Old 04-07-2015, 14:11   #1 (permalink)
blang's Avatar
Member: 2368
Sonork: 100.111111
Thanks Meter: 186,557
Step by step manual how to repair KMVTU000LM-B503 in pictures.
*****SCRENSHOTS KMVTU000LM REPAIR*****
DEAD EMMC:
Connect TP to GND:
LOG OF EMMC AFTER TP to GND:
REMOVE eMMC TP from GND ( Break Wire )
SELECT FIRMWARE UPDATE:
CONFIRM EMMC PART NUMBER:
FIRMWARE UPDATE DONE:
RECONNECT EMMC AND IDENTIFY
TRY TO READ SOMETHING:
The Following 25 Users Say Thank You to blang For This Useful Post:
Old 04-07-2015, 14:19   #2 (permalink)
oktay50000's Avatar
Member: 678886
Sonork: 100.1661586
Thanks Meter: 171
where is tp??...........
The Following 2 Users Say Thank You to oktay50000 For This Useful Post:
Old 04-07-2015, 14:21   #3 (permalink)
blang's Avatar
Member: 2368
Sonork: 100.111111
its not TP. its z3x magic TP
login to forum and you will see attached picture.
The Following 3 Users Say Thank You to blang For This Useful Post:
Old 04-07-2015, 14:31   #4 (permalink)
rajeshchiyyan's Avatar
Member: 1347585
Sonork: 100.1596390
Thanks Meter: 467
Here IS the MAGIC TP
The Following 4 Users Say Thank You to rajeshchiyyan For This Useful Post:
Old 04-07-2015, 14:45   #5 (permalink)
Member: 384775
Sonork: 100.1605469
Thanks Meter: 159
Z3X EasyJtag Software ver. 1.9.0.5
Loading eMMC Addon Firmware... IO: 2800 mV
Box S/N: 1818031584A59CAF, ,FW Ver.: 01.52
CMD Pullup Level:2062 mV
CMD Active Level:2382 mV
eMMC Device Information
EMMC CID : 1501005654553030300C20138686416E
EMMC CSD : D02701320F5903FFF6DBFFFF8E40406C
EMMC Manufacturer ID: 0015 , OEM ID: 0100
EMMC Date: 04/2014 Rev.0xC
EMMC NAME: VTU000 , S/N: 538150534
EMMC NAME (HEX): 56545530303000
EMMC ROM1 (Main User Data) Capacity: 15028 MB
EMMC ROM2 (Boot Partition 1) Capacity: 2048 kB
EMMC ROM3 (Boot Partition 2) Capacity: 2048 kB
EMMC RPMB (Replay Protected Memory Block) Capacity: 128 kB
EMMC Permanent Write Protection: No
EMMC Temporary Write Protection: No
Extended CSD rev 1.6 (MMC 4.5)
Boot configuration [PARTITION_CONFIG: 0x00] No boot partition configured.
Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x00.
Backup saved: VTU000_ 538150534_20150302_1643.extcsd
later
repaired log:
CMD Active Level:2392 mV
Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1)
Boot bus config [177]: 0x01 , width 4bits , Partition config [179]: 0x48.
Backup saved: VTU000_ 538150534_20150302_1644.extcsd
Done.
The Following 4 Users Say Thank You to cemalefendi For This Useful Post:
Old 04-07-2015, 15:16   #6 (permalink)
Member: 1306306
Sonork: 240888
Thanks Meter: 36
Verifying eMMC firmware fail: NO Error
please help sir..
log :
CMD Pullup Level:2145 mV
CMD Active Level:2578 mV
Setup firmware normal update mode, wait 2..30 sec...
Success!
Sending eMMC firmware...
Success!
Verifying eMMC firmware...
Done.
The Following User Says Thank You to alanic For This Useful Post:
Old 04-07-2015, 15:58   #7 (permalink)
Member: 1569669
Thanks Meter: 257
Hi,
This error:
'Verifying eMMC firmware fail: NO Error'
happend because you didn't disconnect everything from eMMC (all lines : 1.8V, 2.8V, CLK, CMD, DAT0) before making short TP to GND !!!!
