06-05-2019, 14:42 | #1 (permalink) |
Freak Poster Join Date: Sep 2015
Member: 2453200 Status: Offline Thanks Meter: 102 | UFS memory connection troubles, question, discuss thread Reading/Writing by partitions |
The Following 17 Users Say Thank You to Resident_Evil For This Useful Post: |
06-06-2019, 09:21 | #2 (permalink) |
Product Supporter Join Date: Jun 2002 Location: Belarus Age: 47
Member: 13148 Status: Offline Thanks Meter: 2,948 | is not a beta test - it's development screenshot. ufs memory do not have bus width as eMMC combobox values will be chanded after I post this screens at me channel https://t.me/Z3X_EasyJTAG_Plus Not ned to be forward it to forum |
The Following 4 Users Say Thank You to layder For This Useful Post: |
07-08-2019, 08:01 | #4 (permalink) |
Major Poster Join Date: Nov 2010
Member: 1438327 Status: Offline Thanks Meter: 26 | Ufs 153 chipset read & write speed!!!!!! I BUY UFS 153 ADAPTOR YESTERDAY NOW MY BOX READ AND WIRTE OPERATION ARE ABOUT 500 KB/s IS IT NORMAL FOR UFS CHIPSET????? ITS VERY SLOWLY |
The Following 5 Users Say Thank You to davoodc For This Useful Post: |
07-08-2019, 11:49 | #7 (permalink) |
Member: 13148 Status: Offline Thanks Meter: 2,948 | Now UFS speed depends on motherboard chipset First we have to improve UFS compatibility, and after - speed Now UFS speed is 0,5 - 3 MB/s (1 channel) After we update box firmware speed will cease to be dependent of chipset, and will be 6-10MB/s (2 channel) First Moorc 3in1 revision have only 1 channel, and max speed it will be have 3-5MB/s All new android devices have crypted userdata and we can't use EasyJTAG box to read data from it, and speed 6-10MB/s is well for boot repair operation Now UFS link freq is 66 MHz We can't use UFS Hi-speed link (1,5GHz) at this hardware Last edited by layder; 07-16-2019 at 13:15. |
The Following 14 Users Say Thank You to layder For This Useful Post: |
07-08-2019, 14:30 | #8 (permalink) |
Member: 1438327 Status: Offline Thanks Meter: 26 | Ufs lun size and count HOW WE CAN CHANGE UFS LUN's SIZE AND GRAET THEM????? I HAVE U ULTRA DUMP WITH THAT LOGS: LUN 0: Block size: 0x1000 Size: 0xEC8C00000 / 59,140,000,000B / 59GB LUN 1 (Boot A): Block size: 0x1000 Size: 0x400000 / 0,004,000,000B / 4MB LUN 2 (Boot B): Block size: 0x1000 Size: 0x400000 / 0,004,000,000B / 4MB LUN 3: Block size: 0x1000 Size: 0xB800000 / 0,184,000,000B / 184MB LUN 4: Block size: 0x1000 Size: 0xB000000 / 0,176,000,000B / 176MB LUN 5: Block size: 0x1000 Size: 0x6400000 / 0,100,000,000B / 100MB Number of W-LUs found: 1 W-LUN 0xC4 (REPORT LUNS): Block size: 0x100 Size: 0x400000 / 0,004,000,000B / 4MB ------ AND ONE UFS CHIP FROM G950F WITH THIS LOGS: LUN 0: Block size: 0x1000 Size: 0xEE4800000 / 59,584,000,000B / 59GB LUN 1 (Boot A): Block size: 0x1000 Size: 0x400000 / 0,004,000,000B / 4MB LUN 2 (Boot B): Block size: 0x1000 Size: 0x800000 / 0,008,000,000B / 8MB LUN 3: Block size: 0x1000 Size: 0x800000 / 0,008,000,000B / 8MB Number of W-LUs found: 1 W-LUN 0xC4 (REPORT LUNS): Block size: 0x100 Size: 0x1000000 / 0,016,000,000B / 16MB HOW I CAN CHANGE LUN PARTITION SIZE??????? AND HOW I CAN GRAET OTHER LUN THAT UFS CHIPSET DOES NOT HAVE IT????????? |
07-08-2019, 15:39 | #9 (permalink) | |
Member: 13148 Status: Offline Thanks Meter: 2,948 | Quote:
