Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Easy-Jtag
Old 04-08-2015, 06:03   #16 (permalink)
Member: 264667
Sonork: 100.105892
Thanks Meter: 469
so i think not 2 easy work...we will remove emmc chip to work with TP????
The Following User Says Thank You to ..::AppleLinks::.. For This Useful Post:
Old 04-08-2015, 10:21   #17 (permalink)
Member: 961313
Sonork: 100.1625300
Thanks Meter: 28
z3x easyjtag software ver. 1.9.0.5
loading emmc addon firmware... Io: 2800 mv
box s/n: , ,fw ver.: 01.52
cmd pullup level:2155 mv
cmd active level:2670 mv
emmc device information
emmc cid : 1501003030303030305620110726589c
emmc csd : 902701320f5903fff6dbffef8a404022
emmc manufacturer id: 0015 , oem id: 0100
emmc date: 05/2005 rev.0x56
emmc name: 000000 , s/n: 537986854
emmc name (hex): 30303030303000
emmc rom1 (main user data) capacity: 16384 mb
emmc rom2 (boot partition 1) capacity: 512 kb
emmc rom3 (boot partition 2) capacity: 512 kb
emmc rpmb (replay protected memory block) capacity: 128 kb
emmc permanent write protection: No
emmc temporary write protection: No
extended csd rev 1.5 (mmc 4.41)
boot configuration [partition_config: 0x00] no boot partition configured.
Boot bus config [177]: 0x00 , width 1bit , partition config [179]: 0x00.
Backup saved: 000000_ 537986854_20150303_1018.extcsd
done.
Running:samsung: Emmc firmware update...
Confirmed emmc part number: Kmvtu000lm
cmd pullup level:2165 mv
setup firmware normal update mode, wait 2..30 sec...
Success!
Sending emmc firmware...
Success!
Verifying emmc firmware...
Success!
Flashing emmc firmware...
Success!
Repairing emmc cid...
Can't init device, reason: Ocr ready timeout error [emmc dead]
done.
what about this error ?
The Following User Says Thank You to Dr.Dekra For This Useful Post:
Old 04-08-2015, 10:50   #18 (permalink)
Member: 624775
Thanks Meter: 18
Z3X EasyJtag Software ver. 1.9.0.5
Loading eMMC Addon Firmware... IO: 2800 mV
Box S/N: 0B01400EE56989F0, ,FW Ver.: 01.52
CMD Pullup Level:3269 mV
CMD Active Level:3135 mV
Can't init device, Reason: OCR Ready Timeout Error [EMMC DEAD]
Done.
CMD Pullup Level:3279 mV
eMMC Device Information
EMMC CID : 1501003030303030305620110726589C
EMMC CSD : 902701320F5903FFF6DBFFEF8A404022
EMMC Manufacturer ID: 0015 , OEM ID: 0100
EMMC Date: 05/2005 Rev.0x56
EMMC NAME: 000000 , S/N: 537986854
EMMC NAME (HEX): 30303030303000
EMMC ROM1 (Main User Data) Capacity: 16384 MB
EMMC ROM2 (Boot Partition 1) Capacity: 512 kB
EMMC ROM3 (Boot Partition 2) Capacity: 512 kB
EMMC RPMB (Replay Protected Memory Block) Capacity: 128 kB
EMMC Permanent Write Protection: No
EMMC Temporary Write Protection: No
Extended CSD rev 1.5 (MMC 4.41)
Boot configuration [PARTITION_CONFIG: 0x00] No boot partition configured.
Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x00.
Backup saved: 000000_ 537986854_20150303_1640.extcsd
Done.
Running:SAMSUNG: eMMC firmware update...
Confirmed eMMC Part Number: KMVTU000LM-B503
CMD Active Level:3124 mV
Setup firmware normal update mode, wait 2..30 sec...
Success!
Sending eMMC firmware...
Success!
Verifying eMMC firmware...
Success!
Flashing eMMC firmware...
Success!
Repairing eMMC CID...
Can't init device, Reason: CMD Timeout Error
Done.
Success!
Success!
Success!
Success!
Success!
eMMC firmware is updated now!
Please reconnect eMMC power lines before next operation!
