Old 01-31-2020, 03:04   #1 (permalink)
1R0niC's Avatar
Member: 2109200
Thanks Meter: 40
Ufs error
I can’t find partition table on this device and I’m using an easy jtag ISP adapter
Sent from my iPhone using Tapatalk
Old 01-31-2020, 05:18   #2 (permalink)
oktay50000's Avatar
Member: 678886
Sonork: 100.1661586
Thanks Meter: 171
Post the full log cant tell anything by half a picture
Old 01-31-2020, 10:21   #3 (permalink)
1R0niC's Avatar
Member: 2109200
Thanks Meter: 40
Old 01-31-2020, 10:22   #4 (permalink)
1R0niC's Avatar
Member: 2109200
Thanks Meter: 40
Old 01-31-2020, 12:52   #5 (permalink)
kothamamun's Avatar
Member: 2556542
Thanks Meter: 1,790
you are upload too zoom to look
Old 01-31-2020, 15:10   #6 (permalink)
1R0niC's Avatar
Member: 2109200
Thanks Meter: 40
Now you can see well ?
Old 01-31-2020, 22:35   #7 (permalink)
oktay50000's Avatar
Member: 678886
Sonork: 100.1661586
Thanks Meter: 171
Ufs pins are clean? Probably not making a good connection , open the socket door and press it harder by hand and identify , see if reads it
Old 02-01-2020, 00:50   #8 (permalink)
1R0niC's Avatar
Member: 2109200
Thanks Meter: 40
It identifies it with no problem
Problem as you can read it says : select interface tab
And there is not an interface tab
Old 02-01-2020, 00:52   #9 (permalink)
oktay50000's Avatar
Member: 678886
Sonork: 100.1661586
Thanks Meter: 171
Well i see that but when identifies it should give you full page of info which im not seeing there
Old 02-01-2020, 00:53   #10 (permalink)
oktay50000's Avatar
Member: 678886
Sonork: 100.1661586
Thanks Meter: 171
Also try with plus version see it reads it
Old 02-01-2020, 02:13   #11 (permalink)
1R0niC's Avatar
Member: 2109200
Thanks Meter: 40
It reads my ufs memory but not partitions
Old 02-01-2020, 06:46   #12 (permalink)
Member: 2902578
Thanks Meter: 151
isp BGA254 ISP PCB Conncetion with wires ?
Old 02-01-2020, 09:13   #13 (permalink)
1R0niC's Avatar
Member: 2109200
Thanks Meter: 40
Yes
Old 02-01-2020, 09:14   #14 (permalink)
1R0niC's Avatar
Member: 2109200
Thanks Meter: 40
Actually it is from an A50
Old 02-01-2020, 12:05   #15 (permalink)
Member: 2902578
Thanks Meter: 151
you cannot conect
A50 HAVE uMCP BGA 254 Inside & you are in try to connect with some other BGA Socket tarcks for ISP Jumpers.
the end line you are using too much smart team product
Page generated in 0.26170 seconds with 8 queries