Some current leakege apply from CMD, CLK, DAT0 box lines and eMMC goto wrong state, when disconnect only 1.8/2.8V power lines.
eMMC wrong state cause 'Verifying eMMC firmware fail: NO Error'
No Error - means no communication error, only firmware update error occurs.
Disconnect everything from eMMC, make short TP to GND, plug eMMC power then remove TP to GND, plug into box, make sure that eMMC Identify 000000, start update firmware again. eMMC Update Firmware should be OK this time !!!!!!!!!
DON'T FORGET TO REMOVE TP TO GND CONNECTION BEFORE FIRMWARE UPDATE, BECAUSE WILL BE SAME ERROR: 'Verifying eMMC firmware fail: NO Error' !!!!!!!!!
Regards Viktor
The Following User Says Thank You to vikboston For This Useful Post:
Old 04-07-2015, 16:47   #8 (permalink)
freeman2001's Avatar
Member: 206476
Thanks Meter: 459
Originally Posted by alanic View Post
verifying emmc firmware fail: No error
please help sir..
Log :
cmd pullup level:2145 mv
cmd active level:2578 mv
setup firmware normal update mode, wait 2..30 sec...
Success!
Sending emmc firmware...
Success!
Verifying emmc firmware...
Verifying emmc firmware fail: No error
done.
check your tp must be connected antil last operation
Old 04-07-2015, 16:51   #9 (permalink)
Member: 206476
Thanks Meter: 459
CMD Active Level:2186 mV
Success!
Success!
Success!
Flashing eMMC firmware...
Success!
Repairing eMMC CID...
Success!
eMMC firmware is updated now!
Please reconnect eMMC power lines before next operation!
Please don't forget to repair extCSD from backup!
Please don't forget to configure BOOT sizes!
Done.
rePAIR DONE
CMD Pullup Level:752 mV
Input file : D:\Documents and Settings\freeman\My Documents\Downloads\i9300\EMMC_ROM2_00000000_00200 000.bin
Writing 0000200000 bytes to 00000000 ...ROM2 (BOOT1 ROM)
Done. Write Speed: 1017 kB/s
EMMC CID : 15010056545530304DFC3D39868641FA
EMMC Date: 04/2014 Rev.0xFC
EMMC NAME: VTU00M , S/N: 1027180166
EMMC NAME (HEX): 56545530304D00
Backup saved: VTU00M_1027180166_20150302_1747.extcsd
Done.
ROM 1 OKI
ROM 2 OKI
I9300 REPAIR DEAD EMMC VIA TP WITHOUT REMOVE EMMC IN SPAIN HEEEEEEEEEEH
The Following 5 Users Say Thank You to freeman2001 For This Useful Post:
Old 04-07-2015, 18:32   #10 (permalink)
Member: 804802
Thanks Meter: 9
Success!
Success!
Success!
Success!
Success!
Done.
rePAIR DONE
Done.
ROM 1 OKI
ROM 2 OKI
but how via tp and witout remove the emmc ????
how to connect tp to gnd witout remove the emmc
the tp is under the emmc
Old 04-07-2015, 18:49   #11 (permalink)
Member: 206476
Thanks Meter: 459
The question of one million must be smart and from dreambox tp sony geniration lol
Old 04-07-2015, 22:33   #12 (permalink)
javsoft's Avatar
Member: 750419
Sonork: 100.1604828
Thanks Meter: 45
the z3x magic question , how to do tp?
Old 04-07-2015, 22:38   #13 (permalink)
shoaibrao's Avatar
Member: 412843
Sonork: 100.1604902
Thanks Meter: 497
But Bro DreamBox Sony TP On CPU
And Its Under The EMMC And EMMC Fully Glued
If You Dont Mind Will You Share Here The Answer Of One Million Ques
Old 04-08-2015, 02:08   #14 (permalink)
gerferomb's Avatar
Member: 840912
Sonork: 100.1596244
Thanks Meter: 89
What cable we use to connect TP from box?
The Following User Says Thank You to gerferomb For This Useful Post:
Old 04-08-2015, 02:10   #15 (permalink)
Member: 1279781
Thanks Meter: 67
amazing....
good job broo...
Page generated in 0.23402 seconds with 10 queries
