09-04-2013, 15:59 | #1 (permalink) |
Insane Poster Join Date: May 2009
Member: 1031907 Status: Offline Thanks Meter: 44 | [TUTORIAL] How to use partition scripts 1) Start Easy JTAG program and switch to the JTAG Flasher tab. 2) Select brand type and MCU, in my case m using Galaxy S3 R530U, so most of the similar phones init will work with this phone too. Hence i have selected SPH-L710. 3) Click Connect to device and check log for successful connection. 4) Now go to your Easy-JTAG installation directory, in my case it was H:\Mobiles\Z3x\EasyJTAG\ . Now go to scripts folder and copy file named "Show_Paritions_EMMC_GPT.txt". 5) Make a new folder some where with model name of the phone of which you are going to take backup, I made folder on my desktop as "R530". Paste the "Show_Paritions_EMMC_GPT.txt" file inside this folder. 6) Now in program, click on Run Script, and select the "Show_Paritions_EMMC_GPT.txt" files in the R530 folder you created. It will show log output in program if you have selected proper partitioning script. This will create 2 new files in the R530 folder, i.e. "dump_partitions.txt" and "write_partitions.txt". 7) Now open dump_partitions.txt and de-select partitions which you dont want to flash/restore/backup. You need to add # in the start of each partition, in this case, we are not going to backup MODEM,BOOT,SYSTEM,USERDATA,CACHE and GROW so i have added # in the start of each line. 8) Once the backup is done, you should see a log like this. 9) Now you need to similarly edit the write_partitions.txt file as you did with the dump_partitions.txt file. Now click on Run Script again and select "write_partitions.txt" file and you should see something like this. 10) Now connect phone which you want to repair, i.e another bricked R530 and click on Run Script. Select "write_partitions.txt" script inside the R530 folder and you will see something like this. Be sure that you have added # ahead of each partition line which you dont want to flash or which is not in the folder, do not rename the files. So this is it, as you can see it is pretty much easy and hassle free. Enjoy your Z3X EasyJTAG box |
The Following 14 Users Say Thank You to kanishk For This Useful Post: |
09-04-2013, 16:28 | #2 (permalink) |
Member: 1031907 Status: Offline Thanks Meter: 44 | NOTE: Do not always include EFS to flash, only restore in conditions which you are sure that the phone is having issues related to EFS |
The Following 2 Users Say Thank You to kanishk For This Useful Post: |
09-04-2013, 19:44 | #4 (permalink) |
No Life Poster Join Date: Jun 2010 Location: Xique-Xique-Bahia, Brasil Age: 46
Member: 1320000 Status: Offline Sonork: 100.1667898 Thanks Meter: 272 | I feel much more riff box already does this for a long time and a lot easier to run. Not a big update for us users. |
09-05-2013, 02:09 | #7 (permalink) |
No Life Poster Join Date: Dec 2005 Location: Ha Noi - Viet Nam Age: 18
Member: 207400 Status: Offline Sonork: 100.1582556 Thanks Meter: 262 | |
09-05-2013, 02:15 | #8 (permalink) |
Freak Poster Join Date: Aug 2006
Member: 337794 Status: Offline Thanks Meter: 19 | I suggest that the 2 step not need Select brand type and MCU Should be changed to automatic detection CPU Add automatic detection function option like atuo scan cpu So that we don't know need to repair the mobile phone CPU model |
09-05-2013, 04:13 | #9 (permalink) | |
Member: 1031907 Status: Offline Thanks Meter: 44 | Quote: No, even if different phones have same mcu, thr halt sequence can be different. Hence you need to manually select appropriate init/model first to properly halt and read from the device. Last edited by kanishk; 09-05-2013 at 04:19. | |
The Following User Says Thank You to kanishk For This Useful Post: |
09-06-2013, 10:05 | #11 (permalink) |
Product Supporter Join Date: Mar 2005 Location: China
Member: 129885 Status: Offline Sonork: 100:1603514 Thanks Meter: 6,202 | Thats impossible for new MCU , only for old ones. There are no universal loaders for all memory types. We can make suggestions for detected ID ( What inits may match your config ) |
09-06-2013, 11:42 | #12 (permalink) |
Temporary banned !! Join Date: Nov 2009 Location: P.H Age: 38