Please don't forget to repair extCSD from backup!
Please don't forget to configure BOOT sizes!
Done.
Nice update...
The Following User Says Thank You to kococos For This Useful Post:
Old 04-08-2015, 10:57   #19 (permalink)
Member: 1569669
Thanks Meter: 250
"setup firmware normal update mode, wait 2..30 sec...
Success!
Success!
Success!
Success!
done."
Hi,
"This solution can repair 90% dead KMVTU000LM-B503 eMMC"
This error means that eMMC can not be repaired only with
firmware update. Probably eMMC internal block mapping area damaged
or eMMC hw fail.
Best Regards
The Following 3 Users Say Thank You to vikboston For This Useful Post:
Old 04-08-2015, 11:11   #20 (permalink)
Member: 961313
Sonork: 100.1625300
Thanks Meter: 28
my problem solved
can't init device, reason: Ocr ready timeout error [emmc dead]
done.
done.
Z3x easyjtag software ver. 1.9.0.5
loading emmc addon firmware... Io: 3300 mv
box s/n: 07ffd00b044beaae, ,fw ver.: 01.52
cmd active level:2681 mv
Backup saved: 000000_ 537986854_20150303_1105.extcsd
done.
Confirmed emmc part number: Kmvtu000lm-b503
cmd pullup level:2186 mv
cmd active level:3176 mv
Success!
Success!
Verifying emmc firmware fail: No error
done.
cmd pullup level:2175 mv
cmd active level:3196 mv
Success!
Success!
Success!
Success!
Success!
Emmc firmware is updated now!
Please reconnect emmc power lines before next operation!
Please don't forget to repair extcsd from backup!
Please don't forget to configure boot sizes!
Done.
cmd active level:2805 mv
emmc cid : 15010056545530304dfc3d39868641fa
emmc csd : D02701320f5903fff6dbffff8e40406c
emmc date: 04/2014 rev.0xfc
emmc name: Vtu00m , s/n: 1027180166
emmc name (hex): 56545530304d00
emmc rom1 (main user data) capacity: 15028 mb
emmc rom2 (boot partition 1) capacity: 2048 kb
emmc rom3 (boot partition 2) capacity: 2048 kb
extended csd rev 1.6 (mmc 4.5)
Backup saved: Vtu00m_1027180166_20150303_1108.extcsd
done.
i just select 3.3volt in emmc voltage
thanks for this real solution
Old 04-08-2015, 11:33   #21 (permalink)
Edocomsel's Avatar
Member: 76239
Sonork: 100.1584414
Thanks Meter: 210
Please support this type of EMMC:
Box S/N: 0606171217xxxxxx, ,FW Ver.: 01.52
CMD Pullup Level:2691 mV
CMD Active Level:2763 mV
Done.
CMD Pullup Level:2681 mV
CMD Active Level:2732 mV
EMMC ROM1 (Main User Data)   Capacity: 4095 MB
Backup saved: 000000_ 537986854_20150303_1714.extcsd
Searching for partition tables...
Read Pages Failed, Reason: CMD Timeout Error
Partitioning not detected...
Done.
CMD Pullup Level:2072 mV
CMD Active Level:2155 mV
EMMC CID : 15010053355530304D0203438A74C0F0
EMMC CSD : D02701320F5903FFF6DBFFE18E404028
EMMC Date: 12/2013 Rev.0x2
EMMC NAME: S5U00M , S/N: 54758004
EMMC NAME (HEX): 53355530304D00
EMMC ROM1 (Main User Data) Capacity: 3728 MB
EMMC ROM2 (Boot Partition 1) Capacity: 2048 kB
EMMC ROM3 (Boot Partition 2) Capacity: 2048 kB
Backup saved: S5U00M_ 54758004_20150303_1729.extcsd
Done.
EMMC NAME: S5U00M
This eMMC is not supported yet!
To force eMMC Firmware Update:
* Press and keep 'Shift' key
* Start 'SAMSUNG: eMMC Firmware Update'
* Type and press 'Confirm' eMMC Part Number
eMMC can be fully damaged, if type non-original Part Number!
