Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Easy-Jtag
Old 05-20-2014, 19:53   #1 (permalink)
drjaved_akhter's Avatar
Member: 585807
Thanks Meter: 756
Successfully repaired VTU00M name 00000000, for GT-i9300
logs
EasyJtag Suite ver.: 1.5.0.0 / wxWidgets 3.1.0-W-U started.
Operating system ver.: Windows 7 (build 7601, Service Pack 1).
Successefuly connected to box on COM3Box S/N: 1717160DCD0D8A9F, ,FW Ver.: 01.50Box Working Mode: JTAG Box.Box Drivers version: 3.0.0.0, are OK
Z3X Card Serial : AA3B-2511 , ver: 22
Z3X Card Activation [LG] : NOT ACTIVATED , ACTIVATE NOW
Z3X Card Activation [SAMS] : NOT ACTIVATED , ACTIVATE NOW
Z3X Card Activation [JTAG] : ACTIVATED
Z3X EasyJtag Software ver. 1.5.0.0
Loading eMMC Addon Firmware... IO: 1850 mV
CMD Pullup Level:1825 mV
CMD Active Level:1897 mV
eMMC Device Information
EMMC CID : 1501003030303030305620110726589C
EMMC CSD : 902701320F5903FFF6DBFFEF8A404022
EMMC Manufacturer ID: 0015 , OEM ID: 0100
EMMC Date: 05/2005 Rev.0x56
EMMC NAME: 000000 , S/N: 537986854
EMMC ROM1 (Main User Data) Capacity: 16384 MB
EMMC ROM2 (Boot Partition 1) Capacity: 512 kB
EMMC ROM3 (Boot Partition 2) Capacity: 512 kB
EMMC RPMB (Replay Protected Memory Block) Capacity: 128 kB
Extended CSD rev 1.5 (MMC 4.41)
Boot configuration [PARTITION_CONFIG: 0x00] No boot partition configured.
Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x00.
Backup saved: 000000_ 537986854_20140402_1105.extcsd
Done.
Running:SAMSUNG: MoviNAND VTU00M Name 0000 Repair...
Skip loading eMMC Addon Firmware
Start EMMC repair:
Entering repair mode 1...
Success
Erasing repair area...
Success
Writing repair area...
Success
Exit repair mode 1...
Success
Init EMMC...
Can't init EMMC, Reason: CARD Ready Timeout Error
Please, Reconnect EMMC power lines and press 'VTU00M Repair' again
CMD Pullup Level:1815 mV
CMD Active Level:1887 mV
EMMC CID : 15010056545530304DF17AA34B12AFCA
EMMC CSD : D02701320F5903FFF6DBFFFF8E40406C
EMMC Date: 10/2012 Rev.0xf1
EMMC NAME: VTU00M , S/N: 2057521938
EMMC ROM1 (Main User Data) Capacity: 15028 MB
EMMC ROM2 (Boot Partition 1) Capacity: 2048 kB
EMMC ROM3 (Boot Partition 2) Capacity: 2048 kB
Extended CSD rev 1.6 (MMC 4.5)
Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1)
Boot bus config [177]: 0x01 , width 4bits , Partition config [179]: 0x48.
Backup saved: VTU00M_2057521938_20140402_1107.extcsd
Done.
CMD Pullup Level:2660 mV
CMD Active Level:2722 mV
Start EMMC repair:
Entering repair mode 2...
Success
Success
Success
Exit repair mode 2...
Reading S.M.A.R.T
Can't init EMMC, Reason: CMD Timeout Error
Running:SAMSUNG: Read S.M.A.R.T Report...
Reading S.M.A.R.T
S.M.A.R.T Ver. 0 , Card Error mode : Normal
Super Block size : 0x00800000 (8388608 bytes)
Super Page size : 0x00004000 (16384 bytes)
Optimal Write size : 0x00010000 (65536 bytes)
Read Reclaim count : 0
Optimal TRIM size : 0x00002000 (8192 bytes)
Total Number of banks : 4
Initial bad blocks per bank : 1,1,2,15
Runtime bad blocks per bank : 0,0,0,0
Reserved blocks left per bank : 50,50,49,36
All Erase counts (min,avg,max): 0,0,1
SLC Erase counts (min,avg,max): 0,0,1
MLC Erase counts (min,avg,max): 0,0,0
S.M.A.R.T Report Done !!!
EMMC NAME: VTU00M , S/N: 537986854
Backup saved: VTU00M_2057521938_20140402_1138.extcsd
Done.
Start EMMC repair:
Success
Success
Success
Reading S.M.A.R.T
Reading S.M.A.R.T
CMD Pullup Level:1804 mV
Backup saved: VTU00M_2057521938_20140402_1139.extcsd
Done.
Writing file...E:\ALL DEVISES\z3x\9. Easy Jtag files\Samsung\GT-I9300\Dump\EMMC_ROM2_00000000_00200000.bin
Writing 000000200000 bytes to 00000000 ...ROM2 (BOOT1 ROM)
Write Speed: 819 kB/s
Done !!!
