Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Easy-Jtag
Old 04-23-2015, 13:27   #31 (permalink)
Member: 2381287
DJ Morgan, can you please show us how to do it with picture shots? Thank you.
Old 04-23-2015, 17:02   #32 (permalink)
unlock in nepal's Avatar
Member: 1686564
Sonork: PM me
Thanks Meter: 155
FIRMWARE UPDATE ok writing error
Z3X EasyJtag Software ver. 1.9.1.2
Loading eMMC Addon Firmware... IO: 2800 mV
Box S/N: 191911044D64DB2C, ,FW Ver.: 01.52
CMD Pullup Level:2052 mV
CMD Active Level:2629 mV
eMMC Device Information
EMMC CID : 1501003030303030305620110726589C
EMMC CSD : 902701320F5903FFF6DBFFEF8A404022
EMMC Manufacturer ID: 0015 , OEM ID: 0100
EMMC Date: 05/2005 Rev.0x56
EMMC NAME: 000000 , S/N: 537986854
EMMC NAME (HEX): 30303030303000
EMMC ROM1 (Main User Data) Capacity: 16384 MB
EMMC ROM2 (Boot Partition 1) Capacity: 512 kB
EMMC ROM3 (Boot Partition 2) Capacity: 512 kB
EMMC RPMB (Replay Protected Memory Block) Capacity: 128 kB
EMMC Permanent Write Protection: No
EMMC Temporary Write Protection: No
Extended CSD rev 1.5 (MMC 4.41)
Boot configuration [PARTITION_CONFIG: 0x00] No boot partition configured.
Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x00.
Backup saved: 000000_ 537986854_20150304_2118.extcsd
Done.
eMMC firmware update
Running:SAMSUNG: eMMC firmware update...
Confirmed eMMC Part Number: KMVTU000LM-B503
CMD Active Level:2619 mV
Setup firmware update mode, wait 2..30 sec...
Success!
Sending eMMC firmware...
Success!
Verifying eMMC firmware...
Success!
Flashing eMMC firmware...
Success!
Repairing eMMC CID...
Success!
eMMC firmware is updated now!
Please reconnect all eMMC lines before next operation!
Please don't forget to repair extCSD from backup!
Please don't forget to configure BOOT sizes!
Done.
Rading ok
Skip loading eMMC Addon Firmware
CMD Pullup Level:2031 mV
CMD Active Level:2382 mV
Output file :C:\Documents and Settings\Narayanmobile\My Documents\EMMC_ROM1_00000000_20000000.bin
Reading 0x000020000000 bytes from 0x000000000000 ...ROM1 ( USER ROM)
Done. Read Speed: 637 kB/s
writing error
Input file : C:\Documents and Settings\Narayanmobile\Desktop\I9300 Fromsupport\EMMC_ROM1_00000000_20000000.bin
Writing 0020000000 bytes to 00000000 ...ROM1 (USER ROM)
Retry writing adress 0x00000000 (Attempt #1)...
Retry Success! Disabling Write Optimistations...
Retry writing adress 0x00003E00 (Attempt #1)...
Retry writing adress 0x00007C00 (Attempt #1)...
Retry writing adress 0x0000BA00 (Attempt #1)...
Retry writing adress 0x0000F800 (Attempt #1)...
Retry writing adress 0x00011E00 (Attempt #1)...
Retry writing adress 0x00013E00 (Attempt #1)...
Retry Fail!
Retry writing adress 0x00013E00 (Attempt #2)...
Retry Fail!
Retry writing adress 0x00013E00 (Attempt #3)...
Retry Fail!
Write Block Failed, Reason: CARD Ready Timeout Error
Done.
Emmc info
EMMC CID : 15010056545530304DFC3D39868641FA
EMMC CSD : D02701320F5903FFF6DBFFFF8E40406C
EMMC Date: 04/2014 Rev.0xFC
EMMC NAME: VTU00M , S/N: 1027180166
EMMC NAME (HEX): 56545530304D00
EMMC ROM1 (Main User Data) Capacity: 15028 MB
EMMC ROM2 (Boot Partition 1) Capacity: 2048 kB
EMMC ROM3 (Boot Partition 2) Capacity: 2048 kB
Extended CSD rev 1.6 (MMC 4.5)
Backup saved: VTU00M_1027180166_20150304_2149.extcsd
Done.
