Old 06-05-2019, 14:42   #1 (permalink)
Member: 2453200
Thanks Meter: 102
UFS memory connection troubles, question, discuss thread
UFS memory at test
Reading/Writing by partitions
The Following 17 Users Say Thank You to Resident_Evil For This Useful Post:
Old 06-06-2019, 09:21   #2 (permalink)
layder's Avatar
Member: 13148
Thanks Meter: 2,948
is not a beta test - it's development screenshot.
ufs memory do not have bus width as eMMC
combobox values will be chanded after
I post this screens at me channel
https://t.me/Z3X_EasyJTAG_Plus
Not ned to be forward it to forum
The Following 4 Users Say Thank You to layder For This Useful Post:
Old 06-06-2019, 23:43   #3 (permalink)
Member: 1041150
Thanks Meter: 32
Here is my log, i read a BGA95 from galaxy s6 edge
The Following 7 Users Say Thank You to Quetzaltloani For This Useful Post:
Old 07-08-2019, 08:01   #4 (permalink)
Member: 1438327
Thanks Meter: 26
Ufs 153 chipset read & write speed!!!!!!
I BUY UFS 153 ADAPTOR YESTERDAY
NOW MY BOX READ AND WIRTE OPERATION ARE ABOUT 500 KB/s
IS IT NORMAL FOR UFS CHIPSET?????
ITS VERY SLOWLY
The Following 5 Users Say Thank You to davoodc For This Useful Post:
Old 07-08-2019, 11:36   #5 (permalink)
Member: 2902578
Thanks Meter: 151
its 2.5 MBPS On Moorc 3 in 1 UFS Socket
The Following 8 Users Say Thank You to Gulzar-Ahmad For This Useful Post:
Old 07-08-2019, 11:47   #6 (permalink)
Member: 1438327
Thanks Meter: 26
Realy???????
I have easy jtag orginal adaptor
where is problam
The Following 2 Users Say Thank You to davoodc For This Useful Post:
Old 07-08-2019, 11:49   #7 (permalink)
layder's Avatar
Member: 13148
Thanks Meter: 2,948
Now UFS speed depends on motherboard chipset
First we have to improve UFS compatibility, and after - speed
Now UFS speed is 0,5 - 3 MB/s (1 channel)
After we update box firmware speed will cease to be dependent of chipset, and will be 6-10MB/s (2 channel)
First Moorc 3in1 revision have only 1 channel, and max speed it will be have 3-5MB/s
All new android devices have crypted userdata and we can't use EasyJTAG box to read data from it, and speed 6-10MB/s is well for boot repair operation
Now UFS link freq is 66 MHz
We can't use UFS Hi-speed link (1,5GHz) at this hardware
The Following 14 Users Say Thank You to layder For This Useful Post:
Old 07-08-2019, 14:30   #8 (permalink)
Member: 1438327
Thanks Meter: 26
Ufs lun size and count
HOW WE CAN CHANGE UFS LUN's SIZE AND GRAET THEM?????
I HAVE U ULTRA DUMP WITH THAT LOGS:
LUN 0:
Block size: 0x1000
Size: 0xEC8C00000 / 59,140,000,000B / 59GB
LUN 1 (Boot A):
Block size: 0x1000
Size: 0x400000 / 0,004,000,000B / 4MB
LUN 2 (Boot B):
Block size: 0x1000
LUN 3:
Block size: 0x1000
Size: 0xB800000 / 0,184,000,000B / 184MB
LUN 4:
Block size: 0x1000
Size: 0xB000000 / 0,176,000,000B / 176MB
LUN 5:
Block size: 0x1000
Size: 0x6400000 / 0,100,000,000B / 100MB
Number of W-LUs found: 1
W-LUN 0xC4 (REPORT LUNS):
Block size: 0x100
AND ONE UFS CHIP FROM G950F WITH THIS LOGS:
LUN 0:
Block size: 0x1000
Size: 0xEE4800000 / 59,584,000,000B / 59GB
LUN 1 (Boot A):
Block size: 0x1000
LUN 2 (Boot B):
Block size: 0x1000
Size: 0x800000 / 0,008,000,000B / 8MB
LUN 3:
Block size: 0x1000
Block size: 0x100
Size: 0x1000000 / 0,016,000,000B / 16MB
HOW I CAN CHANGE LUN PARTITION SIZE???????
AND HOW I CAN GRAET OTHER LUN THAT
UFS CHIPSET DOES NOT HAVE IT?????????
