Step by step manual how to repair KMVTU000LM-B503 in pictures. 3 Attachment(s) *****SCRENSHOTS KMVTU000LM REPAIR***** DEAD EMMC: http://i.gyazo.com/c376f40b4a45303c755a103c10f0659a.gif Connect TP to GND: http://forum.gsmhosting.com/vbb/atta...hmentid=336465 LOG OF EMMC AFTER TP to GND: http://i.gyazo.com/1e8c12ff8298c7bde26e7fb364de16ae.gif REMOVE eMMC TP from GND ( Break Wire ) SELECT FIRMWARE UPDATE: http://i.gyazo.com/f78cd2472019a1e676cfa5ba46438767.gif CONFIRM EMMC PART NUMBER: http://i.gyazo.com/74237abca6bbb67cb08f06efb8d2f4cf.png FIRMWARE UPDATE DONE: http://i.gyazo.com/6c353259a2d534abe3661bc50b8ed83d.gif RECONNECT EMMC AND IDENTIFY http://i.gyazo.com/3367889245ba988551ea0368218ba0d0.gif TRY TO READ SOMETHING: http://i.gyazo.com/3ad1752a5cec898ebdc639ab40682e09.gif |
where is tp??........... |
login to forum and you will see attached picture. |
http://forum.gsmhosting.com/vbb/atta...9&d=1428411307 |
Z3X EasyJtag Software ver. 1.9.0.5 Loading eMMC Addon Firmware... IO: 2800 mV Box S/N: 1818031584A59CAF, ,FW Ver.: 01.52 CMD Pullup Level:2062 mV CMD Active Level:2382 mV eMMC Device Information EMMC CID : 1501005654553030300C20138686416E EMMC CSD : D02701320F5903FFF6DBFFFF8E40406C EMMC Manufacturer ID: 0015 , OEM ID: 0100 EMMC Date: 04/2014 Rev.0xC EMMC NAME: VTU000 , S/N: 538150534 EMMC NAME (HEX): 56545530303000 EMMC ROM1 (Main User Data) Capacity: 15028 MB EMMC ROM2 (Boot Partition 1) Capacity: 2048 kB EMMC ROM3 (Boot Partition 2) Capacity: 2048 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 128 kB EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD rev 1.6 (MMC 4.5) Boot configuration [PARTITION_CONFIG: 0x00] No boot partition configured. Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x00. Backup saved: VTU000_ 538150534_20150302_1643.extcsd later repaired log: Z3X EasyJtag Software ver. 1.9.0.5 Loading eMMC Addon Firmware... IO: 2800 mV Box S/N: 1818031584A59CAF, ,FW Ver.: 01.52 CMD Pullup Level:2062 mV CMD Active Level:2392 mV eMMC Device Information EMMC CID : 1501005654553030300C20138686416E EMMC CSD : D02701320F5903FFF6DBFFFF8E40406C EMMC Manufacturer ID: 0015 , OEM ID: 0100 EMMC Date: 04/2014 Rev.0xC EMMC NAME: VTU000 , S/N: 538150534 EMMC NAME (HEX): 56545530303000 EMMC ROM1 (Main User Data) Capacity: 15028 MB EMMC ROM2 (Boot Partition 1) Capacity: 2048 kB EMMC ROM3 (Boot Partition 2) Capacity: 2048 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 128 kB EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD rev 1.6 (MMC 4.5) Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x01 , width 4bits , Partition config [179]: 0x48. Backup saved: VTU000_ 538150534_20150302_1644.extcsd Done. |
Verifying eMMC firmware fail: NO Error please help sir.. log : CMD Pullup Level:2145 mV CMD Active Level:2578 mV Setup firmware normal update mode, wait 2..30 sec... Success! Sending eMMC firmware... Success! Verifying eMMC firmware... Verifying eMMC firmware fail: NO Error Done. |
Hi, This error: 'Verifying eMMC firmware fail: NO Error' happend because you didn't disconnect everything from eMMC (all lines : 1.8V, 2.8V, CLK, CMD, DAT0) before making short TP to GND !!!! Some current leakege apply from CMD, CLK, DAT0 box lines and eMMC goto wrong state, when disconnect only 1.8/2.8V power lines. eMMC wrong state cause 'Verifying eMMC firmware fail: NO Error' No Error - means no communication error, only firmware update error occurs. Disconnect everything from eMMC, make short TP to GND, plug eMMC power then remove TP to GND, plug into box, make sure that eMMC Identify 000000, start update firmware again. eMMC Update Firmware should be OK this time !!!!!!!!! DON'T FORGET TO REMOVE TP TO GND CONNECTION BEFORE FIRMWARE UPDATE, BECAUSE WILL BE SAME ERROR: 'Verifying eMMC firmware fail: NO Error' !!!!!!!!! Regards Viktor |
CMD Active Level:2186 mV Setup firmware normal update mode, wait 2..30 sec... Success! Sending eMMC firmware... Success! Verifying eMMC firmware... Success! Flashing eMMC firmware... Success! Repairing eMMC CID... Success! eMMC firmware is updated now! Please reconnect eMMC power lines before next operation! Please don't forget to repair extCSD from backup! Please don't forget to configure BOOT sizes! Done. rePAIR DONE CMD Pullup Level:752 mV CMD Active Level:2186 mV Input file : D:\Documents and Settings\freeman\My Documents\Downloads\i9300\EMMC_ROM2_00000000_00200 000.bin Writing 0000200000 bytes to 00000000 ...ROM2 (BOOT1 ROM) Done. Write Speed: 1017 kB/s eMMC Device Information EMMC CID : 15010056545530304DFC3D39868641FA EMMC CSD : D02701320F5903FFF6DBFFFF8E40406C EMMC Manufacturer ID: 0015 , OEM ID: 0100 EMMC Date: 04/2014 Rev.0xFC EMMC NAME: VTU00M , S/N: 1027180166 EMMC NAME (HEX): 56545530304D00 EMMC ROM1 (Main User Data) Capacity: 15028 MB EMMC ROM2 (Boot Partition 1) Capacity: 2048 kB EMMC ROM3 (Boot Partition 2) Capacity: 2048 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 128 kB EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD rev 1.6 (MMC 4.5) Boot configuration [PARTITION_CONFIG: 0x00] No boot partition configured. Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x00. Backup saved: VTU00M_1027180166_20150302_1747.extcsd Done. ROM 1 OKI CMD Pullup Level:752 mV CMD Active Level:2186 mV Input file : D:\Documents and Settings\freeman\My Documents\Downloads\i9300\EMMC_ROM2_00000000_00200 000.bin Writing 0000200000 bytes to 00000000 ...ROM2 (BOOT1 ROM) Done. Write Speed: 1017 kB/s ROM 2 OKI I9300 REPAIR DEAD EMMC VIA TP WITHOUT REMOVE EMMC IN SPAIN HEEEEEEEEEEH |
how to connect tp to gnd witout remove the emmc the tp is under the emmc |
The question of one million must be smart and from dreambox tp sony geniration lol |
the z3x magic question , how to do tp? |
And Its Under The EMMC And EMMC Fully Glued If You Dont Mind Will You Share Here The Answer Of One Million Ques ;) |
What cable we use to connect TP from box? |
amazing.... good job broo... |
