Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Easy-Jtag
Old 05-24-2014, 15:55   #16 (permalink)
drjaved_akhter's Avatar
Member: 585807
Thanks Meter: 757
Originally Posted by skyulock View Post
bro.
thanks for this.
have this no need to write rom 1 ................................................
if not enter download mode u want rom1 and rom2
Old 05-24-2014, 18:57   #17 (permalink)
Member: 585807
Thanks Meter: 757
gt-n7100 repair emmc name oooo
logs
Success
EMMC repair Done
Please don't forget to repair extCSD from backup!!!
Please don't forget to configure BOOT sizes!!!
Z3X EasyJtag Software ver. 1.5.1.0
Loading eMMC Addon Firmware... IO: 1850 mV
Box S/N: 1717160DCD0D8A9F, ,FW Ver.: 01.50
CMD Pullup Level:1206 mV
CMD Active Level:1598 mV
eMMC Device Information
EMMC CID : 15010056545530304DF123C502998F80
EMMC CSD : D02701320F5903FFF6DBFFFF8E40406C
EMMC Manufacturer ID: 0015 , OEM ID: 0100
EMMC Date: 08/2012 Rev.0xf1
EMMC NAME: VTU00M , S/N: 600113817
EMMC ROM1 (Main User Data) Capacity: 15028 MB
EMMC ROM2 (Boot Partition 1) Capacity: 2048 kB
EMMC ROM3 (Boot Partition 2) Capacity: 2048 kB
EMMC RPMB (Replay Protected Memory Block) Capacity: 128 kB
Extended CSD rev 1.6 (MMC 4.5)
Boot configuration [PARTITION_CONFIG: 0x00] No boot partition configured.
Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x00.
Backup saved: VTU00M_ 600113817_20140406_0944.extcsd
Done.
Writing file...E:\ALL DEVISES\z3x\9. Easy Jtag files\Samsung\GT-N7100\Dump\EMMC_00000000_00200000.bin
Skip loading eMMC Addon Firmware
Writing 000000200000 bytes to 00000000 ...ROM2 (BOOT1 ROM)
Write Speed: 824 kB/s
Done !!!
CMD Pullup Level:1185 mV
Done.
Running:Repair extCSD...
Writing...
extCSD file...C:\Program Files\Z3X\EASYJTAG\Backups\VTU00M_ 600113817_20140406_0941.extcsd
Writing...
Done!
Done.
Write Speed: 829 kB/s
Done !!!
Writing file...E:\ALL DEVISES\z3x\9. Easy Jtag files\Samsung\GT-N7100\Dump\N7100_Rom1_Alive_Dump_BN.bin
Writing 000020000000 bytes to 00000000 ...ROM1 (USER ROM)
Write Speed: 837 kB/s
Done !!!
Old 05-25-2014, 03:59   #18 (permalink)
Member: 1043356
Thanks Meter: 20
Z3X EasyJtag Software ver. 1.5.0.0
Box S/N: xxxxxxxxxxxxxxxxxxxx, ,FW Ver.: 01.50
CMD Pullup Level:2145 mV
CMD Active Level:2227 mV
Can't init EMMC, Reason: CMD Timeout Error
Done.
Old 05-25-2014, 04:18   #19 (permalink)
Member: 1043356
Thanks Meter: 20
Box S/N: xxxxxxxxxxxxxxxx, ,FW Ver.: 01.50
Warning: CMD Pullup Level (897 mV) too low , check cables etc.!!!
CMD Active Level:2000 mV
Done.
Old 05-25-2014, 13:54   #20 (permalink)
skyulock's Avatar
Member: 757064
Thanks Meter: 210
Done.
bro check soliding ...............................
Old 05-26-2014, 07:03   #21 (permalink)
Member: 4627
Sonork: 57528:debeliamark
Thanks Meter: 892
Done !!!
It's working for you? Without to configure boot partition?
Old 05-27-2014, 09:01   #22 (permalink)
Member: 585807
Thanks Meter: 757
yes working after this ................working f9
Old 05-27-2014, 09:17   #23 (permalink)
Member: 585807
Thanks Meter: 757
after confing.....................................
Old 05-28-2014, 21:48   #24 (permalink)
Member: 585807
Thanks Meter: 757
one more gt-i9300 repair
CMD Pullup Level:1237 mV
CMD Active Level:1608 mV
Repair VTU00M eMMC:
Entering repair mode 2...
Success
Erasing repair area...
Success
Writing repair area...
Success
Exit repair mode 2...
