04-15-2016, 16:55 | #1 (permalink) |
Junior Member Join Date: Jun 1999 Location: Turkey Age: 50
Member: 182 Status: Offline Thanks Meter: 0 | asus T100ta tablet pc bios help needed |
09-21-2017, 13:01 | #3 (permalink) |
Insane Poster Join Date: Apr 2015 Location: S Y R I A
Member: 2383669 Status: Offline Thanks Meter: 10 | SPI Connect Error Hello I Have Macbook Air and am trying to remove EFI I connect like in pinout shown on SPI flasher program but not detected by program so what is the problem ?? the Vcc and GND I use an ethernet cable and dissemble and connect first line and last I try also 2 different SPI one across battery and one in the back both not working Can anyone help me ?? |
10-22-2017, 21:33 | #5 (permalink) |
Junior Member Join Date: Mar 2005 Location: BY Age: 52
Member: 124147 Status: Offline Thanks Meter: 20 | Log of flashing Winbond 25Q64BV (for Susra stv-lc22t860fl) today Code: EasyJTAG SPI Flasher v 1.0.0.0 Action: Initialize programmer Info: Programmer initialization is successful. Action: Auto identification. Info: Found Winbond flash chip "W25Q64.V" (8192 kB, SPI) on easyjtag_spi. Info: Device is auto selected and confirmed. Action: Check Programmer Action: Check Device Action: Action start: Action: Unlock flash. Action: Read flash. Info: Action is SUCCESSFUL. Info: Time spent 0:25 Action: Check Programmer Action: Check Device Action: Action start: Action: Unlock flash. Info: Reading flash chip contents. Info: Reading contents from file. Action: Write to flash. Info: Reading new flash chip contents. Action: Verifying flash. Info: VERIFIED. Info: Action is SUCCESSFUL. Info: Time spent 1:00 |
The Following User Says Thank You to mcalister1972 For This Useful Post: |
10-23-2017, 12:33 | #6 (permalink) | |
Member: 2368 Status: Offline Sonork: 100.111111 Thanks Meter: 186,551 | Quote:
01-01-2018, 18:45 | #8 (permalink) | |
No Life Poster Join Date: Oct 2002 Location: tunisia
Member: 16625 Status: Offline Sonork: 1578753 Thanks Meter: 161 | Quote:
03-18-2018, 12:02 | #9 (permalink) |
No Life Poster Join Date: Sep 2007 Location: PAKISTAN
Member: 585807 Status: Offline Thanks Meter: 781 | spi flasher not found chip EasyJTAG SPI Flasher v 1.0.0.0 Action: Initialize programmer Info: Starting programmer with device on port COM32 Info: Programmer initialization is successful. Action: Auto identification. Info: Found Macronix flash chip "MX25L3205(A)" (4096 kB, SPI) on easyjtag_spi. Info: Found Macronix flash chip "MX25L3205D/MX25L3208D" (4096 kB, SPI) on easyjtag_spi. Info: Found Macronix flash chip "MX25L3206E/MX25L3208E" (4096 kB, SPI) on easyjtag_spi. Info: Found Macronix flash chip "MX25L3273E" (4096 kB, SPI) on easyjtag_spi. Info: Multiple flash chip definitions match. Info: Please specify which chip to use. flash chip mx25l3236f please update |
06-01-2018, 01:41 | #10 (permalink) | |
Freak Poster Join Date: Sep 2003 Location: FRANCE Age: 42
Member: 39679 Status: Offline Thanks Meter: 41 | Spi programming failed Need Help Quote:
Error: FAILED at 0x00000288! Expected=0xff, Found=0xfe, failed byte count from 0x00000000-0x007fffff: 0xa8b | |
09-03-2018, 12:28 | #11 (permalink) |
No Life Poster Join Date: Aug 2011
Member: 1630066 Status: Offline Sonork: 520074 Thanks Meter: 215 | where are spi pinouts i want to program bios in EasyJTAG SPI Flasher but dont know how attach there are pinuts on easy jtag TDI ,TCK ,TMS ,TDO, SRST, AND TRST BUT ON BIOS IC PINOUT NEED DO ,WP , DI ,CLK AND IO |
09-03-2018, 18:56 | #12 (permalink) |
Product Supporter Join Date: Jun 2002 Location: Belarus Age: 47
Member: 13148 Status: Online Thanks Meter: 2,948 | EasyJTAG box (color box) - at attach photo: 1 = MOSI (SI) 3 = SCK 5 = MISO (SO) 15 = #CS 20 = GND VCC - RJ45 pin 1 HOLD - RJ45 pin 1 WP - 100 Omh to RJ45 pin 1 (VCC) EasyJTAG PLUS box (b/w box) 1 = MOSI (SI) 3 = SCK 5 = MISO (SO) 15 = #CS 17+19 = VCC 20 = GND HOLD+WP - 1k resistor to PIN 17+19 (VCC) Last edited by layder; 08-18-2020 at 18:45. |
09-07-2018, 12:20 | #13 (permalink) | |
Member: 1630066 Status: Offline Sonork: 520074 Thanks Meter: 215 | Quote:
EasyJTAG SPI Flasher v 1.0.0.0 Action: Initialize programmer Info: Starting programmer with device on port COM16 Info: Clock rate ~ 16MHz Info: Programmer initialization is successful. Action: Registering device insert notification... Info: Success register device notification #box gen 0 Action: Registering device insert notification is finished Action: Check device configuration. Info: Found GigaDevice flash chip "GD25Q64(B)" (8192 kB, SPI) on easyjtag_spi. Info: Device is auto selected and confirmed. Action: Check Programmer Action: Check Device Action: Action start: Action: Unlock flash. Action: Erase flash. Info: Action is SUCCESSFUL. Info: Time spent 1:56 Action: Check Programmer Action: Check Device Action: Action start: Action: Unlock flash. Info: Reading flash chip contents. Action: Verifying flash. Info: Flash is blank. Info: Action is SUCCESSFUL. Info: Time spent 0:29 Action: Check Programmer Action: Check Device Action: Action start: Action: Unlock flash. Info: Reading flash chip contents. Info: Reading contents from file. Action: Write to flash. Info: Reading new flash chip contents. Action: Verifying flash. Info: VERIFIED. Info: Action is SUCCESSFUL. Info: Time spent 1:52 | |
02-11-2019, 21:52 | #14 (permalink) |
No Life Poster Join Date: Feb 2009 Location: inside apples a15
Member: 975554 Status: Offline Sonork: KG state:prenormal Thanks Meter: 252 | spi flasher help i want to unlock bios from macbook chip is winbond 25q64fv is this supported? logs EasyJTAG SPI Flasher v 1.1.0.0 Action: Registering device insert notification... Info: Success register device notification Action: Initialize programmer Info: Starting programmer with device on port COM05 Info: Clock rate ~ 14MHz Info: Programmer initialization is successful. Action: Auto identification. Info: Device not found. Action: Check device configuration. Info: Device not found. tried to select w25q64v and w25q64w but both of thim is not detected |
