trouble with two phones asusz00ad desire 816n hi guys i reprogram asus emmc 32gb in support 16gbdump 32gbdump and asus z00a ze551ml 2.12.40.11 user file everything ok but replacae emmc only moorefield device and then try to debrick fuullchange emmc file something happened in dos commands but phone not working any solution??? another one i reprogram desire 816n different two emmcs 16gb and 32gb everything ok but phone storage is everytime error storage full... i write firmware via ruu method flash zip but still same same any advance |
For Asus ZE551ML: 1) You need dowload debrick archive from support 2a) If you change eMMC, you need run debrick_change_EMMC.bat 2b) If you change CPU, you need run debrick_change_SoC.bat For HTC D816: You need check eMMC via "Random Verify Test" (300-500MB) from EasyJTAG Plus software Or run "Linear verify test" of userdata partition at same software (Read by Vendor Tab) Probably the eMMC is dead, and needed to replace |
bro i try it i change emmc and then pc detedt moorefield device and then debrick img nothing happened i want to know am i do somethin wrong thank you bro maybe asus hardware problem for htc i try your solution because try 2 emmc same, storage full thanks for your support |
if 8 gb replace any problem with storage bro? |
I was changed eMMC at D816 at 2018, and all be ok. Now I don't forget change procedure, but I was make all standart procedures when eMMC is change Quote:
Desire_816n_write_by_vendor_qualcomm.zip D816w_dump_write_by_vendor_qualcomm.zip it's a full firmware - write and run device |
4stage_resize_userdata | EasyJtag ? Fastest Memory Programmer in the word! |
