Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Easy-Jtag
Old 07-18-2019, 11:44   #46 (permalink)
Member: 2639224
what does the following message mean after identify UFS ? tks
Can't init device, Code: -101, Reason: UTP: Received unexpected response
Old 07-18-2019, 11:55   #47 (permalink)
Member: 2639224
what's the difference between wipe userdata and format userdata? tks
Old 07-20-2019, 00:19   #48 (permalink)
Member: 1041150
Thanks Meter: 17
I do wipe user data to samsung A50 and the phone hang on the samsung logo,
Old 07-21-2019, 02:26   #49 (permalink)
Member: 2114838
SKHYNIX h2mu64122mar UFS JTAG NOT SUPPORTED
I want to recover data from samsung sm-g925f with chip-off
Any info on this problem?
Setting interface to EasyJtag2/UFS
Socket Information :
Socket Mark: EasyJTAG UFS Socket BGA-95 by EasyJTAG 26.05.19
Socket Serial: 012XXXXXXXXX63C6EE
UFS Power Information :
Mode: Low, VCC: 3259mV, VCCQ2: 1828mV
UFS Device Information :
UFS Manufacturer: SKHYNIX, UFS ProductName: HBG4a
UFS OemID: 01AD, UFS SerialNumber: 0x0228052D7A80
Maximum Number of LUs: 0, Number of LUs found: 0, Number of WLUs found: 0, LUs Re-configure: Enabled
This UFS is temporarily not supported.
UFS Init completed.
Old 07-21-2019, 18:09   #50 (permalink)
Member: 13148
Thanks Meter: 1,199
this eMMC is down sometime when it connect.
we are temporary disable it, becouse it may be dead at read/write operations
Old 07-22-2019, 04:25   #51 (permalink)
Member: 2114838
Any chance to enable it as it seems that is working ok at read operation .?
Old 07-22-2019, 06:01   #52 (permalink)
Member: 13148
Thanks Meter: 1,199
We ordered a lot of such chips from China
And we work with them on tests. And they work fine.
But we have information that the users have failed these chips when working with them.
We still can not understand for what reason this is happening, and while the software has disabled the ability to work with them, in order to avoid complaints about sudden death syndrome
The Following 2 Users Say Thank You to layder For This Useful Post:
Old 07-22-2019, 15:06   #53 (permalink)
Member: 2639224
Identify UFS chip and got following message, how to solve this problem?
Z3X EasyJtag Software ver. 3.6.1.2
UFS Socket Info.
Serial: 012xxxxxxxxxxx1EE
Description: EasyJTAG UFS Socket BGA-153 by EasyJTAG 15.05.19
Can't open link, Code: -507, Reason: UIC: Link initialization fail
Done.
Old 07-22-2019, 15:58   #54 (permalink)
Member: 13148
Thanks Meter: 1,199
Try to use latest SW (3.6.1.9 or 3.6.1.13)
EasyJTAG 3.6 UFS UPDATES
Old 07-23-2019, 14:39   #55 (permalink)
hitech care's Avatar
Member: 1834832
Thanks Meter: 1,222
What If User Mistakenly Use EMMC Socket For UFS Chip N Do Identify Or Any Other Operation I Know It Will Not Work Give Error But Is It Also Damage Chip Also...?
Can U Post What Error We Get If We Try UFS Chip With EMCP Socket...Also Add Hint For Error In Next Update "May Be Chip Type UFS Try With UFS Socket" Something Like This...
Same Question For UFS Socket Too...
Old 07-23-2019, 17:23   #56 (permalink)
Member: 13148
Thanks Meter: 1,199
UFS chips have different technology, different pins
and this idea can not be released
Old 07-24-2019, 19:22   #57 (permalink)
Member: 1834832
Thanks Meter: 1,222
You missunderstood my query friend.. I am asking if user mistakenly use the ufs ic in emmc socket if user do any operation (i know it will fail) but is it make any damage to ic?
Old 07-24-2019, 20:32   #58 (permalink)
Member: 13148
Thanks Meter: 1,199
I already answered that these chips have completely different pins in function.
I tried to put UFS chips to eMMC socket, and it live
Old 07-25-2019, 05:18   #59 (permalink)
Member: 90058
Thanks Meter: 89
Mr.LAYDER WICH PARTITION HAVE USER DATA AND FRP MDM BLOCKS PL EXPLAIN WITH IMAGE IS HELPFULL
Old 07-25-2019, 17:30   #60 (permalink)
Member: 13148
Thanks Meter: 1,199
To remove FRP from UFS chips you need press "Remove FRP"
UserData at most UFS chips is crypted
Samsung G920/G925/N920 have not-crypted userdata
Page generated in 0.35369 seconds with 8 queries
