Old 03-12-2019, 18:01   #1 (permalink)
Member: 1929052
Thanks Meter: 22
trouble with two phones asusz00ad desire 816n
hi guys i reprogram asus emmc 32gb in support 16gbdump 32gbdump and asus z00a ze551ml 2.12.40.11 user file everything ok but replacae emmc only moorefield device and then try to debrick fuullchange emmc file something happened in dos commands but phone not working any solution???
another one i reprogram desire 816n different two emmcs 16gb and 32gb everything ok but phone storage is everytime error storage full... i write firmware via ruu method flash zip but still same same any advance
Old 03-13-2019, 00:32   #2 (permalink)
layder's Avatar
Member: 13148
Thanks Meter: 2,948
For Asus ZE551ML:
1) You need dowload debrick archive from support
2a) If you change eMMC, you need run debrick_change_EMMC.bat
2b) If you change CPU, you need run debrick_change_SoC.bat
For HTC D816:
You need check eMMC via "Random Verify Test" (300-500MB) from EasyJTAG Plus software
Or run "Linear verify test" of userdata partition at same software (Read by Vendor Tab)
Probably the eMMC is dead, and needed to replace
Old 03-13-2019, 10:25   #3 (permalink)
Member: 1929052
Thanks Meter: 22
bro i try it i change emmc and then pc detedt moorefield device and then debrick img nothing happened i want to know am i do somethin wrong thank you bro maybe asus hardware problem
for htc i try your solution because try 2 emmc same, storage full
thanks for your support
Old 03-13-2019, 12:07   #4 (permalink)
Member: 818380
Thanks Meter: 56
Originally Posted by layder View Post
For Asus ZE551ML:
For HTC D816:
I encountered that case on D816 when I tried to replace emmc larger than 8GB, I couldn't resize the partition width when I flashed fw.
Old 03-13-2019, 12:41   #5 (permalink)
Member: 1929052
Thanks Meter: 22
if 8 gb replace any problem with storage bro?
Old 03-13-2019, 18:34   #6 (permalink)
layder's Avatar
Member: 13148
Thanks Meter: 2,948
I was changed eMMC at D816 at 2018, and all be ok. Now I don't forget change procedure, but I was make all standart procedures when eMMC is change
if you use EasyJTAG Plus software and "write by venor" mode - last partition size is automatic resize.
Old 03-13-2019, 19:18   #7 (permalink)
Member: 818380
Thanks Meter: 56
i use standard write dump after flash ruu all change with gpt will lost.
Old 03-13-2019, 22:35   #8 (permalink)
layder's Avatar
Member: 13148
Thanks Meter: 2,948
I was upload files to Z3x shell:
Desire_816n_write_by_vendor_qualcomm.zip
D816w_dump_write_by_vendor_qualcomm.zip
it's a full firmware - write and run device
Old 03-14-2019, 12:56   #9 (permalink)
Member: 1929052
Thanks Meter: 22
i fix problem with this guide
4stage_resize_userdata | EasyJtag ? Fastest Memory Programmer in the word!
Page generated in 0.19914 seconds with 8 queries
