12-09-2016, 13:46 | #1 (permalink) | |
No Life Poster Join Date: Mar 2009 Location: YT - Channel RealFix-GRS.TV Age: 37
Member: 990711 Status: Offline Sonork: 100.1597405 Thanks Meter: 1,779 | Tested emmc pinout sm-j110h/ds Quote:
The Following 33 Users Say Thank You to MARVZ_TG For This Useful Post: |
04-03-2017, 12:34 | #7 (permalink) |
No Life Poster Join Date: Jul 2005 Location: In My PC Age: 46
Member: 165971 Status: Offline Thanks Meter: 65 | i use flash file and pit but phone still dead !! is any dump or good methode to repair emmc ? Code: HiPower mode is OFF CMD Pullup Level: 2134 mV CMD Active Level: 2464 mV EMMC Device Information : EMMC CID: 90014A48344732621101DFD16E58821A EMMC CSD: D07F01320F5903FFFFFFFFEF8A4040DA EMMC Manufacture Name: SKHYNIX EMMC NAME: H4G2b , S/N: DFD16E58 , rev. 01 EMMC NAME (HEX): 483447326211 EMMC ROM 1 (Main User Data) Capacity: 3728 MB (0000E9000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Backup saved: H4G2b_DFD16E58_20170403_115951.extcsd EMMC Init completed. HiPower mode is OFF CMD Pullup Level: 2145 mV CMD Active Level: 2464 mV EMMC Device Information : EMMC CID: 90014A48344732621101DFD16E58821A EMMC CSD: D07F01320F5903FFFFFFFFEF8A4040DA EMMC Manufacture Name: SKHYNIX EMMC NAME: H4G2b , S/N: DFD16E58 , rev. 01 EMMC NAME (HEX): 483447326211 EMMC ROM 1 (Main User Data) Capacity: 3728 MB (0000E9000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Backup saved: H4G2b_DFD16E58_20170403_115959.extcsd EMMC Init completed. Opening file: SM-J110H_12-9-2016_6-12-17.pit Pit: SM-J110H_12-9-2016_6-12-17.pit Entry count: 30 The size of the last section has been updated J110HXXU0AQC1_J110HOJV0AQC1_J110HXXU0APH4_HOME.tar.md5 The list of files in the firmware: boot.img recovery.img system.img cache.img hidden.img sprdcp.img sprddsp.img HiPower mode is OFF CMD Pullup Level: 2134 mV CMD Active Level: 2485 mV EMMC Device Information : EMMC CID: 90014A48344732621101DFD16E58821A EMMC CSD: D07F01320F5903FFFFFFFFEF8A4040DA EMMC Manufacture Name: SKHYNIX EMMC NAME: H4G2b , S/N: DFD16E58 , rev. 01 EMMC NAME (HEX): 483447326211 EMMC ROM 1 (Main User Data) Capacity: 3728 MB (0000E9000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Backup saved: H4G2b_DFD16E58_20170403_120018.extcsd EMMC Init completed. Operation: Write by vendor (Samsung) Creating GPT-partitioninig Writing PIT at address: 000000080000 GPT-partitioning done Unpacking file: sprddsp.img Unpacking file: sprdcp.img Unpacking file: boot.img Unpacking file: recovery.img Unpacking file: cache.img Unpacking file: system.img Unpacking file: hidden.img Partition name: WDSP Filename: sprddsp.img , Offset: 000000C00000 , filesize: 2097152 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1151,56 Kb/s Partition name: MODEM Filename: sprdcp.img , Offset: 000001000000 , filesize: 8388608 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 819,74 Kb/s Partition name: KERNEL Filename: boot.img , Offset: 000004500000 , filesize: 5569536 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 786,24 Kb/s Partition name: RECOVERY Filename: recovery.img , Offset: 000005500000 , filesize: 6906880 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 786,92 Kb/s Partition name: CSC Filename: cache.img , Offset: 000006E00000 , filesize: 37499152 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Sparse image found v.1.0 Total chunks: 15 Done writing partition. Write speed: 848,54 Kb/s Partition name: SYSTEM Filename: system.img , Offset: 000013600000 , filesize: 950687856 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Sparse image found v.1.0 Total chunks: 1669 Done writing partition. Write speed: 749,07 Kb/s Partition name: HIDDEN Filename: hidden.img , Offset: 000053C00000 , filesize: 8073520 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Sparse image found v.1.0 Total chunks: 17 Done writing partition. Write speed: 1033,83 Kb/s All done |
04-03-2017, 15:46 | #8 (permalink) |
Member: 165971 Status: Offline Thanks Meter: 65 | i try another pit and other flash file still dead seriously is this box work ????? many repair lg and samsung finish ok but phone never alive what is this box ????????!!! waste of time and the best supporter never reply Code: Changelog: 09.03.2017 (ver 1.0.0.43) Fix: Bugs that have been found through your crash report Add: Some improvements Add: Write by vendor "Spreadtrum" (While only SC773X) Add: Search for tables nVidia Tegra Add: Completely rewritten Explorer HiPower mode is OFF CMD Pullup Level: 2000 mV CMD Active Level: 2464 mV EMMC Device Information : EMMC CID: 90014A48344732621101DFD16E58821A EMMC CSD: D07F01320F5903FFFFFFFFEF8A4040DA