=https://*********/b9wdODXTvxY
The Following User Says Thank You to kzafquiel For This Useful Post:
Old 06-19-2019, 07:49   #6 (permalink)
kzafquiel's Avatar
Member: 1318721
Thanks Meter: 140
Videohttps://m.youtube.com/watch?feature=&v=b9wdODXTvxY
Page generated in 0.14328 seconds with 7 queries
