Old 01-02-2016, 10:22   #61 (permalink)
Member: 2208230
Thanks Meter: 6
my easy jatg show error
Originally Posted by madgoeslim View Post
Today I got Lumia 520 "ERROR : Unable to find a bootable option. press any key to shutdown".
This ia common trouble when upgrading WP 8.0 to 8.1, and this is
very easy to Fix, by EasyJTAG
While other box failed to detect "ivalid blablabla", Easy Jtag show the power
Here's step by step how to:
1.) Solder only 4 wire : CMD, CLK, DAT0, and GND
2.) Open Easyjtag Emmc tool, n connet usb directly to pcb as power of Vcc&vccq
3. Click Emmc Tool, set eMMC Voltage to : 3,3v
Detect eMMC card, you will see in log "Emmc Permanent Write Protection : YES"
This is the problem, just click on Advanced Opt, select "SAMSUNG : remove write protection" and execute by Custom Operation -->
4. Detect Emmc Card again to see the result, the trouble maker is remove Now , ..
5. Assemble phone, and flash normally with any box u have.
And, just it, you just revive your phone back to live...
Don't forget to Thanks to EasyJTAG
i try same prossses but show this error
Z3X EasyJtag Software ver. 2.0.6.0
Loading eMMC Addon Firmware... IO: 3300 mV
Box S/N: 07070919FB06808C, ,FW Ver.: 01.52
Warning: CMD Pullup Level (0 mV) too low , check cables etc.!
CMD Active Level:0 mV
Can't init device, Reason: CMD Timeout Error
Done.
Old 01-03-2016, 17:43   #62 (permalink)
Member: 1960501
Sonork: 100.1638964
Thanks Meter: 23
check soldering properly
Old 01-06-2016, 17:33   #63 (permalink)
Member: 554917
thanks. working good
Old 01-08-2016, 11:20   #64 (permalink)
Nishan_gsm's Avatar
Member: 2429238
Sonork: 7736828392
Thanks Meter: 70
1. DO NOT USE THE PHONE"S BATTERY
2. Connect the Soldered TP Connections to ATF Box
3. Disconnect the USB Cable and Wait until the
the ATF Software will tell you to Connect the USB.
Interface Reset OK!
eMMC Access Type: SECTOR MODE
eMMC Supported Voltage Range:
3.5-3.6V, 3.4-3.5V, 3.3-3.4V, 3.2-3.3V, 3.1-3.2V
3.0-3.1V, 2.9-3.0V, 2.8-2.9V, 2.7-2.8V, 1.9-2.0V
CID : 1501004D384732594300714C655D606B
CSD : D02701320F5903FFF6DBFFEF96406007
eMMC Boot Information
Revision 1.5 (for MMC v4.41)
BOOT PARTITION : USER AREA
PARTITION ACCESS : R/W USER PARTITION
PERM_BOOT_CFG_PROT : DISABLED
PWR_BOOT_CFG_PROT : DISABLED
BOOT MODE : x1 SINGLE DATA RATE + LOW SPEED
RESET BUS WIDTH : ENABLED
eMMC FirmW UPDATE : DISABLED
EMMC CACHE SIZE : 0 KB
SUPER PAGE SIZE : 3584 KB
HC ERASE GROUP SIZE: 512 KB
USER AREA SIZE : 7818182656 BYTES
BOOT PARTITION SIZE: 4096 KB
RPMB PARTITION SIZE: 512 KB
eMMC Device Information
Manufacturer ID: SAMSUNG
Device Type : Embedded BGA
Application ID : 00
Product Name : M8G2YC
Product Rev : 0.0
Product SN : 714C655D
Manufactured : June 1997
Card Specific Data
CSD_STRUCTURE : Extended
SPEC_VERS : Version 4.1/4.2/4.3
TAAC : 13 ns
TRAN_SPEED : 4000000 KHz
READ_BL_LEN : 512 Bytes
C_SIZE : HIGH CAPACITY
WP_GRP_ENABLE : YES
WRITE_BL_LEN : 512 Bytes
CONTENT_PROT_APP : NO
PERM_WRITE_PROTECT: YES
TMP_WRITE_PROTECT : NO
Extended CSD Saved:
1501004D384732594300714C655D606B.ext_csd
Backup Directory:
C:\AdvanceBox Turbo Flasher\eMMC\EXT_CSD\
Writing MBR + GPT...
Write Success!
Writing SBL1...
Write Success!
Writing SBL2...
Write Success!
Writing SBL3...
Write Success!
Writing UEFI...
Write Success!
Writing RPM...
Write Success!
Writing TZ...
Write Success!