EMMC Manufacture Name: SKHYNIX EMMC NAME: H4G2b , S/N: DFD16E58 , rev. 01 EMMC NAME (HEX): 483447326211 EMMC ROM 1 (Main User Data) Capacity: 3728 MB (0000E9000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Backup saved: H4G2b_DFD16E58_20170403_151412.extcsd EMMC Init completed. Opening file: J1POP3G.pit Pit: J1POP3G.pit Entry count: 30 The size of the last section has been updated J110HXXU0AOGA_J110HOJV0AOGB_J110HXXU0AOGA_HOME.tar.md5 The list of files in the firmware: spl.img sboot.bin sboot2.bin boot.img recovery.img system.img sprdcp.img sprddsp.img cache.img hidden.img HiPower mode is OFF CMD Pullup Level: 2000 mV CMD Active Level: 2464 mV EMMC Device Information : EMMC CID: 90014A48344732621101DFD16E58821A EMMC CSD: D07F01320F5903FFFFFFFFEF8A4040DA EMMC Manufacture Name: SKHYNIX EMMC NAME: H4G2b , S/N: DFD16E58 , rev. 01 EMMC NAME (HEX): 483447326211 EMMC ROM 1 (Main User Data) Capacity: 3728 MB (0000E9000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Backup saved: H4G2b_DFD16E58_20170403_151439.extcsd EMMC Init completed. Operation: Write by vendor (Samsung) Creating GPT-partitioninig Writing PIT at address: 000000080000 GPT-partitioning done Unpacking file: spl.img Unpacking file: sboot.bin Unpacking file: sboot2.bin Unpacking file: sprddsp.img Unpacking file: sprdcp.img Unpacking file: boot.img Unpacking file: recovery.img Unpacking file: cache.img Unpacking file: system.img Unpacking file: hidden.img Partition name: BOOT Filename: spl.img , Offset: 000000000000 , filesize: 32768 bytes eMMC switching to ROM2 Erasing partition... Writing partition... Done writing partition. Write speed: 171,19 Kb/s Partition name: SBOOT Filename: sboot.bin , Offset: 000000400000 , filesize: 1573888 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 984,41 Kb/s Partition name: SBOOT2 Filename: sboot2.bin , Offset: 000000600000 , filesize: 1573888 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 970,78 Kb/s Partition name: WDSP Filename: sprddsp.img , Offset: 000000C00000 , filesize: 2097152 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1123,05 Kb/s Partition name: MODEM Filename: sprdcp.img , Offset: 000001000000 , filesize: 8388608 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 820,00 Kb/s Partition name: KERNEL Filename: boot.img , Offset: 000004500000 , filesize: 5567488 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 786,34 Kb/s Partition name: RECOVERY Filename: recovery.img , Offset: 000005500000 , filesize: 6898688 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 787,13 Kb/s Partition name: CSC Filename: cache.img , Offset: 000006E00000 , filesize: 39825680 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Sparse image found v.1.0 Total chunks: 15 Done writing partition. Write speed: 845,95 Kb/s Partition name: SYSTEM Filename: system.img , Offset: 000013600000 , filesize: 945108928 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Sparse image found v.1.0 Total chunks: 1658 Done writing partition. Write speed: 750,56 Kb/s Partition name: HIDDEN Filename: hidden.img , Offset: 000053C00000 , filesize: 17625488 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Sparse image found v.1.0 Total chunks: 23 Done writing partition. Write speed: 873,79 Kb/s All done |
The Following User Says Thank You to bendou For This Useful Post: |
04-03-2017, 17:06 | #9 (permalink) | |
Freak Poster Join Date: Oct 2011 Location: uf1 b0x land
Member: 1675290 Status: Offline Thanks Meter: 177 | Quote:
i said that coz this is my daily job to drill and change emmc ... | |
The Following 6 Users Say Thank You to bagus.dps For This Useful Post: |
04-04-2017, 00:37 | #10 (permalink) |
Freak Poster Join Date: Nov 2016 Location: INDONESIA
Member: 2650126 Status: Offline Thanks Meter: 42 | Yes dont waste your time for repair emmc skhynix . Change emmc is best solution . Im many change j110h j110g always successfull dont forget to click thanks !!! |
05-15-2017, 20:56 | #13 (permalink) |
No Life Poster Join Date: Dec 2006 Location: GSM WORLD
Member: 412843 Status: Offline Sonork: 100.1604902 Thanks Meter: 497 | @Alll I Need Working Dump + Exdcsd Plz Written Bootloader Files With PIT With EASY JTAG PLUS But Still Dead Will Be Grateful To All Thanks Anticipation |
The Following User Says Thank You to shoaibrao For This Useful Post: |
09-28-2017, 10:13 | #15 (permalink) |
No Life Poster Join Date: Jan 2002 Location: tunis,Tunisia Age: 54
Member: 8228 Status: Offline Sonork: 12399830 Thanks Meter: 136 | Any working dump to repair j110h/ds dead boot after flash thx for help |
The Following 2 Users Say Thank You to patric For This Useful Post: |
