Old 05-16-2020, 09:24   #1 (permalink)
Member: 1438327
Thanks Meter: 26
Ufs bga 254 pinout needed
I need ufs bga 254 pinout for using it with ufs bga 153 adaptor
Old 05-17-2020, 07:16   #2 (permalink)
Member: 1438327
Thanks Meter: 26
after one day hard work I can do that but the software doesnt let me to do this
Z3X EasyJtag Software ver. 3.6.2.3
UFS Socket Info.
Serial: 0123631645670883EE
Description: EasyJTAG UFS Socket BGA-153 by EasyJTAG 19.05.19
Identify UFS Chip.
UFS Chip Voltage: High
Can't init device, Code: -115, Reason: Wrong socket type, this socket licensed for another chip type
VCC: 3267mV
VCCQ2: 2767mV
Chip Info:
Manufacturer: SAMSUNG
ProductName: KM2V7001CM-B706
SerialNumber: 0x2A4514E8530D7ED5BAEB17ACF28158423138393534483931
OemID: SAMSUNG_OEM_ID
UFS Version: 2.1
Done.
The Following User Says Thank You to davoodc For This Useful Post:
Old 05-17-2020, 07:31   #3 (permalink)
Member: 1438327
Thanks Meter: 26
https://pichost.net/img/00.tyg5Z
Old 05-17-2020, 07:45   #4 (permalink)
Member: 1438327
Thanks Meter: 26
all my work
https://pichost.net/img/11.tytVa
mr lyder please help me.
i am in iran. now in cant buy bga254 adaptor any more
Old 05-17-2020, 09:43   #5 (permalink)
layder's Avatar
Member: 13148
Thanks Meter: 2,948
Now only BGA254 socket have ISP pins
Old 05-17-2020, 09:54   #6 (permalink)
Member: 1438327
Thanks Meter: 26
for now i dont have problem with ISP pins or how to conect ufs chip with the box.
JAST FOR NOW THE SOFTWARE doesnt let me to do opartion.
it show licenc error.
is there any way to slave the problem
Old 05-17-2020, 09:58   #7 (permalink)
Member: 1438327
Thanks Meter: 26
https://pichost.net/img/666.ty4BQ
Old 05-17-2020, 12:25   #8 (permalink)
layder's Avatar
Member: 13148
Thanks Meter: 2,948
You cant connect BGA254 chip to this socket
Old 05-18-2020, 00:04   #9 (permalink)
Member: 2772222
Thanks Meter: 9
Why is not possible connect?
Old 05-18-2020, 12:25   #10 (permalink)
layder's Avatar
Member: 13148
Thanks Meter: 2,948
Adapter have protect chips for disable clone by chinese not-autorized PCB-Socket designers
UFS chips require high connection standards, the current operating frequency is 66Mhz, and one tracks length and short tracks are also required.
Therefore, the ISP mode for UFS chiips was practically not tested (rerely PCB ISP pins found).
We want many send-recive data errors with work at wires at ISP mode for UFS
For example, even in socket mode for eMMC 56 MHz give errors, therefore, the frequency is limited to 42 MHz in the case with eMMC
For ufs chips, an ISP pins and connection was added for only 254 adapters as experimental function.
Z3x team not make UFS activation for our BOX, but we need spend a lot of time, effort and money on the development and support of this function.
We make it as produced original sockets and by chips protection. It's better for reduce connection problem with UFS chips.
The Following 3 Users Say Thank You to layder For This Useful Post:
Page generated in 0.15644 seconds with 8 queries