Reading S.M.A.R.T
S.M.A.R.T Ver. 0 , Card Error mode : Normal
Super Block size : 0x00800000 (8388608 bytes)
Super Page size : 0x00004000 (16384 bytes)
Optimal Write size : 0x00010000 (65536 bytes)
Read Reclaim count : 0
Optimal TRIM size : 0x00002000 (8192 bytes)
Total Number of banks : 4
Initial bad blocks per bank : 2,2,2,2
Runtime bad blocks per bank : 0,0,0,0
Reserved blocks left per bank : 49,49,49,49
All Erase counts (min,avg,max): 0,0,1
SLC Erase counts (min,avg,max): 0,0,1
MLC Erase counts (min,avg,max): 0,0,0
S.M.A.R.T Report Done !!!
Success
EMMC repair Done
extCSD file...C:\Program Files\Z3X\EASYJTAG\Backups\000000_ 537986854_20140403_1228.extcsd
Writing...
Done!
Done.
Running:Change BOOT CONFIG...
Writing eMMC Register...
Written: REG : 179 VAL :8
Done.
CMD Pullup Level:1216 mV
EMMC CID : 15010056545530304DF1E9AC06326F48
EMMC Date: 06/2012 Rev.0xf1
EMMC NAME: VTU00M , S/N: 3920365106
Boot configuration [PARTITION_CONFIG: 0x08] Boot from:ROM2 (Boot Partition 1)
Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x08.
Backup saved: VTU00M_3920365106_20140403_1236.extcsd
Done.
Writing file...E:\ALL DEVISES\z3x\9. Easy Jtag files\Samsung\GT-I9300\Dump\EMMC_ROM2_00000000_00200000.bin
Write Speed: 819 kB/s
Done !!!
Writing file...E:\ALL DEVISES\z3x\9. Easy Jtag files\Samsung\GT-I9300\Dump\EMMC_ROM1_00000000_20000000.bin
Write Speed: 836 kB/s
Done !!!
Old 06-02-2014, 20:12   #25 (permalink)
Member: 1788767
Sonork: walidjamil
Thanks Meter: 28
help me bro
help me pliz,i am trying to repair emmc 000000 but i cant cuz its saying *Reconnect eMMC power lines and press 'VTU00M Repair' again* i am reconecting but the same thing and i cant read with *read smart report*
EasyJtag Suite ver.: 1.5.2.1 / wxWidgets 3.1.0-W-U started.
Operating system ver.: Windows 7 (build 7600), 64-bit edition.
Successefuly connected to box on COM28
Box S/N: 1313031079C084EF, ,FW Ver.: 01.50
Box Working Mode: JTAG Box.
Box Drivers version: 3.0.0.0, are OK
Z3X Card Serial : AAEC-9CD5 , ver: 22
Z3X Card Activation [LG] : NOT ACTIVATED , ACTIVATE NOW
Z3X Card Activation [SAMS] : NOT ACTIVATED , ACTIVATE NOW
Z3X Card Activation [JTAG] : ACTIVATED
Z3X EasyJtag Software ver. 1.5.2.1
CMD Active Level:1619 mV
EMMC CID : 1501003030303030300C201301281062
EMMC Date: 01/2013 Rev.0xc
EMMC NAME: 000000 , S/N: 538116392
EMMC ROM2 (Boot Partition 1) Capacity: 0 kB
EMMC ROM3 (Boot Partition 2) Capacity: 0 kB
EMMC RPMB (Replay Protected Memory Block) Capacity: 0 kB
Boot configuration [PARTITION_CONFIG: 0x38] Boot from:ROM1 (Main User Area)
Boot bus config [177]: 0x14 , width 1bit , Partition config [179]: 0x38.
Backup saved: 000000_ 538116392_20140501_2008.extcsd
Done.
Running:SAMSUNG: MoviNAND VTU00M Name 0000 Repair...
Repair VTU00M eMMC:
Entering repair mode 1...
Success
Success
Success
Exit repair mode 1...
Success
NOTE: This stage was reapir only eMMC NAME , not wear leveling data!!
NOTE: Repair Stage 2 must be done to make eMMC repair completely!
Please, Reconnect eMMC power lines and press 'VTU00M Repair' again
Repair VTU00M eMMC:
Success
Success
Success
Success
logs
EasyJtag Suite ver.: 1.5.0.0 / wxWidgets 3.1.0-W-U started.
Operating system ver.: Windows 7 (build 7601, Service Pack 1).
Successefuly connected to box on COM3Box S/N: 1717160DCD0D8A9F, ,FW Ver.: 01.50Box Working Mode: JTAG Box.Box Drivers version: 3.0.0.0, are OK
Z3X Card Serial : AA3B-2511 , ver: 22
CMD Pullup Level:1825 mV
CMD Active Level:1897 mV
EMMC CID : 1501003030303030305620110726589C
EMMC CSD : 902701320F5903FFF6DBFFEF8A404022
EMMC Date: 05/2005 Rev.0x56
EMMC NAME: 000000 , S/N: 537986854
EMMC ROM1 (Main User Data) Capacity: 16384 MB
EMMC ROM2 (Boot Partition 1) Capacity: 512 kB
EMMC ROM3 (Boot Partition 2) Capacity: 512 kB
Extended CSD rev 1.5 (MMC 4.41)
Backup saved: 000000_ 537986854_20140402_1105.extcsd
Done.