Old 07-08-2019, 15:39   #9 (permalink)
layder's Avatar
Member: 13148
Thanks Meter: 2,948
UFS LUN's size can changed by "Write Chip Config" file via EasyJTAG Classic software for UFS chips, who have "Re-Configure: Enabled"
this UFS chips can't Re-Configure (OTP zone is set)
UFS Device Information :
UFS Manufacturer: SAMSUNG, UFS ProductName: KM2V7001CM-B706
UFS OemID: SAMSUNG_OEM_ID, UFS SerialNumber: 0x2A90A9BCE90D7ED56F564316F28158423138395430454231
Maximum Number of LUs: 8, Number of LUs found: 4, Number of WLUs found: 1, LUs Re-configure: Disabled
UFS LUN 0 Capacity: 121972 MB (001DC7400000)
UFS LUN 1 (Boot A) Capacity: 4 MB (000000400000)
UFS LUN 2 (Boot B) Capacity: 4 MB (000000400000)
UFS LUN 3 Capacity: 60 MB (000003C00000)
UFS W-LUN 0xC4 (REPORT LUNS) Capacity: 16 MB (000001000000)
UFS Init completed.
The Following 8 Users Say Thank You to layder For This Useful Post:
Old 07-08-2019, 16:12   #10 (permalink)
Member: 1438327
Thanks Meter: 26
Then we have to use same as ufs chipset as the mobile ufs chipset with same lun size and count (how many lun are),yes?????????
Old 07-08-2019, 16:27   #11 (permalink)
Member: 1438327
Thanks Meter: 26
that means if i want change g950f ufs chip i have to use another g950f ufs chipset.!!!!
and i cant use any other phone's ufs chip becuse we cant change LUN number and size
and its about 1% to find ufs chip from any other phone Exactly like as that we needed,yes??????????
The Following 3 Users Say Thank You to davoodc For This Useful Post:
Old 07-08-2019, 16:58   #12 (permalink)
layder's Avatar
Member: 13148
Thanks Meter: 2,948
UFS chip, as computer HDD can be partitioning
After partitioning, chip's may be write OTP - close Re-Configure function
if Re-Configure function not close (Enabled), chip can partitioning many times
The Following 9 Users Say Thank You to layder For This Useful Post:
Old 07-08-2019, 20:01   #13 (permalink)
Member: 2895768
Thanks Meter: 10
i have activated my box, latest version and i have Morc Adpters
But when i want to read a UFS give this error.
With EMMC and ISP works normal.
The problem is when i want to read a memory UFS.
Box Drivers version: 3.2.0.0
Z3X Card Serial : AAD1-FXXX , ver: 22
Z3X Card Activation [JTAGPLUS] : ACTIVATED
Z3X Card Activation [LG] : NOT ACTIVATED
Z3X Card Activation [SAMS] : NOT ACTIVATED
Z3X Card Activation [JTAG] : ACTIVATED
Found 1 serial devices
COM5 USB\VID_1781&PID_AAAC&REV_0100&MI_00 MediaTek USB VCOM (Android) (COM5)
Selected pinout: GEN2 High Speed Pinout
Change EasyJTAG Pinout OK
Z3X EasyJtag Software ver. 3.6.1.2
UFS Socket Info.
Serial: 0123C09D037CXXXXX
Description: EasyJTAG UFS Socket 3 in 1 by MOORC 15.05.19
Can't open link, Code: -56, Reason: BOX: Chip not connected
Done.
UFS Socket Info.
Serial: 0123C09D037CC85BEE
Done.
Can you help me, please.
in Easy jtag plus does not enable me frequency and bus width https://ibb.co/Byg2nbJ
Or i need to buy another activation? where buy that activation?
The Following 2 Users Say Thank You to Gaelymateo2 For This Useful Post:
Old 07-09-2019, 00:53   #14 (permalink)
layder's Avatar
Member: 13148
Thanks Meter: 2,948
UFS connection use one freq: 66MHz
UFS not have bus width
1) update you soft to latest version
2) reboll you chip
http://forum.gsmhosting.com/vbb/f672.../#post13726620
http://forum.gsmhosting.com/vbb/f672.../#post13717343
The Following User Says Thank You to layder For This Useful Post:
Old 07-09-2019, 01:52   #15 (permalink)
MOORC's Avatar
Member: 1737647
Sonork: 100.1645466
Thanks Meter: 278
Moorc icfriend Sockets has 2 lanes design. You can open it.
UFS LS 1 lane is 0.6-2.5MB/S. UFS-LS 2 lanes is 5-10MB/S.
从我的 iPhone 发送,使用 Tapatalk
The Following 4 Users Say Thank You to MOORC For This Useful Post:
Page generated in 0.23382 seconds with 10 queries