Old 04-23-2015, 17:04   #33 (permalink)
Member: 1686564
Sonork: PM me
Thanks Meter: 155
Originally Posted by yalamandareddy View Post
bro . make sharp needle and connect to pin .
Fore this remmove emmc ic
Old 04-23-2015, 17:13   #34 (permalink)
Moderator
Nizda Mobile's Avatar
Member: 1464783
Thanks Meter: 1,073
Done.
Success!
Success!
Success!
Success!
Success!
Done.
Rading ok
writing error
Retry Fail!
Retry Fail!
Retry Fail!
Done.
Emmc info
Done.
set boot partition............
Nizda Mobile
Old 04-24-2015, 05:46   #35 (permalink)
Member: 1686564
Sonork: PM me
Thanks Meter: 155
Nizda Mobile
How to sate boot partiton
Old 04-24-2015, 11:18   #36 (permalink)
Moderator
Member: 1464783
Thanks Meter: 1,073
Nizda Mobile
The Following User Says Thank You to Nizda Mobile For This Useful Post:
Old 04-29-2015, 09:30   #37 (permalink)
Member: 1813698
Thanks Meter: 8
Z3X EasyJtag Software ver. 1.9.1.0
Box S/N: 0303FF1EE5A6F6B4, ,FW Ver.: 01.52
CMD Pullup Level:2114 mV
Success!
Success!
Verifying eMMC firmware fail: NO Error
Done.
Old 04-29-2015, 10:17   #38 (permalink)
Member: 1813698
Thanks Meter: 8
CMD Pullup Level:1258 mV
CMD Active Level:2650 mV
Success!
Success!
Success!
Success!
Can't init device, Reason: CMD Timeout Error
Done.
CMD Pullup Level:1227 mV
Done.
Old 05-14-2015, 17:43   #39 (permalink)
DJ Morgan's Avatar
Member: 120827
Thanks Meter: 129
Just make your own adapter, working perfect if profilled correctly
Old 05-30-2015, 21:49   #40 (permalink)
Member: 1090661
Thanks Meter: 15
cAN ANYONE GIVE ME A HAND?
Hi everyone, I am trying to fix a I9300, it has a white lcd when I try to turn it on, I can access download mode normally, I coonect 6 cables to pcb according to the pictures on z3x server. after that I am using EMMC adaptor, I plug the cable to a phone charger 5 V, and When I try to detect EMMC y get this message:
Z3X EasyJtag Software ver. 2.0.0.2
Box S/N: 1717160E617F118E, ,FW Ver.: 01.52
CMD Pullup Level:3114 mV
CMD Active Level:3196 mV
Done.
Whitout care the Voltage I select is always same answer, If I press Set i9300/i7100 Config
Running:Change BOOT CONFIG...
CMD Pullup Level:1753 mV
CMD Active Level:1815 mV
Done.
Running:Change BOOT WIDTH...
Done.
Old 06-06-2015, 14:41   #41 (permalink)
sumatera's Avatar
Member: 756701
Sonork: 100.1592286
Thanks Meter: 91
please ADD firmware emmc samsung KMK5U000VM-B309
for Gt-s7270
Z3X EasyJtag Software ver. 2.0.0.0
Loading eMMC Addon Firmware... IO: 3300 mV
Box S/N: 07070xxxxxxxxx, ,FW Ver.: 01.52
CMD Pullup Level:2145 mV
CMD Active Level:3104 mV
EMMC NAME: <b>000000</b> , S/N: 537986854
EMMC ROM1 (Main User Data) Capacity: 4095 MB
Backup saved: 000000_ 537986854_20150505_1826.extcsd
Done.
Old 06-17-2015, 05:45   #42 (permalink)
Crazy Poster
Member: 1065227
Thanks Meter: 10
Hi all,
Any chance we can set the Firmware update to not re-initialize the eMMC chip.?