Writing WINSECAPP...
Write Success!
BOOT Images Written Successfully!
I try With ATF BUT Same condition
Old 01-24-2016, 17:00   #65 (permalink)
Member: 2520907
same problem with my lumia 520
sir i want to know which wire to sold and where to connect the wire?
Old 02-07-2016, 18:46   #66 (permalink)
Member: 2528253
Even i have the same problem with my lumia 520. I am unable to do all those things. please help me.
Old 02-08-2016, 10:39   #67 (permalink)
Member: 1837438
Sonork: unknown
Thanks Meter: 659
follow the first post.....100%
Old 02-12-2016, 13:52   #68 (permalink)
Member: 2505604
Thanks Meter: 12
Z3X EasyJtag Software ver. 2.0.7.0
Box S/N: 0B00D014D9806E2E, ,FW Ver.: 01.52
CMD Pullup Level:2083 mV
CMD Active Level:3073 mV
HiPower™ mode is off!
EMMC CID : 1501004D3847325943009F85C011A090
EMMC CSD : D02701320F5903FFF6DBFFEF96406006
EMMC Manufacturer ID: 0015 , OEM ID: 0100
EMMC Date: 10/2013 Rev.0x0
EMMC NAME: M8G2YC , S/N: 2676342801
EMMC NAME (HEX): 4D384732594300
Can't init EMMC, Reason: CARD Data FIFO Timeout Error
Check Data Line!
Done.
what is this error ??
Old 02-12-2016, 15:12   #69 (permalink)
Member: 2505604
Thanks Meter: 12
CMD Pullup Level:1433 mV
CMD Active Level:1588 mV
HiPower™ mode is ON!
EMMC CSD : D02701320F5903FFF6DBFFEF96404062
EMMC ROM1 (Main User Data) Capacity: 7456 MB
EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB
EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB
EMMC RPMB (Replay Protected Memory Block) Capacity: 512 kB
EMMC Permanent Write Protection: No
EMMC Temporary Write Protection: No
Extended CSD rev 1.5 (MMC 4.41)
Boot configuration [PARTITION_CONFIG: 0x38] Boot from:ROM1 (Main User Area)
Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x38.
H/W reset function [RST_N_FUNCTION]: 0x01
Backup saved: M8G2YC_2676342801_20160212_1939.extcsd
Done.
You ROCKS MAN. i repaired this ! problem was DATA0 line i solderd was shorting. i removed and again solderd properly.
Thanks EASY JTAG.
The Following User Says Thank You to comsi For This Useful Post:
Old 02-14-2016, 15:30   #70 (permalink)
Member: 715814
Sonork: 100.1662740
Thanks Meter: 2
lumia 520 done by easy jtag emmc tool
100% good solution i test now phone working well
thanks
Old 02-15-2016, 10:23   #71 (permalink)
Member: 2505604
Thanks Meter: 12
Exclamation
Done.
Thanks EASY JTAG.
after 2 days this phone again came to me same problem !!
Connecting to Target...
JTAG device: MSM8227.
CPU IDCODE : 0x4F1F0F0F Mfg.: 0x787, Part: 0xf1f0, Ver.: 0x4
CPU Manufacturer: Samsung , CPU Name: ARM7GEN
CPU IDCODE : 0x207D00E1 Mfg.: 0x070, Part: 0x07d0, Ver.: 0x2
CPU Manufacturer: QUALCOMM , CPU Name: MSM8227
Halting CPU...
Initialize hardware...
Starting target communication...
Detecting emmc memory parameters of bank (0) ...
EMMC #0 : ID : 0x00000015 Name : M8G2YC Size : 7.3 G , (15269888) Blocks
EMMC #1 : ID : 0x00000015 Name : M8G2YC Size : 4.0 M , (8192) Blocks
eMMC flash device(s) found, Device ID : 0x00150000
do i need to flash anything with jtag ??? as WRITE PROTECT was already removed !!!
Old 02-19-2016, 03:16   #72 (permalink)
Member: 2533755
Why not see your education
Old 03-14-2016, 07:06   #73 (permalink)
madgoeslim's Avatar
Member: 1853929
Sonork: 1653495
Thanks Meter: 426
Halting CPU...