Old 04-09-2015, 19:13   #22 (permalink)
Member: 961313
Sonork: 100.1625300
Thanks Meter: 28
you are the best team ...maybe it's 100%
Box S/N: 07FFD00B044BEAAE, ,FW Ver.: 01.52
CMD Pullup Level:2175 mV
CMD Active Level:2815 mV
Done.
Loading eMMC Addon Firmware... IO: 3300 mV
CMD Pullup Level:2165 mV
CMD Active Level:2670 mV
Backup saved: 000000_ 537986854_20150304_1905.extcsd
Done.
CMD Pullup Level:2186 mV
CMD Active Level:3207 mV
Success!
Success!
Success!
Success!
Success!
Done.
CMD Active Level:2805 mV
EMMC CID : 15010056545530304DFC3D39868641FA
EMMC CSD : D02701320F5903FFF6DBFFFF8E40406C
EMMC Date: 04/2014 Rev.0xFC
EMMC NAME: VTU00M , S/N: 1027180166
EMMC NAME (HEX): 56545530304D00
EMMC ROM1 (Main User Data) Capacity: 15028 MB
Extended CSD rev 1.6 (MMC 4.5)
Backup saved: VTU00M_1027180166_20150304_1908.extcsd
Done.
secand phone is ok
this vtu from n7100
Old 04-10-2015, 06:26   #23 (permalink)
mobifone's Avatar
Member: 860880
Thanks Meter: 83
kindly can somebody post video tutorial from test point to software repair step by step .
The Following User Says Thank You to mobifone For This Useful Post:
Old 04-10-2015, 12:55   #24 (permalink)
Member: 1528719
Klm8g2ff3b-b001 not suport .....
Old 04-17-2015, 13:25   #25 (permalink)
DJ Morgan's Avatar
Member: 120827
Thanks Meter: 129
Done - probably first phone in Poland repaired without removing eMMC chip
Just use very thin rounded injection needle.
Box S/N: 1300300A9980D735, ,FW Ver.: 01.52
CMD Pullup Level:2083 mV
CMD Active Level:2536 mV
Backup saved: 000000_ 537986854_20150305_1352.extcsd
Done.
CMD Active Level:2547 mV
Success!
Success!
Success!
Success!
Success!
Done.
Old 04-21-2015, 10:13   #26 (permalink)
Member: 278546
Thanks Meter: 142
yahooo. i am from india repair done 2 s3 and one note 2 , with out remove emmc . thanks to blang .now must needed box z3x jtag for every one.
Old 04-21-2015, 15:55   #27 (permalink)
Member: 63751
Thanks Meter: 9
To Mr. Blang,
i have a question for you after we finish reviving our dead emmc.
" eMMC firmware is updated now!
Please reconnect all eMMC lines before next operation!
Please don't forget to configure BOOT sizes!"
how do you configure BOOT sizes on the following eMMC?
-- S3
--Note II
etc.....
can you please show us or teach us the correct values and how do we perform it using our easy jtag program.
thank you very much and i am waiting for your reply.
Old 04-22-2015, 07:33   #28 (permalink)
Member: 278546
Thanks Meter: 142
Originally Posted by rathbone View Post
To Mr. Blang,
-- S3
--Note II
etc.....
see there . special i9300/n7100 boot config button . just press that tab to config boot .
The Following User Says Thank You to yalamandareddy For This Useful Post:
Old 04-22-2015, 08:16   #29 (permalink)
unlock in nepal's Avatar
Member: 1686564
Sonork: PM me
Thanks Meter: 152
Originally Posted by blang View Post
*****SCRENSHOTS KMVTU000LM REPAIR*****
DEAD EMMC:
Connect TP to GND:
LOG OF EMMC AFTER TP to GND:
REMOVE eMMC TP from GND ( Break Wire )
SELECT FIRMWARE UPDATE:
CONFIRM EMMC PART NUMBER:
FIRMWARE UPDATE DONE:
RECONNECT EMMC AND IDENTIFY
TRY TO READ SOMETHING:
Fore This work we nead to remove emmc ic or any spacel tp point in pcb
Old 04-22-2015, 11:09   #30 (permalink)
Member: 278546
Thanks Meter: 142
bro . make sharp needle and connect to pin .
Page generated in 0.54756 seconds with 8 queries