In order to preserve customer / client data?
Thanks in advance.
Paolo
Old 09-01-2015, 07:56   #43 (permalink)
>>PakFones<<'s Avatar
Member: 553178
Sonork: 100.1592454
Thanks Meter: 942
Samsung i9300 totally dead EMMC repair done without removing EMMC
Hi, friends here i am going to share Samsung i9300 totally dead EMMC [KMVTU000LM-B503] repair info how i have done this without removing EMMC from board. its not easy and also not possible without special devices. its just information if you have any emmc repair device you can get much information from this post. if you have dead phone in hands and have not any professional tool you can visit our service Lab to fix that.
What we need to do this.
1= Z3X Easy Jtag
2= i9300 with dead emmc
3= special needle [shown in picture]
4= Good soldering skills
Let's start get i9300 direct emmc pinouts from support. and remove glue under emmc near TP
Solder pinouts carefully on board and emmc adapter witch come with x3x jtag insert needle and try then connect emmc adapter to easy jtag box. then try to detect emmc when you see emmc detected log in lo window you can remove needle. then start formware upgrade and follow instruction carefully given in easy jtag box log window.
some screenshots.
Complete Log
Success!
Success!
Success!
Success!
Success!
Done.
extCSD file...C:\Program Files\Z3X\EASYJTAG\Backups\000000_ 537986854_20150602_1959.extcsd
Running:Repair extCSD...
Z3X EasyJtag Software ver. 2.0.3.0
CMD Pullup Level:742 mV
CMD Active Level:2186 mV
Writing...
Done.
Box S/N: xxxxxxxxxxxx, ,FW Ver.: 01.52
CMD Active Level:2196 mV
Backup saved: VTU00M_1027180166_20150602_2001.extcsd
Done.
Writing eMMC Register...
Written: REG : 179 VAL :48
Done.
Written: REG : 177 VAL :1
Done.
Box S/N: xxxxxxxxxxx, ,FW Ver.: 01.52
Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1)
Boot bus config [177]: 0x01 , width 4bits , Partition config [179]: 0x48.
Backup saved: VTU00M_1027180166_20150602_2002.extcsd
Done.
i9300\EMMC_ROM1_00000000_20000000.bin
Done. Write Speed: 4800 kB/s
Checking NAND Image : C:\Documents and Settings\ABDUL HAKEEM\Desktop\i9300 ec dead\dump i9300\EMMC_ROM2_00000000_00200000.bin
File successefuly loaded!
Processing file...C:\Documents and Settings\ABDUL HAKEEM\Desktop\i9300 ec dead\dump i9300\EMMC_ROM2_00000000_00200000.bin
CMD Pullup Level:721 mV
CMD Active Level:1134 mV
Input file : C:\Documents and Settings\ABDUL HAKEEM\Desktop\i9300 ec dead\dump i9300\EMMC_ROM2_00000000_00200000.bin
Writing 0000200000 bytes to 00000000 ...ROM2 (BOOT1 ROM)
Done. Write Speed: 818 kB/s
Output file :C:\Documents and Settings\ABDUL HAKEEM\Desktop\i9300 ec dead\EMMC_ROM1_00000000_02000000.bin
Reading 0x000002000000 bytes from 0x000000000000 ...ROM1 ( USER ROM)
Done. Read Speed: 629 kB/s
Br,
PAK FONES
The Following 3 Users Say Thank You to >>PakFones<< For This Useful Post:
Old 09-01-2015, 08:11   #44 (permalink)
>>PakFones<<'s Avatar
Member: 553178
Sonork: 100.1592454
Thanks Meter: 942
The Following 6 Users Say Thank You to >>PakFones<< For This Useful Post:
Old 09-01-2015, 14:53   #45 (permalink)
Member: 1383093
Thanks Meter: 51
How to remove emmc ic and how to put repair or new emmc
The Following 3 Users Say Thank You to ahmc For This Useful Post:
Page generated in 0.48376 seconds with 8 queries