Member: 1151970 Status: Offline Sonork: 100.1597000 Thanks Meter: 378 | cherry mobile s100 how to problem # Hi , this is automatically generated write script # Everything you need to do , are commant or uncomment # Parts that you need to write to phone in automated mode # ------------------------------------------------------- echo "Writing MBR" emmc write 0 MBR.BIN 0x000000 # Script end HERE > # ------------------------------------------------------- # Hi , this is automatically generated dump script # Everything you need to do , are commant or uncomment # Parts that you need to read from phone in automated mode # ------------------------------------------------------- echo "Dumping MBR" emmc dump 0 MBR.BIN 0x000000 0x200 EasyJtag Suite ver.: 1.0.64.0 started. Operating system ver.: Windows 7 (build 7600). For support and updates visit http://easy-jtag.com Initialising: Samsung GT-S7562 Config ver.:1.00 I/O Level set to : 2600 mV Box S/N Connecting to Target... JTAG device: CPU IDCODE : 0x00000000 Mfg.: 0x000, Part: 0x0000, Ver.: 0x0 Halting CPU... Initialize hardware... Starting target communication... Detecting emmc memory parameters of bank (0) ... EMMC #0 : ID : 0x646F0000 Name : NROM M Size : 128.0 M , (262144) Blocks eMMC flash device(s) found, Device ID : 0x0000006f ------------------------------------------------------ Executing: C:\Users\datu lakay\Desktop\New folder (4)\Show_Partitions_EMMC_GPT.txt Searching for partition tables... Error! Unexpected packet size... Code (FFFFFF00B9) dcc_emmc_read_pages error (a:00000200,d:00000000,s:00000600,f:00) happened... Reading EMMC flash page failed Invalid EFI Signature. Created helper script 'dump_partitions.txt' for dumping all regions in device Created helper script 'write_partitions.txt' for writing all regions in device OK ------------------------------------------------------ Executing: C:\Users\datu lakay\Desktop\New folder (4)\dump_partitions.txt Dumping MBR Reading 00000200 bytes from emmc adress 000000000000 Error! Unexpected packet size... Code (FFFFFF00B9) dcc_emmc_read_pages error (a:00000000,d:00000000,s:00000200,f:00) happened... reading emmc flash page failed Done with error(s)... ------------------------------------------------------ Executing: C:\Users\datu lakay\Desktop\New folder (4)\write_partitions.txt Writing MBR eMMC Write OK! Elapsed time: 0.010000s (0.000 KiB/s) OK ------------------------------------------------------ Executing: C:\Program Files\Z3X\EASYJTAG\Backups\readme.txt Done with error(s)... CPU IDCODE : 0x00000000 Mfg.: 0x000, Part: 0x0000, Ver.: 0x0 Halting CPU... Initialize hardware... Starting target communication... Detecting emmc memory parameters of bank (0) ... EMMC #0 : ID : 0x646F0000 Name : NROM M Size : 128.0 M , (262144) Blocks eMMC flash device(s) found, Device ID : 0x0000006f # Script end HERE > # ------------------------------------------------------- |
09-07-2013, 06:42 | #14 (permalink) |
Member: 1151970 Status: Offline Sonork: 100.1597000 Thanks Meter: 378 | # Hi , this is automatically generated write script # Everything you need to do , are commant or uncomment # Parts that you need to write to phone in automated mode # ------------------------------------------------------- echo "Writing MBR" emmc write 0 MBR.BIN 0x000000 echo "Writing MMCBLK0P0" emmc write 0 MMCBLK0P0.BIN 0x90000000 echo "Writing MMCBLK0P1" emmc write 0 MMCBLK0P1.BIN 0x17000 # Script end HERE > # ------------------------------------------------------- Executing: C:\Users\datu lakay\Desktop\New folder (4)\Show_Partitions_EMMC_MBR.txt Searching for partition tables... Error! Unexpected packet size... Code (FFFFFF00B9) dcc_emmc_read_pages error (a:00000000,d:00000000,s:00000400,f:00) happened... Reading EMMC flash page failed Note: mbr signature: 0 (bad) Disk Signature: 80010000 MMCBLK0P0 BF:0x5c Type: Unknown:0x96 Start: 90000000 Len: D00D0E00 MMCBLK0P1 BF:0xb2 Type: NTFS Vol. Set Start: 17000 Len: 0 Created helper script 'dump_partitions.txt' for dumping all regions in device Created helper script 'write_partitions.txt' for writing all regions in device OK |
The Following User Says Thank You to KIKO_GSM For This Useful Post: |
09-07-2013, 07:48 | #15 (permalink) |
Member: 1151970 Status: Offline Sonork: 100.1597000 Thanks Meter: 378 | how to Partitions_EMMC s100 cherry mobile Executing: C:\Users\datu lakay\Desktop\New folder (4)\dump_partitions.txt Dumping MBR Continue 00000200 bytes from emmc adress 000000000000 Error! Unexpected packet size... Code (FFFFFF00B9) dcc_emmc_read_pages error (a:00000000,d:00000000,s:00000200,f:00) happened... reading emmc flash page failed Done with error(s)... |
