11-06-2019, 09:43 | #92 (permalink) |
Freak Poster Join Date: Jun 2002 Location: Sanok, Poland Age: 40
Member: 12835 Status: Offline Thanks Meter: 20 | Reading the memory through the original interface is very slow. 500-700kb/s. 32GB memory DUMP using the BGA95 interface is around 10-11 hours. Why are the non-original interface faster? Maybe I have some damaged equipment? My interface is "EasyJTAG UFS Socket BGA-95 by EasyJTAG 26.05.19". I thought that when I bought the original product from the BOX manufacturer I would have maximum compatibility. You wrote in advance that only the original interface guarantees proper operation. Something went wrong? I currently have 23 pieces of Samsung S6 and I need to make a full binary copy. It will take approximately 11 days for me to read continuously. Maybe I can change the settings to make it work faster? I don't want to buy MOORC because I already have an interface from you |
11-06-2019, 10:13 | #93 (permalink) | |
Product Supporter Join Date: Jun 2002 Location: Belarus Age: 47
Member: 13148 Status: Offline Thanks Meter: 2,948 | Quote:
We work to increase speed at all controller uo to 3MB/s After we add work with 2 line (6MB/s) M-PHYs support two main transmission modes/active states: low speed (LS), which supports 3 to 576 Mbps, and high speed (HS), which supports 1,248 to 5,824 Mbps per the M-PHY v3.0 specification. Our hardware now work at LS (PWM-G4) mode (66Mhz) HS mode requare USB 3.0 and new hardware Max speed, what be can get from EasyJTAG Plus box PWM-G4 mode - 6-10MB/s (with compression) It done to repair boot's and read-write backups of main partitions New Android phones have crypted userdata, and now where are no way to decrypt it, and no need HS PWM-G5/G6/G7 is many UFS chips not supported Last edited by layder; 11-06-2019 at 11:06. | |
11-06-2019, 10:32 | #94 (permalink) |
Member: 12835 Status: Offline Thanks Meter: 20 | The BOX has been connected to two different computers, to 8 different USB 2.0 ports, the maximum speed is about 805 kbps At the moment I'm backing up another UFS BGA95. Look at the estimated time to the end. I had MOORC for 1 day and 2Mb / s went without any problems. |
11-06-2019, 10:46 | #95 (permalink) | |
At few FW box update we transfer some UFS code to box, and speed will be not depend of MB USB controller I reconnect box from USB 2.0 to external USB 3.0 contoller and speed be increased fom 0,7 to 1,5MB/s Some people have 3,0MB/s speed at his MB Now we optimize UFS core for different UFS chips. After it we transwer UFS core to internal box firmware, and speed will be not depends from USB MB ports Last edited by layder; 11-06-2019 at 10:53. | |
11-06-2019, 11:46 | #96 (permalink) | |
Member: 12835 Status: Offline Thanks Meter: 20 | Quote:
11-08-2019, 15:33 | #97 (permalink) | |||
Freak Poster Join Date: Mar 2010 Location: Earth Age: 39
Member: 1265640 Status: Online Sonork: 100.1622602 Thanks Meter: 51 | how to make dump from devices with UFS chip? for example, I have SM-G930V Quote:
UFS_KLUBG4G1CE-B0B1_0_00000000_100000000.bin 4.00 GB (4,294,967,296 bytes) UFS_KLUBG4G1CE-B0B1_1_00000000_00400000.bin 4.00 MB (4,194,304 bytes) UFS_KLUBG4G1CE-B0B1_2_00000000_00400000.bin 4.00 MB (4,194,304 bytes) UFS_KLUBG4G1CE-B0B1_3_00000000_03C00000.bin 60.0 MB (62,914,560 bytes) and write those dumps to the same UFS chip(KLUBG4G1CE-B0B1) but. after soldering chip on the logic board no boot and detect by cpu with pc | |||
11-25-2019, 16:32 | #98 (permalink) | |
Member: 1265640 Status: Online Sonork: 100.1622602 Thanks Meter: 51 | Quote:
11-29-2019, 09:44 | #102 (permalink) | |
Major Poster Join Date: Apr 2014
Member: 2161268 Status: Offline Thanks Meter: 0 | Quote:
I couldnt find any programmer which supports it. | |
11-29-2019, 11:56 | #103 (permalink) | |
And it will be dead some next time You need select "Low" voltage You need select "Disable UFS safe mode" at setting And pray to recover all Data ) Use EasyJTAG Plus software with Low voltage and Explorer Do it faster - go to needed folder and save files And you need return "Disable UFS safe mode" at setting to Safe mode after | |
12-02-2019, 15:29 | #104 (permalink) | |
Thank you for your answere, but it's not working: Identify UFS Chip. UFS Chip Voltage: Low Can't init device, Code: -115, Reason: Wrong socket type, this socket licensed for another chip type VCC: 3292mV VCCQ2: 1794mV Manufacturer: SKHYNIX ProductName: HBG4a SerialNumber: 0x0228B722A380 OemID: 01AD Done. I can't find the disable UFS safe Mode in the easy jtag plus software. Is there any other chance to recover the data? Best regards | |
