Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Easy-Jtag
Old 02-01-2020, 12:30   #16 (permalink)
1R0niC's Avatar
Member: 2109200
Thanks Meter: 29
Originally Posted by Gulzar-Ahmad View Post
A50 HAVE uMCP BGA 254 Inside & you are in try to connect with some other BGA Socket tarcks for ISP Jumpers.
the end line you are using too much smart team product
A50 is 153 not 254 thatís why I use an ISP for that by easy jtag
So your answer is out of mind mate
Sent from my iPhone using Tapatalk
Old 02-01-2020, 12:45   #17 (permalink)
Member: 2902578
Thanks Meter: 68
answerd in hurry
yes you are right in my mind the model was A920 ,NOT OUT OF MIND Which socket you are using to make ISP ? Some newely relesed BGA254 ISP Pad based socket ?
Old 02-01-2020, 12:47   #18 (permalink)
1R0niC's Avatar
Member: 2109200
Thanks Meter: 29
Old 02-01-2020, 13:14   #19 (permalink)
Member: 2902578
Thanks Meter: 68
You can only Connect ISP OF BGA254 IC Based phone, as i said, just switch the words
Old 02-01-2020, 14:37   #20 (permalink)
1R0niC's Avatar
Member: 2109200
Thanks Meter: 29
Donít think so cause my memory is detected
Old 02-01-2020, 14:47   #21 (permalink)
Member: 2902578
Thanks Meter: 68
its hows all Logic Unit Numbers ?
Old 02-01-2020, 14:49   #22 (permalink)
1R0niC's Avatar
Member: 2109200
Thanks Meter: 29
Old 02-01-2020, 15:11   #23 (permalink)
Member: 2902578
Thanks Meter: 68
You Called it " my memory is detected " ok play with it
Old 02-01-2020, 15:31   #24 (permalink)
1R0niC's Avatar
Member: 2109200
Thanks Meter: 29
Yes mate it is detected but in tab partitions it says I need to select proper interface and I donít know where to select it
Old 02-01-2020, 15:33   #25 (permalink)
1R0niC's Avatar
Member: 2109200
Thanks Meter: 29
Old 02-08-2020, 09:30   #26 (permalink)
rogerboogie's Avatar
Member: 103024
Thanks Meter: 602
Jajaja
Keep it up haha
Old 02-08-2020, 16:35   #27 (permalink)
1R0niC's Avatar
Member: 2109200
Thanks Meter: 29
Originally Posted by rogerboogie View Post
Jajaja
Keep it up haha
Ahhh que house ! Nunca entendiste que no todo es ser aZadon
Old 02-14-2020, 13:30   #28 (permalink)
Member: 2902578
Thanks Meter: 68
Z3X EasyJTAG UFS ISP Pinouts share,Connection,Troubles Discussion
Page generated in 0.18733 seconds with 7 queries
