Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Easy-Jtag
Old 07-28-2019, 23:53   #61 (permalink)
Member: 388862
Thanks Meter: 64
Code: -403 ?????
Identify UFS Chip.
UFS Chip Voltage: Low
VCC: 3309mV
VCCQ2: 1865mV
Manufacturer: SAMSUNG
ProductName: KM2B8001CM-BB01
SerialNumber: 332991b5ef1d
OemID: SAMSUNG_OEM_ID
Maximum Number of LUs: 8
Number of LUs found: 6
LUN 0:
Block size: 0x1000
Size: 0x3A2E000000 / 232,736,000,000B / 232GB
LUN 1 (Boot A):
Block size: 0x1000
Size: 0x400000 / 0,004,000,000B / 4MB
LUN 2 (Boot B):
Block size: 0x1000
LUN 3:
Block size: 0x1000
Size: 0x8000000 / 0,128,000,000B / 128MB
LUN 4:
Block size: 0x1000
Size: 0x100000000 / 4,000,000,000B / 4GB
LUN 5:
Block size: 0x1000
Size: 0x60000000 / 1,512,000,000B / 1GB
Number of W-LUs found: 1
W-LUN 0xC4 (REPORT LUNS):
Block size: 0x100
Size: 0x1000000 / 0,016,000,000B / 16MB
Full size: 0x3B97800000 / 238,376,000,000B / 238GB
Read GPT From LUN 0.
Partition info successfully found
Found Data areas (firmware parts) count is: 13
P0 (SSD) [0x6000 0x2000] Size: 8.0KB
P1 (PERSIST) [0x8000 0x2000000] Size: 32.0MB
P2 (MISC) [0x2008000 0x100000] Size: 1.0MB
P3 (KEYSTORE) [0x2108000 0x80000] Size: 512.0KB
P4 (FRP) [0x2188000 0x80000] Size: 512.0KB
P5 (VM-KYSTORE) [0x2208000 0x100000] Size: 1.0MB
P6 (VM-DATA) [0x2308000 0xa00000] Size: 10.0MB
P7 (VM-SYSTEM) [0x2d08000 0x8000000] Size: 128.0MB
P8 (VM-LINUX) [0xad08000 0x2000000] Size: 32.0MB
P9 (CACHE) [0xcd08000 0x10000000] Size: 256.0MB
P10 (SYSTEM) [0x1cd08000 0x136c00000] Size: 4.855GB
P11 (ODM) [0x153908000 0x10000000] Size: 256.0MB
P12 (USERDATA) [0x163908000 0x38ca6f3000] Size: 227.162GB
------ Android information ------
Detected LINUX(Android) SYSTEM : 0x001CD08000 (4.855GB)
Unable to read prop.plist , code : 2
Detected USERDATA USERDATA : 0x0163908000 (227.162GB)
Unable to mount USERDATA , code : 95
Z3X EasyJtag Software ver. 3.6.1.4
UFS Socket Info.
Serial: 0123512AF7EB3812EE
Description: EasyJTAG UFS Socket 3 in 1 by MOORC 15.05.19
Read UFS LUN0, Address:1CD08000 ,Length: 136C00000
Output file :C:\Users\Administrator\Desktop\Reno\LUN0_8G\UFS_K M2B8001CM-BB01332991b5ef1d_LU0_0x1cd08000_SYSTEM_0x136c00000 .bin
Start
Can't read address 0x22308000, Code: -403, Reason: UAP SCSI: Command sense: MEDIUM_ERROR
Read, time taken: 392 sec. Average Reading Speed: 229 kB/s
Done.
Old 07-29-2019, 18:53   #62 (permalink)
Member: 2556868
Originally Posted by layder View Post
To remove FRP from UFS chips you need press "Remove FRP"
UserData at most UFS chips is crypted
Samsung G920/G925/N920 have not-crypted userdata
There is no way to decrypt User Data?There are companies offering to decrypt it?
Old 08-01-2019, 17:54   #63 (permalink)
NoName®'s Avatar
Member: 129885
Sonork: 100:1603514
Thanks Meter: 6,107
Originally Posted by lihua View Post
Code: -403 ?????
Identify UFS Chip.
VCC: 3309mV
VCCQ2: 1865mV
LUN 0:
Block size: 0x1000
LUN 1 (Boot A):
Block size: 0x1000
LUN 2 (Boot B):
Block size: 0x1000
LUN 3:
Block size: 0x1000
LUN 4:
Block size: 0x1000
LUN 5:
Block size: 0x1000
Block size: 0x100
UFS Socket Info.
Start
Done.
MEDIUM_ERROR is a error, very specific to Samsung UFS memory. MEDIUM_ERROR caused if UFS chip is unable to read internal NAND page or unable to correct ECC errors. Generally such error caused by changing chip environment like power level. MEDIUM errors gone if you erase chip contents. Samsung UFS may have some vendor commands for internal recalibration. Currently we working on them.
Old 08-06-2019, 08:56   #64 (permalink)
Member: 2639224
verified UFS chip (samsung S7) ang got following message, any way to solve it
Can't init device, Code: -118, Reason: This chip is temporary unsupported
VCC: 3298mV
VCCQ2: 1816mV
Manufacturer: SKHYNIX
产品名称: HBG4a
SerialNumber: 0x03A0A456AB6D
OemID: 01AD
Done(完成)。
Old 08-06-2019, 10:03   #65 (permalink)
Member: 13148
Thanks Meter: 1,199
VCC: 3298mV
VCCQ2: 1816mV
产品名称: HBG4a
OemID: 01AD
Done(完成)。
this chips temporary disabled - this chips is sometimes dead after 3-5 operations
Page generated in 0.25605 seconds with 8 queries
