Ufs error I can’t find partition table on this device and I’m using an easy jtag ISP adapter https://uploads.tapatalk-cdn.com/202...fe8036704f.jpghttps://uploads.tapatalk-cdn.com/202...4fcbbbf755.jpg Sent from my iPhone using Tapatalk |
Post the full log cant tell anything by half a picture |
https://uploads.tapatalk-cdn.com/202...2562de1c92.jpg Sent from my iPhone using Tapatalk |
https://uploads.tapatalk-cdn.com/202...17b403abbf.jpg Sent from my iPhone using Tapatalk |
you are upload too zoom to look |
https://uploads.tapatalk-cdn.com/202...f918c2387c.png Now you can see well ? Sent from my iPhone using Tapatalk |
Ufs pins are clean? Probably not making a good connection , open the socket door and press it harder by hand and identify , see if reads it |
It identifies it with no problem Problem as you can read it says : select interface tab And there is not an interface tab Sent from my iPhone using Tapatalk |
Well i see that but when identifies it should give you full page of info which im not seeing there |
Also try with plus version see it reads it |
It reads my ufs memory but not partitions Sent from my iPhone using Tapatalk |
isp BGA254 ISP PCB Conncetion with wires ? |
Yes Sent from my iPhone using Tapatalk |
Actually it is from an A50 Sent from my iPhone using Tapatalk |
you cannot conect Quote:
the end line you are using too much smart team product :) |
