03-15-2018, 13:18 | #1 (permalink) |
No Life Poster Join Date: Feb 2015 Location: IRAN-TABRIIZ
Member: 2339474 Status: Offline Sonork: 100.1662352 Thanks Meter: 332 | CMD CRC Error OS ver.: Windows 7 (build 7601, Service Pack 1), 64-bit edition. Admin rights OK Android Explorer ver:1.0.0.24 Autorun Agent ver:1.0.0.0 Crash Reporting ver:1.4.0.3 eMMC Odin ver:1.0.11.3 QUALCOMM Direct ver:1.0.6306.57125 Android ADB API ver:2.0.0.0 FTDI API ver:3.2.4.0 LibUSB API ver:1.2.6.0 Visual C++ Runtime ver:10.0.30319.1 Setting box Pinout ... Box Drivers version: 1.2.0.0 Z3X Card Serial : AA55-9616 , ver: 22 Z3X Card Activation [LG] : ACTIVATED Z3X Card Activation [SAMS] : ACTIVATED Z3X Card Activation [JTAGPLUS] : ACTIVATED Z3X Card Activation [JTAG] : ACTIVATED Selected pinout: GEN2 ISP Pinout Change EasyJTAG Pinout OK Compression if OFF Z3X EasyJtag Software ver. 2.9.0.0 Loading eMMC GEN2 Firmware... IO: 3300 mV Box S/N: 7604E355A5D3B120, ,FW Ver.: 02.21 CMD Pullup Level:1127 mV CMD Active Level:2695 mV Box IO Level:3300 mV CLK Rate:9000 kHz Bus Width:1bit,SDR HiPower mode is ON! Can't init device, Reason: CMD Timeout Error Done. Compression if OFF Z3X EasyJtag Software ver. 2.9.0.0 Loading eMMC GEN2 Firmware... IO: 3300 mV Box S/N: 7604E355A5D3B120, ,FW Ver.: 02.21 CMD Pullup Level:1762 mV CMD Active Level:3010 mV Box IO Level:3300 mV CLK Rate:9000 kHz Bus Width:1bit,SDR HiPower mode is ON! ---------- eMMC Device Information ---------- EMMC CID : 15010056335730304D00E9129BA750FD EMMC CSD : D02701320F5903FFF6DBFFEF8E40400D EMMC Manufacturer ID: 0015 , OEM ID: 0100 EMMC Date: 05/2013 Rev.0x0 EMMC NAME: V3W00M , S/N: 3910310823 EMMC NAME (HEX): 56335730304D00 EMMC ROM1 (Main User Data) Capacity: 15028 MB EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 512 kB EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.7 (MMC 5.0) Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x01 , width 4bits , Partition config [179]: 0x48. H/W reset function [RST_N_FUNCTION]: 0x00 High-capacity W protect group size [HC_WP_GRP_SIZE: 0x00000000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: V3W00M_3910310823_20180315_1533.extcsd Done. Compression if OFF Z3X EasyJtag Software ver. 2.9.0.0 Loading eMMC GEN2 Firmware... IO: 1800 mV Box S/N: 7604E355A5D3B120, ,FW Ver.: 02.21 CMD Pullup Level:1740 mV CMD Active Level:1843 mV Box IO Level:1800 mV CLK Rate:9000 kHz Bus Width:1bit,SDR HiPower mode is ON! Can't init device, Reason: CMD Timeout Error Done. Compression if OFF Z3X EasyJtag Software ver. 2.9.0.0 Loading eMMC GEN2 Firmware... IO: 2800 mV Box S/N: 7604E355A5D3B120, ,FW Ver.: 02.21 CMD Pullup Level:1755 mV CMD Active Level:2595 mV Box IO Level:2800 mV CLK Rate:9000 kHz Bus Width:1bit,SDR HiPower mode is ON! ---------- eMMC Device Information ---------- EMMC CID : 15010056335730304D00E9129BA750FD EMMC CSD : D02701320F5903FFF6DBFFEF8E40400D EMMC Manufacturer ID: 0015 , OEM ID: 0100 EMMC Date: 05/2013 Rev.0x0 EMMC NAME: V3W00M , S/N: 3910310823 EMMC NAME (HEX): 56335730304D00 EMMC ROM1 (Main User Data) Capacity: 15028 MB EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 512 kB EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.7 (MMC 5.0) Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x01 , width 4bits , Partition config [179]: 0x48. H/W reset function [RST_N_FUNCTION]: 0x00 High-capacity W protect group size [HC_WP_GRP_SIZE: 0x00000000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: V3W00M_3910310823_20180315_1534.extcsd Done. Compression if OFF Z3X EasyJtag Software ver. 2.9.0.0 Loading eMMC GEN2 Firmware... IO: 2800 mV Box S/N: 7604E355A5D3B120, ,FW Ver.: 02.21 CMD Pullup Level:1757 mV CMD Active Level:2595 mV Box IO Level:2800 mV CLK Rate:24000 kHz Bus Width:1bit,SDR HiPower mode is ON! ---------- eMMC Device Information ---------- EMMC CID : 15010056335730304D00E9129BA750FD EMMC CSD : D02701320F5903FFF6DBFFEF8E40400D EMMC Manufacturer ID: 0015 , OEM ID: 0100 EMMC Date: 05/2013 Rev.0x0 EMMC NAME: V3W00M , S/N: 3910310823 EMMC NAME (HEX): 56335730304D00 EMMC ROM1 (Main User Data) Capacity: 15028 MB EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 512 kB EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.7 (MMC 5.0) Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x01 , width 4bits , Partition config [179]: 0x48. H/W reset function [RST_N_FUNCTION]: 0x00 High-capacity W protect group size [HC_WP_GRP_SIZE: 0x00000000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: V3W00M_3910310823_20180315_1534.extcsd Done. Z3X EasyJtag Software ver. 2.9.0.0 Skip loading eMMC Addon Firmware CMD Pullup Level:1756 mV CMD Active Level:2595 mV Box IO Level:2800 mV CLK Rate:24000 kHz Bus Width:1bit,SDR Reading 0x000400000000 (16.0GB) from 0x000000000000 ...ROM1 ( USER ROM) Read Length has been corrected to 0x0003AB400000 (14.675GB)... Output file :C:\Users\gsm\Desktop\EMMC_ROM1_V3W00M_3910310823_ 00000000_3AB400000.bin Error reading address 0x2A620000 Error Code:-2 Reason :CMD CRC Error Retry reading address 0x2A620000 (Attempt #1) Retry Success! Error reading address 0x2A620000 Error Code:-2 Reason :CMD CRC Error Retry reading address 0x30A20000 (Attempt #1) Retry Success! Error reading address 0x2A620000 Error Code:-2 Reason :CMD CRC Error Retry reading address 0x36C40000 (Attempt #1) Retry Success! Error reading address 0x2A620000 Error Code:-2 Reason :CMD CRC Error Retry reading address 0x5C940000 (Attempt #1) Retry Success! Error reading address 0x2A620000 Error Code:-2 Reason :CMD CRC Error Retry reading address 0x74860000 (Attempt #1) Retry Success! |
