Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Easy-Jtag
Old 02-11-2019, 21:52   #1 (permalink)
Member: 975554
Thanks Meter: 19
spi flasher help
i want to unlock bios from macbook
chip is winbond 25q64fv
is this supported?
logs
EasyJTAG SPI Flasher v 1.1.0.0
Action: Registering device insert notification...
Info: Success register device notification
Action: Initialize programmer
Info: Starting programmer with device on port COM05
Info: Clock rate ~ 14MHz
Info: Programmer initialization is successful.
Action: Auto identification.
Info: Device not found.
Action: Check device configuration.
tried to select
w25q64v
and
w25q64w
but both of thim is not detected
Old 02-12-2019, 10:32   #2 (permalink)
Member: 13148
Thanks Meter: 736
Check connection (EasyJTAG Plus box):
PIN 1 - SI (box output)
PIN 3 - SCK (box output)
PIN 5 - SO (box input)
PIN 15 - CS (box output)
PIN 17 - 1.8 - 3.3V (power from box)
PIN 20 - GND
WP - 100om to PIN 17 (VCC)
Old 02-12-2019, 11:59   #3 (permalink)
Member: 975554
Thanks Meter: 19
i folowed this
PIN 20 - GND
i flowed this sir how about the vcc and hold from rj45 should i just short it?
i used 200ohms resistor from pin 17 to WP connection
Old 02-12-2019, 17:11   #4 (permalink)
Member: 13148
Thanks Meter: 736
If you use EasyJTAG box 1-st generation (old box), you need make 1,8/3.3 power supply adapter (from RJ45 or USB)
Old 02-13-2019, 15:00   #5 (permalink)
Member: 975554
Thanks Meter: 19
i use easy jtag plus box..the black one
this is my 1st time to use spi flasher..im confused in 3.3v of this pinouts in bios chip
WP VCC HOLD..i tried to connect all of them at same pin in rj45 but its not working
also tried to connect WP to pin 17 with resistor
i also tried to put 1.8v 2.8v 3.3v in software but when i put tester in vcc pin voltage is not changing..always at 4.2v
Old 02-13-2019, 19:59   #6 (permalink)
Member: 13148
Thanks Meter: 736
I was wrote pinout to you.
You doun't need use RJ45!!!!!
Old 02-14-2019, 13:17   #7 (permalink)
Member: 1630066
Sonork: 520074
Thanks Meter: 158
i tryed many bios and spi chips from computers latptops wifi routers and dish receiver some chips detects and many of chips from list are failes to detect but those chips detects on CH341A BIOES FLASHER
i recomend to use to use CH341A PROGRAMMER for work on SPI CHIPS
Old 02-14-2019, 23:32   #8 (permalink)
Member: 13148
Thanks Meter: 736
How to connect SPI flash to EasyJTAG Plus box
You need select correct VCC from Box (1,8-2,8-3,3v)
Also you can add capacitor from VCC to GND (1-5 F)
Old 02-15-2019, 01:07   #9 (permalink)
Member: 975554
Thanks Meter: 19
thank you so much for the reply..i will try to work on this tomorow and post the result
Old 02-16-2019, 21:00   #10 (permalink)
Member: 975554
Thanks Meter: 19
finaly able to connect to the chip and its detected as w25Q64V...but i used external 2.5v power suply i dont have this capacitors and 1k resistor
the problem now is when i try to do job the software crashes..
after the read function the file is saved and then crashes
also when i try the unlock also crashes
Old 02-17-2019, 17:28   #11 (permalink)
Member: 13148
Thanks Meter: 736
Crash reports is a sended to server or not?
If it's sended, we try to fix it at next updates
Old Today, 01:58   #12 (permalink)
Member: 975554
Thanks Meter: 19
yes
yes sir i sended the crash report
Page generated in 0.19584 seconds with 8 queries