For better result:
-backup extcsd and 512Mb of user partition (ROM 1)
-go to advanced tab, do factory format & reset
-go to advanced tab, do emmc firmware upgrade
-close your eyes n pray
-after success upgrade the emmc, restore extcsd, and write back your user partition (ROM1)backup
- flash with any nokia tool you have...
now your lumia will free from wp bug
Old 03-17-2016, 07:28   #74 (permalink)
NAVAKO's Avatar
Member: 1206897
Sonork: Aleandros
Thanks Meter: 34
I followed the procedure and removed the wp lock, see log:
Z3X EasyJtag Software ver. 2.0.7.3
Box S/N:xxxxxxxxxxxxxxxxxxxxxx, ,FW Ver.: 01.52
CMD Pullup Level:1381 mV
CMD Active Level:1515 mV
EMMC CID : 1501004D3847325943004FF9C06290A8
EMMC Date: 09/2013 Rev.0x0
EMMC NAME: M8G2YC , S/N: 1341767778
Backup saved: M8G2YC_1341767778_20160317_0707.extcsd
Searching for partition tables...
Detected GPT over MBR...
Medium UUID: AE420040-13DD-41F2-AE7F-0DC35854C8D7
Warning: Entries Count = 128
MMCBLK0P0 (DPP) Range: [0X200000,0X9FFE00] ,Len: 800000
MMCBLK0P1 (MODEM_FSG) Range: [0XA00000,0XCFFE00] ,Len: 300000
MMCBLK0P2 (SSD) Range: [0XE00000,0XE03E00] ,Len: 4000
MMCBLK0P3 (SBL1) Range: [0X1000000,0X1176E00] ,Len: 177000
MMCBLK0P4 (SBL2) Range: [0X1200000,0X1376E00] ,Len: 177000
MMCBLK0P5 (SBL3) Range: [0X1400000,0X15FFE00] ,Len: 200000
MMCBLK0P6 (BACKUP_UEFI) Range: [0X1600000,0X1870E00] ,Len: 271000
MMCBLK0P7 (BACKUP_RPM) Range: [0X1A00000,0X1A7CE00] ,Len: 7D000
MMCBLK0P8 (TZ) Range: [0X1C00000,0X1C7CE00] ,Len: 7D000
MMCBLK0P9 (WINSECAPP) Range: [0X1E00000,0X1E7FE00] ,Len: 80000
MMCBLK0P10 (BACKUP_SBL1) Range: [0X2000000,0X2176E00] ,Len: 177000
MMCBLK0P11 (BACKUP_SBL2) Range: [0X2200000,0X2376E00] ,Len: 177000
MMCBLK0P12 (BACKUP_SBL3) Range: [0X2400000,0X25FFE00] ,Len: 200000
MMCBLK0P13 (UEFI) Range: [0X2600000,0X2870E00] ,Len: 271000
MMCBLK0P14 (RPM) Range: [0X2A00000,0X2A7CE00] ,Len: 7D000
MMCBLK0P15 (BACKUP_TZ) Range: [0X2C00000,0X2C7CE00] ,Len: 7D000
MMCBLK0P16 (BACKUP_WINSECAPP) Range: [0X2E00000,0X2E7FE00] ,Len: 80000
MMCBLK0P17 (UEFI_BS_NV) Range: [0X3000000,0X303FE00] ,Len: 40000
MMCBLK0P18 (UEFI_NV) Range: [0X3200000,0X323FE00] ,Len: 40000
MMCBLK0P19 (PLAT) Range: [0X3400000,0X3BFFE00] ,Len: 800000
MMCBLK0P20 (EFIESP) Range: [0X4000000,0X7FFFE00] ,Len: 4000000
MMCBLK0P21 (MODEM_FS1) Range: [0X8000000,0X82FFE00] ,Len: 300000
MMCBLK0P22 (MODEM_FS2) Range: [0X8400000,0X86FFE00] ,Len: 300000
MMCBLK0P23 (UEFI_RT_NV) Range: [0X8800000,0X883FE00] ,Len: 40000
MMCBLK0P24 (UEFI_RT_NV_RPMB) Range: [0X8A00000,0X8A1FE00] ,Len: 20000
MMCBLK0P25 (MMOS) Range: [0X8C00000,0XE48E000] ,Len: 588E200
MMCBLK0P26 (MAINOS) Range: [0XE800000,0X81087400] ,Len: 72887600
MMCBLK0P27 (DATA) Range: [0X81800000,0X1D1FFBC00] ,Len: 1507FBE00
Done...Presets has been updated...
Done.
now i have phone connected in this mode:
i try to flash with windows device recovery tool but program not recognized, i have cyclone box but not have compatible firmware for this box.
Any help? thanks
Old 03-18-2016, 10:35   #75 (permalink)
Member: 2506242
Thanks Meter: 3
hi sir what is dato i have a 6 ways 3.3,clk,cmd,gnd,dd,1.8,vcc can you please show me what is dato
Page generated in 0.29039 seconds with 8 queries
