11-28-2018, 02:47 | #1 (permalink) |
Insane Poster Join Date: Oct 2017
Member: 2772222 Status: Offline Thanks Meter: 9 | Unpack Bootloader.img From Firmware Motorola Phone I want to repair XT635-02 Bootloader (Moto Z Play) but I dont have Dump file and I know that is possible to repair boot using files from Firmware. My questions: How to unpack Bootloader.img from firmware and use this files in z3X to repair boot? Is it possible to flash motorola phones using Z3X without Dump Files? Is it possible to use another boot files, for exemple sbl1 from XT1640 to repair XT1635? Thanks. |
11-28-2018, 06:30 | #2 (permalink) |
Product Supporter Join Date: Mar 2013 Location: JTAG/eMMC/UFS
Member: 1902789 Status: Offline Thanks Meter: 1,101 | I want to repair XT635-02 Bootloader (Moto Z Play) but I dont have Dump file and I know that is possible to repair boot using files from Firmware. How to unpack Bootloader.img from firmware and use this files in z3X to repair boot? Ans is Right now Motorola Factory Firmware writing not supported in Easy Jtag Plus Tool. Is it possible to flash motorola phones using Z3X without Dump Files? Ans is without Dump right now not possible using Z3X. Is it possible to use another boot files, for exemple sbl1 from XT1640 to repair XT1635? Ans is not tested, I think not possible. if you read ROM1_256MB, ROM2, ROM3, EXT_CSD from ur dead phone & upload any where & give me link in PM. then I will try to make working dump for you. But sure Team will add Motorola Factory Flasher in next upcoming updates... Last edited by Pijush Das; 11-28-2018 at 06:38. |
11-28-2018, 11:46 | #3 (permalink) |
Member: 2772222 Status: Offline Thanks Meter: 9 | @Pijush Das Aren't there any program that can unpack Bootloader.img? Inside in Bootloader has: rpm, tz,devcfg, cmnlib, cmnlib64, keymaster, prov and sbl1. I try RK3xxx_firmware to unpack Bootloader.img but no successful. At this moment my Friend read files in Medusa Pro and extract for me. (I'm just explaining how I do). @layder @blang |
11-29-2018, 13:45 | #5 (permalink) |
Junior Member Join Date: Jul 2016 Location: Brazil - Santa Catarina Age: 34
Member: 2601424 Status: Offline Thanks Meter: 1 | Hello, my noble G-Ziel. The method I used to achieve a DUMP was by using a memory of another device making a Standard Formatting and then performing an erase. After this procedure, I installed a 100% compatible Firmware for the model in question, after I generated a DUMP file through the CONSTRUCTOR tool. |
The Following User Says Thank You to o__rionTG For This Useful Post: |
12-05-2018, 20:29 | #10 (permalink) |
Freak Poster Join Date: Oct 2016 Location: india
Member: 2636476 Status: Offline Thanks Meter: 61 | I have moto xt1562 by hard bricked can't find same emmc firmware in shell can i repair with new version i have set in hand If need to check with new version then i am ready EMMC Manufacture Name: TOSHIBA , EMMC NAME: 032G72 EMMC NAME (HEX): 303332473732 |
12-06-2018, 10:33 | #14 (permalink) |
Product Supporter Join Date: Jun 2002 Location: Belarus Age: 47
Member: 13148 Status: Offline Thanks Meter: 2,949 | XT1635_boot_files.zip https://mega.nz/#!eAI3ka5A!BjaMRXwtw...nzgLGTwoystsCs XT1635-2_boot_files.zip https://mega.nz/#!ScZF3KoL!3tpifcqpP...YeqTs6oCccurQs |
The Following User Says Thank You to layder For This Useful Post: |