Start EMMC repair:
Success
Success
Success
Success
Init EMMC...
Can't init EMMC, Reason: CARD Ready Timeout Error
Please, Reconnect EMMC power lines and press 'VTU00M Repair' again
CMD Pullup Level:1815 mV
CMD Active Level:1887 mV
EMMC CID : 15010056545530304DF17AA34B12AFCA
EMMC Date: 10/2012 Rev.0xf1
EMMC NAME: VTU00M , S/N: 2057521938
Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1)
Boot bus config [177]: 0x01 , width 4bits , Partition config [179]: 0x48.
Backup saved: VTU00M_2057521938_20140402_1107.extcsd
Done.
CMD Pullup Level:2660 mV
CMD Active Level:2722 mV
Start EMMC repair:
Success
Success
Success
Reading S.M.A.R.T
Running:SAMSUNG: Read S.M.A.R.T Report...
Reading S.M.A.R.T
Initial bad blocks per bank : 1,1,2,15
Reserved blocks left per bank : 50,50,49,36
EMMC NAME: VTU00M , S/N: 537986854
Backup saved: VTU00M_2057521938_20140402_1138.extcsd
Done.
Start EMMC repair:
Success
Success
Success
Reading S.M.A.R.T
Reading S.M.A.R.T
CMD Pullup Level:1804 mV
Backup saved: VTU00M_2057521938_20140402_1139.extcsd
Done.
Done !!!
Done !!!
thanks z3x team.best in the world
Old 06-04-2014, 20:01   #26 (permalink)
Member: 585807
Thanks Meter: 757
Done.
Repair VTU00M eMMC:
Success
Success
Success
Success
Repair VTU00M eMMC:
Success
Success
Success
Success
Old 06-05-2014, 16:57   #27 (permalink)
Member: 1769339
Sonork: 100.1627057
Thanks Meter: 12
i have gt i9300 if i put in download mode,
PRODUCT NAME:
CUSTOM BINARY DOWNLOAD: NO
can easy jtag repair ?
Old 06-06-2014, 10:09   #28 (permalink)
Member: 1741973
Thanks Meter: 109
z3x jtag repair EMMC 00000
after this step close software and unplug pc then plug box in pc and start exe
i want to know the final steps after error in 8-9 [ reading smart... cant init EMMC timedout] removed power lines after this
it is gonna repeat the procedure at step 1, detect emmc card then set to rom2 instead of repeating all steps to get the exact logs without any error?
thanks for this drjaved_akhter...
Old 06-06-2014, 17:38   #29 (permalink)
Member: 71290
Sonork: 100.1645657
Thanks Meter: 97
Thk Z3X EASY JTAG ;)
<br>
Z3X EasyJtag Software ver. 1.5.2.0
Box S/N: 161606050BBA9215, ,FW Ver.: 01.50
CMD Pullup Level:1330 mV
CMD Active Level:1753 mV
EMMC NAME: <b>000000</b> , S/N: 538116392
Backup saved: 000000_ 538116392_20140403_1338.extcsd
Done.
<br>
Repair VTU00M eMMC:
Success
Success
Success
Success
<font color="red">NOTE: This stage was reapir only eMMC NAME , not wear leveling data!!</font>
<font color="red">NOTE: Repair Stage 2 must be done to make eMMC repair completely!</font>
<font color="red">Please, Reconnect eMMC power lines and press 'VTU00M Repair' again</font>
<br>
CMD Active Level:1732 mV
EMMC CID : 15010056545530304DF16B75594F4FA4
EMMC Date: 04/2012 Rev.0xf1
EMMC NAME: <b>VTU00M</b> , S/N: 1802852687
Backup saved: VTU00M_1802852687_20140403_1340.extcsd
Done.
Old 06-06-2014, 19:46   #30 (permalink)
maplegsm's Avatar
Member: 391664
Sonork: Python
Thanks Meter: 1,063
CMD Active Level:1742 mV
Access to current partition forbidden ( size=0 )
Done !!!
Box S/N: 16160C0B8F6638CB, ,FW Ver.: 01.50
CMD Pullup Level:1299 mV
EMMC CID : 15010056545530304DF124152A395FDA
EMMC Date: 05/2012 Rev.0xf1
EMMC NAME: VTU00M , S/N: 605366841
Backup saved: VTU00M_ 605366841_20140505_2227.extcsd
Done.
Writing file...H:\Z3x\jtag\i9300\dump\EMMC_ROM1_00000000_2 0000000.bin
Write Speed: 687 kB/s
Done !!!
after repair emmc name 0000.. ROM2 and ROM3 adress not good
how to resize ?
Page generated in 0.53224 seconds with 7 queries
