07-28-2019, 23:53 | #61 (permalink) |
No Life Poster Join Date: Nov 2006 Location: GOOD
Member: 388862 Status: Offline Thanks Meter: 107 | Identify UFS Chip. UFS Chip Voltage: Low VCC: 3309mV VCCQ2: 1865mV Manufacturer: SAMSUNG ProductName: KM2B8001CM-BB01 SerialNumber: 332991b5ef1d OemID: SAMSUNG_OEM_ID Maximum Number of LUs: 8 Number of LUs found: 6 LUN 0: Block size: 0x1000 Size: 0x3A2E000000 / 232,736,000,000B / 232GB LUN 1 (Boot A): Block size: 0x1000 Size: 0x400000 / 0,004,000,000B / 4MB LUN 2 (Boot B): Block size: 0x1000 Size: 0x400000 / 0,004,000,000B / 4MB LUN 3: Block size: 0x1000 Size: 0x8000000 / 0,128,000,000B / 128MB LUN 4: Block size: 0x1000 Size: 0x100000000 / 4,000,000,000B / 4GB LUN 5: Block size: 0x1000 Size: 0x60000000 / 1,512,000,000B / 1GB Number of W-LUs found: 1 W-LUN 0xC4 (REPORT LUNS): Block size: 0x100 Size: 0x1000000 / 0,016,000,000B / 16MB Full size: 0x3B97800000 / 238,376,000,000B / 238GB Read GPT From LUN 0. Partition info successfully found Found Data areas (firmware parts) count is: 13 --------------------------------------------- P0 (SSD) [0x6000 0x2000] Size: 8.0KB P1 (PERSIST) [0x8000 0x2000000] Size: 32.0MB P2 (MISC) [0x2008000 0x100000] Size: 1.0MB P3 (KEYSTORE) [0x2108000 0x80000] Size: 512.0KB P4 (FRP) [0x2188000 0x80000] Size: 512.0KB P5 (VM-KYSTORE) [0x2208000 0x100000] Size: 1.0MB P6 (VM-DATA) [0x2308000 0xa00000] Size: 10.0MB P7 (VM-SYSTEM) [0x2d08000 0x8000000] Size: 128.0MB P8 (VM-LINUX) [0xad08000 0x2000000] Size: 32.0MB P9 (CACHE) [0xcd08000 0x10000000] Size: 256.0MB P10 (SYSTEM) [0x1cd08000 0x136c00000] Size: 4.855GB P11 (ODM) [0x153908000 0x10000000] Size: 256.0MB P12 (USERDATA) [0x163908000 0x38ca6f3000] Size: 227.162GB ------ Android information ------ Detected LINUX(Android) SYSTEM : 0x001CD08000 (4.855GB) Unable to read prop.plist , code : 2 --------------------------------------------- Detected USERDATA USERDATA : 0x0163908000 (227.162GB) Unable to mount USERDATA , code : 95 Z3X EasyJtag Software ver. 3.6.1.4 UFS Socket Info. Serial: 0123512AF7EB3812EE Description: EasyJTAG UFS Socket 3 in 1 by MOORC 15.05.19 Read UFS LUN0, Address:1CD08000 ,Length: 136C00000 Output file :C:\Users\Administrator\Desktop\Reno\LUN0_8G\UFS_K M2B8001CM-BB01332991b5ef1d_LU0_0x1cd08000_SYSTEM_0x136c00000 .bin Start Can't read address 0x22308000, Code: -403, Reason: UAP SCSI: Command sense: MEDIUM_ERROR Read, time taken: 392 sec. Average Reading Speed: 229 kB/s Done. |
08-01-2019, 17:54 | #63 (permalink) | |
Product Supporter Join Date: Mar 2005 Location: China
Member: 129885 Status: Offline Sonork: 100:1603514 Thanks Meter: 6,202 | Quote:
08-06-2019, 08:56 | #64 (permalink) |
Junior Member Join Date: Oct 2016
Member: 2639224 Status: Offline Thanks Meter: 0 | verified UFS chip (samsung S7) ang got following message, any way to solve it ====================================== UFS Chip Voltage: Low Can't init device, Code: -118, Reason: This chip is temporary unsupported VCC: 3298mV VCCQ2: 1816mV Manufacturer: SKHYNIX 产品名称: HBG4a SerialNumber: 0x03A0A456AB6D OemID: 01AD Done(完成)。 |
08-06-2019, 10:03 | #65 (permalink) | |
Product Supporter Join Date: Jun 2002 Location: Belarus Age: 47
Member: 13148 Status: Offline Thanks Meter: 2,948 | Quote:
09-15-2019, 11:05 | #66 (permalink) |
Junior Member Join Date: Oct 2005 Location: Novo
Member: 192578 Status: Offline Thanks Meter: 0 | Z3X EasyJtag Software ver. 3.6.1.17 UFS Socket Info. Serial: 01237D77F52D1F31EE Description: EasyJTAG UFS Socket 3 in 1 by MOORC 15.05.19 Can't open link, Code: -56, Reason: BOX: Chip not connected Сделано. Help. Hardware 2.50 |
09-15-2019, 18:35 | #67 (permalink) | |
What help you need? | |
09-27-2019, 08:49 | #70 (permalink) |
Junior Member Join Date: Sep 2019 Location: lithuania
Member: 2929551 Status: Offline Thanks Meter: 0 | hi problem with me Description: EasyJTAG UFS Socket BGA-153 by EasyJTAG 19.05.19 Identify UFS Chip. UFS Chip Voltage: High Can't init device, Code: -113, Reason: UTP: Failed to NOP request VCC: 3299mV VCCQ2: 2805mV Done. socket easyjtag ufs 153 Last edited by kamreikia; 09-27-2019 at 08:58. |
09-30-2019, 12:59 | #71 (permalink) |
No Life Poster Join Date: Mar 2012 Location: china
Member: 1737647 Status: Offline Sonork: 100.1645466 Thanks Meter: 278 | 1.Fixed some mircon bug on Icfriend socket. Mircon BGA153 2.plese sure your socket is like this pins. If now same. Please change a new one from your resller 从我的 iPhone 发送,使用 Tapatalk |
The Following User Says Thank You to MOORC For This Useful Post: |
09-30-2019, 12:59 | #72 (permalink) | |
Member: 1737647 Status: Offline Sonork: 100.1645466 Thanks Meter: 278 | Quote:
Don’t use VCCQ2 2.8V 从我的 iPhone 发送,使用 Tapatalk | |
09-30-2019, 13:05 | #75 (permalink) | |
Please use 3.6.17. And sure 2 pictures thanks 从我的 iPhone 发送,使用 Tapatalk | |