Writing file...E:\ALL DEVISES\z3x\9. Easy Jtag files\Samsung\GT-I9300\Dump\EMMC_ROM1_00000000_20000000.bin
Writing 000020000000 bytes to 00000000 ...ROM1 (USER ROM)
Write Speed: 836 kB/s
Done !!!
thanks z3x team.best in the world
The Following 7 Users Say Thank You to drjaved_akhter For This Useful Post:
Old 05-20-2014, 20:15   #2 (permalink)
Member: 585807
Thanks Meter: 756
one more
Backup saved: 000000_ 537986854_20140402_1157.extcsd
Done.
Start EMMC repair:
Success
Success
Success
Success
Init EMMC...
Success
Warning Can't enter repair mode 2, Reason: CARD Ready Timeout Error
Start EMMC repair:
Success
Success
Success
Reading S.M.A.R.T
Reading S.M.A.R.T
Initial bad blocks per bank : 3,2,2,6
Reserved blocks left per bank : 48,49,49,45
Start EMMC repair:
Success
Success
Success
Reading S.M.A.R.T
Reading S.M.A.R.T
EMMC CID : 15010056545530304DF15F0D25A19F68
EMMC Date: 09/2012 Rev.0xf1
EMMC NAME: VTU00M , S/N: 1594697121
Backup saved: VTU00M_1594697121_20140402_1201.extcsd
Done.
Write Speed: 824 kB/s
Done !!!
Done !!!
The Following 5 Users Say Thank You to drjaved_akhter For This Useful Post:
Old 05-21-2014, 00:13   #3 (permalink)
dre2's Avatar
Member: 1190283
Thanks Meter: 59
Pls.post also step by step how to do that
Tia
The Following User Says Thank You to dre2 For This Useful Post:
Old 05-21-2014, 05:25   #4 (permalink)
Mansour Pakdel's Avatar
Member: 2186335
Thanks Meter: 44
Tia
you can read sterp by step in update threath
forum.gsmhosting.com/vbb/f672/easy-jtag-update-1-5-0-0-easy-jtag-1-year-birthday-update-boom-exclusive-update-1816784/
The Following 2 Users Say Thank You to Mansour Pakdel For This Useful Post:
Old 05-21-2014, 08:25   #5 (permalink)
rasheedc007's Avatar
Member: 1245320
Sonork: 100.1612126
Thanks Meter: 138
which adapter u use for this isp write.....
The Following User Says Thank You to rasheedc007 For This Useful Post:
Old 05-21-2014, 15:14   #6 (permalink)
Member: 585807
Thanks Meter: 756
i am not use adapter .i use power in box
The Following User Says Thank You to drjaved_akhter For This Useful Post:
Old 05-21-2014, 15:49   #7 (permalink)
skyulock's Avatar
Member: 757064
Thanks Meter: 209
bro pls help me step by step......
Old 05-23-2014, 15:30   #8 (permalink)
Member: 585807
Thanks Meter: 756
after this step close software and unplug pc then plug box in pc and start exe
The Following 6 Users Say Thank You to drjaved_akhter For This Useful Post:
Old 05-23-2014, 16:37   #9 (permalink)
Member: 1245320
Sonork: 100.1612126
Thanks Meter: 138
what problam mobile when come..pls explain...
Old 05-23-2014, 17:57   #10 (permalink)
Member: 585807
Thanks Meter: 756
no power .see pic no 1 emmc name 00000
Old 05-24-2014, 03:31   #11 (permalink)
Member: 724190
Sonork: zabih
Thanks Meter: 16
please by which cable to connect explain i have gpg mmc adapter not working
Old 05-24-2014, 07:31   #12 (permalink)
blang's Avatar
Member: 2368
Sonork: 100.111111
Thanks Meter: 174,512
FAQ - Direct EMMC connect in pictures! Please stop ask again "HOW CONNECT"
Old 05-24-2014, 10:03   #13 (permalink)
skyulock's Avatar
Member: 757064
Thanks Meter: 209
bro.
thanks for this no need to write rom 1 ................................................
Old 05-24-2014, 10:11   #14 (permalink)
skyulock's Avatar
Member: 757064
Thanks Meter: 209
bro.
thanks for this.
have this no need to write rom 1 ................................................
Old 05-24-2014, 14:35   #15 (permalink)
..::Thanh_gsm::..'s Avatar
Member: 207400
Sonork: 100.1582556
Thanks Meter: 258
I'm not luck, always get dead emmc . Try 20 pcs not ok, tommorrow try more.
Loading eMMC Addon Firmware... IO: 2850 mV
Box S/N: xxxxxxxxxxxx, ,FW Ver.: 01.50
CMD Pullup Level:2805 mV
CMD Active Level:2825 mV
The Following User Says Thank You to ..::Thanh_gsm::.. For This Useful Post:
Page generated in 0.44259 seconds with 7 queries
