03-12-2019, 18:01 | #1 (permalink) |
Freak Poster Join Date: May 2013 Location: Ortahisar
Member: 1929052 Status: Offline Thanks Meter: 22 | trouble with two phones asusz00ad desire 816n another one i reprogram desire 816n different two emmcs 16gb and 32gb everything ok but phone storage is everytime error storage full... i write firmware via ruu method flash zip but still same same any advance |
03-13-2019, 00:32 | #2 (permalink) |
Product Supporter Join Date: Jun 2002 Location: Belarus Age: 47
Member: 13148 Status: Offline Thanks Meter: 2,948 | For Asus ZE551ML: 1) You need dowload debrick archive from support 2a) If you change eMMC, you need run debrick_change_EMMC.bat 2b) If you change CPU, you need run debrick_change_SoC.bat For HTC D816: You need check eMMC via "Random Verify Test" (300-500MB) from EasyJTAG Plus software Or run "Linear verify test" of userdata partition at same software (Read by Vendor Tab) Probably the eMMC is dead, and needed to replace |
03-13-2019, 10:25 | #3 (permalink) |
Member: 1929052 Status: Offline Thanks Meter: 22 | bro i try it i change emmc and then pc detedt moorefield device and then debrick img nothing happened i want to know am i do somethin wrong thank you bro maybe asus hardware problem for htc i try your solution because try 2 emmc same, storage full thanks for your support |
03-13-2019, 12:07 | #4 (permalink) | |
Freak Poster Join Date: Jul 2008
Member: 818380 Status: Offline Thanks Meter: 56 | Quote:
03-13-2019, 18:34 | #6 (permalink) |
Member: 13148 Status: Offline Thanks Meter: 2,948 | I was changed eMMC at D816 at 2018, and all be ok. Now I don't forget change procedure, but I was make all standart procedures when eMMC is change if you use EasyJTAG Plus software and "write by venor" mode - last partition size is automatic resize. Last edited by layder; 03-13-2019 at 18:50. |
03-14-2019, 12:56 | #9 (permalink) | |
Member: 1929052 Status: Offline Thanks Meter: 22 | Quote:
4stage_resize_userdata | EasyJtag ? Fastest Memory Programmer in the word! | |