this UFS chips can't Re-Configure (OTP zone is set) ========== UFS Device Information : UFS Manufacturer: SAMSUNG, UFS ProductName: KM2V7001CM-B706 UFS OemID: SAMSUNG_OEM_ID, UFS SerialNumber: 0x2A90A9BCE90D7ED56F564316F28158423138395430454231 Maximum Number of LUs: 8, Number of LUs found: 4, Number of WLUs found: 1, LUs Re-configure: Disabled UFS LUN 0 Capacity: 121972 MB (001DC7400000) UFS LUN 1 (Boot A) Capacity: 4 MB (000000400000) UFS LUN 2 (Boot B) Capacity: 4 MB (000000400000) UFS LUN 3 Capacity: 60 MB (000003C00000) UFS W-LUN 0xC4 (REPORT LUNS) Capacity: 16 MB (000001000000) UFS Init completed. ========== | |
The Following 8 Users Say Thank You to layder For This Useful Post: |
07-08-2019, 16:12 | #10 (permalink) |
Member: 1438327 Status: Offline Thanks Meter: 26 | Then we have to use same as ufs chipset as the mobile ufs chipset with same lun size and count (how many lun are),yes????????? |
07-08-2019, 16:27 | #11 (permalink) |
Member: 1438327 Status: Offline Thanks Meter: 26 | that means if i want change g950f ufs chip i have to use another g950f ufs chipset.!!!! and i cant use any other phone's ufs chip becuse we cant change LUN number and size and its about 1% to find ufs chip from any other phone Exactly like as that we needed,yes?????????? |
The Following 3 Users Say Thank You to davoodc For This Useful Post: |
07-08-2019, 16:58 | #12 (permalink) | |
After partitioning, chip's may be write OTP - close Re-Configure function if Re-Configure function not close (Enabled), chip can partitioning many times | |
The Following 9 Users Say Thank You to layder For This Useful Post: |
07-08-2019, 20:01 | #13 (permalink) |
Insane Poster Join Date: Feb 2019
Member: 2895768 Status: Offline Thanks Meter: 10 | i have activated my box, latest version and i have Morc Adpters But when i want to read a UFS give this error. With EMMC and ISP works normal. The problem is when i want to read a memory UFS. Box Drivers version: 3.2.0.0 Z3X Card Serial : AAD1-FXXX , ver: 22 Z3X Card Activation [JTAGPLUS] : ACTIVATED Z3X Card Activation [LG] : NOT ACTIVATED Z3X Card Activation [SAMS] : NOT ACTIVATED Z3X Card Activation [JTAG] : ACTIVATED Found 1 serial devices COM5 USB\VID_1781&PID_AAAC&REV_0100&MI_00 MediaTek USB VCOM (Android) (COM5) Selected pinout: GEN2 High Speed Pinout Change EasyJTAG Pinout OK Z3X EasyJtag Software ver. 3.6.1.2 UFS Socket Info. Serial: 0123C09D037CXXXXX Description: EasyJTAG UFS Socket 3 in 1 by MOORC 15.05.19 Can't open link, Code: -56, Reason: BOX: Chip not connected Done. Z3X EasyJtag Software ver. 3.6.1.2 UFS Socket Info. Serial: 0123C09D037CC85BEE Description: EasyJTAG UFS Socket 3 in 1 by MOORC 15.05.19 Can't open link, Code: -56, Reason: BOX: Chip not connected Done. Can you help me, please. in Easy jtag plus does not enable me frequency and bus width https://ibb.co/Byg2nbJ Or i need to buy another activation? where buy that activation? Last edited by layder; 07-09-2019 at 00:51. |
The Following 2 Users Say Thank You to Gaelymateo2 For This Useful Post: |
07-09-2019, 00:53 | #14 (permalink) |
Member: 13148 Status: Offline Thanks Meter: 2,948 | UFS connection use one freq: 66MHz UFS not have bus width 1) update you soft to latest version 2) reboll you chip http://forum.gsmhosting.com/vbb/f672.../#post13726620 http://forum.gsmhosting.com/vbb/f672.../#post13717343 Last edited by layder; 07-09-2019 at 01:00. |
The Following User Says Thank You to layder For This Useful Post: |
07-09-2019, 01:52 | #15 (permalink) |
No Life Poster Join Date: Mar 2012 Location: china
Member: 1737647 Status: Offline Sonork: 100.1645466 Thanks Meter: 278 | Moorc icfriend Sockets has 2 lanes design. You can open it. UFS LS 1 lane is 0.6-2.5MB/S. UFS-LS 2 lanes is 5-10MB/S. 从我的 iPhone 发送,使用 Tapatalk |
The Following 4 Users Say Thank You to MOORC For This Useful Post: |
